How are you attempting to connect to the internet?
hwinfo --disk
YesShould I reset my BIOS to factory default settings?
Are the data (to the drive and controller) and power cables connected and snug?
What is the make and model?
All connections are good. The DVD drive does show in the BIOS. I will try connecting the HD to the DVD cables and see what happens. I also tried connecting an external HD via USB and it did work. I hope resetting the BIOS works.Yes
What Sata port # is the HDD connected to?
When you boot linux from the USB drive does it see the DVD drives?
Try connecting the HDD to that SATA cable.
How do I find that? I reset the BIOS and it now shows the HD.Connect the hard drive to the sata port labelled 0
I put a 500gb HD in it and I put Ubuntu on it. I don't know much about Linux.Now which Operating System are you wanting to install?
Will this be a dual boot system?
What size is the HDD?
How old is that HDD and have you tested it to make sure that there are no issues with it?
Honestly would not put Linux on it if you are going to sell it.
It is solvedNot a problem do you need any other help on this or do you consider it solved?
