PC audio randomly cuts out
suisei
23
My audio randomly cuts out for some reason. I thought it was just my headset, but my headsets work perfectly for other devices. My audio would randomly cut out, and the audio icon on the bottom right of the screen would have a red x. I have always had this issue but before it was really minor. It was not until I put in a new CPU, motherboard, and RAM that these issues started getting worse.
Sorry but you have post on a tech forum asking for help but have provided zero information about your computer or it`s hardware, this makes it impossible for anyone to even hazard a guess as to what is going on.
Is the computer a custom build or brand name such as Dell or HP, if a brand name, provide the model name or series number (not serial) if a custom build post the brand and model name or number for the CPU, MB, the RAM (including the amount) add on video card if one is used and the PSU (power supply unit) providing these details will enable folk to better help you.
