No sound after system reset
Went back into BIOS and followed all options but no sign of optimise defaults.....the only place I didnt go was command line prompt
Some confusion me thinks as there is no command prompt in the BIOS, command prompt is a part of Windows which you may recall from my earlier reply has no bearing on the BIOS.
To get into the BIOS it will either be done by continually tapping the Del or the F2 key once you have powered up the computer, if Del does not work you will need to restart the computer and try again but this time by continually tapping the F2 key.
Tip
If using a computer and not a mobile phone, please avoid adding multiple posts while waiting for us to reply to your last, edit your last post to include anything that you wish to add, this will ensure nothing gets overlooked which can sometimes happen if a thread has more than one page, it avoids filling up folks inbox and last but not least it amounts to bumping your thread which puts folk to the bottom of any reply list.
