Need Help With my Desktop PC
Mowin Lewis
4
34
So a while back i bought a custom built pc from Pc Specialists and now its out of warranty and guarantee
so i upgraded my Pc from windows 10 - Windows 11 then i reset it back to windows 10 as i having issues with bsod and other issues
anyways after i reset my windows back to windows 10 now my pc is having issue when it comes to over heating its even before it starts windows i get error message that my cpu is overheating in bios i ran bios settings and hit it back to reset to default but its still the same.
here is my specs when i bought the pc and have not changed any component
Processor (CPU)AMD Ryzen 7 3700X Eight Core CPU (3.6GHz-4.4GHz/36MB CACHE/AM4)
MotherboardASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready!
Memory (RAM)16GB Corsair VENGEANCE DDR4 3000MHz (4 x 4GB)
Graphics Card8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1st Storage Drive256GB PCS 2.5" SSD, SATA 6 Gb (500MB/R, 400MB/W)
Partitions: 256GB
2nd Storage Drive2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE
Partitions: 1000GB, 1000GB
Power SupplyCORSAIR 650W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingPCS FrostFlow 120 Series RGB High Performance Liquid Cooler
Thermal PasteARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
Extra Case Fans1x 120mm Black Case Fan (configured to extract from rear/roof)
Sound CardONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless Network CardWIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD
USB/Thunderbolt OptionsMIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Let's get some more information:
Download and run the free version of speccy.
Once you have ran speccy, follow the instructions to upload a snapshot found here.
hi unfortunately i can't even switch on the pc without it auto shutting down and when i do start it up again i get CPU over Temperature Error i never encountered it before i was using the pc just fine yesterday :(
When was the last time you cleaned the dust from the system.
Was this a fresh install and where did and how was the install media created.
so i upgraded my windows from windows 10 to windows 11 when i got message through windows update but then i reset it back through windows recovery in system settings back to windows 10
How did you clean it?
When you look into your PC, is the fan for the radiator spinning?
Can you hear the pump running? (The circular puck looking bit on-top of the processor).
You don't need to quote your replies, the website will line them up by time posted, it helps us to not miss things. :)
A few clear detailed pictures of the inside of your computer could help us spot anything out of place as well - if you feel comfortable with that.
Being that the OP revisited the forum but chose not to reply this thread will be closed.
