Im not having a bad time, just keep getting interuppted by customers with petty issues "My water meter is spinning and the leak is in the yard, can you come right away" "My air conditioner is not running, its 100 degrees in the house and I have a new born, can you come right away" Chill out people, I have serious issues, my R9's won't crossfire....I appreciate the encouragement LCG'day Papa D. Here is a bit of trivia that may help calm your nerves in regards to reading these log files. The trick is knowing what should be in them, what should not be in them, what will be in them regardless of whether your PC is running right or not and what pertains to your issue. Most things will be harmless. Someone good with these log files can separate the fluff from the chaff. Not to worry.
I may have accidentally plugged up the secondary HDD thinking it was the media drive. Its unplugged now. I had the media drive plugged up so I could install network driver from disc. my mouse and keyboard. and speakers. the onboard devices usb, card reader.When you installed the os again what devices did you have connected?
Yeah, that is the razer sysnopses I choose do not install, it is wanting to install cause the mouse is plugged in and its settings are in a cloud. Maybe I shoul duse a different mouse, but will try to locate the exe and remove it.Hi there,
Don't mind me, just chirping in here
I see in your log that "RzWizard.exe" faulted and rebooted your computer. I need you to remove it and try it again. My gut and brain still point to a overloaded PSU.
RzWizard.exe is related to Razer hardware, but I'm curious to see if you can remove it and run the benchmark without rebooting. If so, that was the culprit. If not, I'm leaning towards your PSU not being able to handle 2 R9 cards in a CF configuration without resetting itself in protection.
The single card runs furmark with no trouble. Am going to try 3d mark now with single card. Then switch cards and repeat.
Thank all of you for helping. I am far better with my trades than I am computers!
