Solved No Sound after Power Supply Replacement
before you reinstall windows go here and download the audio driver
Download
1. Click Download File.
2. When the File Download window is displayed, click Save to save the file to your hard drive.
Installation
1. Browse to the location where you downloaded the file and double-click the new file.
2. Read the information in the dialog window.
3. Download and install any prerequisites that are identified in the dialog window before proceeding.
4. Click the Install button.
5. Follow the remaining prompts to perform the update.
Installed an old Hard drive that I cloned from the one in this Opti 760 and everything seems to work now ..Think the whole problem was that stupid bios battery ... I am going to switch it into where I do most of my "computer stuff" and take this old 760 opti out for a spare .. It works fine ..but I want to see what 4 cores rather than 2 in the processor does also the "new" one holds 4 times as much ram ..so we will see ...
I just didn't want to leave this question I had open ..Someone helped and I really appreciate it .. I will come back to this thread if it breaks down ...again .
Thanks Again for the Help ... Don
What about all the other options, have you tried them, if yes, what happened, if no, give them a try.
Did you not understand the fact that you have to use drivers provided by Dell and installed in the exact order that they tell you to;
Hello .. sorry I couldn't figure how to reply to you without hitting the reply key ..been trying to keep up with what I have tried .. The Dell website wanted me to download and install some kind of installer ...I downloaded and opened it and it told me something would be in my toolbar to click on ..but nothing was there ...anyhow I finally figured how to ask and download all the updates and bios for my pc by the service tag # .. I used your list you posted to install the programs in order ..It's running now .. I had replaced the 2032 battery and thought it was OK as it ran for 3/4 of a day before the blue screen .. Using my 760 here again for my Entertainment PC .. I do everything but games on here ..
Just wanted to update this .. i will make that 9020 my main computer again ..tomorrow ..and see if it doesn't crash .. I Hope
So thanks for your suggestions ..it just took me a while to figure how to use them ... And I'm still not sure it's "fixed"
Thanks Again ..Have a Good Evening .. Don
Thanks for the update Don and fingers crossed for you that your perseverance has paid off (y)
