O S not found
Azules
7
57
Hi guys
My daughters laptop a vaio PC, has been giving the dreaded operating system not found screen
I can get it going ith inteenet working, but after a while it will revert back to not working screen
I did not make a back up disc origanlly, but have made one now, while I have it going, (not sure if thats any good now )
my question is, I have done a system restore and back to default settings, but this still happens
Does this point at the hard drive needing to be changed ?
Thanks
Hi Azules and welcome to PCHF :)
Are you able to run programs? If so, please do the following.
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Also what exactly is the make and model (year too) of the laptop?
Yes. I can get acces for a short while
I will try this thanks
I will get back to you with other details as I find it out
My daughter has stripped the machine bare of any logos
Ran by Jess (administrator) on 03-05-2017 at 17:59:03
Running from "C:\Users\Jess\Downloads"
Microsoft Windows 8 (X64)
Model: SVE1512J6EW Manufacturer: Sony Corporation
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Qualcomm Atheros AR9485WB-EG Wireless Network Adapter = Wi-Fi (Connected)
Realtek PCIe GBE Family Controller = Ethernet (Media disconnected)
Bluetooth Device (Personal Area Network) = Bluetooth Network Connection (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
set interface interface="Local Area Connection* 9" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 11" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth Network Connection" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Jessica
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 08-3E-8E-C3-A3-20
Wireless LAN adapter Local Area Connection* 11:
Physical Address. . . . . . . . . : 1A-3E-8E-C3-A3-1F
Ethernet adapter Ethernet:
Physical Address. . . . . . . . . : 30-F9-ED-C3-3D-C3
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Qualcomm Atheros AR9485WB-EG Wireless Network Adapter
Physical Address. . . . . . . . . : 08-3E-8E-C3-A3-1F
Link-local IPv6 Address . . . . . : fe80::a12d:d33d:2fda:d461%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.14(Preferred)
Lease Obtained. . . . . . . . . . : 03 May 2017 17:54:05
Lease Expires . . . . . . . . . . : 04 May 2017 17:54:05
DHCPv6 IAID . . . . . . . . . . . : 252198542
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-18-05-05-E6-08-3E-8E-C3-A3-1F
DNS Servers . . . . . . . . . . . : 192.168.0.1
Tunnel adapter isatap.{E5A365FF-75AD-4870-9185-3E1BD30B2002}:
Tunnel adapter Local Area Connection* 13:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:3093:2403:a313:b9d4(Preferred)
Link-local IPv6 Address . . . . . : fe80::3093:2403:a313:b9d4%19(Preferred)
Default Gateway . . . . . . . . . : ::
Server: routerlogin.net
Address: 192.168.0.1
Addresses: 2a00:1450:4009:813::200e
172.217.23.46
172.217.23.46
172.217.23.46
Pinging google.com [172.217.23.46] with 32 bytes of data:
Reply from 172.217.23.46: bytes=32 time=50ms TTL=53
Reply from 172.217.23.46: bytes=32 time=21ms TTL=53
Ping statistics for 172.217.23.46:
Minimum = 21ms, Maximum = 50ms, Average = 35ms
Addresses: 2001:4998:58:c02::a9
2001:4998:44:204::a7
2001:4998:c:a06::2:4008
206.190.36.45
98.139.183.24
98.138.253.109
Pinging yahoo.com [98.138.253.109] with 32 bytes of data:
Reply from 98.138.253.109: bytes=32 time=159ms TTL=47
Reply from 98.138.253.109: bytes=32 time=140ms TTL=47
Ping statistics for 98.138.253.109:
Minimum = 140ms, Maximum = 159ms, Average = 149ms
Interface List
17...08 3e 8e c3 a3 20 ......Bluetooth Device (Personal Area Network)
14...1a 3e 8e c3 a3 1f ......Microsoft Wi-Fi Direct Virtual Adapter
13...30 f9 ed c3 3d c3 ......Realtek PCIe GBE Family Controller
12...08 3e 8e c3 a3 1f ......Qualcomm Atheros AR9485WB-EG Wireless Network Adapter
15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
16...00 00 00 00 00 00 00 e0 Microsoft 6to4 Adapter
19...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.14 25
192.168.0.0 255.255.255.0 On-link 192.168.0.14 281
192.168.0.14 255.255.255.255 On-link 192.168.0.14 281
192.168.0.255 255.255.255.255 On-link 192.168.0.14 281
224.0.0.0 240.0.0.0 On-link 192.168.0.14 281
255.255.255.255 255.255.255.255 On-link 192.168.0.14 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
19 306 ::/0 On-link
1 306 ::1/128 On-link
19 306 2001::/32 On-link
19 306 2001:0:4137:9e76:3093:2403:a313:b9d4/128
On-link
12 281 fe80::/64 On-link
19 306 fe80::/64 On-link
19 306 fe80::3093:2403:a313:b9d4/128
On-link
12 281 fe80::a12d:d33d:2fda:d461/128
On-link
1 306 ff00::/8 On-link
19 306 ff00::/8 On-link
12 281 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [52224] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [67584] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [67584] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [55296] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [21504] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [50688] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [289280] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [66560] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [85504] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [85504] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [72192] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [53760] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [64000] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [355328] (Microsoft Corporation)
Application errors:
Error: (05/02/2017 09:36:51 AM) (Source: Microsoft-Windows-Immersive-Shell) (User: Jessica)
Description: Activation of app Microsoft.Studios.Wordament_8wekyb3d8bbwe!Wordament failed with error: -2144927142 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Error: (05/02/2017 09:36:48 AM) (Source: Microsoft-Windows-Immersive-Shell) (User: Jessica)
Description: App Microsoft.Studios.Wordament_8wekyb3d8bbwe!Wordament did not launch within its allotted time.
Error: (05/02/2017 08:35:59 AM) (Source: Software Protection Platform Service) (User: )
Description: License Activation (slui.exe) failed with the following error code:
hr=0x80072EFD
Command-line arguments:
RuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=9e4b231b-3e45-41f4-967f-c914f178b6ac;NotificationInterval=1440;Trigger=UserLogon;SessionId=3
Error: (05/02/2017 08:35:55 AM) (Source: Software Protection Platform Service) (User: )
Description: Acquisition of genuine ticket failed (hr=0x80072EFD) for template Id {88d92734-d682-4d71-983e-d6ec3f16059f}
Description: License acquisition failure details.
hr=0x80072EFD
Error: (05/02/2017 12:08:50 AM) (Source: Software Protection Platform Service) (User: )
hr=0x80072EFD
RuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=9e4b231b-3e45-41f4-967f-c914f178b6ac;NotificationInterval=1440;Trigger=UserLogon;SessionId=1
Error: (05/02/2017 12:08:47 AM) (Source: Software Protection Platform Service) (User: )
Description: Acquisition of End User License failed. hr=0x80072EFD
Sku Id=9e4b231b-3e45-41f4-967f-c914f178b6ac
hr=0x80072EFD
System errors:
Error: (05/02/2017 10:56:03 AM) (Source: BugCheck) (User: )
Description: 0x0000007a (0xfffff6fb800083f8, 0xffffffffc000000e, 0x000000011eba9880, 0xfffff7000107f7d0)C:\WINDOWS\MEMORY.DMP050217-24468-01
Error: (05/02/2017 10:55:54 AM) (Source: EventLog) (User: )
Description: The previous system shutdown at 10:35:24 on ‎02/‎05/‎2017 was unexpected.
Error: (05/02/2017 10:18:25 AM) (Source: BugCheck) (User: )
Description: 0x0000007a (0xfffff6fb800083f8, 0xffffffffc000000e, 0x000000010216b880, 0xfffff7000107f610)C:\WINDOWS\MEMORY.DMP
Description:
Error: (05/02/2017 10:18:23 AM) (Source: EventLog) (User: )
Description: The previous system shutdown at 09:54:31 on ‎02/‎05/‎2017 was unexpected.
Error: (05/02/2017 09:48:43 AM) (Source: Service Control Manager) (User: )
Description: A timeout (30000 milliseconds) was reached while waiting for a transaction response from the McNASvc service.
Error: (05/02/2017 09:48:33 AM) (Source: Service Control Manager) (User: )
Description: A timeout (30000 milliseconds) was reached while waiting for a transaction response from the mcpltsvc service.
Description: A timeout (30000 milliseconds) was reached while waiting for a transaction response from the UNS service.
Description: A timeout (30000 milliseconds) was reached while waiting for a transaction response from the mfevtp service.
Error: (05/02/2017 09:47:55 AM) (Source: Service Control Manager) (User: )
Description: The Windows Update service did not shut down properly after receiving a preshutdown control.
Microsoft Office Sessions:
Error: (05/02/2017 09:36:51 AM) (Source: Microsoft-Windows-Immersive-Shell)(User: Jessica)
Description: Microsoft.Studios.Wordament_8wekyb3d8bbwe!Wordament-2144927142
Error: (05/02/2017 09:36:48 AM) (Source: Microsoft-Windows-Immersive-Shell)(User: Jessica)
Error: (05/02/2017 08:35:59 AM) (Source: Software Protection Platform Service)(User: )
Description: hr=0x80072EFDRuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=9e4b231b-3e45-41f4-967f-c914f178b6ac;NotificationInterval=1440;Trigger=UserLogon;SessionId=3
Error: (05/02/2017 08:35:55 AM) (Source: Software Protection Platform Service)(User: )
Description: hr=0x80072EFD{88d92734-d682-4d71-983e-d6ec3f16059f}
Description: hr=0x80072EFD00010001(0x00000000, 08:35:51:140 - https://validation.sls.microsoft.com/SLWGA/slwga.asmx)
00020001(0x00000000, 08:35:51:156)
00030001(0x00000000, 08:35:51:156 - https://validation.sls.microsoft.com)
00030002(0x00000000, 08:35:51:156 - 0)
00040001(0x00000000, 08:35:51:156 - https://validation.sls.microsoft.com)
00040002(0x00000000, 08:35:51:156 - 1, <NULL>, <NULL>, <NULL>)
00050002(0x80072F94, 08:35:51:156 - 0, 1)
00040006(0x00000001, 08:35:51:156 - 0, https://validation.sls.microsoft.com, <N/A>, <N/A>)
00020005(0x00000000, 08:35:51:156 - 0)
00020008(0x80072EFD, 08:35:55:172 - SOAPAction: "http://microsoft.com/SL/GenuineAdvantageService/IssueToken"
Content-Type: text/xml; charset=utf-8
, <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"><soap:Body><RequestSecurityToken xmlns="http://schemas.xmlsoap.org/ws/2004/04/security/trust"><TokenType>SLWGA</TokenType><RequestType>http://schemas.xmlsoap.org/ws/2004/04/security/trust/Issue</RequestType><UseKey><Values xsi:nil="1"/></UseKey><Claims><Values xmlns:q1="http://schemas.xmlsoap.org/ws/2004/04/security/trust" soapenc:arrayType="q1:TokenEntry[5]"><TokenEntry><Name>GenuineAdvantagePhase</Name><Value>GenuineAdvantagePhase1</Value></TokenEntry><TokenEntry><Name>GenuineAdvantageVersion</Name><Value>1.0</Value></TokenEntry><TokenEntry><Name>GenuineAdvantageTemplateId</Name><Value>{88d92734-d682-4d71-983e-d6ec3f16059f}</Value></TokenEntry><TokenEntry><Name>GenuineAdvantageClientTransactionId</Name><Value>67fbc561-9716-4e00-a3cc-801465b218a9</Value></TokenEntry><TokenEntry><Name>GenuineAdvantageClientToken</Name><Value></Value></TokenEntry></Values></Claims></RequestSecurityToken></soap:Body></soap:Envelope>)
00010002(0x80072EFD, 08:35:55:172 - <NULL>)
00010003(0x80072EFD, 08:35:55:172)
Error: (05/02/2017 12:08:50 AM) (Source: Software Protection Platform Service)(User: )
Description: hr=0x80072EFDRuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=9e4b231b-3e45-41f4-967f-c914f178b6ac;NotificationInterval=1440;Trigger=UserLogon;SessionId=1
Error: (05/02/2017 12:08:47 AM) (Source: Software Protection Platform Service)(User: )
Description: hr=0x80072EFD9e4b231b-3e45-41f4-967f-c914f178b6ac
Description: hr=0x80072EFD00010001(0x00000000, 00:08:40:096 - https://activation.sls.microsoft.com/SLActivateProduct/SLActivateProduct.asmx?configextension=DM)
00020001(0x00000000, 00:08:40:096)
00030001(0x00000000, 00:08:40:096 - https://activation.sls.microsoft.com)
00030002(0x00000000, 00:08:40:096 - 0)
00040001(0x00000000, 00:08:40:096 - https://activation.sls.microsoft.com)
00040002(0x00000000, 00:08:40:284 - 1, <NULL>, <NULL>, <NULL>)
00050002(0x80072F94, 00:08:40:284 - 0, 1)
00040006(0x00000001, 00:08:40:284 - 0, https://activation.sls.microsoft.com, <N/A>, <N/A>)
00020005(0x00000000, 00:08:40:284 - 0)
00020008(0x80072EFD, 00:08:47:659 - SOAPAction: "http://microsoft.com/SL/ProductActivationService/IssueToken"
, <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"><soap:Body><RequestSecurityToken xmlns="http://schemas.xmlsoap.org/ws/2004/04/security/trust"><TokenType>ProductActivation</TokenType><RequestType>http://schemas.xmlsoap.org/ws/2004/04/security/trust/Issue</RequestType><UseKey><Values xmlns:q1="http://schemas.xmlsoap.org/ws/2004/04/security/trust" soapenc:arrayType="q1:TokenEntry[1]"><TokenEntry><Name>PublishLicense</Name><Value>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</Value></TokenEntry></Values></UseKey><Claims><Values xmlns:q1="http://schemas.xmlsoap.org/ws/2004/04/security/trust" soapenc:arrayType="q1:TokenEntry[16]"><TokenEntry><Name>SessionKey</Name><Value>R5QTSitB33fRj0hJwOEG3ByOG1PFvMT9yTMkiXtiqvLGL3bdP4dR3pnJx7VxW1f2TlYdQFqBDgWN4Ncdy5HOWDt9HrV/wzDhiqanoy/CdM/uiXERXscgvNtHcw3vLNf6NlmOsSp/CcKeKMtbNDCBzR1TDBq06LpvjLiligHJBK26gPs0reoAfWbdsiNSyFXz9SD1eorc74dVLOTzwxpsNMzb4J8m2D3stTxcB8jyZd4rSAZo7l4rLIHDJRPGPtTstcYBebG21n7xag1tyZ2BXjO4TUBhl+S1dLkg7h6A0zLlJKnBVxd0RozUhKJCVysoInvYsbx9FTrLo/hQqyMGmg==</Value></TokenEntry><TokenEntry><Name>BindingType</Name><Value>7V1/N2t0MOmNhs4T8xkgkGeIpV6sS6Y+FEM5NVmf0dE=</Value></TokenEntry><TokenEntry><Name>Binding</Name><Value>+lOTw3G1uBnT/nyEsPPA27MRxS5uEX59UEuRShu/fW+oQzcTd4RD5ONiUiKHeCKhzKczxaWUTSN37PfJD1cKcX4lV089SGBcNLZnGAjRZMg=</Value></TokenEntry><TokenEntry><Name>ProductKey</Name><Value>nzS74MgWBMST5QzUz9AP2W93VYwu8/RTctVuvZ32Q+4=</Value></TokenEntry><TokenEntry><Name>ProductKeyType</Name><Value>7V1/N2t0MOmNhs4T8xkgkERKH9kwgh5wY8SZ9HwffCU=</Value></TokenEntry><TokenEntry><Name>ProductKeyActConfigId</Name><Value>b7Zp3atk6BWgib15WnpcIBNCFN5ALwTsoFmZOSOj0aoa/138liu1RdEq/M/9qrL+TgLN24U+Ae+hVWYnU2ItTVvACH8NWBO8wO5llqaw+G0=</Value></TokenEntry><TokenEntry><Name>otherInfoPublic.licenseCategory</Name><Value>B20zA26BW2BRTiEPvaX6ed4C+GBEEgy/Tl53z8pbEE8=</Value></TokenEntry><TokenEntry><Name>otherInfoPrivate.licenseCategory</Name><Value>B20zA26BW2BRTiEPvaX6efu//MjkHsWNtbjm//OFoZ0=</Value></TokenEntry><TokenEntry><Name>otherInfoPublic.sysprepAction</Name><Value>xRtDToT8ApwMLm1bXD7atQ==</Value></TokenEntry><TokenEntry><Name>otherInfoPrivate.sysprepAction</Name><Value>xRtDToT8ApwMLm1bXD7atQ==</Value></TokenEntry><TokenEntry><Name>ClientInformation</Name><Value>E8Hpon3LSFknnVM+m/Zl9V6bU9o5ppgS8yS0MXIlffnXoPbLq8uOIi42V60CmGqLif3S08mJl9OfS/6Mjp+mGw==</Value></TokenEntry><TokenEntry><Name>ReferralInformation</Name><Value>fYyeVD/wsgqWviE6hbMFxZudwOpc0a9vJSqCsv2glpAQdBmzfSKflSTxHkt5lPOEFPW0boNCRHxo5KVOUgnzjw==</Value></TokenEntry><TokenEntry><Name>ClientSystemTime</Name><Value>/y/kHiiBqOrtLnZ+/JAbXz62y6ZJOb0oAkottcBi42w=</Value></TokenEntry><TokenEntry><Name>ClientSystemTimeUtc</Name><Value>/y/kHiiBqOrtLnZ+/JAbXz62y6ZJOb0oAkottcBi42w=</Value></TokenEntry><TokenEntry><Name>otherInfoPublic.secureStoreId</Name><Value>SHtNN5ajuERYBofErLbFEr8/TjvPlpoZBsh6xxkA0OUpYWFQcBoZwPlIQVz+M1j4</Value></TokenEntry><TokenEntry><Name>otherInfoPrivate.secureStoreId</Name><Value>SHtNN5ajuERYBofErLbFEr8/TjvPlpoZBsh6xxkA0OUpYWFQcBoZwPlIQVz+M1j4</Value></TokenEntry></Values></Claims></RequestSecurityToken></soap:Body></soap:Envelope>)
00010002(0x80072EFD, 00:08:47:659 - <NULL>)
00010003(0x80072EFD, 00:08:47:659)
Adobe Reader X MUI (HKLM-x32\...\{AC76BA86-7AD7-FFFF-7B44-AA0000000001}) (Version: 10.0.0 - Adobe Systems Incorporated)
Agatha Christie - Death on the Nile (HKLM-x32\...\WTA-3b5c5121-20e5-42bb-a14b-3ad160eeea57) (Version: 2.2.0.98 - WildTangent) Hidden
Aloha TriPeaks (HKLM-x32\...\WTA-0a188a65-4c81-4fd8-8362-c67af17c02b4) (Version: 2.2.0.98 - WildTangent) Hidden
Bejeweled 3 (HKLM-x32\...\WTA-9c21cff6-2afa-4960-846f-77cf28f4a877) (Version: 2.2.0.98 - WildTangent) Hidden
Build-a-lot: On Vacation (HKLM-x32\...\WTA-551a77b4-fbc7-4d8c-bb3c-13ff5f596598) (Version: 2.2.0.110 - WildTangent) Hidden
Chronicles of Albian (HKLM-x32\...\WTA-c7d61a4b-6a4a-45ed-b3f6-5d355ded8c4b) (Version: 2.2.0.110 - WildTangent) Hidden
Chuzzle Deluxe (HKLM-x32\...\WTA-59963323-2ce1-4f73-9655-4ccc5fa9391d) (Version: 2.2.0.95 - WildTangent) Hidden
Cradle Of Egypt Collector's Edition (HKLM-x32\...\WTA-d55fec95-7c02-4e0f-a361-60f0e1afc8ed) (Version: 2.2.0.110 - WildTangent) Hidden
CyberLink Power2Go 8 (HKLM-x32\...\InstallShield_{2A87D48D-3FDF-41fd-97CD-A1E370EFFFE2}) (Version: 8.0.0.1923 - CyberLink Corp.)
CyberLink PowerDVD (HKLM-x32\...\InstallShield_{A8516AC9-AAF1-47F9-9766-03E2D4CDBCF8}) (Version: 9.0.5601.52 - CyberLink Corp.)
FATE (HKLM-x32\...\WTA-13a3f739-6eb6-4e8d-bbaa-0f3fe6e28b19) (Version: 2.2.0.97 - WildTangent) Hidden
FDUx86 (HKLM-x32\...\{3490653F-2789-46A1-B1BF-6BD4CF4131AB}) (Version: 1.0.0 - Sony Corporation) Hidden
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 58.0.3029.81 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.5 - Google Inc.) Hidden
Heroes of Hellas 3: Athens (HKLM-x32\...\WTA-49be7be2-35e0-4070-b6ff-afe12a61db3c) (Version: 2.2.0.110 - WildTangent) Hidden
Intel AppUp(SM) center (HKLM-x32\...\Intel AppUp(SM) center 38645) (Version: 03.05.11 - Intel)
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 8.1.0.1252 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 9.17.10.2817 - Intel Corporation)
Intel(R) Rapid Storage Technology (HKLM-x32\...\{3E29EE6C-963A-4aae-86C1-DC237C4A49FC}) (Version: 11.5.3.1004 - Intel Corporation)
Intel(R) SDK for OpenCL - CPU Only Runtime Package (HKLM-x32\...\{FCB3772C-B7D0-4933-B1A9-3707EBACC573}) (Version: 2.0.0.37149 - Intel Corporation)
Java(TM) 7 Update 5 (64-bit) (HKLM\...\{26A24AE4-039D-4CA4-87B4-2F86417005FF}) (Version: 7.0.50 - Oracle)
Java(TM) 7 Update 5 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F83217005FF}) (Version: 7.0.50 - Oracle)
KUx86 (HKLM-x32\...\{857087BB-A988-4462-A5C6-CF6739143B56}) (Version: 1.0.0 - Sony Corporation) Hidden
Luxor HD (HKLM-x32\...\WTA-799e1891-d59b-48d3-84c9-d1c337bfd6e2) (Version: 2.2.0.110 - WildTangent) Hidden
Mahjongg Artifacts (HKLM-x32\...\WTA-a36f9d7f-49f5-4ad8-9b41-4146285f8aec) (Version: 2.2.0.110 - WildTangent) Hidden
McAfee Internet Security (HKLM-x32\...\MSC) (Version: 11.6.385 - McAfee, Inc.)
McAfee Parental Controls (HKLM-x32\...\MOCP) (Version: 3.2.226.1 - McAfee, Inc.)
Microsoft Office (HKLM-x32\...\{95140000-0070-0000-0000-0000000FF1CE}) (Version: 14.0.6120.5004 - Microsoft Corporation)
Mystery of Mortlake Mansion (HKLM-x32\...\WTA-405699b5-615b-41de-a751-9fdce646d62c) (Version: 2.2.0.98 - WildTangent) Hidden
Mystery P.I. - The London Caper (HKLM-x32\...\WTA-75db1564-d0d1-4efd-80ce-3085a35c4ff0) (Version: 2.2.0.95 - WildTangent) Hidden
Plants vs. Zombies - Game of the Year (HKLM-x32\...\WTA-91a6c028-fc42-43cf-b094-9c55902c64a5) (Version: 2.2.0.98 - WildTangent) Hidden
PlayMemories Home (HKLM-x32\...\{10DD6128-A810-4A90-9523-475D573FBB37}) (Version: 6.3.02.07270 - Sony Corporation)
Polar Bowler (HKLM-x32\...\WTA-95dc2232-336c-4549-a07d-6a8864be63ee) (Version: 2.2.0.97 - WildTangent) Hidden
Qualcomm Atheros Bluetooth Suite (64) (HKLM\...\{A84A4FB1-D703-48DB-89E0-68B6499D2801}) (Version: 8.0.0.206 - Qualcomm Atheros Communications)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.6695 - Realtek Semiconductor Corp.)
Realtek PCIE Card Reader (HKLM-x32\...\{C1594429-8296-4652-BF54-9DBE4932A44C}) (Version: 6.1.8400.28121 - Realtek Semiconductor Corp.)
Restore (HKLM-x32\...\{ECCEB4D0-7080-4F8A-B498-E40A32A4FBED}) (Version: 1.0.0 - Sony Corporation) Hidden
Shared C Run-time for x64 (HKLM\...\{EF79C448-6946-4D71-8134-03407888C054}) (Version: 10.0.0 - McAfee)
SSLx64 (HKLM\...\{312395BC-7CC2-434C-A660-30250276A926}) (Version: 1.0.0 - Sony Corporation ) Hidden
SSLx86 (HKLM-x32\...\{63C43435-F428-42BA-8E7B-5848749D9262}) (Version: 1.0.0 - Sony Corporation ) Hidden
Synaptics Pointing Device Driver (HKLM\...\SynTPDeinstKey) (Version: 16.2.10.5 - Synaptics Incorporated)
Update Installer for WildTangent Games App (HKLM-x32\...\{2FA94A64-C84E-49d1-97DD-7BF06C7BBFB2}.WildTangent Games App) (Version: - WildTangent) Hidden
VAIO - Xperia Link (HKLM-x32\...\{D91558BF-D1F3-411F-AEFE-8774CB406512}) (Version: 1.0.0.08170 - Sony Corporation)
VAIO Care (HKLM\...\{E0F928B4-2BB2-4D7E-B16E-2B202CB58EDE}) (Version: 8.0.0.08150 - Sony Corporation)
VAIO Control Center (HKLM-x32\...\{8E797841-A110-41FD-B17A-3ABC0641187A}) (Version: 6.0.0.08200 - Sony Corporation)
VAIO CPU Fan Diagnostic (HKLM-x32\...\{BCE6E3D7-B565-4E1B-AC77-F780666A35FB}) (Version: 1.1.0.09200 - Sony Corporation)
VAIO Data Restore Tool (HKLM-x32\...\{57B955CE-B5D3-495D-AF1B-FAEE0540BFEF}) (Version: 1.10.0.07270 - Sony Corporation)
VAIO Easy Connect (HKLM-x32\...\{7C80D30A-AC02-4E3F-B95D-29F0E4FF937B}) (Version: 1.2.0.08150 - Sony Corporation) Hidden
VAIO Gate (HKLM-x32\...\{14AC95A2-7675-4988-A5BD-3F5B943AED08}) (Version: 3.0.0.08140 - Sony Corporation)
VAIO Gate Default (HKLM-x32\...\{B7546697-2A80-4256-A24B-1C33163F535B}) (Version: 3.0.0.08060 - Sony Corporation)
VAIO Gesture Control (HKLM-x32\...\{692955F2-DE9F-4078-8FAA-858D6F3A1776}) (Version: 2.0.0.08240 - Sony Corporation)
VAIO Gesture Control (HKLM-x32\...\{AA4B3623-6213-41EC-9BFB-F001D72C47A6}) (Version: 2.0.0.08240 - Sony Corporation) Hidden
VAIO Image Optimizer (HKLM-x32\...\{5597C927-029A-46A7-A0C0-8DABD9891A50}) (Version: 3.0.00.08170 - Sony Corporation) Hidden
VAIO Image Optimizer (HKLM-x32\...\InstallShield_{5597C927-029A-46A7-A0C0-8DABD9891A50}) (Version: 3.0.00.08170 - Sony Corporation)
VAIO Improvement (HKLM-x32\...\{3A26D9BD-0F73-432D-B522-2BA18138F7EF}) (Version: 2.0.0.08090 - Sony Corporation)
VAIO Manual (HKLM-x32\...\{C6E893E7-E5EA-4CD5-917C-5443E753FCBD}) (Version: 3.0.0.08100 - Sony Corporation)
VAIO Media Server Settings (HKLM\...\{62A172B2-550E-499D-9A82-5190D18390AA}) (Version: 1.0.0.08240 - Sony Corporation)
VAIO Movie Creator Template Data (HKLM-x32\...\{00A663F1-6C03-48CA-8E85-55806AAE2615}) (Version: 4.0.00.08170 - Sony Corporation) Hidden
VAIO Movie Creator Template Data (HKLM-x32\...\InstallShield_{00A663F1-6C03-48CA-8E85-55806AAE2615}) (Version: 4.0.00.08170 - Sony Corporation)
VAIO Transfer Support (HKLM-x32\...\{5DDAFB4B-C52E-468A-9E23-3B0CEEB671BF}) (Version: 1.8.0.08212 - Sony Corporation)
VAIO Update (HKLM-x32\...\{9FF95DA2-7DA1-4228-93B7-DED7EC02B6B2}) (Version: 6.0.0.08170 - Sony Corporation)
VCCx64 (HKLM\...\{AB447E3B-7A95-4CA6-8ECD-B25C96314B67}) (Version: 1.0.0 - Sony Corporation) Hidden
VCCx86 (HKLM-x32\...\{B31938C7-7E97-49EE-8F88-951E156268A3}) (Version: 1.0.0 - Sony Corporation) Hidden
VGClientX64 (HKLM\...\{5388ABD8-6E23-4498-BE10-01079387590F}) (Version: 1.0.0 - Sony Corporation) Hidden
VHD (HKLM-x32\...\{9D8112DB-3490-4BF1-AAFA-1D224FFB5D3C}) (Version: 1.0.0 - Sony Corporation) Hidden
Virtual Villagers 4 - The Tree of Life (HKLM-x32\...\WTA-63112c68-d436-4303-bace-ccf9156a93e8) (Version: 2.2.0.98 - WildTangent) Hidden
VIx64 (HKLM\...\{D55EAC07-7207-44BD-B524-0F063F327743}) (Version: 1.0.0 - Sony Corporation) Hidden
VIx86 (HKLM-x32\...\{D17C2A58-E0EA-4DD7-A2D6-C448FD25B6F6}) (Version: 1.0.0 - Sony Corporation) Hidden
VMLx86 (HKLM-x32\...\{7E5A5CA6-B7D0-406E-A75E-157CAB47EB94}) (Version: 1.0.0 - Sony Corporation) Hidden
VPMx64 (HKLM\...\{DBEAA361-F8A4-4298-B41C-9E9DCB9AAB84}) (Version: 1.0.0 - Sony Corporation ) Hidden
VSSTx64 (HKLM\...\{4F31AC31-0A28-4F5A-8416-513972DA1F79}) (Version: 1.0.0 - Sony Corporation ) Hidden
VSSTx86 (HKLM-x32\...\{B24BB74E-8359-43AA-985A-8E80C9219C70}) (Version: 1.0.0 - Sony Corporation) Hidden
VU5x64 (HKLM\...\{46261E1C-5E0D-484E-8CCC-7F770375FBA2}) (Version: 1.0.0 - Sony Corporation ) Hidden
VU5x86 (HKLM-x32\...\{D2D23D08-D10E-43D6-883C-78E0B2AC9CC6}) (Version: 1.0.0 - Sony Corporation ) Hidden
VUx64 (HKLM\...\{4B432082-B58C-4035-91FB-F28D504D3148}) (Version: 1.0.0 - Sony Corporation ) Hidden
VUx86 (HKLM-x32\...\{10181264-340D-4BE7-B879-3A49604A6FD1}) (Version: 1.0.0 - Sony Corporation ) Hidden
VWSTx86 (HKLM-x32\...\{B8991D99-88FD-41F2-8C32-DB70278D5C30}) (Version: 1.0.0 - Sony Corporation) Hidden
WildTangent Games (HKLM-x32\...\WildTangent sony Master Uninstall) (Version: 1.0.3.0 - WildTangent)
WildTangent Games App (HKLM-x32\...\{70B446D1-E03B-4ab0-9B3C-0832142C9AA8}.WildTangent Games App-sony) (Version: 4.0.8.7 - WildTangent) Hidden
XperiaLinkx86 (HKLM-x32\...\{CD650B6A-FE79-40E0-A069-299CF6575E6B}) (Version: 1.0.0 - Sony Corporation) Hidden
Percentage of memory in use: 22%
Total physical RAM: 3975.27 MB
Available physical RAM: 3065.7 MB
Total Virtual: 8071.27 MB
Available Virtual: 6699.67 MB
1 Drive c: () (Fixed) (Total:566.1 GB) (Free:529.58 GB) NTFS
User accounts for \\JESSICA
Administrator Guest Jess
**** End of log ****
Run Check Disk
Run chkdsk /f /r from elevated command prompt.
After the checkdisk....
Scan with ListChkDskResult
Please download ListChkDskResult by SleepyDude and save it to your desktop.
  • Right-click on
    icon and select
    Run as Administrator to start the tool.
  • A message about checking Windows Event Log will pop-up. Click OK.
  • Wait patiently until a notepad window will open. This won't take long.
  • The displayed logfile will be also saved to your desktop as ListChkDskResult.txt.
Please include the content of this file in your next reply.
Thanks for the reply guys
I will try to do so if the laptop will stay on long enough, watch this space please :-)
Reactions: jmarket
Right, jmarket, sorry my freind, I cant get the dump to go into a zipfile
it just ask me what app I want to open it with,
To grab a dump file.
Install 7 zip
Everything Search Engine portable.
Copy and paste C:\Windows\Minidump into the Everything Search window.
Right click the minidump folder and select Add to Minidump.zip
Drag the new dump folder to your desktop and upload it here.
If it is too large, then use sendspace.com and send us the link.
Hi
The problem is, it will not allow me to open the dump file
So I cant get in it to copy and paste it
It just asks me what I would like to open ghe dump file with
You do not need to open the dump file, read my instructions and you will be able to zip them up. :)
Sysnative Tool.
1. Download the Sysnative BSOD Dump + System File Collection App - Unzip and save to Documents folder -
2. Run the app - Double-click on the downloaded EXE file
Output = new folder created in Documents + a zipped version -- SysnativeFileCollectionApp + SysnativeFileCollectionApp.zip
Upload the SysnativeFileCollectionApp.zip into your next reply,.
Reactions: veeg
