Solved Microphone Quiet
Ben Davis
52
Australia
Motherboard - Msi Gaming M3 z270 Headset - Sades SA-708
I know you can turn on the mic boost however upon doing so theres some pretty bad static, although i have heard that this headset is pretty bad if this is the case could someone recommend a reasonable headset with a reasonable price? Thanks
Yeah that headset only got 3.8 stars on Amazon.. To be more specific...what is you budget on these headsets?
I'm hoping to spend at least less than $90 although, if possible I would also like a headset that doesn't pickup background noise so much and doesn't require Mic boost
