Both drive are showing no bad sectors that is a good thing.
Have you tried rolling the entire system back to a prior date?
That is if Windows Back up is turned on.
There may be leftover from this that can be still causing issues.
Please download
MiniToolBox and save it to your desktop. Run the program by right clicking on it and selecting Run as administrator. When the program opens select the following boxes:
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
COPY and PASTE the complete information for the MTB.txt file into you next post.
Ran by brink (administrator) on 21-08-2021 at 17:45:37
Running from "C:\Users\brink\Downloads"
Microsoft Windows 10 Pro (X64)
Model: To Be Filled By O.E.M. Manufacturer: To Be Filled By O.E.M.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
NETGEAR A6100 WiFi Adapter = Wi-Fi (Connected)
Realtek PCIe GbE Family Controller = Ethernet (Media disconnected)
Kaspersky Security Data Escort Adapter = Ethernet 2 (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global
set interface interface="Ethernet (Kernel Debugger)" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 10" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : DESKTOP-TBPBO3J
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : A8-A1-59-2A-6D-B2
Wireless LAN adapter Local Area Connection* 1:
Physical Address. . . . . . . . . : 3A-94-ED-15-04-C7
Wireless LAN adapter Local Area Connection* 10:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : 38-94-ED-15-04-C7
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : Kaspersky Security Data Escort Adapter
Physical Address. . . . . . . . . : 00-FF-42-63-0A-4B
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : NETGEAR A6100 WiFi Adapter
Link-local IPv6 Address . . . . . : fe80::7c9d:ff4f:55db:e328%10(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.205(Preferred)
Lease Obtained. . . . . . . . . . : Saturday, August 21, 2021 5:09:29 PM
Lease Expires . . . . . . . . . . : Sunday, August 22, 2021 5:43:48 PM
DHCPv6 IAID . . . . . . . . . . . : 87594221
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-26-DA-27-5D-A8-A1-59-2A-6D-B2
Server: router.asus.com
Address: 192.168.1.1
Addresses: 2607:f8b0:4004:815::200e
172.217.164.174
Pinging google.com [172.217.164.174] with 32 bytes of data:
Reply from 172.217.164.174: bytes=32 time=16ms TTL=115
Ping statistics for 172.217.164.174:
Minimum = 16ms, Maximum = 16ms, Average = 16ms
Addresses: 2001:4998:24:120d::1:0
2001:4998:44:3507::8000
2001:4998:44:3507::8001
2001:4998:24:120d::1:1
2001:4998:124:1507::f000
2001:4998:124:1507::f001
74.6.231.20
74.6.143.25
74.6.143.26
98.137.11.164
98.137.11.163
74.6.231.21
Pinging yahoo.com [74.6.231.21] with 32 bytes of data:
Reply from 74.6.231.21: bytes=32 time=42ms TTL=51
Ping statistics for 74.6.231.21:
Minimum = 42ms, Maximum = 42ms, Average = 42ms
Interface List
5...a8 a1 59 2a 6d b2 ......Realtek PCIe GbE Family Controller
12...3a 94 ed 15 04 c7 ......Microsoft Wi-Fi Direct Virtual Adapter
16...38 94 ed 15 04 c7 ......Microsoft Wi-Fi Direct Virtual Adapter #2
4...00 ff 42 63 0a 4b ......Kaspersky Security Data Escort Adapter
10...38 94 ed 15 04 c7 ......NETGEAR A6100 WiFi Adapter
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.205 55
192.168.1.0 255.255.255.0 On-link 192.168.1.205 311
192.168.1.205 255.255.255.255 On-link 192.168.1.205 311
192.168.1.255 255.255.255.255 On-link 192.168.1.205 311
224.0.0.0 240.0.0.0 On-link 192.168.1.205 311
255.255.255.255 255.255.255.255 On-link 192.168.1.205 311
Persistent Routes:
None
IPv6 Route Table
Active Routes:
1 331 ::1/128 On-link
10 311 fe80::/64 On-link
10 311 fe80::7c9d:ff4f:55db:e328/128
On-link
1 331 ff00::/8 On-link
10 311 ff00::/8 On-link
Persistent Routes:
None
Application errors:
Error: (08/21/2021 05:09:20 PM) (Source: CertEnroll) (User: NT AUTHORITY)
Description: WORKGROUP\DESKTOP-TBPBO3J$
https://AMD-KeyId-578c545f796951421...softaik.azure.net/templates/Aik/scepGetCACaps
GET(16ms)GetCACapsThe server name or address could not be resolved 0x80072ee7 (WinHttp: 12007 ERROR_WINHTTP_NAME_NOT_RESOLVED)
Error: (08/21/2021 03:36:36 PM) (Source: Microsoft-Windows-Defrag) (User: )
Description: The storage optimizer couldn't complete retrim on New Volume (D
because: The operation requested is not supported by the hardware backing the volume. (0x8900002A)
Error: (08/21/2021 12:49:18 PM) (Source: Windows Search Service) (User: )
Description: Notifications for the volume D:\ are not active.
Context: Windows Application
Details:
The volume change journal is not active. (HRESULT : 0x8007049b) (0x8007049b)
Error: (08/21/2021 12:42:15 PM) (Source: CertEnroll) (User: NT AUTHORITY)
GET(156ms)GetCACapsThe server name or address could not be resolved 0x80072ee7 (WinHttp: 12007 ERROR_WINHTTP_NAME_NOT_RESOLVED)
Error: (08/21/2021 12:36:38 PM) (Source: CertEnroll) (User: NT AUTHORITY)
GET(63ms)GetCACapsThe server name or address could not be resolved 0x80072ee7 (WinHttp: 12007 ERROR_WINHTTP_NAME_NOT_RESOLVED)
Error: (08/21/2021 12:13:19 PM) (Source: CertEnroll) (User: NT AUTHORITY)
GetCACaps: Not Found
{"Message":"The authority \"amd-keyid-578c545f796951421221a4a578acdb5f682f89c8.microsoftaik.azure.net\" does not exist."}
HTTP/1.1 404 Not Found
Date: Sat, 21 Aug 2021 16:13:18 GMT
Content-Length: 121
Content-Type: application/json; charset=utf-8
X-Content-Type-Options: nosniff
Strict-Transport-Security: max-age=31536000;includeSubDomains
x-ms-request-id: 8fea436d-7cd1-4fb2-9d26-6e76b51ad22f
GET(218ms)GetCACapsNot found (404). 0x80190194 (-2145844844 HTTP_E_STATUS_NOT_FOUND)
Error: (08/20/2021 11:08:10 PM) (Source: CertEnroll) (User: NT AUTHORITY)
GET(32ms)GetCACapsThe server name or address could not be resolved 0x80072ee7 (WinHttp: 12007 ERROR_WINHTTP_NAME_NOT_RESOLVED)
Error: (08/20/2021 11:03:13 PM) (Source: Application Error) (User: )
Description: Faulting application name: dwm.exe, version: 10.0.19041.746, time stamp: 0x6be51595
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1151, time stamp: 0x891df6d3
Exception code: 0xe0464645
Fault offset: 0x000000000010bd3e
Faulting process id: 0x2928
Faulting application start time: 0xdwm.exe0
Faulting application path: dwm.exe1
Faulting module path: dwm.exe2
Report Id: dwm.exe3
Faulting package full name: dwm.exe4
Faulting package-relative application ID: dwm.exe5
Error: (08/20/2021 10:51:32 PM) (Source: CertEnroll) (User: NT AUTHORITY)
Error: (08/20/2021 10:44:25 PM) (Source: CertEnroll) (User: NT AUTHORITY)
System errors:
Error: (08/21/2021 05:43:39 PM) (Source: TPM) (User: )
Description: The device driver for the Trusted Platform Module (TPM) encountered a non-recoverable error in the TPM hardware, which prevents TPM services (such as data encryption) from being used. For further help, please contact the computer manufacturer.
Error: (08/21/2021 05:09:15 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (User: NT AUTHORITY)
Description: WLAN Extensibility Module has failed to start.
Module Path: C:\WINDOWS\system32\Rtlihvs.dll
Error Code: 126
Error: (08/21/2021 05:09:07 PM) (Source: Service Control Manager) (User: )
Description: The CorsairGamingAudioConfig service failed to start due to the following error:
%%2 = The system cannot find the file specified.
Error: (08/21/2021 05:09:02 PM) (Source: TPM) (User: NT AUTHORITY)
Error: (08/21/2021 12:42:14 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (User: NT AUTHORITY)
Error Code: 126
Error: (08/21/2021 12:42:07 PM) (Source: Service Control Manager) (User: )
Error: (08/21/2021 12:42:01 PM) (Source: TPM) (User: NT AUTHORITY)
Error: (08/21/2021 12:42:06 PM) (Source: EventLog) (User: )
Description: The previous system shutdown at 12:36:28 PM on 8/21/2021 was unexpected.
Error: (08/21/2021 12:36:37 PM) (Source: Microsoft-Windows-WLAN-AutoConfig) (User: NT AUTHORITY)
Error Code: 126
Error: (08/21/2021 12:36:29 PM) (Source: Service Control Manager) (User: )
Microsoft Office Sessions:
Error: (08/21/2021 05:09:20 PM) (Source: CertEnroll)(User: NT AUTHORITY)
Error: (08/21/2021 03:36:36 PM) (Source: Microsoft-Windows-Defrag)(User: )
Description: retrimNew Volume (D
Error: (08/21/2021 12:49:18 PM) (Source: Windows Search Service)(User: )
Description: Context: Windows Application
Details:
D:\
Error: (08/21/2021 12:42:15 PM) (Source: CertEnroll)(User: NT AUTHORITY)
Error: (08/21/2021 12:36:38 PM) (Source: CertEnroll)(User: NT AUTHORITY)
Error: (08/21/2021 12:13:19 PM) (Source: CertEnroll)(User: NT AUTHORITY)
Content-Length: 121
Error: (08/20/2021 11:08:10 PM) (Source: CertEnroll)(User: NT AUTHORITY)
Error: (08/20/2021 11:03:13 PM) (Source: Application Error)(User: )
Description: dwm.exe10.0.19041.7466be51595KERNELBASE.dll10.0.19041.1151891df6d3e0464645000000000010bd3e292801d7963913a81f27C:\WINDOWS\system32\dwm.exeC:\WINDOWS\System32\KERNELBASE.dll5037def1-945b-4569-8fae-cc85bc4853ff
Error: (08/20/2021 10:51:32 PM) (Source: CertEnroll)(User: NT AUTHORITY)
Error: (08/20/2021 10:44:25 PM) (Source: CertEnroll)(User: NT AUTHORITY)
CodeIntegrity Errors:
Date: 2021-08-21 17:11:17.0200000Z
Description: Code Integrity determined that a process (\Device\HarddiskVolume2\Windows\System32\svchost.exe) attempted to load \Device\HarddiskVolume2\Program Files (x86)\Kaspersky Lab\Kaspersky Security Cloud 21.3\x64\antimalware_provider.dll that did not meet the Windows signing level requirements.
Date: 2021-08-21 17:11:17.0080000Z
Date: 2021-08-21 17:11:16.3750000Z
Date: 2021-08-21 17:11:16.3690000Z
Date: 2021-08-21 17:10:54.3800000Z
Date: 2021-08-21 17:10:54.3760000Z
Date: 2021-08-21 17:10:54.3690000Z
Date: 2021-08-21 12:44:15.8690000Z
Date: 2021-08-21 12:44:15.8570000Z
Date: 2021-08-21 12:44:15.1960000Z
(HKLM\...\UDK-c6b63982-286e-4eb3-b39b-2cab07a63656) (Version: - RuneStorm
7-Zip 19.00 (x64) (HKLM\...\7-Zip) (Version: 19.00 - Igor Pavlov)
Amazon Games (HKCU\...\{4DD10B06-78A4-4E6F-AA39-25E9C38FA568}) (Version: 1.7.172.1 - Amazon.com Services, Inc.)
Among Us (HKLM\...\Steam App 945360) (Version: - Innersloth)
Armored Warfare (HKLM\...\Steam App 443110) (Version: - Obsidian Entertainment)
Assassin's Creed Odyssey (HKLM\...\Steam App 812140) (Version: - Ubisoft Quebec)
Audacity 2.4.2 (HKLM-x32\...\Audacity_is1) (Version: 2.4.2 - Audacity Team)
Autodesk SketchBook (HKLM\...\{AE6C5657-8710-4968-BEB5-1E2ED89CB2D2}) (Version: 8.71.0000 - Autodesk)
Batman™: Arkham Knight (HKLM\...\Steam App 208650) (Version: - Rocksteady Studios)
Battlefield 1 ™ (HKLM\...\Steam App 1238840) (Version: - DICE)
Battlefield™ 1 (HKLM-x32\...\{335B50BC-6130-4BAF-9A6A-F1561270587B}) (Version: - Electronic Arts, Inc.)
Blue Sherpa (HKLM\...\{DF4B2C22-DFD0-4A11-AFBE-ADBC87F92853}) (Version: 1.4.16 - Blue Microphones) Hidden
Blue Sherpa (HKLM-x32\...\Blue Sherpa) (Version: 1.4.16 - Blue Microphones)
Call of Duty Modern Warfare (HKLM-x32\...\Call of Duty Modern Warfare) (Version: - Blizzard Entertainment)
CORSAIR iCUE Software (HKLM-x32\...\{F3FDA3E9-1209-40AF-96AA-2A1CB18C5CDE}) (Version: 3.30.97 - Corsair)
CPUID CPU-Z 1.93 (HKLM\...\CPUID CPU-Z_is1) (Version: 1.93 - CPUID, Inc.)
CurseForge (HKCU\...\Overwolf_cchhcaiapeikjbdbpfplgmpobbcdkdaphclbmkbj) (Version: 0.181.1.2 - Overwolf app)
Discord (HKCU\...\Discord) (Version: 0.0.309 - Discord Inc.)
EA Desktop (HKLM\...\{C2622085-ABD2-49E5-8AB9-D3D6A642C091}) (Version: 12.0.73.4891 - Electronic Arts) Hidden
EA Desktop (HKLM-x32\...\{723c8155-ff99-417d-858d-b7251460511c}) (Version: 12.0.73.4891 - Electronic Arts)
Epic Games Launcher (HKLM-x32\...\{0EE6DDEF-E36B-45EB-9E03-5A266EC8A8F8}) (Version: 1.1.279.0 - Epic Games, Inc.)
Epic Games Launcher Prerequisites (x64) (HKLM\...\{F9C5C994-F6B9-4D75-B3E7-AD01B84073E9}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Fallout 4 (HKLM\...\Steam App 377160) (Version: - Bethesda Game Studios)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 92.0.4515.159 - Google LLC)
GPX Common OSS (POCO, OpenSSL) and libprotobuf binaries (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GpxCommon.Oss) (Version: 7.1 - NVIDIA Corporation) Hidden
Guild Wars 2 (HKLM\...\Guild Wars 2) (Version: - NCsoft Corporation, Ltd.)
Halo: The Master Chief Collection (HKLM\...\Steam App 976730) (Version: - 343 Industries)
Java 8 Update 301 (64-bit) (HKLM\...\{26A24AE4-039D-4CA4-87B4-2F64180301F0}) (Version: 8.0.3010.9 - Oracle Corporation)
Kaspersky Password Manager (HKLM-x32\...\{B2F7333E-6C8D-4994-AAC4-FEC8EBBF9611}) (Version: 9.0.2.767 - Kaspersky Lab) Hidden
Kaspersky Password Manager (HKLM-x32\...\InstallWIX_{B2F7333E-6C8D-4994-AAC4-FEC8EBBF9611}) (Version: 9.0.2.767 - Kaspersky Lab)
Kaspersky Security Cloud (HKLM-x32\...\{4FC79BE9-AD63-46C0-9626-E4F6BCE6A976}) (Version: 21.3.10.391 - Kaspersky) Hidden
Kaspersky Security Cloud (HKLM-x32\...\InstallWIX_{4FC79BE9-AD63-46C0-9626-E4F6BCE6A976}) (Version: 21.3.10.391 - Kaspersky)
Kaspersky VPN (HKLM-x32\...\{FF2A12B8-AEB7-48C0-95C8-E2E3D67DFCB2}) (Version: 21.3.10.391 - Kaspersky) Hidden
Kaspersky VPN (HKLM-x32\...\InstallWIX_{FF2A12B8-AEB7-48C0-95C8-E2E3D67DFCB2}) (Version: 21.3.10.391 - Kaspersky)
Launcher Prerequisites (x64) (HKLM-x32\...\{43a03b9c-4770-409c-a999-587b60700b63}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Messenger 97.11.116 (HKCU\...\c1b3adcf-2068-5e8d-b25d-30ce588e3a4c) (Version: 97.11.116 - Facebook, Inc.)
Microsoft Edge (HKLM-x32\...\Microsoft Edge) (Version: 92.0.902.78 - Microsoft Corporation)
Microsoft Edge Update (HKLM-x32\...\Microsoft Edge Update) (Version: 1.3.151.27 - )
Microsoft Edge WebView2 Runtime (HKLM-x32\...\Microsoft EdgeWebView) (Version: 92.0.902.78 - Microsoft Corporation)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 21.139.0711.0001 - Microsoft Corporation)
Microsoft Update Health Tools (HKLM\...\{852D8FE5-BC66-4061-B1C4-CADF51E5B27D}) (Version: 2.82.0.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.28.29325 (HKLM-x32\...\{33628a12-6787-4b9f-95a1-92449f69fae0}) (Version: 14.28.29325.2 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.28.29325 (HKLM-x32\...\{d7a6435f-ac9a-4af6-8fdc-ca130d13fac9}) (Version: 14.28.29325.2 - Microsoft Corporation)
Microsoft XNA Framework Redistributable 4.0 Refresh (HKLM-x32\...\{D69C8EDE-BBC5-436B-8E0E-C5A6D311CF4F}) (Version: 4.0.30901.0 - Microsoft Corporation)
Minecraft Launcher (HKLM-x32\...\{27B34E47-68AE-4802-822A-9F0C187AF84A}) (Version: 1.0.0.0 - Mojang)
Mozilla Firefox (x64 en-US) (HKLM\...\Mozilla Firefox 91.0.1 (x64 en-US)) (Version: 91.0.1 - Mozilla)
Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 89.0 - Mozilla)
MSI Afterburner 4.6.4 Beta 3 (HKLM-x32\...\Afterburner) (Version: 4.6.4 Beta 3 - MSI Co., LTD)
NVAPI Monitor plugin for NvContainer (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvContainer.NvapiMonitor) (Version: 1.33 - NVIDIA Corporation) Hidden
NVIDIA FrameView SDK 1.1.4923.29968894 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_FrameViewSdk) (Version: 1.1.4923.29968894 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.23.0.74 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.23.0.74 - NVIDIA Corporation)
NVIDIA Graphics Driver 471.68 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 471.68 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.38.60 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.38.60 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.19.0218 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.19.0218 - NVIDIA Corporation)
NvModuleTracker (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvModuleTracker.Driver) (Version: 6.14.24370.22713 - NVIDIA Corporation) Hidden
OpenAL (HKLM-x32\...\OpenAL) (Version: - )
Origin (HKLM-x32\...\Origin) (Version: 10.5.102.48654 - Electronic Arts, Inc.)
Overwolf (HKLM-x32\...\Overwolf) (Version: 0.176.87.27 - Overwolf Ltd.)
Plex Media Server (HKLM-x32\...\{464E7912-8036-4352-B3BE-70827306361F}) (Version: 1.20.2402 - Plex, Inc.) Hidden
Plex Media Server (HKLM-x32\...\{dd20eb3a-03cd-49de-ac7f-302f5a7a4b3e}) (Version: 1.20.2.3402 - Plex, Inc.)
Rainmeter (HKLM-x32\...\Rainmeter) (Version: 4.4 beta r3404 - Rainmeter)
Rockstar Games Launcher (HKLM-x32\...\Rockstar Games Launcher) (Version: 1.0.39.355 - Rockstar Games)
Rockstar Games Social Club (HKLM-x32\...\Rockstar Games Social Club) (Version: 2.0.8.1 - Rockstar Games)
Spotify (HKCU\...\Spotify) (Version: 1.1.66.578.gc54d0f69 - Spotify AB)
Stopping Plex (HKLM-x32\...\{27EA5B98-8A96-4519-97FC-433A8FDA4E3F}) (Version: 1.20.2402 - Plex, Inc.) Hidden
Tank Mechanic Simulator (HKLM\...\Steam App 407130) (Version: - DeGenerals S.A.)
Team Fortress 2 (HKLM\...\Steam App 440) (Version: - Valve)
TreeSize Free V4.5.1 (HKLM-x32\...\TreeSize Free_is1) (Version: 4.5.1 - JAM Software)
Twitch (HKCU\...\{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 8.0.0 - Twitch Interactive, Inc.)
Ubisoft Connect (HKLM-x32\...\Uplay) (Version: 38.2 - Ubisoft)
Viscera Cleanup Detail (HKLM\...\Steam App 246900) (Version: - RuneStorm)
Viscera Cleanup Detail: alpha v0.25
Vortex (HKLM\...\57979c68-f490-55b8-8fed-8b017a5af2fe) (Version: 1.4.15 - Black Tree Gaming Ltd.)
WizTree v3.35 (HKLM\...\WizTree_is1) (Version: 3.35 - Antibody Software)
World of Guns: Gun Disassembly (HKLM\...\Steam App 262410) (Version: - Noble Empire Corp.)
Percentage of memory in use: 18%
Total physical RAM: 16310.46 MB
Available physical RAM: 13282.63 MB
Total Virtual: 20918.46 MB
Available Virtual: 16009.3 MB
1 Drive c: () (Fixed) (Total:111.24 GB) (Free:25.86 GB) NTFS
2 Drive d: (New Volume) (Fixed) (Total:931.51 GB) (Free:268.4 GB) NTFS
User accounts for \\DESKTOP-TBPBO3J
Administrator brink DefaultAccount
Guest WDAGUtilityAccount
**** End of log ****
