I'll give details but incase they are not needed to answer my question I'll do the tl;dr first. I am building new PC (not my first) and had everything ready to flip the power switch on power supply, but when I did various lights flickered and then nothing happened and the power button for PC didn't work. Did various things, kept trying and then I seen a small puff of smoke. Pulled out phone and made 3 videos of me searching for and finding smoke which ended up being 2 chips on the motherboard that had holes on top of them that would poof smoke every time I flipped power switch on power supply.
Is there anything I could have done to cause this, something I should watch out for when my fixed motherboard comes back and I try again?
or
when this occurs, is it obvious that it is a motherboard issue and I shouldn't have issues when it comes back? (there is a reason I'm asking)
Brand New Parts
-i7 - 12700k
-MSI Z790 Gaming Pro Motherboard
-Thermaltake Toughpower 750W 80+ Gold
-Cooler Master Hyper 620s
-G.Skill Trident Z5 (2x16GB) DDR5 7200
-be quiet! Pure Base 500DX
Used Parts
- Kingspec SSD 1TB ( 2 months old. I bought it for the new PC but tested it in my 6 yr old built PC with HDD to feel the difference. I did not format it or anything, when I was ready for new PC I removed from old PC and plugged into new PC. )
- Mouse & Keyboard are wired and over a year old from old PC.
Inside of the PC I had everything plugged into motherboard. Case, lights from case, lights from fans
Items I Had Connected to Motherboard Externally
-Mouse & Keyboard (does them having old USB plugs and the motherboard having all 3.2 USB inputs matter?)
-Ethernet Cable (cat6 - don't know if that matters)
-Old USB Flash Drive with an ISO version of windows
-HDMI cable (not new and possibly over 2-3 years old)
After realizing the 2 chips had holes I unplugged PC and hooked old keyboard & mouse and the SSD back up to my old pc. The mouse does not work at all, the keyboard works but the lights do not and the SSD that I used for 2 months can not even be recognized by the old PC. I do not know if CPU or memory was affected the same way, no way to test. The PSU seems fine and makes the motherboard smoke every time switch is flipped so "I guess" it's working.
1. Is there anything I could have done to cause this?
2. Why does my mouse and SSD not work anymore?
3. If the damage goes farther than mouse and SSD (CPU or memory) am I screwed or is the motherboard maker at fault, kind of thing? I'm already down a mouse, SSD and the RGB lighting from my keyboard.
4. Is it good to have EVERYTHING plugged in on first post or is there a certain/special way to hook things up? From posting PC with only motherboard (if possible) to only plugging certain cables in at certain points? ( I don't know how to ask what I am asking but hopefully you get it
Here are the 3 videos of the motherboard.
Had to pay $50 to send a brand new board that doesn't work correctly back to be fixed (which I don't understand) so I'm trying to make sure it works this time. I'm going to replace the SSD with an M.2 SSD this time as well. I tried to look up mouse and keyboards with 3.2 USB connectors but that doesn't seem to be a thing when searching so I'm guessing that my old keyboard and mouse were not an issue.
ANY advise is appreciated. Thank You
or
Brand New Parts
-i7 - 12700k
Used Parts
