Monitor white line
andrew123
24
My monitor got a white line at the bottom , if i take a screenshot the monitor is normal , it also has screen burn . This happened to the monitor before but it got back to normal after 5-10 minutes. Please help?
Sounds like a dead pixel to me, sometimes running through certain colors or patterns can cause the pixel to come back for a bit.
Try running through this dead pixel tester and see where it gets you, is your monitor still under warranty?
Saddly is not under warranty , but thanks for the advice ,it seems like that white line is stuck there i dont know what it means , the line is semi transparent because i can adjust my image to get under this line. The display image is stuttering its like the monitor is on drugs .
happen om a different Monitor?
happen if connected to a different system?
speccy report
What is the brand and model name or number of the PSU.
