Solved Memory usage above 90%
Then that means they don't exist but remnants do. That could explain why your memory is high. You did have some malware on your system, so we need to do more cleaning.
We will need a log from Zemana, can you please download the free trial HERE. Save it to somewhere you can find, double click the downloaded file and start the installation. Accept the default install options and you can safely ignore any security warnings and allow Zemana to complete the install. Once completed click the new desktop icon
zamicon-jpg.786
to open the program. If Zemana opens and informs of any available updates allow it to so. Next change Zemana's default from "Smart Scan" to Deep Scan as shown below.
zem1-jpg.780
Then click scan
zem2-jpg.782
When the scan is complete allow Zemana to Quarantine any infections found by clicking Next
zem3-jpg.783
Once the infections are quarantined a message box will indicate success, then click the logs icon as below.
zem4a-jpg.784
Select the latest scan and choose Open Report from the upper menu. or simply double left click on the scan just run.
zem5-jpg.785
The log will open as a text file. Please Copy and Paste the contents of that file in your next post :)
Download attached fixlist.txt file and save it to the Desktop. NOTE. It's important that both files, FRST/FRST64 and fixlist.txt are in the same location or the fix will not work. NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system. Run FRST/FRST64 and press the Fix button just once and wait. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run. When finished FRST will generate a log on the Desktop (Fixlog.txt). Please post it to your reply as well as a fresh set of FRST and Addition Logs :)
I think I used zemana before and theres no more free trial so I couldnt run it. Any other option for that?
Fix result of Farbar Recovery Scan Tool (x64) Version: 13.03.2018
Ran by ASUS (14-03-2018 21:41:49) Run:6
Running from C:\Users\ASUS\Desktop
Loaded Profiles: defaultuser0 & ASUS (Available Profiles: defaultuser0 & ASUS)
Boot Mode: Normal
fixlist content:
start
CreateRestorePoint:
CloseProcesses:
HKLM\...\StartupApproved\Run32: => "AvastUI.exe"
HKLM\SOFTWARE\Policies\Microsoft\Windows Defender: Restriction <==== ATTENTION
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia
Hosts:
CMD: netsh advfirewall reset
CMD: netsh advfirewall set allprofiles state On
RemoveProxy:
CMD: ipconfig /flushdns
CMD: netsh winsock reset catalog
CMD: netsh int ip reset c:\resetlog.txt
CMD: ipconfig /release
CMD: ipconfig /renew
CMD: netsh int ipv4 reset
CMD: netsh int ipv6 reset
EmptyTemp:
reboot:
end
Error: (0) Failed to create a restore point.
"HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run32\\AvastUI.exe" => removed successfully
"HKLM\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\AvastUI.exe" => not found
"HKLM\SOFTWARE\Policies\Microsoft\Windows Defender" => removed successfully
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek => moved successfully
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake => moved successfully
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\apdfllckaahabafndbhieahigkjlhalf => moved successfully
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo => moved successfully
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap => moved successfully
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi => moved successfully
C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\pjkljhegncpnkpknbcohdijeoejaedia => moved successfully
C:\Windows\System32\Drivers\etc\hosts => moved successfully
Hosts restored successfully.
========= netsh advfirewall reset =========
Ok.
========= netsh advfirewall set allprofiles state On =========
Ok.
"HKLM\SOFTWARE\Policies\Microsoft\Internet Explorer" => removed successfully
"HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\DefaultConnectionSettings" => removed successfully
"HKU\S-1-5-21-2746278279-2939389576-4119914495-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\DefaultConnectionSettings" => removed successfully
"HKU\S-1-5-21-2746278279-2939389576-4119914495-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\SavedLegacySettings" => removed successfully
"HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\DefaultConnectionSettings" => removed successfully
"HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Connections\\SavedLegacySettings" => removed successfully
Windows IP Configuration
========= netsh winsock reset catalog =========
Sucessfully reset the Winsock Catalog.
You must restart the computer in order to complete the reset.
========= netsh int ip reset c:\resetlog.txt =========
Resetting Compartment Forwarding, OK!
Resetting Compartment, OK!
Resetting Control Protocol, OK!
Resetting Echo Sequence Request, OK!
Resetting Global, OK!
Resetting Interface, OK!
Resetting Anycast Address, OK!
Resetting Multicast Address, OK!
Resetting Unicast Address, OK!
Resetting Neighbor, OK!
Resetting Path, OK!
Resetting Potential, OK!
Resetting Prefix Policy, OK!
Resetting Proxy Neighbor, OK!
Resetting Route, OK!
Resetting Site Prefix, OK!
Resetting Subinterface, OK!
Resetting Wakeup Pattern, OK!
Resetting Resolve Neighbor, OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , failed.
Access is denied.
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Restart the computer to complete this action.
========= ipconfig /release =========
No operation can be performed on Ethernet while it has its media disconnected.
No operation can be performed on Local Area Connection* 3 while it has its media disconnected.
No operation can be performed on Bluetooth Network Connection while it has its media disconnected.
Ethernet adapter Ethernet:
Wireless LAN adapter Local Area Connection* 3:
Wireless LAN adapter WiFi:
Link-local IPv6 Address . . . . . : fe80::fc9a:5de4:6a87:4582%16
Default Gateway . . . . . . . . . :
Ethernet adapter Bluetooth Network Connection:
========= ipconfig /renew =========
Connection-specific DNS Suffix . : zaq.ne.jp
IPv4 Address. . . . . . . . . . . : 192.168.0.10
========= netsh int ipv4 reset =========
Resetting Path, OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , failed.
Access is denied.
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
========= netsh int ipv6 reset =========
Resetting Path, OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , failed.
Access is denied.
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
Resetting , OK!
BITS transfer queue => 7888896 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 15911860 B
Java, Flash, Steam htmlcache => 291 B
Windows/system/drivers => 667358 B
Edge => 1836438 B
Chrome => 393894122 B
Firefox => 0 B
Opera => 0 B
Default => 0 B
Users => 0 B
ProgramData => 0 B
Public => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 5742 B
NetworkService => 0 B
defaultuser0 => 0 B
ASUS => 20203948 B
RecycleBin => 0 B
EmptyTemp: => 420 MB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 21:43:18 ====
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 13.03.2018
Ran by ASUS (14-03-2018 21:51:29)
Windows 10 Enterprise Version 1709 16299.248 (X64) (2017-11-25 18:31:33)
Boot Mode: Normal
Administrator (S-1-5-21-2746278279-2939389576-4119914495-500 - Administrator - Disabled)
ASUS (S-1-5-21-2746278279-2939389576-4119914495-1001 - Administrator - Enabled) => C:\Users\ASUS
DefaultAccount (S-1-5-21-2746278279-2939389576-4119914495-503 - Limited - Disabled)
defaultuser0 (S-1-5-21-2746278279-2939389576-4119914495-1000 - Limited - Disabled) => C:\Users\defaultuser0
Guest (S-1-5-21-2746278279-2939389576-4119914495-501 - Limited - Disabled)
WDAGUtilityAccount (S-1-5-21-2746278279-2939389576-4119914495-504 - Limited - Disabled)
AV: 360 Total Security (Enabled - Up to date) {0371CA44-3F80-A1D3-BECE-910620B58D50}
AS: 360 Total Security (Enabled - Up to date) {B8102BA0-19BA-AE5D-847E-AA745B32C7ED}
360 Total Security (HKLM-x32\...\360TotalSecurity) (Version: 9.6.0.1270 - 360 Security Center)
ACDSee Pro 3 (HKLM-x32\...\{1B280FAF-AE10-4E31-A41A-DB3917D651DC}) (Version: 3.0.355 - ACD Systems International Inc.)
Active Directory Authentication Library for SQL Server (HKLM\...\{32C0D7B2-1046-43AC-98AD-B748E1910916}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
Active Directory Authentication Library for SQL Server (x86) (HKLM-x32\...\{F40FA676-46B1-4609-85EF-D2F1F79E0C0E}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 18.011.20038 - Adobe Systems Incorporated)
Adobe Flash Player 29 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 29.0.0.113 - Adobe Systems Incorporated)
Adobe Photoshop CS6 (HKLM-x32\...\{74EB3499-8B95-4B5C-96EB-7B342F3FD0C6}) (Version: 13.0 - Adobe Systems Incorporated)
Alcor Micro USB Card Reader Driver (HKLM-x32\...\{9D569A6E-C9DF-490E-93E0-7AFD28D1F9BB}) (Version: 20.23.401.14519 - Alcor Micro Corp.) Hidden
Alcor Micro USB Card Reader Driver (HKLM-x32\...\InstallShield_{9D569A6E-C9DF-490E-93E0-7AFD28D1F9BB}) (Version: 20.23.401.14519 - Alcor Micro Corp.)
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 382.33 - NVIDIA Corporation) Hidden
Apple Application Support (32-bit) (HKLM-x32\...\{D4C80B0C-CF67-43A7-90C3-466853543B54}) (Version: 6.3 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{B2A2E8AF-BC48-4191-B2C4-3846A19835CA}) (Version: 6.3 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{AA7D90D2-2387-4FA5-A3AF-96811BE49BFD}) (Version: 11.0.5.14 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{19589375-5C58-4AFA-842F-8B34744CCEAD}) (Version: 2.5.0.1 - Apple Inc.)
Application Insights Tools for Visual Studio 2015 (HKLM-x32\...\{0E4C791E-B78E-477D-BD5A-CDD0985BA6EC}) (Version: 7.0.20622.1 - Microsoft Corporation)
ArcSoft WebCam Companion 3 (HKLM-x32\...\{34985F59-8F6F-46F4-9AD5-53E2714294D2}) (Version: 3.0.189 - ArcSoft)
ASUS PTP Driver (HKLM-x32\...\{7618E419-9124-4E6C-9AF4-487A6DDEC1C5}) (Version: 11.0.11 - ASUS)
ASUS Touchpad Handwriting (HKLM-x32\...\{F3ED910A-9041-49D0-9C70-BD9E1DC5B08E}) (Version: 1.0.2 - ASUS)
ATK Package (HKLM-x32\...\{AB5C933E-5C7D-4D30-B314-9C83A49B94BE}) (Version: 1.0.0043 - ASUS)
AudioWizard (HKLM-x32\...\{57E770A2-2BAF-4CAA-BAA3-BD896E2254D3}) (Version: 1.0.0.157 - ICEpower a/s)
AutoHotkey 1.1.28.00 (HKLM\...\AutoHotkey) (Version: 1.1.28.00 - Lexikos)
AutoIt v3.3.14.2 (HKLM-x32\...\AutoItv3) (Version: 3.3.14.2 - AutoIt Team)
Azure AD Authentication Connected Service (HKLM-x32\...\{8A1AD070-269F-4A15-AAB5-76AB896EF195}) (Version: 14.0.25420 - Microsoft Corporation) Hidden
AzureTools.Notifications (HKLM-x32\...\{1E5CA362-39B6-4BD0-B9C0-69CF15F0FEA2}) (Version: 2.7.30611.1601 - Microsoft Corporation) Hidden
Bandicam (HKLM-x32\...\Bandicam) (Version: 3.3.3.1209 - Bandisoft)
Bandicam MPEG-1 Decoder (HKLM-x32\...\BandiMPEG1) (Version: - Bandicam.com)
BattlePing (HKLM-x32\...\{DB480AC3-1578-B8DC-3F8F-786A2A4E3BC7}) (Version: 1.4.3 - BattlePing)
Blend for Visual Studio SDK for .NET 4.5 (HKLM-x32\...\{37E53780-3944-4A6A-842F-727128E8616E}) (Version: 3.0.40218.0 - Microsoft Corporation) Hidden
CCleaner (HKLM\...\CCleaner) (Version: 5.41 - Piriform)
Cheat Engine 6.7 (HKLM-x32\...\Cheat Engine 6.7_is1) (Version: - Cheat Engine)
ClickOnce Bootstrapper Package for Microsoft .NET Framework (HKLM-x32\...\{D1844DC3-B378-47CC-AB40-7FC16C79A2CD}) (Version: 4.7.02558 - Microsoft Corporation) Hidden
Conexant HD Audio (HKLM\...\CNXT_AUDIO_HDA) (Version: 8.66.34.55 - Conexant)
DiagnosticsHub_CollectionService (HKLM\...\{A5DD0731-C724-4037-B35B-B80782AACE00}) (Version: 15.0.27128 - Microsoft Corporation) Hidden
Dotfuscator and Analytics Community Edition 5.22.0 (HKLM-x32\...\{60018889-9E0F-43E8-9B89-29E8C828B40A}) (Version: 5.22.0.3788 - PreEmptive Solutions) Hidden
Entity Framework 6.1.3 Tools for Visual Studio 15 (HKLM-x32\...\{F8C0447E-D45C-4E52-94E8-C6340AAC9DB8}) (Version: 6.1.60104.0 - Microsoft Corporation) Hidden
Entity Framework 6.1.3 Tools for Visual Studio 2015 Update 1 (HKLM-x32\...\{2A56910C-69C8-495D-8ED8-9080F0A14E58}) (Version: 14.0.41103.0 - Microsoft Corporation)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 65.0.3325.162 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.7 - Google Inc.) Hidden
Hotspot Shield 6.5.2 (HKLM-x32\...\{AF599C42-A2E5-4251-B7EE-4925B177CBA7}) (Version: 6.5.2.10372 - AnchorFree Inc.) Hidden
Hotspot Shield 6.5.2 (HKLM-x32\...\HotspotShield) (Version: 6.5.2 - AnchorFree Inc.) Hidden
HxD Hex Editor version 1.7.7.0 (HKLM-x32\...\HxD Hex Editor_is1) (Version: 1.7.7.0 - Maël Hörz)
icecap_collection_neutral (HKLM-x32\...\{9149432D-3BEE-4869-B6F5-7A5CF843A612}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
icecap_collection_x64 (HKLM\...\{D0C9796E-CB35-4440-885D-9630A0153D1E}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
icecap_collectionresources (HKLM-x32\...\{B96B62E4-2EE4-45EC-8082-246FFC1B12E3}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
icecap_collectionresourcesx64 (HKLM-x32\...\{262EE643-72FF-406D-9776-C6B65443DA5B}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
IDA Pro v6.8 and Hex-Rays Decompiler (ARM,x64,x86) (HKLM-x32\...\IDA Pro_6.8_is1) (Version: - Hex-Rays SA)
Intel(R) Chipset Device Software (HKLM-x32\...\{aaa7f0fb-02dc-4576-beef-7d24842c5fbe}) (Version: 10.1.1.32 - Intel(R) Corporation) Hidden
Intel(R) Dynamic Platform and Thermal Framework (HKLM-x32\...\{654EE65D-FAA4-4EA6-8C07-DC94E6A304D4}) (Version: 8.2.10900.330 - Intel Corporation)
Intel(R) Management Engine Components (HKLM\...\{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.5.0.1015 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 21.20.16.4550 - Intel Corporation)
Intel(R) Serial IO (HKLM\...\{9FD91C5C-44AE-4D9D-85BE-AE52816B0294}) (Version: 30.63.1620.3 - Intel Corporation)
Intel® Security Assist (HKLM-x32\...\{8B08DDA1-FDE7-4897-8EB6-E0B048A6D88B}) (Version: 1.0.1.618 - Intel Corporation)
IntelliTraceProfilerProxy (HKLM-x32\...\{0A2EDF2C-9A71-43D7-964A-696BB7CEAC65}) (Version: 15.0.25.0 - Microsoft Corporation) Hidden
iTunes (HKLM\...\{1D7D1271-5258-4F5A-B8C1-7176BF398782}) (Version: 12.7.3.46 - Apple Inc.)
K-Lite Mega Codec Pack 14.0.0 (HKLM-x32\...\KLiteCodecPack_is1) (Version: 14.0.0 - KLCP)
Malwarebytes version 3.4.4.2398 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.4.4.2398 - Malwarebytes)
Microsoft .NET Framework 4.5 Multi-Targeting Pack (HKLM-x32\...\{56E962F0-4FB0-3C67-88DB-9EAA6EEFC493}) (Version: 4.5.50710 - Microsoft Corporation)
Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (ENU) (HKLM-x32\...\{D3517C62-68A5-37CF-92F7-93C029A89681}) (Version: 4.5.50932 - Microsoft Corporation)
Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (HKLM-x32\...\{6A0C6700-EA93-372C-8871-DCCF13D160A4}) (Version: 4.5.50932 - Microsoft Corporation)
Microsoft .NET Framework 4.5.1 SDK (HKLM-x32\...\{19A5926D-66E1-46FC-854D-163AA10A52D3}) (Version: 4.5.51641 - Microsoft Corporation)
Microsoft .NET Framework 4.5.2 Multi-Targeting Pack (ENU) (HKLM-x32\...\{290FC320-2F5A-329E-8840-C4193BD7A9EE}) (Version: 4.5.51209 - Microsoft Corporation)
Microsoft .NET Framework 4.5.2 Multi-Targeting Pack (HKLM-x32\...\{19E8AE59-4D4A-3534-B567-6CC08FA4102E}) (Version: 4.5.51651 - Microsoft Corporation)
Microsoft .NET Framework 4.6 SDK (HKLM-x32\...\{B5915D37-0637-4A26-A3AA-C5DC9F856370}) (Version: 4.6.00081 - Microsoft Corporation)
Microsoft .NET Framework 4.6 Targeting Pack (ENU) (HKLM-x32\...\{034547E9-D8FA-49E7-8B9C-4C9861FB9146}) (Version: 4.6.00127 - Microsoft Corporation)
Microsoft .NET Framework 4.6 Targeting Pack (HKLM-x32\...\{2CC6A4A7-AAC2-46C9-9DBB-3727B5954F65}) (Version: 4.6.00081 - Microsoft Corporation)
Microsoft .NET Framework 4.6.1 SDK (HKLM-x32\...\{2F0ECC80-B9E4-4485-8083-CD32F22ABD92}) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft .NET Framework 4.6.1 Targeting Pack (ENU) (HKLM-x32\...\{8EEB28EE-5141-411C-9CF0-9952264FE4AF}) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft .NET Framework 4.6.1 Targeting Pack (HKLM-x32\...\{8BC3EEC9-090F-4C53-A8DA-1BEC913040F9}) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft .NET Version Manager (x64) 1.0.0-beta5 (HKLM\...\{c5a4aba3-1aba-3ef8-b2d5-c3fa37f59738}) (Version: 1.0.10609.0 - Microsoft Corporation)
Microsoft DirectX SDK (August 2007) (HKLM-x32\...\{F0A4913F-46A5-48F2-BC73-EE41A6C81EB3}) (Version: 9.20.1057 - Microsoft® Corporation)
Microsoft Office Professional Plus 2016 - en-us (HKLM\...\ProplusRetail - en-us) (Version: 16.0.6769.2040 - Microsoft Corporation)
Microsoft OneDrive (HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\OneDriveSetup.exe) (Version: 18.025.0204.0009 - Microsoft Corporation)
Microsoft Project Professional 2016 - en-us (HKLM\...\ProjectProRetail - en-us) (Version: 16.0.6769.2040 - Microsoft Corporation)
Microsoft Silverlight (HKLM-x32\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
Microsoft SQL Server 2012 Command Line Utilities (HKLM\...\{9D573E71-1077-4C7E-B4DB-4E22A5D2B48B}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft SQL Server 2012 Native Client (HKLM\...\{49D665A2-4C2A-476E-9AB8-FCC425F526FC}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft SQL Server 2014 Management Objects (HKLM-x32\...\{2774595F-BC2A-4B12-A25B-0C37A37049B0}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2014 Management Objects (x64) (HKLM\...\{1F9EB3B6-AED7-4AA7-B8F1-8E314B74B2A5}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2014 Transact-SQL ScriptDom (HKLM\...\{020CDFE0-C127-4047-B571-37C82396B662}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2014 T-SQL Language Service (HKLM-x32\...\{47D08E7A-92A1-489B-B0BF-415516497BCE}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2016 LocalDB (HKLM\...\{E359515A-92E6-4FA3-A2C9-E1BA02D8DE6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft SQL Server 2016 Management Objects (HKLM-x32\...\{0F1C8E2F-199A-4946-B3BF-0906DACFD032}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft SQL Server 2016 Management Objects (x64) (HKLM\...\{20EA85AA-2A1D-4F11-B09F-4BA2BF3C8989}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft SQL Server 2016 T-SQL Language Service (HKLM-x32\...\{8BFDE775-C5B8-46DB-84EF-43FFC8A2E8AD}) (Version: 13.0.14500.10 - Microsoft Corporation)
Microsoft SQL Server 2016 T-SQL ScriptDom (HKLM\...\{D091DE8C-EA0F-49AF-8DE3-BD6C79737C6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft SQL Server Compact 4.0 SP1 x64 ENU (HKLM\...\{78909610-D229-459C-A936-25D92283D3FD}) (Version: 4.0.8876.1 - Microsoft Corporation)
Microsoft SQL Server Data Tools - enu (14.0.60519.0) (HKLM-x32\...\{4E27B0EF-7BAB-432A-AF3D-3FC8F3F7353F}) (Version: 14.0.60519.0 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2014 (HKLM\...\{FC3BB979-AA54-4B60-BBA3-2C4DA6E08D80}) (Version: 12.0.2402.29 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2014 (HKLM-x32\...\{091CE6AA-2753-4F6E-AD1C-0E875744EB54}) (Version: 12.0.2402.29 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2016 (HKLM\...\{96EB5054-C775-4BEF-B7B9-AA96A295EDCD}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2016 (HKLM-x32\...\{84C23ECA-FE4D-494F-9247-3EBAD57E7F0C}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2017 CTP2.1 (HKLM\...\{9BAD8F82-A221-42CE-AFF0-7CAB825790C9}) (Version: 14.0.600.250 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2017 CTP2.1 (HKLM-x32\...\{F0DD1AA8-44D7-4ACE-AF65-7378EA5D884C}) (Version: 14.0.600.250 - Microsoft Corporation)
Microsoft Visio Professional 2016 - en-us (HKLM\...\VisioProRetail - en-us) (Version: 16.0.6769.2040 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.30319 (HKLM\...\{DA5E371C-6333-3D8A-93A4-6FD5B20BCC6E}) (Version: 10.0.30319 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32\...\{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 (HKLM-x32\...\{95716cce-fc71-413f-8ad5-56c2892d4b3a}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32\...\{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 (HKLM-x32\...\{ce085a78-074e-4823-8dc1-8a721b94b76d}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x64) - 14.12.25810 (HKLM-x32\...\{e2ee15e2-a480-4bc5-bfb7-e9803d1d9823}) (Version: 14.12.25810.0 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x86) - 14.12.25810 (HKLM-x32\...\{56e11d69-7cc9-40a5-a4f9-8f6190c4d84d}) (Version: 14.12.25810.0 - Microsoft Corporation)
Microsoft Visual Studio Community 2015 with Updates (HKLM-x32\...\{79b486b9-c5f0-4096-a00c-8351f59587c2}) (Version: 14.0.25420.1 - Microsoft Corporation)
Microsoft Visual Studio Installer (HKLM\...\{6F320B93-EE3C-4826-85E0-ADF79F8D4C61}) (Version: 1.14.164.111 - Microsoft Corporation)
Microsoft Web Deploy 3.6 (HKLM\...\{94E1227C-08A9-4962-B388-1F05D89AEA75}) (Version: 3.1238.1962 - Microsoft Corporation)
MSBuild/NuGet Integration 14.0 (x86) (HKLM-x32\...\{128C1654-3B9E-4959-8BFB-CE6F09C0A01D}) (Version: 14.0.25420 - Microsoft Corporation) Hidden
Multi-Device Hybrid Apps using C# - Templates - ENU (HKLM-x32\...\{12D99739-FFD3-3761-8AA6-F929E0FE407E}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
Mumble 1.2.19 (HKLM-x32\...\{F62A874F-2354-49B1-87BE-CAAD7C8FA084}) (Version: 1.2.19 - Thorvald Natvig)
NovaRO (HKLM-x32\...\NovaRO_is1) (Version: 1.1.0 - NovaRO)
NVIDIA PhysX System Software 9.17.0524 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.17.0524 - NVIDIA Corporation)
Office 16 Click-to-Run Extensibility Component (HKLM\...\{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.6729.1019 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.6729.1019 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (HKLM\...\{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.6729.1019 - Microsoft Corporation) Hidden
PDF Settings CS6 (HKLM-x32\...\{BFEAAE77-BD7F-4534-B286-9C5CB4697EB1}) (Version: 11.0 - Adobe Systems Incorporated) Hidden
PreEmptive Analytics Visual Studio Components (HKLM-x32\...\{436A18DD-5F2C-4B3C-985E-AD3C13B0CC25}) (Version: 1.2.5134.1 - PreEmptive Solutions) Hidden
Prerequisites for SSDT (HKLM-x32\...\{21373064-AD95-48DB-A32E-0D9E08EF7355}) (Version: 12.0.2000.8 - Microsoft Corporation)
Prerequisites for SSDT (HKLM-x32\...\{B7E94916-7AE6-4F7F-A377-7A410A42BA19}) (Version: 13.0.1601.5 - Microsoft Corporation)
Python 2.7.12 (HKLM-x32\...\{9DA28CE5-0AA5-429E-86D8-686ED898C665}) (Version: 2.7.12150 - Python Software Foundation)
Qualcomm Atheros Bluetooth Suite (64) (HKLM\...\{A84A4FB1-D703-48DB-89E0-68B6499D2801}) (Version: 10.0.1.7 - Qualcomm Atheros)
Qualcomm Atheros Client Installation Program (HKLM-x32\...\{28006915-2739-4EBE-B5E8-49B25D32EB33}) (Version: 10.0 - Qualcomm Atheros)
Ragnarok Online (HKLM-x32\...\{181579B5-0028-4E01-AC27-97ED80352279}) (Version: 15.2.2 - Gravity Interactive, Inc.)
Ragnarok Restart (HKLM-x32\...\{06A73F7C-3719-4664-89DC-21FB0B3D7C9D}) (Version: 1.0.2 - Gravity Interactive, Inc.) Hidden
Ragnarok Restart (HKLM-x32\...\Ragnarok Restart 1.0.2) (Version: 1.0.2 - Gravity Interactive, Inc.)
RAMDisk (HKLM-x32\...\{08051769-4EA7-48EA-BB07-8BB683433F62}) (Version: 4.4.0.36 - Dataram, Inc.)
Razer Cortex (HKLM-x32\...\Razer Cortex_is1) (Version: 8.5.11.584 - Razer Inc.)
Razer Synapse (HKLM-x32\...\{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.20.17.116 - Razer Inc.)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 10.9.422.2016 - Realtek)
Roslyn Language Services - x86 (HKLM-x32\...\{6970C7E1-F99D-388D-8903-DF8FCE677FED}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
Roslyn Language Services - x86 (HKLM-x32\...\{6C1985E7-E1C5-3A95-86EF-2C62465F15C3}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
SciTE4AutoHotkey v3.0.06.01 (HKLM-x32\...\SciTE4AutoHotkey) (Version: v3.0.06.01 - fincs)
Speccy (HKLM\...\Speccy) (Version: 1.30 - Piriform)
Spotify (HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\Spotify) (Version: 1.0.58.573.g57c9cd87 - Spotify AB)
SWFPlayer 2.6.2.0 (HKLM-x32\...\SWFPlayer_is1) (Version: 2.6.2.0 - Michael Faust, Alpha Interactive)
Team Explorer for Microsoft Visual Studio 2015 Update 3.1 (HKLM-x32\...\{7A95671A-759E-3B83-B763-4289D1D24D73}) (Version: 14.102.25619 - Microsoft) Hidden
TeamSpeak 3 Client (HKLM\...\TeamSpeak 3 Client) (Version: 3.1.8 - TeamSpeak Systems GmbH)
Test Tools for Microsoft Visual Studio 2015 (HKLM-x32\...\{9EABBFE1-7EED-47D9-8FB8-21D7E4808057}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
TypeScript Power Tool (HKLM-x32\...\{465ACA24-B8D6-4FEC-A42D-9EFCB92CD560}) (Version: 1.8.34.0 - Microsoft Corporation) Hidden
TypeScript Tools for Microsoft Visual Studio 2015 (HKLM-x32\...\{BA5762C7-D35F-4725-A4BD-525854127018}) (Version: 1.8.36.0 - Microsoft Corporation) Hidden
Universal CRT Extension SDK (HKLM-x32\...\{1FBCBC17-4527-2340-0832-B1D49C41FF67}) (Version: 10.0.26624 - Microsoft Corporation) Hidden
Universal CRT Extension SDK (HKLM-x32\...\{284FA9A0-CEDD-81D3-5A19-5858E95FD0C4}) (Version: 10.0.10150 - Microsoft Corporation) Hidden
Universal CRT Headers Libraries and Sources (HKLM-x32\...\{8BFBEC30-33CC-13B4-849F-3B036F27466A}) (Version: 10.0.26624 - Microsoft Corporation) Hidden
Universal CRT Headers Libraries and Sources (HKLM-x32\...\{ABD37F71-FC3F-F525-C7B3-BDD95F684C51}) (Version: 10.0.10150 - Microsoft Corporation) Hidden
Universal CRT Redistributable (HKLM-x32\...\{A9D6F52C-694E-3E41-7AB8-5BEB644742A5}) (Version: 10.1.16299.15 - Microsoft Corporation) Hidden
Universal CRT Tools x64 (HKLM\...\{E053089E-7953-3219-814F-F485FC151C54}) (Version: 10.1.16299.15 - Microsoft Corporation) Hidden
Universal CRT Tools x86 (HKLM-x32\...\{B9424F08-0617-C4F6-A798-5A9250C1A738}) (Version: 10.1.16299.15 - Microsoft Corporation) Hidden
Update for (KB2504637) (HKLM-x32\...\{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}.KB2504637) (Version: 1 - Microsoft Corporation)
vcpp_crt.redist.clickonce (HKLM-x32\...\{0074562E-F896-4994-9086-79F8BC8DE02C}) (Version: 14.12.25830 - Microsoft Corporation) Hidden
Vegas Pro 13.0 (64-bit) (HKLM-x32\...\Vegas Pro 13.0 (64-bit)) (Version: 13.0 (64-bit) - Exµs ™)
Visual Studio 2012 x64 Redistributables (HKLM\...\{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
Visual Studio 2015 Update 3 (KB3022398) (HKLM-x32\...\{7a68448b-9cf2-4049-bd73-5875f1aa7ba2}) (Version: 14.0.25420 - Microsoft Corporation)
Visual Studio Community 2017 (HKLM\...\e145a82c) (Version: 15.5.27130.2024 - Microsoft Corporation)
VLC media player (HKLM-x32\...\VLC media player) (Version: 3.0.1 - VideoLAN)
VS Immersive Activate Helper (HKLM-x32\...\{8A2BDA07-3417-46C1-9058-CB32BC63E30E}) (Version: 16.0.76.0 - Microsoft Corporation) Hidden
VS JIT Debugger (HKLM\...\{F8F52853-A1A7-42C7-A082-5A6D5853BB0B}) (Version: 16.0.76.0 - Microsoft Corporation) Hidden
VS Script Debugging Common (HKLM\...\{0EE5749D-2DC0-460F-AB1C-06B3EDB42426}) (Version: 16.0.76.0 - Microsoft Corporation) Hidden
VS Update core components (HKLM-x32\...\{B2918D01-1D89-34D3-87EF-A28121BC6EB7}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
vs_BlendMsi (HKLM-x32\...\{18640789-304F-40B5-884B-130B4A97D83B}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_clickoncebootstrappermsi (HKLM-x32\...\{A68D7884-F036-4A0D-AE1A-410E0311E135}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_clickoncebootstrappermsires (HKLM-x32\...\{91DDDFB5-1782-48C2-BA2A-8F4D9DE39D27}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_clickoncesigntoolmsi (HKLM-x32\...\{6A1ECF65-2CBF-4B33-9D4A-D1C0A0E5FE45}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_communitymsi (HKLM-x32\...\{595F5D63-8773-4182-A1E0-EC9ECF4B6EA4}) (Version: 15.0.27102 - Microsoft Corporation) Hidden
vs_communitymsires (HKLM-x32\...\{40040E64-50EB-4FCF-B209-DA0B20821759}) (Version: 15.0.26621 - Microsoft Corporation) Hidden
vs_devenvmsi (HKLM-x32\...\{BFFA2FFB-1095-4ADD-A352-368806D2412B}) (Version: 15.0.26621 - Microsoft Corporation) Hidden
vs_filehandler_amd64 (HKLM-x32\...\{9414C260-D479-49EB-B0BF-01C1F5076EA0}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_filehandler_x86 (HKLM-x32\...\{A57BD1C0-42AD-42F8-AFEB-FAC7E6ABB005}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_FileTracker_Singleton (HKLM-x32\...\{70F69B4F-7950-4841-8139-5D0C7EDD2FE6}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_Graphics_Singletonx64 (HKLM\...\{B11D79C6-332C-47B6-B58C-2F88A4911C7C}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_Graphics_Singletonx86 (HKLM-x32\...\{2497054A-0269-4F45-98AE-F469F89CC45F}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_minshellinteropmsi (HKLM-x32\...\{231C8ADB-BF59-458E-A909-CFA825F46388}) (Version: 15.0.27102 - Microsoft Corporation) Hidden
vs_minshellmsi (HKLM-x32\...\{9CDD69A2-765A-4970-AB6B-595A740C614F}) (Version: 15.0.27019 - Microsoft Corporation) Hidden
vs_minshellmsires (HKLM-x32\...\{6DFE6F8D-B61D-4348-AB70-4ABF1210DFD5}) (Version: 15.0.26621 - Microsoft Corporation) Hidden
vs_SQLClickOnceBootstrappermsi (HKLM-x32\...\{5779B6DD-604A-41CE-BC3D-9D4BDDA22AD2}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_tipsmsi (HKLM-x32\...\{1AC6CC3D-7724-4D84-9270-798A2191AB1C}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_update3notification (HKLM-x32\...\{AB3DF932-C990-34D4-BF43-970F760DA3CD}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
Vulkan Run Time Libraries 1.0.42.1 (HKLM\...\VulkanRT1.0.42.1) (Version: 1.0.42.1 - LunarG, Inc.)
WCF Data Services 5.6.4 Runtime (HKLM-x32\...\{DB85E7BD-B2DD-43D4-B3C0-23D7B527B597}) (Version: 5.6.62175.4 - Microsoft Corporation) Hidden
WCF Data Services Tools for Microsoft Visual Studio 2015 (HKLM-x32\...\{0A3B508E-5638-4471-BCC9-954E1868CB86}) (Version: 5.6.62175.4 - Microsoft Corporation) Hidden
Windows Driver Package - ASUS (AsusPTPDrv) HIDClass (06/03/2016 11.0.0.11) (HKLM\...\0B4533347E894EFA3F8DC5D4B35CF2D1B1BF756F) (Version: 06/03/2016 11.0.0.11 - ASUS)
WinFlash (HKLM-x32\...\{8F21291E-0444-4B1D-B9F9-4370A73E346D}) (Version: 3.2.1 - ASUS)
WinPcap 4.1.3 (HKLM-x32\...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
WinRAR 5.50 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.50.0 - win.rar GmbH)
WOERO (HKLM-x32\...\WOERO_is1) (Version: 20171206 - WOERO)
Zemana AntiMalware (HKLM-x32\...\{8F0CD7D1-42F3-4195-95CD-833578D45057}_is1) (Version: 2.74.0.150 - Zemana Ltd.)
ContextMenuHandlers1: [2.0 Zemana AntiMalware] -> {6ABB1C11-E261-4CEA-BBB5-3836225689DD} => C:\Program Files (x86)\Zemana AntiMalware\ZAMShellExt64.dll [2018-03-14] ()
ContextMenuHandlers1: [SD360] -> {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-03-13] ()
ContextMenuHandlers3: [MBAMShlExt] -> [CC]{57CE581A-0CB6-4266-9CA0-19364C90A0B3} => -> No File
ContextMenuHandlers4: [SD360] -> {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-03-13] ()
ContextMenuHandlers5: [igfxDTCM] -> {9B5F5829-A529-4B12-814A-E81BCB8D93FC} => C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_463164d40c3d26ce\igfxDTCM.dll [2016-11-30] (Intel Corporation)
ContextMenuHandlers5: [NvCplDesktopContext] -> {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\WINDOWS\system32\nvshext.dll [2017-05-18] (NVIDIA Corporation)
ContextMenuHandlers6: [2.0 Zemana AntiMalware] -> {6ABB1C11-E261-4CEA-BBB5-3836225689DD} => C:\Program Files (x86)\Zemana AntiMalware\ZAMShellExt64.dll [2018-03-14] ()
ContextMenuHandlers6: [MBAMShlExt] -> [CC]{57CE581A-0CB6-4266-9CA0-19364C90A0B3} => -> No File
ContextMenuHandlers6: [SD360] -> {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-03-13] ()
Task: {24B7B055-D882-4EA8-8DCD-C8D0230D6D57} - System32\Tasks\Microsoft\VisualStudio\VSIX Auto Update 14 => C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\VSIXAutoUpdate.exe [2016-06-20] (Microsoft Corporation)
Task: {8688567E-8102-4D27-933A-9E759A314CCD} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe [2018-03-07] (Piriform Ltd)
Task: {8FA86C41-F674-466C-B102-C41673D92761} - System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2016-04-24] (Microsoft Corporation)
Task: {99AC7774-A7D4-48EB-B1A4-DC2622F0AB58} - System32\Tasks\Microsoft\Office\Office Automatic Updates => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2016-04-24] (Microsoft Corporation)
Task: {9E1E8147-710E-4510-87D0-FFBA9E04817B} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2017-10-12] (Apple Inc.)
Task: {A325DA10-9C1F-43F4-BE04-697633F99F34} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2017-04-01] (Google Inc.)
Task: {A365C2D0-3A4C-4008-838E-2B38D48CA98D} - System32\Tasks\Intel PTT EK Recertification => C:\Program Files\Intel\iCLS Client\IntelPTTEKRecertification.exe [2016-02-20] (Intel(R) Corporation)
Task: {A48B624F-9686-454B-977E-AF581340E27A} - System32\Tasks\Adobe Flash Player NPAPI Notifier => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_29_0_0_113_Plugin.exe [2018-03-14] (Adobe Systems Incorporated)
Task: {A59F0840-F079-4D2A-B2B8-A23C6ABFD5FF} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2018-03-14] (Adobe Systems Incorporated)
Task: {AD0E0F2C-6881-4714-A7DF-58956934C44F} - System32\Tasks\ASUS Touchpad Handwriting (x64) => C:\Program Files (x86)\ASUS\ASUS Touchpad Handwriting\Exe\x64\AsusHWLaunch64.exe [2016-06-20] (ASUSTeK Computer Inc.)
Task: {C2A4DE53-B0EB-42AE-8991-E8E8E3BF10EB} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2017-04-01] (Google Inc.)
Task: {C4BBAEA8-0A0A-4AAD-A85D-D6B007C20383} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2018-03-07] (Piriform Ltd)
Task: {CED1D1E4-8EF4-4635-940D-F63260CFFCC6} - System32\Tasks\Microsoft\Office\OfficeTelemetryAgentLogOn2016 => C:\Program Files\Microsoft Office\root\Office16\msoia.exe [2017-02-14] (Microsoft Corporation)
Task: {D105CB65-FB62-4DEF-8CA1-1AFBD26C4358} - System32\Tasks\Microsoft\Office\OfficeTelemetryAgentFallBack2016 => C:\Program Files\Microsoft Office\root\Office16\msoia.exe [2017-02-14] (Microsoft Corporation)
Task: {DF1EB0D6-4DDD-42E9-9E01-DBE3F09E9C81} - System32\Tasks\DropboxUpdateTaskMachineCore => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
Task: {DF9A8A99-4703-4106-B209-7ABA0D8AFEB3} - System32\Tasks\DropboxUpdateTaskMachineUA => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
ShortcutWithArgument: C:\Users\ASUS\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) -> --disk-cache-dir=G:\
ShortcutWithArgument: C:\Users\ASUS\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\ImplicitAppShortcuts\5d696d521de238c3\Google Chrome.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) -> --profile-directory=Default
2017-09-29 22:41 - 2017-09-29 22:41 - 000184432 _____ () C:\WINDOWS\SYSTEM32\inputhost.dll
2018-01-05 00:14 - 2018-01-05 00:14 - 000088888 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
2018-01-05 00:13 - 2018-01-05 00:13 - 001356088 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
2017-02-14 18:28 - 2016-04-24 16:24 - 000172224 _____ () C:\Program Files\Common Files\Microsoft Shared\ClickToRun\ApiClient.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 011044864 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CortanaApi.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 001804288 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Core.dll
2018-03-14 21:33 - 2018-03-13 20:15 - 000099240 _____ () C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll
2018-03-14 21:33 - 2018-03-13 20:15 - 000567392 _____ () C:\Program Files (x86)\360\Total Security\safemon\wdui2.dll
2016-05-17 13:50 - 2016-05-17 13:50 - 001243936 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
2018-03-14 21:42 - 2018-03-14 21:42 - 000000027 _____ C:\WINDOWS\system32\Drivers\etc\hosts
127.0.0.1 localhost
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\Control Panel\Desktop\\Wallpaper -> C:\Windows\web\wallpaper\Windows\img0.jpg
DNS Servers: 122.197.254.7 - 122.197.254.4
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer => (SmartScreenEnabled: RequireAdmin)
Windows Firewall is enabled.
HKLM\...\StartupApproved\Run: => "SecurityHealth"
HKLM\...\StartupApproved\Run: => "WindowsDefender"
HKLM\...\StartupApproved\Run: => "AdobeAAMUpdater-1.0"
HKLM\...\StartupApproved\Run: => "ShadowPlay"
HKLM\...\StartupApproved\Run: => "iTunesHelper"
HKLM\...\StartupApproved\Run32: => "VoodooShield"
HKLM\...\StartupApproved\Run32: => "Dropbox"
HKLM\...\StartupApproved\Run32: => "AdobeAAMUpdater-1.0"
HKLM\...\StartupApproved\Run32: => "SmartAudio"
HKLM\...\StartupApproved\Run32: => "SecurityHealth"
HKLM\...\StartupApproved\Run32: => "WindowsDefender"
HKLM\...\StartupApproved\Run32: => "GrpConv"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\StartupFolder: => "hide.me VPN.lnk"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "CCleaner"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "Spotify Web Helper"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "Steam"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "uTorrent"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "CyberGhost"
FirewallRules: [{D539C200-2E6A-4354-99AA-A66C10163F59}] => (Allow) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
FirewallRules: [{8CE90D4D-4815-4721-A057-96864428FB40}] => (Allow) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
ATTENTION: System Restore is disabled
Application errors:
Error: (03/14/2018 09:51:45 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
Description: License Activation (slui.exe) failed with the following error code:
hr=0xC004F074
Command-line arguments:
RuleId=eeba1977-569e-4571-b639-7623d8bfecc0;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=73111121-5638-40f6-bc11-f1d7b0d64300;NotificationInterval=1440;Trigger=NetworkQuarantineRetry
Error: (03/14/2018 09:49:36 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
RuleId=eeba1977-569e-4571-b639-7623d8bfecc0;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=73111121-5638-40f6-bc11-f1d7b0d64300;NotificationInterval=1440;Trigger=NetworkAvailable
Error: (03/14/2018 09:49:15 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
RuleId=eeba1977-569e-4571-b639-7623d8bfecc0;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=73111121-5638-40f6-bc11-f1d7b0d64300;NotificationInterval=1440;Trigger=UserLogon;SessionId=1
Error: (03/14/2018 09:47:18 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
Error: (03/14/2018 09:31:22 PM) (Source: MsiInstaller) (EventID: 11316) (User: MAMBA)
Description: Product: Hotspot Shield 6.5.2 -- Error 1316. The specified account already exists.
Error: (03/14/2018 09:05:13 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
RuleId=eeba1977-569e-4571-b639-7623d8bfecc0;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=73111121-5638-40f6-bc11-f1d7b0d64300;NotificationInterval=1440;Trigger=TimerEvent
Error: (03/14/2018 07:57:34 PM) (Source: Application Error) (EventID: 1000) (User: )
Description: Faulting application name: Sakray.exe, version: 1.0.0.1, time stamp: 0x4a51c887
Faulting module name: KERNELBASE.dll, version: 10.0.16299.248, time stamp: 0x13ae3814
Exception code: 0xe06d7363
Fault offset: 0x001008c2
Faulting process ID: 0x950
Faulting application start time: 0x01d3bb8244bc19c0
Faulting application path: D:\Games\Ragnarok\iRO\Gravity\openkore\sakray\Sakray.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report ID: 098b69b9-d8af-4ecb-8bcf-f6910c5169d4
Faulting package full name:
Error: (03/13/2018 10:30:01 PM) (Source: Perflib) (EventID: 1008) (User: )
Description: The Open Procedure for service "WmiApRpl" in DLL "C:\WINDOWS\system32\wbem\wmiaprpl.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
System errors:
Error: (03/14/2018 09:50:00 PM) (Source: DCOM) (EventID: 10016) (User: MAMBA)
and APPID
to the user MAMBA\ASUS SID (S-1-5-21-2746278279-2939389576-4119914495-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Error: (03/14/2018 09:49:36 PM) (Source: DCOM) (EventID: 10016) (User: MAMBA)
and APPID
Error: (03/14/2018 09:48:00 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The ZAM Controller Service service terminated unexpectedly. It has done this 1 time(s).
Error: (03/14/2018 09:47:30 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The Razer Central Service service terminated unexpectedly. It has done this 1 time(s).
Error: (03/14/2018 09:44:14 PM) (Source: TPM) (EventID: 15) (User: NT AUTHORITY)
Description: The device driver for the Trusted Platform Module (TPM) encountered a non-recoverable error in the TPM hardware, which prevents TPM services (such as data encryption) from being used. For further help, please contact the computer manufacturer.
Error: (03/14/2018 09:43:21 PM) (Source: DCOM) (EventID: 10010) (User: MAMBA)
Description: The server Microsoft.Windows.Cortana_1.9.6.16299_neutral_neutral_cw5n1h2txyewy!CortanaUI.AppXtpp90jhw9p0njjb85kvhxpppgrqfp117.mca did not register with DCOM within the required timeout.
Error: (03/14/2018 09:42:22 PM) (Source: Service Control Manager) (EventID: 7032) (User: )
Description: The Service Control Manager tried to take a corrective action (Restart the service) after the unexpected termination of the Windows Search service, but this action failed with the following error:
An instance of the service is already running.
Error: (03/14/2018 09:42:01 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Windows Defender:
Date: 2018-03-12 18:34:39.999
Description:
Windows Defender Antivirus has detected malware or other potentially unwanted software.
For more information please see the following:
https://go.microsoft.com/fwlink/?li...2/WpePro!rfn&threatid=2147692509&enterprise=0
Severity: Medium
Category: Tool
Path: file:_C:\Users\ASUS\Desktop\wpe pro - modified - Shortcut.lnk;file:_F:\wpepro09mod (3)\wpe pro - modified.exe
Detection Origin: Local machine
Detection Type: Concrete
Detection Source: Real-Time Protection
Process Name: C:\Windows\explorer.exe
Signature Version: AV: 1.263.443.0, AS: 1.263.443.0, NIS: 118.5.0.0
Engine Version: AM: 1.1.14600.4, NIS: 2.1.14202.0
Date: 2018-03-12 18:33:47.399
Description:
Severity: Medium
Category: Tool
Path: file:_F:\wpepro09mod (3)\wpe pro - modified.exe
Date: 2018-03-12 18:21:23.941
Description:
Severity: Medium
Category: Tool
Detection Source: System
Date: 2018-03-12 18:00:25.066
Description:
Severity: Medium
Category: Tool
Date: 2018-03-12 17:28:46.891
Description:
Severity: Medium
Category: Tool
Process Name: C:\Users\ASUS\Desktop\ZHPDiag3.exe
Date: 2018-01-01 11:27:08.344
Description:
Windows Defender Antivirus has encountered an error trying to update signatures.
New Signature Version:
Previous Signature Version: 1.259.923.0
Update Source: Microsoft Malware Protection Center
Signature Type: AntiVirus
Update Type: Full
Current Engine Version:
Previous Engine Version: 1.1.14405.2
Error code: 0x80070645
Error description: This action is only valid for products that are currently installed.
Description:
Signature Type: AntiSpyware
Update Type: Full
Description:
Update Type: Full
Date: 2018-01-01 10:57:13.344
Description:
Update Type: Full
Description:
Update Type: Full
CodeIntegrity:
Date: 2018-03-14 21:51:58.311
Description:
Code Integrity determined that a process (\Device\HarddiskVolume3\Windows\System32\svchost.exe) attempted to load \Device\HarddiskVolume3\Program Files\Bonjour\mdnsNSP.dll that did not meet the Microsoft signing level requirements.
Date: 2018-03-14 21:51:58.310
Description:
Date: 2018-03-14 21:50:26.523
Description:
Date: 2018-03-14 21:50:26.522
Description:
Date: 2018-03-14 21:49:49.443
Description:
Date: 2018-03-14 21:49:49.442
Description:
Date: 2018-03-14 21:49:31.425
Description:
Date: 2018-03-14 21:49:31.424
Description:
Processor: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
Percentage of memory in use: 67%
Total physical RAM: 3979.04 MB
Available physical RAM: 1303.01 MB
Total Virtual: 6411.04 MB
Available Virtual: 3559.58 MB
Drive c: () (Fixed) (Total:124.09 GB) (Free:43.57 GB) NTFS
Drive d: () (Fixed) (Total:687.37 GB) (Free:310.2 GB) NTFS
Drive f: (F) (Fixed) (Total:119.56 GB) (Free:119.18 GB) NTFS
Drive g: (RAMDISK) (Fixed) (Total:0.78 GB) (Free:0.78 GB) FAT32
\\?\Volume{d89045d1-0000-0000-0000-100000000000}\ (System Reserved) (Fixed) (Total:0.49 GB) (Free:0.45 GB) NTFS
Disk: 0 (Size: 800 MB) (Disk ID: CA82D378)
Partition 1: (Active) - (Size=800 MB) - (Type=0B)
Disk: 1 (MBR Code: Windows 7/8/10) (Size: 931.5 GB) (Disk ID: D89045D1)
Partition 1: (Active) - (Size=500 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=124.1 GB) - (Type=07 NTFS)
Partition 3: (Not Active) - (Size=119.6 GB) - (Type=0F Extended)
Partition 4: (Not Active) - (Size=687.4 GB) - (Type=07 NTFS)
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 13.03.2018
Ran by ASUS (administrator) on MAMBA (14-03-2018 21:49:07)
Loaded Profiles: ASUS (Available Profiles: defaultuser0 & ASUS)
Platform: Windows 10 Enterprise Version 1709 16299.248 (X64) Language: English (United Kingdom)
Internet Explorer Version 11 (Default browser: Edge)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
(QIHU 360 SOFTWARE CO. LIMITED) C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe
(Microsoft Corporation) C:\Windows\System32\SppExtComObj.Exe
(Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
(Intel Corporation) C:\Windows\System32\Intel\DPTF\esif_uf.exe
(Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_463164d40c3d26ce\IntelCpHDCPSvc.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Security Assist\isaHelperService.exe
(Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
(Windows (R) Win 7 DDK provider) C:\Program Files (x86)\Bluetooth Suite\AdminService.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
(Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_463164d40c3d26ce\IntelCpHeciSvc.exe
(Razer Inc.) D:\Program Files (x86)\Razer\Razer Cortex\RzKLService.exe
(Intel Corporation) C:\Windows\Temp\DPTF\esif_assist_64.exe
(Microsoft Corporation) C:\Program Files\Microsoft Office\root\Office16\msoia.exe
(Microsoft Corporation) C:\Windows\System32\smartscreen.exe
(QIHU 360 SOFTWARE CO. LIMITED) C:\Program Files (x86)\360\Total Security\safemon\QHWatchdog.exe
(ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\ASUS Touchpad Handwriting\Exe\x64\AsusHWCenter64.exe
(QIHU 360 SOFTWARE CO. LIMITED) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
(Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(Microsoft Corporation) C:\Windows\System32\wbem\WMIADAP.exe
(Microsoft Corporation) C:\Windows\System32\slui.exe
==================== Registry (Whitelisted) ===========================
HKLM\...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [298296 2018-01-22] (Apple Inc.)
HKLM\...\Run: [ZAM] => C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [15775888 2017-08-09] (Copyright 2017.)
HKLM-x32\...\Run: [QHSafeTray] => C:\Program Files (x86)\360\Total Security\safemon\360Tray.exe [345000 2018-03-13] (QIHU 360 SOFTWARE CO. LIMITED)
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\Policies\Explorer: [NoLowDiskSpaceChecks] 1
Tcpip\Parameters: [DhcpNameServer] 122.197.254.7 122.197.254.4
Tcpip\..\Interfaces\{f4d23fd5-4b64-4c07-bed9-ba46ecaf0037}: [DhcpNameServer] 122.197.254.7 122.197.254.4
Internet Explorer:
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
SearchScopes: HKU\S-1-5-21-2746278279-2939389576-4119914495-1001 -> DefaultScope {67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} URL = hxxp://www.bing.com/search?q={searchTerms}&form=MSSEDF&pc=MSE1
SearchScopes: HKU\S-1-5-21-2746278279-2939389576-4119914495-1001 -> {67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} URL = hxxp://www.bing.com/search?q={searchTerms}&form=MSSEDF&pc=MSE1
Handler: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files\Microsoft Office\root\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler-x32: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler-x32: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler-x32: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files\Microsoft Office\root\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler-x32: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Edge:
Edge HomeButtonPage: HKU\S-1-5-21-2746278279-2939389576-4119914495-1001 -> hxxp://www.google.com
FireFox:
FF DefaultProfile: 477a178k.default
FF ProfilePath: C:\Users\ASUS\AppData\Roaming\Mozilla\Firefox\Profiles\477a178k.default [2018-03-09]
FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF64_29_0_0_113.dll [2018-03-14] ()
FF Plugin: @microsoft.com/SharePoint,version=14.0 -> C:\Program Files\Microsoft Office\root\Office16\NPSPWRAP.DLL [2017-02-14] (Microsoft Corporation)
FF Plugin-x32: @adobe.com/FlashPlayer -> C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_29_0_0_113.dll [2018-03-14] ()
FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 -> C:\Program Files (x86)\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 -> C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\NPSPWRAP.DLL [2017-02-14] (Microsoft Corporation)
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.33.7\npGoogleUpdate3.dll [2017-11-15] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.33.7\npGoogleUpdate3.dll [2017-11-15] (Google Inc.)
FF Plugin-x32: Adobe Reader -> C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2018-02-12] (Adobe Systems Inc.)
Chrome:
CHR DefaultProfile: Default
CHR Profile: C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default [2018-03-14]
CHR Extension: (360 Internet Protection) - C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\glcimepnljoholdmjchkloafkggfoijh [2018-03-12]
CHR Extension: (Chrome Web Store Payments) - C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2018-03-12]
CHR Extension: (Chrome Media Router) - C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2018-03-07]
CHR HKLM-x32\...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [glcimepnljoholdmjchkloafkggfoijh] - hxxps://clients2.google.com/service/update2/crx
R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2018-01-05] (Apple Inc.)
R2 AtherosSvc; C:\Program Files (x86)\Bluetooth Suite\adminservice.exe [325600 2016-05-20] (Windows (R) Win 7 DDK provider)
R3 ClickToRunSvc; C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe [2838760 2016-04-24] (Microsoft Corporation)
R2 esifsvc; C:\WINDOWS\System32\Intel\DPTF\esif_uf.exe [1585784 2016-05-23] (Intel Corporation)
S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [974632 2016-02-20] (Intel(R) Corporation)
S3 Intel(R) Security Assist; C:\Program Files (x86)\Intel\Intel(R) Security Assist\isa.exe [335872 2016-03-03] (Intel Corporation) [File not signed]
R2 isaHelperSvc; C:\Program Files (x86)\Intel\Intel(R) Security Assist\isaHelperService.exe [8704 2016-03-03] (Intel Corporation) [File not signed]
R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [215328 2016-05-17] (Intel Corporation)
S3 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [6440736 2018-03-03] (Malwarebytes)
S3 ose64; C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE [242720 2016-04-23] (Microsoft Corporation) [File not signed]
R2 QHActiveDefense; C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe [929888 2018-03-13] (QIHU 360 SOFTWARE CO. LIMITED)
S2 Razer Game Manager Service; C:\Program Files (x86)\Razer\Razer Services\GMS\GameManagerService.exe [253776 2017-12-01] (Razer Inc)
S3 Razer Game Scanner Service; C:\Program Files (x86)\Razer\Razer Services\GSS\GameScannerService.exe [189264 2016-09-25] ()
S2 RzActionSvc; C:\Program Files (x86)\Razer\Razer Services\Razer Central\RazerCentralService.exe [532352 2017-11-07] (Razer Inc.)
R2 RzKLService; D:\Program Files (x86)\Razer\Razer Cortex\RzKLService.exe [502144 2018-01-16] (Razer Inc.)
S3 Sense; C:\Program Files\Windows Defender Advanced Threat Protection\MsSense.exe [4329952 2017-11-26] (Microsoft Corporation)
S3 Te.Service; C:\Program Files (x86)\Windows Kits\10\Testing\Runtimes\TAEF\Wex.Services.exe [187904 2017-09-28] (Microsoft Corporation) [File not signed]
S3 VSStandardCollectorService140; C:\Program Files (x86)\Microsoft Visual Studio 14.0\Team Tools\DiagnosticsHub\Collector\StandardCollector.Service.exe [108776 2016-09-06] (Microsoft Corporation)
S3 VSStandardCollectorService150; C:\Program Files (x86)\Microsoft Visual Studio\Shared\Common\DiagnosticsHub.Collection.Service\StandardCollector.Service.exe [142432 2017-11-09] (Microsoft Corporation)
S3 WdNisSvc; C:\ProgramData\Microsoft\Windows Defender\platform\4.12.17007.18022-0\NisSrv.exe [356152 2018-03-09] (Microsoft Corporation)
S3 WinDefend; C:\ProgramData\Microsoft\Windows Defender\platform\4.12.17007.18022-0\MsMpEng.exe [106280 2018-03-09] (Microsoft Corporation)
S2 ZAMSvc; C:\Program Files (x86)\Zemana AntiMalware\ZAM.exe [15775888 2017-08-09] (Copyright 2017.)
R2 NVDisplay.ContainerLocalSystem; "C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe" -s NVDisplay.ContainerLocalSystem -f "C:\ProgramData\NVIDIA\NVDisplay.ContainerLocalSystem.log" -l 3 -d "C:\Program Files\NVIDIA Corporation\Display.NvContainer\plugins\LocalSystem" -r -p 30000
R2 NvTelemetryContainer; "C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe" -s NvTelemetryContainer -f "C:\ProgramData\NVIDIA\NvTelemetryContainer.log" -l 3 -d "C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\plugins" -r
R1 360AntiHacker; C:\WINDOWS\System32\Drivers\360AntiHacker64.sys [192176 2018-03-01] (360.cn)
R3 360AvFlt; C:\WINDOWS\System32\DRIVERS\360AvFlt.sys [95232 2018-03-01] (360.cn)
R3 360AvFlt; C:\Windows\SysWOW64\DRIVERS\360AvFlt.sys [95232 2018-03-13] (360.cn)
R1 360Box64; C:\WINDOWS\System32\DRIVERS\360Box64.sys [339456 2018-03-13] (360.cn)
R1 360Camera; C:\WINDOWS\System32\Drivers\360Camera64.sys [57848 2018-03-01] (360.cn)
R1 360FsFlt; C:\WINDOWS\System32\DRIVERS\360FsFlt.sys [442544 2018-03-01] (360.cn)
R1 360netmon; C:\WINDOWS\System32\DRIVERS\360netmon.sys [96424 2018-03-01] (360.cn)
R3 AsusPTPDrv; C:\WINDOWS\System32\drivers\AsusPTPFilter.sys [97784 2018-01-13] (ASUS Corporation)
R3 athr; C:\WINDOWS\System32\drivers\athw10x.sys [4320176 2018-01-13] (Qualcomm Atheros Communications, Inc.)
R1 BAPIDRV; C:\WINDOWS\System32\DRIVERS\BAPIDRV64.sys [210064 2018-03-01] (360.cn)
R3 dptf_cpu; C:\WINDOWS\System32\drivers\dptf_cpu.sys [69560 2018-01-13] (Intel Corporation)
R3 esif_lf; C:\WINDOWS\System32\drivers\esif_lf.sys [343608 2016-05-23] (Intel Corporation)
R3 HIDSwitch; C:\WINDOWS\System32\drivers\AsRadioControl.sys [31112 2018-01-13] (ASUS)
R2 NPF; C:\WINDOWS\System32\drivers\npf.sys [36600 2013-03-01] (Riverbed Technology, Inc.)
R3 nvlddmkm; C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_8892f62aa9f69fbe\nvlddmkm.sys [14458264 2017-05-19] (NVIDIA Corporation)
R0 RAMDiskVE; C:\WINDOWS\System32\Drivers\RAMDiskVE.sys [86680 2018-01-04] (Dataram, Inc.)
R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [1010624 2018-01-13] (Realtek )
S3 rzendpt; C:\WINDOWS\System32\drivers\rzendpt.sys [50392 2015-08-14] (Razer Inc)
R2 rzpmgrk; C:\Windows\system32\drivers\rzpmgrk.sys [44144 2016-09-17] (Razer, Inc.)
R2 rzpnk; C:\WINDOWS\system32\drivers\rzpnk.sys [140208 2017-09-29] (Razer, Inc.)
R3 SensorsSimulatorDriver; C:\WINDOWS\System32\drivers\WUDFRd.sys [259584 2017-09-29] (Microsoft Corporation)
S3 tap-tb-0901; C:\WINDOWS\System32\drivers\tap-tb-0901.sys [38656 2018-01-31] (The OpenVPN Project)
S3 tapprotonvpn; C:\WINDOWS\System32\drivers\tapprotonvpn.sys [46040 2017-08-25] (The OpenVPN Project)
S3 VSScanner; C:\WINDOWS\System32\DRIVERS\vsscanner.sys [29808 2016-08-18] (VoodooSoft, LLC)
S3 WdBoot; C:\WINDOWS\system32\drivers\wd\WdBoot.sys [46072 2018-03-09] (Microsoft Corporation)
S3 WdFilter; C:\WINDOWS\system32\drivers\wd\WdFilter.sys [288296 2018-03-09] (Microsoft Corporation)
S3 WdNisDrv; C:\WINDOWS\System32\drivers\wd\WdNisDrv.sys [129568 2018-03-09] (Microsoft Corporation)
R1 ZAM; C:\WINDOWS\System32\drivers\zam64.sys [203680 2018-03-14] (Zemana Ltd.)
R1 ZAM_Guard; C:\WINDOWS\System32\drivers\zamguard64.sys [203680 2017-03-22] (Zemana Ltd.)
S4 nvvhci; \SystemRoot\System32\drivers\nvvhci.sys [X]
2018-03-14 21:44 - 2018-03-14 21:50 - 000066570 _____ C:\WINDOWS\ZAM.krnl.trace
2018-03-14 21:44 - 2018-03-14 21:50 - 000029827 _____ C:\WINDOWS\ZAM_Guard.krnl.trace
2018-03-14 21:37 - 2018-03-14 21:38 - 000000000 ____D C:\Program Files (x86)\Zemana AntiMalware
2018-03-14 21:37 - 2018-03-14 21:37 - 006625600 _____ (Zemana Ltd. ) C:\Users\ASUS\Downloads\Zemana.AntiMalware.Setup.exe
2018-03-14 21:37 - 2018-03-14 21:37 - 000203680 _____ (Zemana Ltd.) C:\WINDOWS\system32\Drivers\zam64.sys
2018-03-14 21:37 - 2018-03-14 21:37 - 000001231 _____ C:\Users\Public\Desktop\Zemana AntiMalware.lnk
2018-03-14 21:37 - 2018-03-14 21:37 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Zemana AntiMalware
2018-03-14 21:33 - 2018-03-14 21:33 - 000001234 _____ C:\Users\Public\Desktop\360 Total Security.lnk
2018-03-14 21:33 - 2018-03-13 20:15 - 000339456 _____ (360.cn) C:\WINDOWS\system32\Drivers\360Box64.sys
2018-03-14 21:30 - 2018-03-14 21:33 - 000003048 _____ C:\WINDOWS\System32\Tasks\CCleaner Update
2018-03-14 21:28 - 2018-03-14 21:28 - 000004556 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player NPAPI Notifier
2018-03-14 19:36 - 2018-03-14 19:36 - 000002018 _____ C:\Users\ASUS\Desktop\ZHPFix.txt
2018-03-14 19:33 - 2018-03-14 19:34 - 000000000 ____D C:\Users\ASUS\Downloads\geek (3)
2018-03-14 19:33 - 2018-02-21 17:29 - 006086080 _____ (Geek Unіnstaller) C:\Users\ASUS\Desktop\geek.exe
2018-03-14 19:28 - 2018-03-14 19:28 - 000000000 ____D C:\Users\ASUS\Desktop\Quarantine
2018-03-14 19:26 - 2018-03-14 19:26 - 003061760 _____ (Nicolas Coolman) C:\Users\ASUS\Desktop\ZHPFix.exe
2018-03-14 19:24 - 2018-03-14 19:24 - 001274216 _____ (Microsoft Corporation) C:\Users\ASUS\Downloads\NetFxRepairTool.exe
2018-03-13 21:01 - 2018-03-13 21:02 - 004883368 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2018-03-13 19:40 - 2018-03-13 19:41 - 000461442 _____ C:\Users\ASUS\Desktop\ZHPDiag3.txt
2018-03-13 17:45 - 2018-03-13 17:45 - 000296736 _____ C:\Users\ASUS\Desktop\ZHPDiag.html
2018-03-13 17:45 - 2018-03-13 17:45 - 000214430 _____ C:\Users\ASUS\Desktop\ZHPDiag.txt
2018-03-13 17:13 - 2018-03-13 17:13 - 002402816 _____ (Farbar) C:\Users\ASUS\Desktop\FRST64.exe
2018-03-13 17:13 - 2018-03-13 17:13 - 000000000 ____D C:\Users\ASUS\Desktop\FRST-OlderVersion
2018-03-12 19:01 - 2018-03-12 19:01 - 000002156 _____ C:\Users\ASUS\Desktop\Cleanup.lnk
2018-03-12 18:51 - 2018-03-14 21:50 - 000000000 ____D C:\Users\ASUS\AppData\LocalLow\360WD
2018-03-12 18:51 - 2018-03-14 21:43 - 000000000 _RSHD C:\360SANDBOX
2018-03-12 18:51 - 2018-03-14 21:33 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\360 Security Center
2018-03-12 18:51 - 2018-03-14 19:24 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\360safe
2018-03-12 18:51 - 2018-03-12 18:52 - 000000000 ____D C:\ProgramData\360safe
2018-03-12 18:51 - 2018-03-12 18:51 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\360 Security Center
2018-03-12 18:51 - 2018-03-12 18:51 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\360TotalSecurity
2018-03-12 18:51 - 2018-03-12 18:51 - 000000000 ____D C:\ProgramData\360TotalSecurity
2018-03-12 18:51 - 2018-03-01 18:37 - 000442544 _____ (360.cn) C:\WINDOWS\system32\Drivers\360FsFlt.sys
2018-03-12 18:51 - 2018-03-01 18:37 - 000210064 _____ (360.cn) C:\WINDOWS\system32\Drivers\BAPIDRV64.sys
2018-03-12 18:51 - 2018-03-01 18:37 - 000192176 _____ (360.cn) C:\WINDOWS\system32\Drivers\360AntiHacker64.sys
2018-03-12 18:51 - 2018-03-01 18:37 - 000096424 _____ (360.cn) C:\WINDOWS\system32\Drivers\360netmon.sys
2018-03-12 18:51 - 2018-03-01 18:37 - 000095232 _____ (360.cn) C:\WINDOWS\system32\Drivers\360AvFlt.sys.tmp
2018-03-12 18:51 - 2018-03-01 18:37 - 000057848 _____ (360.cn) C:\WINDOWS\system32\Drivers\360Camera64.sys
2018-03-12 18:48 - 2018-03-12 18:48 - 075346024 _____ C:\Users\ASUS\Downloads\360TS_Setup.exe
2018-03-12 18:47 - 2018-03-12 18:48 - 001497696 _____ (QIHU 360 SOFTWARE CO. LIMITED) C:\Users\ASUS\Downloads\360TS_Setup_Mini.exe
2018-03-12 18:31 - 2018-02-06 11:49 - 000835576 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
2018-03-12 18:31 - 2018-02-06 11:49 - 000177648 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
2018-03-12 17:48 - 2018-03-12 17:48 - 000001920 _____ C:\Users\Public\Desktop\Malwarebytes.lnk
2018-03-12 17:48 - 2018-03-12 17:48 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes
2018-03-12 17:48 - 2018-03-12 17:48 - 000000000 ____D C:\ProgramData\Malwarebytes
2018-03-12 17:48 - 2018-01-18 08:03 - 000076200 _____ C:\WINDOWS\system32\Drivers\mbae64.sys
2018-03-12 17:46 - 2018-03-14 21:24 - 000002920 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task-S-1-5-21-2746278279-2939389576-4119914495-1001
2018-03-12 17:46 - 2018-03-12 17:46 - 000002364 _____ C:\Users\ASUS\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2018-03-12 17:38 - 2018-03-12 17:38 - 001728800 _____ (Patch My PC, LLC) C:\Users\ASUS\Desktop\PatchMyPC.exe
2018-03-11 19:53 - 2018-03-11 19:53 - 000000402 _____ C:\Users\ASUS\Desktop\ROClientEnhancement-master.zip
2018-03-11 19:24 - 2018-03-11 19:26 - 000242326 _____ C:\Users\ASUS\Desktop\¸ùÅ©_h_³².spr
2018-03-11 18:52 - 2018-03-11 19:26 - 000048276 _____ C:\Users\ASUS\Desktop\¸ùÅ©_h_³².act
2018-03-11 18:46 - 2018-03-11 18:46 - 000000000 ____D C:\Users\ASUS\Desktop\stateicon
2018-03-11 09:11 - 2018-03-11 19:25 - 000000000 ____D C:\Users\ASUS\Desktop\Original Sura Sprite
2018-03-11 09:11 - 2018-03-11 19:08 - 000000000 ____D C:\Users\ASUS\Desktop\Edited Sura Sprite Color
2018-03-10 21:41 - 2018-02-10 15:16 - 008603032 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
2018-03-10 21:41 - 2018-02-10 15:15 - 001954048 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntdll.dll
2018-03-10 21:41 - 2018-02-10 15:15 - 000471968 _____ (Microsoft Corporation) C:\WINDOWS\system32\hal.dll
2018-03-10 21:41 - 2018-02-10 15:13 - 000373656 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\clfs.sys
2018-03-10 21:41 - 2018-02-10 15:09 - 000755712 _____ (Microsoft Corporation) C:\WINDOWS\system32\evr.dll
2018-03-10 21:41 - 2018-02-10 15:08 - 003010248 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d11.dll
2018-03-10 21:41 - 2018-02-10 15:07 - 002710728 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
2018-03-10 21:41 - 2018-02-10 15:06 - 000494488 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb.sys
2018-03-10 21:41 - 2018-02-10 15:06 - 000362904 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\pci.sys
2018-03-10 21:41 - 2018-02-10 15:04 - 000603920 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiodg.exe
2018-03-10 21:41 - 2018-02-10 14:21 - 001615712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntdll.dll
2018-03-10 21:41 - 2018-02-10 14:17 - 000597160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dnsapi.dll
2018-03-10 21:41 - 2018-02-10 14:08 - 002193168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
2018-03-10 21:41 - 2018-02-10 14:06 - 000982528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
2018-03-10 21:41 - 2018-02-10 14:05 - 001246432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioEng.dll
2018-03-10 21:41 - 2018-02-10 14:05 - 001149272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsvr.dll
2018-03-10 21:41 - 2018-02-10 14:05 - 000662208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\evr.dll
2018-03-10 21:41 - 2018-02-10 13:50 - 003665408 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
2018-03-10 21:41 - 2018-02-10 13:49 - 000536576 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgeIso.dll
2018-03-10 21:41 - 2018-02-10 13:49 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\system32\AcGenral.dll
2018-03-10 21:41 - 2018-02-10 13:47 - 017160704 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
2018-03-10 21:41 - 2018-02-10 13:47 - 013704192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
2018-03-10 21:41 - 2018-02-10 13:47 - 000140800 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
2018-03-10 21:41 - 2018-02-10 13:46 - 002902528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
2018-03-10 21:41 - 2018-02-10 13:46 - 002393600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AcGenral.dll
2018-03-10 21:41 - 2018-02-10 13:46 - 000344576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgeIso.dll
2018-03-10 21:41 - 2018-02-10 13:46 - 000169472 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhosdeployment.dll
2018-03-10 21:41 - 2018-02-10 13:46 - 000018432 _____ (Microsoft Corporation) C:\WINDOWS\system32\PCShellCommonProxyStub.dll
2018-03-10 21:41 - 2018-02-10 13:44 - 001498112 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebRuntimeManager.dll
2018-03-10 21:41 - 2018-02-10 13:43 - 018923008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
2018-03-10 21:41 - 2018-02-10 13:43 - 000394752 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ks.sys
2018-03-10 21:41 - 2018-02-10 13:43 - 000106496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
2018-03-10 21:41 - 2018-02-10 13:42 - 000708096 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
2018-03-10 21:41 - 2018-02-10 13:42 - 000236032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\FSClient.dll
2018-03-10 21:41 - 2018-02-10 13:41 - 019352576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
2018-03-10 21:41 - 2018-02-10 13:41 - 000815616 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieproxy.dll
2018-03-10 21:41 - 2018-02-10 13:41 - 000369152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
2018-03-10 21:41 - 2018-02-10 13:41 - 000365568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieproxy.dll
2018-03-10 21:41 - 2018-02-10 13:40 - 012831744 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
2018-03-10 21:41 - 2018-02-10 13:40 - 008110080 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
2018-03-10 21:41 - 2018-02-10 13:40 - 001312256 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d11_3SDKLayers.dll
2018-03-10 21:41 - 2018-02-10 13:40 - 001064448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d11_3SDKLayers.dll
2018-03-10 21:41 - 2018-02-10 13:40 - 000559104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9diag.dll
2018-03-10 21:41 - 2018-02-10 13:39 - 011925504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
2018-03-10 21:41 - 2018-02-10 13:39 - 004748288 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
2018-03-10 21:41 - 2018-02-10 13:38 - 002086400 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
2018-03-10 21:41 - 2018-02-10 13:38 - 000462336 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
2018-03-10 21:41 - 2018-02-10 13:37 - 003678720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
2018-03-10 21:41 - 2018-02-10 13:37 - 001488384 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
2018-03-10 21:41 - 2018-02-10 13:36 - 006031360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
2018-03-10 21:41 - 2018-02-10 13:36 - 002869760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
2018-03-10 21:41 - 2018-02-10 13:36 - 002464768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dwmcore.dll
2018-03-10 21:41 - 2018-02-10 13:36 - 000685056 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEndpointBuilder.dll
2018-03-10 21:41 - 2018-02-10 13:34 - 004249600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
2018-03-10 21:41 - 2018-01-01 21:47 - 000082840 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\volmgr.sys
2018-03-10 21:41 - 2018-01-01 21:45 - 000398744 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fltMgr.sys
2018-03-10 21:41 - 2018-01-01 21:39 - 000902416 _____ (Microsoft Corporation) C:\WINDOWS\system32\winhttp.dll
2018-03-10 21:41 - 2018-01-01 21:36 - 000166296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\partmgr.sys
2018-03-10 21:41 - 2018-01-01 21:26 - 000428952 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rdbss.sys
2018-03-10 21:41 - 2018-01-01 20:45 - 005615968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d10warp.dll
2018-03-10 21:41 - 2018-01-01 20:34 - 000703568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winhttp.dll
2018-03-10 21:41 - 2018-01-01 20:18 - 000374784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\FirewallAPI.dll
2018-03-10 21:41 - 2018-01-01 20:18 - 000261632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\actxprxy.dll
2018-03-10 21:41 - 2018-01-01 20:17 - 000542208 _____ (Microsoft Corporation) C:\WINDOWS\system32\FirewallAPI.dll
2018-03-10 21:41 - 2018-01-01 20:16 - 000664576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript.dll
2018-03-10 21:41 - 2018-01-01 20:16 - 000594944 _____ (Microsoft Corporation) C:\WINDOWS\system32\vbscript.dll
2018-03-10 21:41 - 2018-01-01 20:16 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vbscript.dll
2018-03-10 21:41 - 2018-01-01 20:13 - 003121664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Profiles.Gatt.dll
2018-03-10 21:41 - 2018-01-01 20:12 - 002633216 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagtrack.dll
2018-03-10 21:41 - 2018-01-01 20:11 - 000812032 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript.dll
2018-03-10 21:41 - 2018-01-01 20:08 - 000424448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srv.sys
2018-03-10 21:40 - 2018-02-10 15:24 - 000270744 _____ (Microsoft Corporation) C:\WINDOWS\system32\acmigration.dll
2018-03-10 21:40 - 2018-02-10 15:23 - 001577880 _____ (Microsoft Corporation) C:\WINDOWS\system32\appraiser.dll
2018-03-10 21:40 - 2018-02-10 15:23 - 000758168 _____ (Microsoft Corporation) C:\WINDOWS\system32\generaltel.dll
2018-03-10 21:40 - 2018-02-10 15:23 - 000613272 _____ (Microsoft Corporation) C:\WINDOWS\system32\devinv.dll
2018-03-10 21:40 - 2018-02-10 15:23 - 000138136 _____ (Microsoft Corporation) C:\WINDOWS\system32\CompatTelRunner.exe
2018-03-10 21:40 - 2018-02-10 15:22 - 000662936 _____ (Microsoft Corporation) C:\WINDOWS\system32\aeinv.dll
2018-03-10 21:40 - 2018-02-10 15:20 - 001206680 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
2018-03-10 21:40 - 2018-02-10 15:20 - 001055640 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
2018-03-10 21:40 - 2018-02-10 15:18 - 000319864 _____ (Microsoft Corporation) C:\WINDOWS\system32\wow64.dll
2018-03-10 21:40 - 2018-02-10 15:17 - 001209240 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
2018-03-10 21:40 - 2018-02-10 15:16 - 002406456 _____ (Microsoft Corporation) C:\WINDOWS\system32\msmpeg2vdec.dll
2018-03-10 21:40 - 2018-02-10 15:16 - 000739696 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsapi.dll
2018-03-10 21:40 - 2018-02-10 15:15 - 001415296 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
2018-03-10 21:40 - 2018-02-10 15:14 - 004504464 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppsvc.exe
2018-03-10 21:40 - 2018-02-10 15:14 - 002395032 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
2018-03-10 21:40 - 2018-02-10 15:14 - 001002592 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase.dll
2018-03-10 21:40 - 2018-02-10 15:12 - 001277848 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndis.sys
2018-03-10 21:40 - 2018-02-10 15:12 - 000712600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vhdmp.sys
2018-03-10 21:40 - 2018-02-10 15:11 - 000711432 _____ (Microsoft Corporation) C:\WINDOWS\system32\ci.dll
2018-03-10 21:40 - 2018-02-10 15:11 - 000677784 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cng.sys
2018-03-10 21:40 - 2018-02-10 15:10 - 002447768 _____ (Microsoft Corporation) C:\WINDOWS\system32\UpdateAgent.dll
2018-03-10 21:40 - 2018-02-10 15:10 - 000749976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
2018-03-10 21:40 - 2018-02-10 15:10 - 000614160 _____ (Microsoft Corporation) C:\WINDOWS\system32\StateRepository.Core.dll
2018-03-10 21:40 - 2018-02-10 15:09 - 003904296 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
2018-03-10 21:40 - 2018-02-10 15:09 - 000525208 _____ (Microsoft Corporation) C:\WINDOWS\system32\wimserv.exe
2018-03-10 21:40 - 2018-02-10 15:08 - 021351624 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
2018-03-10 21:40 - 2018-02-10 15:08 - 007675784 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
2018-03-10 21:40 - 2018-02-10 15:08 - 002574232 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
2018-03-10 21:40 - 2018-02-10 15:08 - 000048112 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuauclt.exe
2018-03-10 21:40 - 2018-02-10 15:07 - 004506576 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
2018-03-10 21:40 - 2018-02-10 15:07 - 000705944 _____ (Microsoft Corporation) C:\WINDOWS\system32\wimgapi.dll
2018-03-10 21:40 - 2018-02-10 15:07 - 000436632 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHostCommon.dll
2018-03-10 21:40 - 2018-02-10 15:06 - 004486904 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepository.dll
2018-03-10 21:40 - 2018-02-10 15:06 - 000819096 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVClient.exe
2018-03-10 21:40 - 2018-02-10 15:06 - 000519144 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthService.exe
2018-03-10 21:40 - 2018-02-10 15:04 - 007384576 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayReady.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 006791984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001778584 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntVirtualization.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001628056 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVIntegration.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001426672 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001254144 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsvr.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001170008 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioSes.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 000374032 _____ (Microsoft Corporation) C:\WINDOWS\system32\vac.exe
2018-03-10 21:40 - 2018-02-10 15:03 - 001619808 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppobjs.dll
2018-03-10 21:40 - 2018-02-10 15:03 - 000722616 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppwinob.dll
2018-03-10 21:40 - 2018-02-10 15:03 - 000404888 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHost.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 002220952 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntSubsystems64.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 001420696 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntSubsystemController.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000831384 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVOrchestration.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000813976 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntStreamingManager.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000744856 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVReporting.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000670104 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVCatalog.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000645528 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVPublishing.dll
2018-03-10 21:40 - 2018-02-10 14:17 - 002255112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msmpeg2vdec.dll
2018-03-10 21:40 - 2018-02-10 14:15 - 001145624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ucrtbase.dll
2018-03-10 21:40 - 2018-02-10 14:09 - 006092152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
2018-03-10 21:40 - 2018-02-10 14:09 - 003485392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
2018-03-10 21:40 - 2018-02-10 14:09 - 002338776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d11.dll
2018-03-10 21:40 - 2018-02-10 14:09 - 000354200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudExperienceHostCommon.dll
2018-03-10 21:40 - 2018-02-10 14:08 - 000592792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wimgapi.dll
2018-03-10 21:40 - 2018-02-10 14:07 - 025253376 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
2018-03-10 21:40 - 2018-02-10 14:07 - 020286120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
2018-03-10 21:40 - 2018-02-10 14:07 - 000527864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\StateRepository.Core.dll
2018-03-10 21:40 - 2018-02-10 14:06 - 006481640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayReady.dll
2018-03-10 21:40 - 2018-02-10 14:06 - 006014688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
2018-03-10 21:40 - 2018-02-10 14:06 - 004670728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
2018-03-10 21:40 - 2018-02-10 14:04 - 001491352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppVEntSubsystems32.dll
2018-03-10 21:40 - 2018-02-10 13:50 - 001313792 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallService.dll
2018-03-10 21:40 - 2018-02-10 13:50 - 001294848 _____ (Microsoft Corporation) C:\WINDOWS\system32\usocore.dll
2018-03-10 21:40 - 2018-02-10 13:49 - 000326656 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotification.exe
2018-03-10 21:40 - 2018-02-10 13:48 - 002890240 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll
2018-03-10 21:40 - 2018-02-10 13:46 - 001008640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallService.dll
2018-03-10 21:40 - 2018-02-10 13:45 - 007545344 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
2018-03-10 21:40 - 2018-02-10 13:45 - 000115200 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatepolicy.dll
2018-03-10 21:40 - 2018-02-10 13:44 - 000539136 _____ (Microsoft Corporation) C:\WINDOWS\system32\HolographicExtensions.dll
2018-03-10 21:40 - 2018-02-10 13:44 - 000431616 _____ (Microsoft Corporation) C:\WINDOWS\system32\msIso.dll
2018-03-10 21:40 - 2018-02-10 13:43 - 008020480 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
2018-03-10 21:40 - 2018-02-10 13:43 - 006466560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
2018-03-10 21:40 - 2018-02-10 13:43 - 000570368 _____ (Microsoft Corporation) C:\WINDOWS\system32\TileDataRepository.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 023671808 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 001425408 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettings.Handlers.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 001015296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthport.sys
2018-03-10 21:40 - 2018-02-10 13:42 - 000813568 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 000403968 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpAXHolder.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 000098304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\updatepolicy.dll
2018-03-10 21:40 - 2018-02-10 13:41 - 001495552 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.desktop.dll
2018-03-10 21:40 - 2018-02-10 13:41 - 000721408 _____ (Microsoft Corporation) C:\WINDOWS\system32\LogonController.dll
2018-03-10 21:40 - 2018-02-10 13:41 - 000451072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TileDataRepository.dll
2018-03-10 21:40 - 2018-02-10 13:40 - 004498432 _____ (Microsoft Corporation) C:\WINDOWS\system32\xpsrchvw.exe
2018-03-10 21:40 - 2018-02-10 13:40 - 004113408 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
2018-03-10 21:40 - 2018-02-10 13:40 - 003405824 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
2018-03-10 21:40 - 2018-02-10 13:40 - 000601088 _____ (Microsoft Corporation) C:\WINDOWS\system32\ipnathlp.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 004592640 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsThresholdAdminFlowUI.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 002976256 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.pcshell.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 002741248 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssrch.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 002209280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.onecore.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 001669120 _____ (Microsoft Corporation) C:\WINDOWS\system32\Wpc.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 006567936 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 005833216 _____ (Microsoft Corporation) C:\WINDOWS\system32\dbgeng.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 004815360 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 003334144 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 003169280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 002857984 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmcore.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 002771968 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d12SDKLayers.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 001547776 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 001353728 _____ (Microsoft Corporation) C:\WINDOWS\system32\usercpl.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 001167360 _____ (Microsoft Corporation) C:\WINDOWS\system32\ISM.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 001057792 _____ (Microsoft Corporation) C:\WINDOWS\system32\comdlg32.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 000556544 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppBroker.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 004772352 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExplorerFrame.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 003578368 _____ (Microsoft Corporation) C:\WINDOWS\system32\SRH.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 002784256 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 001822208 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 000456704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LockAppBroker.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 002859520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SRH.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 001739264 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 001559552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 001230848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\usercpl.dll
2018-03-10 21:40 - 2018-02-10 13:35 - 004384768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ExplorerFrame.dll
2018-03-10 21:40 - 2018-02-10 13:35 - 002216960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d12SDKLayers.dll
2018-03-10 21:40 - 2018-02-10 13:35 - 000842240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comdlg32.dll
2018-03-10 21:40 - 2018-02-10 13:34 - 002983936 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcndmgr.dll
2018-03-10 21:40 - 2018-02-10 13:33 - 001570816 _____ (Microsoft Corporation) C:\WINDOWS\system32\RecoveryDrive.exe
2018-03-10 21:40 - 2018-02-10 13:33 - 001509888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
2018-03-10 21:40 - 2018-02-09 12:35 - 004959688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmpltfm.dll
2018-03-10 21:40 - 2018-02-02 12:36 - 003903944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmpltfm.dll
2018-03-10 21:40 - 2018-01-02 02:15 - 000956416 _____ (Microsoft Corporation) C:\WINDOWS\system32\Spectrum.exe
2018-03-10 21:40 - 2018-01-01 21:50 - 005905752 _____ (Microsoft Corporation) C:\WINDOWS\system32\StartTileData.dll
2018-03-10 21:40 - 2018-01-01 21:50 - 000780464 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontdrvhost.exe
2018-03-10 21:40 - 2018-01-01 21:48 - 007831760 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d10warp.dll
2018-03-10 21:40 - 2018-01-01 21:42 - 000571288 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\spaceport.sys
2018-03-10 21:40 - 2018-01-01 21:42 - 000184984 _____ (Microsoft Corporation) C:\WINDOWS\system32\sspicli.dll
2018-03-10 21:40 - 2018-01-01 21:41 - 000559512 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storport.sys
2018-03-10 21:40 - 2018-01-01 21:39 - 000129432 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hvsocket.sys
2018-03-10 21:40 - 2018-01-01 21:25 - 000615768 _____ (Microsoft Corporation) C:\WINDOWS\system32\services.exe
2018-03-10 21:40 - 2018-01-01 21:25 - 000147864 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wcifs.sys
2018-03-10 21:40 - 2018-01-01 21:03 - 000650328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontdrvhost.exe
2018-03-10 21:40 - 2018-01-01 21:03 - 000123512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sspicli.dll
2018-03-10 21:40 - 2018-01-01 20:25 - 000097792 _____ C:\WINDOWS\system32\runexehelper.exe
2018-03-10 21:40 - 2018-01-01 20:23 - 000250368 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxAllUserStore.dll
2018-03-10 21:40 - 2018-01-01 20:21 - 000192512 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netvsc.sys
2018-03-10 21:40 - 2018-01-01 20:20 - 000204288 _____ (Microsoft Corporation) C:\WINDOWS\system32\provisioningcsp.dll
2018-03-10 21:40 - 2018-01-01 20:19 - 000461312 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansec.dll
2018-03-10 21:40 - 2018-01-01 20:19 - 000334848 _____ (Microsoft Corporation) C:\WINDOWS\system32\dusmsvc.dll
2018-03-10 21:40 - 2018-01-01 20:19 - 000073216 _____ (Microsoft Corporation) C:\WINDOWS\system32\provtool.exe
2018-03-10 21:40 - 2018-01-01 20:18 - 000432640 _____ (Microsoft Corporation) C:\WINDOWS\system32\provengine.dll
2018-03-10 21:40 - 2018-01-01 20:18 - 000427008 _____ (Microsoft Corporation) C:\WINDOWS\system32\provhandlers.dll
2018-03-10 21:40 - 2018-01-01 20:15 - 012687872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmp.dll
2018-03-10 21:40 - 2018-01-01 20:15 - 000588800 _____ (Microsoft Corporation) C:\WINDOWS\system32\actxprxy.dll
2018-03-10 21:40 - 2018-01-01 20:13 - 013657600 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmp.dll
2018-03-10 21:40 - 2018-01-01 20:12 - 001424896 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwansvc.dll
2018-03-10 21:40 - 2018-01-01 20:11 - 000880640 _____ (Microsoft Corporation) C:\WINDOWS\system32\schedsvc.dll
2018-03-10 21:40 - 2018-01-01 20:09 - 000925184 _____ (Microsoft Corporation) C:\WINDOWS\system32\MPSSVC.dll
2018-03-10 21:40 - 2018-01-01 20:08 - 000726016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srv2.sys
2018-03-10 21:40 - 2018-01-01 20:05 - 002510848 _____ (Microsoft Corporation) C:\WINDOWS\system32\ResetEngine.dll
2018-03-10 21:40 - 2018-01-01 20:05 - 001160704 _____ (Microsoft Corporation) C:\WINDOWS\system32\reseteng.dll
2018-03-10 21:39 - 2018-02-10 15:22 - 002003352 _____ (Microsoft Corporation) C:\WINDOWS\system32\aitstatic.exe
2018-03-10 21:39 - 2018-02-10 15:22 - 000460696 _____ (Microsoft Corporation) C:\WINDOWS\system32\dcntel.dll
2018-03-10 21:39 - 2018-02-10 15:22 - 000387480 _____ (Microsoft Corporation) C:\WINDOWS\system32\invagent.dll
2018-03-10 21:39 - 2018-02-10 15:22 - 000272800 _____ (Microsoft Corporation) C:\WINDOWS\system32\aepic.dll
2018-03-10 21:39 - 2018-02-10 15:22 - 000070040 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32appinventorycsp.dll
2018-03-10 21:39 - 2018-02-10 15:22 - 000035224 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceCensus.exe
2018-03-10 21:39 - 2018-02-10 15:21 - 001092016 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
2018-03-10 21:39 - 2018-02-10 15:21 - 000479912 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase_enclave.dll
2018-03-10 21:39 - 2018-02-10 15:21 - 000279456 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\msiscsi.sys
2018-03-10 21:39 - 2018-02-10 15:20 - 000924648 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
2018-03-10 21:39 - 2018-02-10 15:20 - 000599448 _____ (Microsoft Corporation) C:\WINDOWS\system32\securekernel.exe
2018-03-10 21:39 - 2018-02-10 15:20 - 000077208 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.dll
2018-03-10 21:39 - 2018-02-10 15:19 - 001133888 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVP9DEC.dll
2018-03-10 21:39 - 2018-02-10 15:18 - 001193192 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryPS.dll
2018-03-10 21:39 - 2018-02-10 15:18 - 000098272 _____ (Microsoft Corporation) C:\WINDOWS\system32\FsIso.exe
2018-03-10 21:39 - 2018-02-10 15:18 - 000022400 _____ (Microsoft Corporation) C:\WINDOWS\system32\wow64cpu.dll
2018-03-10 21:39 - 2018-02-10 15:15 - 002514944 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
2018-03-10 21:39 - 2018-02-10 15:13 - 001416392 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3D12.dll
2018-03-10 21:39 - 2018-02-10 15:13 - 000535960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netio.sys
2018-03-10 21:39 - 2018-02-10 15:13 - 000408984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
2018-03-10 21:39 - 2018-02-10 15:12 - 004537040 _____ (Microsoft Corporation) C:\WINDOWS\system32\setupapi.dll
2018-03-10 21:39 - 2018-02-10 15:12 - 001313016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Taskmgr.exe
2018-03-10 21:39 - 2018-02-10 15:11 - 001029528 _____ (Microsoft Corporation) C:\WINDOWS\system32\efscore.dll
2018-03-10 21:39 - 2018-02-10 15:11 - 000494496 _____ (Microsoft Corporation) C:\WINDOWS\system32\pcasvc.dll
2018-03-10 21:39 - 2018-02-10 15:10 - 000246168 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
2018-03-10 21:39 - 2018-02-10 15:10 - 000154520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryClient.dll
2018-03-10 21:39 - 2018-02-10 15:09 - 000491264 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanager.dll
2018-03-10 21:39 - 2018-02-10 15:09 - 000075160 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthProxyStub.dll
2018-03-10 21:39 - 2018-02-10 15:08 - 000687552 _____ (Microsoft Corporation) C:\WINDOWS\system32\StructuredQuery.dll
2018-03-10 21:39 - 2018-02-10 15:08 - 000398824 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsAdminFlows.exe
2018-03-10 21:39 - 2018-02-10 15:08 - 000096200 _____ (Microsoft Corporation) C:\WINDOWS\system32\winbrand.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000824896 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipSVC.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000727448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fvevol.sys
2018-03-10 21:39 - 2018-02-10 15:06 - 000594048 _____ (Microsoft Corporation) C:\WINDOWS\system32\mf.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000356952 _____ (Microsoft Corporation) C:\WINDOWS\system32\wintrust.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000189336 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthAgent.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000100248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryBroker.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000087384 _____ (Microsoft Corporation) C:\WINDOWS\system32\remoteaudioendpoint.dll
2018-03-10 21:39 - 2018-02-10 15:05 - 000688064 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
2018-03-10 21:39 - 2018-02-10 15:05 - 000413888 _____ (Microsoft Corporation) C:\WINDOWS\system32\AUDIOKSE.dll
2018-03-10 21:39 - 2018-02-10 15:05 - 000097176 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdstor.sys
2018-03-10 21:39 - 2018-02-10 15:05 - 000070856 _____ (Microsoft Corporation) C:\WINDOWS\system32\wldp.dll
2018-03-10 21:39 - 2018-02-10 15:04 - 001430760 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcMon.exe
2018-03-10 21:39 - 2018-02-10 15:04 - 000614296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\afd.sys
2018-03-10 21:39 - 2018-02-10 15:04 - 000339872 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkBindingEngineMigPlugin.dll
2018-03-10 21:39 - 2018-02-10 15:04 - 000260896 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
2018-03-10 21:39 - 2018-02-10 15:04 - 000212880 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsensorgroup.dll
2018-03-10 21:39 - 2018-02-10 15:04 - 000093592 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
2018-03-10 21:39 - 2018-02-10 15:03 - 000849304 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicensingWinRT.dll
2018-03-10 21:39 - 2018-02-10 15:03 - 000706600 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeManagerObj.dll
2018-03-10 21:39 - 2018-02-10 15:03 - 000098712 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceReactivation.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 002773400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
2018-03-10 21:39 - 2018-02-10 15:02 - 001103768 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\http.sys
2018-03-10 21:39 - 2018-02-10 15:02 - 000628632 _____ (Microsoft Corporation) C:\WINDOWS\system32\msvcp_win.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 000617304 _____ (Microsoft Corporation) C:\WINDOWS\system32\TextInputFramework.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 000495000 _____ (Microsoft Corporation) C:\WINDOWS\system32\TransportDSA.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 000397720 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVScripting.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 000231320 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVShNotify.exe
2018-03-10 21:39 - 2018-02-10 15:02 - 000040352 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVClientPS.dll
2018-03-10 21:39 - 2018-02-10 14:22 - 001930224 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
2018-03-10 21:39 - 2018-02-10 14:18 - 001384288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVP9DEC.dll
2018-03-10 21:39 - 2018-02-10 14:18 - 000022424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hvsicontainerservice.dll
2018-03-10 21:39 - 2018-02-10 14:17 - 000542856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryPS.dll
2018-03-10 21:39 - 2018-02-10 14:17 - 000211864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aepic.dll
2018-03-10 21:39 - 2018-02-10 14:12 - 004382032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setupapi.dll
2018-03-10 21:39 - 2018-02-10 14:11 - 001250528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Taskmgr.exe
2018-03-10 21:39 - 2018-02-10 14:10 - 000422592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\policymanager.dll
2018-03-10 21:39 - 2018-02-10 14:09 - 001123456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3D12.dll
2018-03-10 21:39 - 2018-02-10 14:09 - 000559976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\StructuredQuery.dll
2018-03-10 21:39 - 2018-02-10 14:08 - 003980720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepository.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000543920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000284112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wintrust.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000123808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryClient.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000089504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryBroker.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000083216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winbrand.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000061024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wldp.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000718232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LicensingWinRT.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000654456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EditionUpgradeManagerObj.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000551672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mf.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000386424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AUDIOKSE.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000193248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsensorgroup.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000129184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfps.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000079256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DeviceReactivation.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000077552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudNotifications.exe
2018-03-10 21:39 - 2018-02-10 14:05 - 000074992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\remoteaudioendpoint.dll
2018-03-10 21:39 - 2018-02-10 14:04 - 000027032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppVClientPS.dll
2018-03-10 21:39 - 2018-02-10 14:03 - 000505160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msvcp_win.dll
2018-03-10 21:39 - 2018-02-10 13:50 - 000849920 _____ (Microsoft Corporation) C:\WINDOWS\system32\uDWM.dll
2018-03-10 21:39 - 2018-02-10 13:50 - 000496128 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatehandlers.dll
2018-03-10 21:39 - 2018-02-10 13:49 - 001664512 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
2018-03-10 21:39 - 2018-02-10 13:49 - 000848896 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusUpdateHandlers.dll
2018-03-10 21:39 - 2018-02-10 13:49 - 000385536 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cldflt.sys
2018-03-10 21:39 - 2018-02-10 13:49 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\system32\convertvhd.exe
2018-03-10 21:39 - 2018-02-10 13:49 - 000211456 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotificationUx.exe
2018-03-10 21:39 - 2018-02-10 13:49 - 000107520 _____ (Microsoft Corporation) C:\WINDOWS\system32\musdialoghandlers.dll
2018-03-10 21:39 - 2018-02-10 13:48 - 000033280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mskssrv.sys
2018-03-10 21:39 - 2018-02-10 13:48 - 000025088 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAppMgmtClient.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000331264 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserexport.exe
2018-03-10 21:39 - 2018-02-10 13:47 - 000201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeManager.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000201216 _____ (Microsoft Corporation) C:\WINDOWS\system32\SharedPCCSP.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000143872 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000055808 _____ (Microsoft Corporation) C:\WINDOWS\system32\virtdisk.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000046080 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidparse.sys
2018-03-10 21:39 - 2018-02-10 13:47 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcimage.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000033792 _____ (Microsoft Corporation) C:\WINDOWS\system32\wups2.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\system32\tzres.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 001470976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000225792 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\winnat.sys
2018-03-10 21:39 - 2018-02-10 13:46 - 000199168 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDeviceRegistration.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000173568 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryUpgrade.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000162304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IndexedDbLegacy.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000135680 _____ (Microsoft Corporation) C:\WINDOWS\system32\shsetup.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000082432 _____ (Microsoft Corporation) C:\WINDOWS\system32\MshtmlDac.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000026112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setup16.exe
2018-03-10 21:39 - 2018-02-10 13:46 - 000004608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user.exe
2018-03-10 21:39 - 2018-02-10 13:45 - 000675328 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000306688 _____ (Microsoft Corporation) C:\WINDOWS\system32\FSClient.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000288768 _____ (Microsoft Corporation) C:\WINDOWS\system32\authz.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000288256 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsku.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtmled.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000079872 _____ (Microsoft Corporation) C:\WINDOWS\system32\nlaapi.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000066048 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrv.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000043008 _____ (Microsoft Corporation) C:\WINDOWS\system32\nshhttp.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000016384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EnterpriseAppMgmtClient.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000800768 _____ (Microsoft Corporation) C:\WINDOWS\system32\Magnify.exe
2018-03-10 21:39 - 2018-02-10 13:44 - 000579072 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Payments.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000503296 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_User.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000427008 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneCoreCommonProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000388608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Search.ProtocolHandler.MAPI2.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000336896 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppLockerCSP.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000302592 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAppMgmtSvc.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000276992 _____ (Microsoft Corporation) C:\WINDOWS\system32\shutdownux.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000276480 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtrans.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000208384 _____ (Microsoft Corporation) C:\WINDOWS\system32\tetheringservice.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000155648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EdgeManager.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000059392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssprxy.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000048640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\virtdisk.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tzres.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 003756032 _____ (Microsoft Corporation) C:\WINDOWS\system32\bootux.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000580608 _____ (Microsoft Corporation) C:\WINDOWS\system32\webio.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000566272 _____ (Microsoft Corporation) C:\WINDOWS\system32\DevicePairing.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000456704 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtmsft.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000391168 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000311808 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeveloperOptionsSettingsHandlers.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000268288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtrans.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000247296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winsku.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000181248 _____ (Microsoft Corporation) C:\WINDOWS\system32\twext.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000150528 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppManagementConfiguration.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000147456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryUpgrade.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000110080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shsetup.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000086528 _____ (Microsoft Corporation) C:\WINDOWS\system32\cldapi.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000084480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppCapture.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000013312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PCShellCommonProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 001216000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.Vpn.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 001113600 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvr.exe
2018-03-10 21:39 - 2018-02-10 13:42 - 000975872 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbiosrvc.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000950784 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasgcw.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000837632 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authentication.Web.Core.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000792064 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssvp.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000731136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Magnify.exe
2018-03-10 21:39 - 2018-02-10 13:42 - 000634880 _____ (Microsoft Corporation) C:\WINDOWS\system32\efswrt.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000459776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webplatstorageserver.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000397824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtmsft.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000286720 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsrslvr.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000270336 _____ (Microsoft Corporation) C:\WINDOWS\system32\ListSvc.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000234496 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkDesktopSettings.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000233984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppLockerCSP.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000228352 _____ (Microsoft Corporation) C:\WINDOWS\system32\ie4uinit.exe
2018-03-10 21:39 - 2018-02-10 13:42 - 000225280 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchFilterHost.exe
2018-03-10 21:39 - 2018-02-10 13:42 - 000184832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authz.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000160768 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockScreenContent.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000160256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserDeviceRegistration.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000130048 _____ (Microsoft Corporation) C:\WINDOWS\system32\rshx32.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\IdCtrls.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000078336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtmled.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000035328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nshhttp.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000024064 _____ (Microsoft Corporation) C:\WINDOWS\system32\regsvr32.exe
2018-03-10 21:39 - 2018-02-10 13:41 - 000859648 _____ (Microsoft Corporation) C:\WINDOWS\system32\appwiz.cpl
2018-03-10 21:39 - 2018-02-10 13:41 - 000820224 _____ (Microsoft Corporation) C:\WINDOWS\system32\netlogon.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000504832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DevicePairing.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000466432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\efswrt.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000405504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Payments.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000401408 _____ (Microsoft Corporation) C:\WINDOWS\system32\ncsi.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000377856 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchProtocolHost.exe
2018-03-10 21:39 - 2018-02-10 13:41 - 000288768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Search.ProtocolHandler.MAPI2.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000255488 _____ (Microsoft Corporation) C:\WINDOWS\system32\edputil.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000221184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netplwiz.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000133120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppManagementConfiguration.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sendmail.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000063488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nlaapi.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 003367936 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncCenter.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 002873344 _____ (Microsoft Corporation) C:\WINDOWS\system32\themeui.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 001234432 _____ (Microsoft Corporation) C:\WINDOWS\system32\SEMgrSvc.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 001002496 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000940544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.Vpn.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000939520 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasdlg.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000930816 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasmans.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000886784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcastdvr.exe
2018-03-10 21:39 - 2018-02-10 13:40 - 000856576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasgcw.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000800256 _____ (Microsoft Corporation) C:\WINDOWS\system32\cscui.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000756736 _____ (Microsoft Corporation) C:\WINDOWS\system32\msfeeds.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000691200 _____ (Microsoft Corporation) C:\WINDOWS\system32\dsreg.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000526336 _____ (Microsoft Corporation) C:\WINDOWS\system32\authui.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000508416 _____ (Microsoft Corporation) C:\WINDOWS\system32\timedate.cpl
2018-03-10 21:39 - 2018-02-10 13:40 - 000499200 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastls.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\timedate.cpl
2018-03-10 21:39 - 2018-02-10 13:40 - 000421376 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputSwitch.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000386560 _____ (Microsoft Corporation) C:\WINDOWS\system32\zipfldr.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000366080 _____ (Microsoft Corporation) C:\WINDOWS\system32\nlasvc.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000343040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000298496 _____ (Microsoft Corporation) C:\WINDOWS\system32\netplwiz.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edputil.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000195072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OneCoreCommonProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000177152 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeHelper.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 005500928 _____ (Microsoft Corporation) C:\WINDOWS\system32\aclui.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 002677760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 002490880 _____ (Microsoft Corporation) C:\WINDOWS\system32\themecpl.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000908800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontext.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000721920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssvp.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000680960 _____ (Microsoft Corporation) C:\WINDOWS\system32\sud.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000658432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netlogon.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000648704 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserLanguagesCpl.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000621056 _____ (Microsoft Corporation) C:\WINDOWS\system32\hgcpl.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000462848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webio.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000447488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastls.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000346112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\zipfldr.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000315904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sysdm.cpl
2018-03-10 21:39 - 2018-02-10 13:39 - 000157696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twext.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000096256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IdCtrls.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000020992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\regsvr32.exe
2018-03-10 21:39 - 2018-02-10 13:38 - 006722560 _____ (Microsoft Corporation) C:\WINDOWS\system32\mspaint.exe
2018-03-10 21:39 - 2018-02-10 13:38 - 003125760 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 002184192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssrch.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 002082304 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcpl.cpl
2018-03-10 21:39 - 2018-02-10 13:38 - 001968640 _____ (Microsoft Corporation) C:\WINDOWS\system32\FntCache.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 001597952 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 001228800 _____ (Microsoft Corporation) C:\WINDOWS\system32\TokenBroker.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 001166336 _____ (Microsoft Corporation) C:\WINDOWS\system32\localspl.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000982016 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchIndexer.exe
2018-03-10 21:39 - 2018-02-10 13:38 - 000939520 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasapi32.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000885248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Search.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000863744 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntshrui.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000755712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\appwiz.cpl
2018-03-10 21:39 - 2018-02-10 13:38 - 000699904 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsm.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000668160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msfeeds.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000653312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sud.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000598528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Security.Authentication.Web.Core.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000524800 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.immersiveshell.serviceprovider.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000509440 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSync.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000506880 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinapi.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000401920 _____ (Microsoft Corporation) C:\WINDOWS\system32\rascustom.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000324608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchProtocolHost.exe
2018-03-10 21:39 - 2018-02-10 13:38 - 000174592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EditionUpgradeHelper.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 004839424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dbgeng.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 003419136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xpsrchvw.exe
2018-03-10 21:39 - 2018-02-10 13:37 - 003287040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SyncCenter.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 002523648 _____ (Microsoft Corporation) C:\WINDOWS\system32\gameux.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000965632 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontext.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000862208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasdlg.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000417792 _____ (Microsoft Corporation) C:\WINDOWS\system32\stobject.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000365568 _____ (Microsoft Corporation) C:\WINDOWS\system32\srchadmin.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000308224 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetSetupSvc.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000199680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchFilterHost.exe
2018-03-10 21:39 - 2018-02-10 13:37 - 000198656 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingMonitor.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 002462208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\themecpl.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 002035712 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcorets.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 001759744 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpncore.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 001342464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Wpc.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000915968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TokenBroker.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000695296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Search.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000666624 _____ (Microsoft Corporation) C:\WINDOWS\system32\DbgModel.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000599552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Core.TextInput.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000576512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hgcpl.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000559104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserLanguagesCpl.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000403968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sppcomapi.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000383488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\stobject.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000141824 _____ (Microsoft Corporation) C:\WINDOWS\system32\FontProvider.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000076288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cldapi.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 005388800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aclui.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 002814976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\themeui.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 002413568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gameux.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 002349568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 002013184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcpl.cpl
2018-03-10 21:39 - 2018-02-10 13:35 - 001474560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000963584 _____ (Microsoft Corporation) C:\WINDOWS\system32\StorSvc.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000943104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.BackgroundMediaPlayback.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000941568 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.BackgroundMediaPlayer.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000918528 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.MediaPlayer.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000862208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasapi32.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000826880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchIndexer.exe
2018-03-10 21:39 - 2018-02-10 13:35 - 000796160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntshrui.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000667136 _____ (Microsoft Corporation) C:\WINDOWS\system32\FrameServer.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000455680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authui.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinapi.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000402944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSync.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000332288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\srchadmin.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputSwitch.dll
2018-03-10 21:39 - 2018-02-10 13:34 - 006532096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspaint.exe
2018-03-10 21:39 - 2018-02-10 13:34 - 000624640 _____ (Microsoft Corporation) C:\WINDOWS\system32\WMVXENCD.DLL
2018-03-10 21:39 - 2018-02-10 13:34 - 000464384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Core.TextInput.dll
2018-03-10 21:39 - 2018-02-10 13:34 - 000433152 _____ (Microsoft Corporation) C:\WINDOWS\system32\WMVSENCD.DLL
2018-03-10 21:39 - 2018-02-10 13:34 - 000111104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.ProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 001936384 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmc.exe
2018-03-10 21:39 - 2018-02-10 13:33 - 001661440 _____ (Microsoft Corporation) C:\WINDOWS\system32\vssapi.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 001557504 _____ (Microsoft Corporation) C:\WINDOWS\system32\VSSVC.exe
2018-03-10 21:39 - 2018-02-10 13:33 - 000621568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.BackgroundMediaPlayback.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000620544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.BackgroundMediaPlayer.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000604672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.MediaPlayer.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000482816 _____ (Microsoft Corporation) C:\WINDOWS\system32\srcore.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000341504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcbase.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000266752 _____ (Microsoft Corporation) C:\WINDOWS\system32\rstrui.exe
2018-03-10 21:39 - 2018-02-10 13:33 - 000217088 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebClnt.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000125952 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxSysprep.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\davclnt.dll
2018-03-10 21:39 - 2018-02-10 13:32 - 002427904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcndmgr.dll
2018-03-10 21:39 - 2018-02-10 13:32 - 000681472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WMVXENCD.DLL
2018-03-10 21:39 - 2018-02-10 13:32 - 000392704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WMVSENCD.DLL
2018-03-10 21:39 - 2018-02-10 13:32 - 000073216 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\npfs.sys
2018-03-10 21:39 - 2018-02-10 13:32 - 000056832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.ProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:32 - 000050176 _____ (Microsoft Corporation) C:\WINDOWS\system32\pcalua.exe
2018-03-10 21:39 - 2018-02-10 13:31 - 001488896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmc.exe
2018-03-10 21:39 - 2018-02-10 13:31 - 001159680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vssapi.dll
2018-03-10 21:39 - 2018-02-10 13:31 - 000301056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcbase.dll
2018-03-10 21:39 - 2018-02-10 13:31 - 000190464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WebClnt.dll
2018-03-10 21:39 - 2018-02-10 13:31 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\davclnt.dll
2018-03-10 21:39 - 2018-02-10 11:59 - 000804240 _____ C:\WINDOWS\SysWOW64\locale.nls
2018-03-10 21:39 - 2018-02-10 11:59 - 000804240 _____ C:\WINDOWS\system32\locale.nls
2018-03-10 21:39 - 2018-02-09 12:35 - 001234888 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmpal.dll
2018-03-10 21:39 - 2018-02-09 12:35 - 001002952 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmcodecs.dll
2018-03-10 21:39 - 2018-02-09 12:35 - 000892872 _____ (Microsoft Corporation) C:\WINDOWS\system32\ortcengine.dll
2018-03-10 21:39 - 2018-02-09 12:35 - 000065992 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmmvrortc.dll
2018-03-10 21:39 - 2018-02-02 12:36 - 000921032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmpal.dll
2018-03-10 21:39 - 2018-02-02 12:36 - 000854976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmcodecs.dll
2018-03-10 21:39 - 2018-02-02 12:36 - 000649672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ortcengine.dll
2018-03-10 21:39 - 2018-02-02 12:36 - 000054720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmmvrortc.dll
2018-03-10 21:39 - 2018-01-01 21:52 - 000066712 _____ (Microsoft Corporation) C:\WINDOWS\system32\iumcrypt.dll
2018-03-10 21:39 - 2018-01-01 21:51 - 000191816 _____ (Microsoft Corporation) C:\WINDOWS\system32\skci.dll
2018-03-10 21:39 - 2018-01-01 21:51 - 000059800 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bam.sys
2018-03-10 21:39 - 2018-01-01 21:49 - 000292376 _____ (Microsoft Corporation) C:\WINDOWS\system32\wscapi.dll
2018-03-10 21:39 - 2018-01-01 21:48 - 000382360 _____ (Adobe Systems Incorporated) C:\WINDOWS\system32\atmfd.dll
2018-03-10 21:39 - 2018-01-01 21:47 - 000649304 _____ (Microsoft Corporation) C:\WINDOWS\system32\advapi32.dll
2018-03-10 21:39 - 2018-01-01 21:46 - 000898216 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
2018-03-10 21:39 - 2018-01-01 21:46 - 000733592 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\acpi.sys
2018-03-10 21:39 - 2018-01-01 21:43 - 001173576 _____ (Microsoft Corporation) C:\WINDOWS\system32\rpcrt4.dll
2018-03-10 21:39 - 2018-01-01 21:43 - 000367336 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Storage.ApplicationData.dll
2018-03-10 21:39 - 2018-01-01 21:43 - 000062872 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fsdepends.sys
2018-03-10 21:39 - 2018-01-01 21:42 - 000109976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbus.sys
2018-03-10 21:39 - 2018-01-01 21:41 - 000549552 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWanAPI.dll
2018-03-10 21:39 - 2018-01-01 21:39 - 000508264 _____ (Microsoft Corporation) C:\WINDOWS\system32\systemreset.exe
2018-03-10 21:39 - 2018-01-01 21:38 - 000103320 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\stornvme.sys
2018-03-10 21:39 - 2018-01-01 21:38 - 000038808 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Diskdump.sys
2018-03-10 21:39 - 2018-01-01 21:37 - 000461720 _____ (Microsoft Corporation) C:\WINDOWS\system32\wifitask.exe
2018-03-10 21:39 - 2018-01-01 21:36 - 000113560 _____ (Microsoft Corporation) C:\WINDOWS\system32\icfupgd.dll
2018-03-10 21:39 - 2018-01-01 21:36 - 000057752 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbios.sys
2018-03-10 21:39 - 2018-01-01 21:34 - 001336344 _____ (Microsoft Corporation) C:\WINDOWS\system32\ole32.dll
2018-03-10 21:39 - 2018-01-01 21:27 - 000163736 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wfplwfs.sys
2018-03-10 21:39 - 2018-01-01 21:26 - 000081304 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmcl.sys
2018-03-10 21:39 - 2018-01-01 21:06 - 000311192 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\atmfd.dll
2018-03-10 21:39 - 2018-01-01 21:03 - 000777904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rpcrt4.dll
2018-03-10 21:39 - 2018-01-01 21:03 - 000566664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
2018-03-10 21:39 - 2018-01-01 20:49 - 000481464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\advapi32.dll
2018-03-10 21:39 - 2018-01-01 20:49 - 000258808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wscapi.dll
2018-03-10 21:39 - 2018-01-01 20:46 - 000289816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Storage.ApplicationData.dll
2018-03-10 21:39 - 2018-01-01 20:45 - 000450928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWanAPI.dll
2018-03-10 21:39 - 2018-01-01 20:42 - 001003152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ole32.dll
2018-03-10 21:39 - 2018-01-01 20:25 - 000475648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieui.dll
2018-03-10 21:39 - 2018-01-01 20:24 - 000240640 _____ (Microsoft Corporation) C:\WINDOWS\system32\AboutSettingsHandlers.dll
2018-03-10 21:39 - 2018-01-01 20:24 - 000202240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppxAllUserStore.dll
2018-03-10 21:39 - 2018-01-01 20:24 - 000096256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontsub.dll
2018-03-10 21:39 - 2018-01-01 20:24 - 000038912 _____ (Adobe Systems) C:\WINDOWS\SysWOW64\atmlib.dll
2018-03-10 21:39 - 2018-01-01 20:23 - 000561152 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieui.dll
2018-03-10 21:39 - 2018-01-01 20:23 - 000121344 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontsub.dll
2018-03-10 21:39 - 2018-01-01 20:23 - 000080384 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmclr.sys
2018-03-10 21:39 - 2018-01-01 20:23 - 000047104 _____ (Adobe Systems) C:\WINDOWS\system32\atmlib.dll
2018-03-10 21:39 - 2018-01-01 20:22 - 000032768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rfxvmt.dll
2018-03-10 21:39 - 2018-01-01 20:22 - 000031744 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Management.Provisioning.ProxyStub.dll
2018-03-10 21:39 - 2018-01-01 20:22 - 000025600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Dumpstorport.sys
2018-03-10 21:39 - 2018-01-01 20:22 - 000017408 _____ (Microsoft Corporation) C:\WINDOWS\system32\VmApplicationHealthMonitorProxy.dll
2018-03-10 21:39 - 2018-01-01 20:21 - 000133632 _____ (Microsoft Corporation) C:\WINDOWS\system32\wificonnapi.dll
2018-03-10 21:39 - 2018-01-01 20:21 - 000097280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WcnApi.dll
2018-03-10 21:39 - 2018-01-01 20:21 - 000097280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\raspptp.sys
2018-03-10 21:39 - 2018-01-01 20:21 - 000080896 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wanarp.sys
2018-03-10 21:39 - 2018-01-01 20:21 - 000062976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndproxy.sys
2018-03-10 21:39 - 2018-01-01 20:21 - 000040448 _____ (Microsoft Corporation) C:\WINDOWS\system32\rfxvmt.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000524288 _____ (Microsoft Corporation) C:\WINDOWS\system32\daxexec.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000215552 _____ (Microsoft Corporation) C:\WINDOWS\system32\fwpolicyiomgr.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000212992 _____ (Microsoft Corporation) C:\WINDOWS\system32\container.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000186368 _____ (Microsoft Corporation) C:\WINDOWS\system32\ACPBackgroundManagerPolicy.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000175616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fwpolicyiomgr.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000134656 _____ (Microsoft Corporation) C:\WINDOWS\system32\WcnApi.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000133632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iepeers.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000104960 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasauto.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000082432 _____ (Microsoft Corporation) C:\WINDOWS\system32\SCardDlg.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000043008 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\RfxVmt.sys
2018-03-10 21:39 - 2018-01-01 20:19 - 000795136 _____ (Microsoft Corporation) C:\WINDOWS\system32\NaturalAuth.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000430080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Internal.Bluetooth.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000416768 _____ (Microsoft Corporation) C:\WINDOWS\system32\html.iec
2018-03-10 21:39 - 2018-01-01 20:19 - 000366080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\daxexec.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000340480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\html.iec
2018-03-10 21:39 - 2018-01-01 20:19 - 000316928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbt.sys
2018-03-10 21:39 - 2018-01-01 20:19 - 000188416 _____ (Microsoft Corporation) C:\WINDOWS\system32\PimIndexMaintenance.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000174592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\P2P.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000149504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\container.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\iepeers.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000097792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msoert2.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000748032 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneProviders.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000699904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CPFilters.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000588800 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmsRouterSvc.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000465920 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcncsvc.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000436224 _____ (Microsoft Corporation) C:\WINDOWS\system32\PsmServiceExtHost.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000425984 _____ (Microsoft Corporation) C:\WINDOWS\system32\vmrdvcore.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000380928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EncDec.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000369664 _____ (Microsoft Corporation) C:\WINDOWS\system32\APHostService.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000259072 _____ (Microsoft Corporation) C:\WINDOWS\system32\SCardSvr.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000210944 _____ (Microsoft Corporation) C:\WINDOWS\system32\P2P.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000144896 _____ (Microsoft Corporation) C:\WINDOWS\system32\appinfo.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000082944 _____ (Microsoft Corporation) C:\WINDOWS\system32\provdatastore.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 001485312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpserverbase.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000791552 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneService.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000616960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Bluetooth.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000555520 _____ (Microsoft Corporation) C:\WINDOWS\system32\SensorService.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000423936 _____ (Microsoft Corporation) C:\WINDOWS\system32\p2psvc.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000341504 _____ (Microsoft Corporation) C:\WINDOWS\system32\pnrpsvc.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\msoert2.dll
2018-03-10 21:39 - 2018-01-01 20:16 - 000966656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Unistore.dll
2018-03-10 21:39 - 2018-01-01 20:16 - 000956928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpbase.dll
2018-03-10 21:39 - 2018-01-01 20:16 - 000624128 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncController.dll
2018-03-10 21:39 - 2018-01-01 20:16 - 000235008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webcheck.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 001657856 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpserverbase.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 001245184 _____ (Microsoft Corporation) C:\WINDOWS\system32\Unistore.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 000970240 _____ (Microsoft Corporation) C:\WINDOWS\system32\sysmain.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 000951808 _____ (Microsoft Corporation) C:\WINDOWS\system32\usermgr.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 000434176 _____ (Microsoft Corporation) C:\WINDOWS\system32\EncDec.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 000258560 _____ (Microsoft Corporation) C:\WINDOWS\system32\webcheck.dll
2018-03-10 21:39 - 2018-01-01 20:14 - 001097728 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpbase.dll
2018-03-10 21:39 - 2018-01-01 20:14 - 000985600 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcomm.dll
2018-03-10 21:39 - 2018-01-01 20:14 - 000870912 _____ (Microsoft Corporation) C:\WINDOWS\system32\CPFilters.dll
2018-03-10 21:39 - 2018-01-01 20:13 - 000897024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcomm.dll
2018-03-10 21:39 - 2018-01-01 20:12 - 001573376 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDataService.dll
2018-03-10 21:39 - 2018-01-01 20:12 - 000760320 _____ (Microsoft Corporation) C:\WINDOWS\system32\spoolsv.exe
2018-03-10 21:39 - 2018-01-01 20:11 - 001955328 _____ (Microsoft Corporation) C:\WINDOWS\system32\PeerDistSvc.dll
2018-03-10 21:39 - 2018-01-01 20:11 - 001816576 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtsvc.dll
2018-03-10 21:39 - 2018-01-01 20:11 - 001343488 _____ (Microsoft Corporation) C:\WINDOWS\system32\wifinetworkmanager.dll
2018-03-10 21:39 - 2018-01-01 20:11 - 000715776 _____ (Microsoft Corporation) C:\WINDOWS\system32\winlogon.exe
2018-03-10 21:39 - 2018-01-01 20:10 - 002528256 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansvc.dll
2018-03-10 21:39 - 2018-01-01 20:10 - 000012800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wscproxystub.dll
2018-03-10 21:39 - 2018-01-01 20:08 - 000505344 _____ (Microsoft Corporation) C:\WINDOWS\system32\taskcomp.dll
2018-03-10 21:39 - 2018-01-01 20:06 - 000018944 _____ (Microsoft Corporation) C:\WINDOWS\system32\wscproxystub.dll
2018-03-09 20:08 - 2018-03-09 20:19 - 000000000 ____D C:\WINDOWS\system32\Drivers\wd
2018-03-09 20:07 - 2018-03-09 20:07 - 003034496 _____ C:\Users\ASUS\Desktop\ZHPDiag3.exe
2018-03-09 20:05 - 2018-03-09 20:05 - 000000008 __RSH C:\ProgramData\ntuser.pol
2018-03-09 20:03 - 2018-03-09 20:03 - 000033163 ____H C:\Users\ASUS\AppData\Local\IconCache.db.backup
2018-03-09 20:00 - 2018-03-14 21:43 - 000010122 _____ C:\Users\ASUS\Desktop\Fixlog.txt
2018-03-08 20:22 - 2018-03-08 21:08 - 001146880 _____ C:\Users\ASUS\Desktop\for dig.exe
2018-03-07 18:38 - 2018-03-07 18:38 - 008222496 _____ (Malwarebytes) C:\Users\ASUS\Desktop\adwcleaner_7.0.8.0.exe
2018-03-07 17:23 - 2018-03-07 17:23 - 000000072 ___SH C:\bootTel.dat
2018-03-07 16:29 - 2018-03-07 16:29 - 000298670 _____ C:\Users\ASUS\Downloads\RAMMap.zip
2018-03-07 16:07 - 2018-03-13 17:19 - 000055713 _____ C:\Users\ASUS\Desktop\Addition.txt
2018-03-07 16:02 - 2018-03-14 21:50 - 000015527 _____ C:\Users\ASUS\Desktop\FRST.txt
2018-03-05 00:19 - 2017-09-29 04:36 - 000140208 _____ (Razer, Inc.) C:\WINDOWS\system32\Drivers\rzpnk.sys
2018-03-04 23:52 - 2018-03-04 23:52 - 000002317 _____ C:\Users\Default\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2018-03-04 23:52 - 2018-03-04 23:52 - 000002317 _____ C:\Users\Default User\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2018-03-04 23:52 - 2018-03-04 23:52 - 000000000 ____D C:\Program Files (x86)\Microsoft OneDrive
2018-03-04 23:00 - 2018-03-04 23:00 - 000002848 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
2018-03-04 23:00 - 2018-03-04 23:00 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AutoHotkey
2018-03-04 22:57 - 2018-01-28 19:00 - 000794112 _____ C:\WINDOWS\system32\xvidcore.dll
2018-03-04 22:57 - 2018-01-28 19:00 - 000694784 _____ C:\WINDOWS\SysWOW64\xvidcore.dll
2018-03-04 22:57 - 2018-01-28 19:00 - 000311296 _____ C:\WINDOWS\system32\xvidvfw.dll
2018-03-04 22:57 - 2018-01-28 19:00 - 000284672 _____ C:\WINDOWS\SysWOW64\xvidvfw.dll
2018-03-04 22:57 - 2017-07-30 20:50 - 003850240 _____ (x264vfw project) C:\WINDOWS\SysWOW64\x264vfw.dll
2018-03-04 22:57 - 2017-07-30 20:50 - 003799552 _____ (x264vfw project) C:\WINDOWS\system32\x264vfw64.dll
2018-03-04 22:55 - 2018-03-04 22:55 - 000001816 _____ C:\Users\Public\Desktop\iTunes.lnk
2018-03-04 22:55 - 2018-03-04 22:55 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
2018-03-04 22:55 - 2018-03-04 22:55 - 000000000 ____D C:\Program Files\iPod
2018-03-04 22:54 - 2018-03-04 22:55 - 000000000 ____D C:\Program Files\iTunes
2018-03-04 22:52 - 2018-03-04 22:52 - 000002579 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Apple Software Update.lnk
2018-03-04 22:52 - 2018-03-04 22:52 - 000000000 ____D C:\WINDOWS\System32\Tasks\Apple
2018-03-04 22:52 - 2018-03-04 22:52 - 000000000 ____D C:\Program Files (x86)\Apple Software Update
2018-03-04 22:51 - 2018-03-14 19:29 - 000000000 ____D C:\Program Files\Bonjour
2018-03-04 22:51 - 2018-03-14 19:29 - 000000000 ____D C:\Program Files (x86)\Bonjour
2018-03-04 22:50 - 2018-03-04 22:51 - 000000000 ____D C:\Program Files\Common Files\Apple
2018-03-04 22:44 - 2018-03-14 21:28 - 000004424 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
2018-03-04 22:42 - 2018-03-07 07:57 - 000000000 ____D C:\Users\ASUS\AppData\Local\Patch_My_PC,_LLC
2018-03-04 22:18 - 2018-03-04 22:18 - 000000000 ____D C:\Users\ASUS\Desktop\autorun
2018-03-04 22:17 - 2018-03-04 22:17 - 001652843 _____ C:\Users\ASUS\Downloads\Autoruns.zip
2018-02-26 22:22 - 2018-02-26 22:22 - 000002487 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
2018-02-19 23:59 - 2018-02-19 23:59 - 001102336 _____ C:\Users\ASUS\Desktop\Otterly.exe
2018-02-17 22:15 - 2018-02-17 22:15 - 000000000 ____D C:\Users\ASUS\Downloads\Murder On The Orient Express (2017) [YTS.AG]
2018-02-17 21:49 - 2018-02-17 21:49 - 000033970 _____ C:\Users\ASUS\Downloads\Murder on the Orient Express (2017) [BluRay] [720p] [YTS.AM].torrent
2018-02-17 21:37 - 2018-02-17 21:37 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\TunnelBear
2018-02-17 21:34 - 2018-02-17 21:34 - 067791208 _____ (TunnelBear) C:\Users\ASUS\Downloads\TunnelBear-Installer.exe
2018-02-17 19:42 - 2018-02-17 19:45 - 178509109 _____ C:\Users\ASUS\Downloads\War server.7z
2018-02-16 21:48 - 2018-02-16 21:52 - 190639422 _____ C:\Users\ASUS\Downloads\[Decoshoot] Kera Sakti II - 03.mp4
2018-02-16 20:28 - 2018-02-16 20:31 - 188188000 _____ C:\Users\ASUS\Downloads\[Decoshoot] Kera Sakti II - 02.mp4
2018-02-14 23:51 - 2018-02-19 22:38 - 001138688 _____ C:\Users\ASUS\Desktop\AutoPot.exe
2018-02-14 23:47 - 2018-03-12 21:26 - 000000000 ____D C:\Users\ASUS\Desktop\AHK
2018-02-14 22:32 - 2018-02-14 22:32 - 004278784 _____ C:\Users\ASUS\Desktop\Effect.EXE
2018-02-12 12:11 - 2018-02-12 12:14 - 171760809 _____ C:\Users\ASUS\Downloads\[Decoshoot] Kera Sakti II - 01 (1).mp4
2018-03-14 21:50 - 2017-04-11 09:08 - 000000040 _____ C:\Program Files (x86)\settings.dat
2018-03-14 21:49 - 2017-11-26 03:00 - 001323662 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2018-03-14 21:49 - 2017-04-01 02:14 - 000000000 ____D C:\FRST
2018-03-14 21:44 - 2017-11-26 03:27 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
2018-03-14 21:44 - 2017-07-14 18:49 - 000000000 ____D C:\ProgramData\NVIDIA
2018-03-14 21:43 - 2017-11-26 03:01 - 000000000 ____D C:\Users\ASUS
2018-03-14 21:43 - 2017-09-29 17:45 - 000524288 _____ C:\WINDOWS\system32\config\BBI
2018-03-14 21:41 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\DeliveryOptimization
2018-03-14 21:35 - 2017-09-29 22:37 - 000000000 ____D C:\WINDOWS\CbsTemp
2018-03-14 21:31 - 2016-08-15 16:22 - 000000000 ____D C:\ProgramData\Package Cache
2018-03-14 21:30 - 2017-04-01 06:50 - 000000863 _____ C:\Users\Public\Desktop\CCleaner.lnk
2018-03-14 21:29 - 2017-04-01 06:50 - 000002379 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
2018-03-14 21:28 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\SysWOW64\Macromed
2018-03-14 21:28 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\Macromed
2018-03-14 21:27 - 2017-04-11 09:10 - 000000000 __SHD C:\ProgramData\360Quarant
2018-03-14 21:27 - 2017-04-02 15:08 - 000000000 __SHD C:\$360Section
2018-03-14 21:19 - 2017-05-05 13:56 - 000000000 ____D C:\Program Files (x86)\Bandicam
2018-03-14 20:19 - 2017-11-26 02:54 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
2018-03-14 19:57 - 2017-02-15 00:01 - 000000000 ____D C:\Users\ASUS\AppData\Local\CrashDumps
2018-03-14 19:37 - 2017-04-01 08:03 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\ZHP
2018-03-14 19:19 - 2017-11-26 03:01 - 000000000 ____D C:\Users\defaultuser0
2018-03-14 19:11 - 2017-02-15 00:47 - 000068005 _____ C:\Users\ASUS\Desktop\Ragnarok.xlsx
2018-03-14 18:08 - 2017-11-26 03:27 - 000004146 _____ C:\WINDOWS\System32\Tasks\User_Feed_Synchronization-{60208B48-6CA6-4424-8E02-7F65C7F3A413}
2018-03-14 02:06 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\AppReadiness
2018-03-13 20:15 - 2017-04-07 08:15 - 000095232 _____ (360.cn) C:\WINDOWS\SysWOW64\Drivers\360AvFlt.sys
2018-03-12 19:01 - 2017-11-21 22:16 - 000000000 ___DC C:\WINDOWS\Panther
2018-03-12 19:01 - 2017-09-29 22:44 - 000000000 ____D C:\WINDOWS\INF
2018-03-12 19:00 - 2017-07-29 23:41 - 000000000 ____D C:\ProgramData\TEMP
2018-03-12 19:00 - 2017-05-06 18:52 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\Mumble
2018-03-12 19:00 - 2017-02-15 14:57 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\Skype
2018-03-12 19:00 - 2017-02-15 00:36 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\MPC-HC
2018-03-12 18:33 - 2017-11-26 03:32 - 000000000 ___RD C:\Users\ASUS\3D Objects
2018-03-12 18:33 - 2016-08-15 16:19 - 000000000 __RHD C:\Users\Public\AccountPictures
2018-03-12 18:32 - 2016-08-15 16:34 - 000000000 __SHD C:\Users\ASUS\IntelGraphicsProfiles
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ___SD C:\WINDOWS\SysWOW64\F12
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ___SD C:\WINDOWS\system32\F12
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\TextInput
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\SysWOW64\Dism
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\oobe
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\migwiz
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\appraiser
2018-03-12 18:23 - 2017-09-29 17:45 - 000000000 ____D C:\WINDOWS\system32\Dism
2018-03-12 18:22 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\ShellExperiences
2018-03-12 18:22 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\Provisioning
2018-03-12 18:22 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\PolicyDefinitions
2018-03-12 18:22 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\bcastdvr
2018-03-12 17:46 - 2016-08-15 16:21 - 000000000 ___RD C:\Users\ASUS\OneDrive
2018-03-11 22:25 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\rescache
2018-03-09 20:19 - 2017-09-29 22:46 - 000000000 ___RD C:\Program Files\Windows Defender
2018-03-09 20:12 - 2017-04-02 15:16 - 000000000 ____D C:\Users\ASUS\AppData\Local\ZHP
2018-03-09 20:11 - 2017-02-15 12:40 - 000548000 ____N (Microsoft Corporation) C:\WINDOWS\system32\MpSigStub.exe
2018-03-09 20:00 - 2017-06-19 20:44 - 000000000 ___HD C:\WINDOWS\system32\GroupPolicy
2018-03-07 18:40 - 2017-04-01 08:27 - 000000000 ____D C:\AdwCleaner
2018-03-07 18:34 - 2017-09-27 21:31 - 000000000 ____D C:\Program Files (x86)\Microsoft Silverlight
2018-03-07 08:16 - 2017-11-26 03:02 - 000000000 ____D C:\Users\ASUS\AppData\Local\Packages
2018-03-07 08:16 - 2017-09-29 22:46 - 000000000 ___HD C:\Program Files\WindowsApps
2018-03-07 08:12 - 2017-10-22 21:28 - 000000000 ____D C:\Program Files\CyberGhost 6
2018-03-07 08:11 - 2017-09-29 18:41 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Kits
2018-03-07 08:08 - 2017-10-21 15:02 - 000000000 ____D C:\Program Files\TAP-Windows
2018-03-07 08:06 - 2017-05-06 20:06 - 000000000 ___RD C:\Program Files (x86)\Skype
2018-03-07 08:06 - 2017-02-15 14:56 - 000000000 ____D C:\ProgramData\Skype
2018-03-06 23:29 - 2017-04-11 09:08 - 000001140 _____ C:\Program Files (x86)\metadata
2018-03-06 23:28 - 2017-04-11 09:08 - 000000000 ____D C:\Program Files (x86)\reports
2018-03-05 00:19 - 2017-02-15 16:12 - 000000000 ____D C:\Users\ASUS\AppData\Local\Razer
2018-03-05 00:19 - 2017-02-15 16:12 - 000000000 ____D C:\ProgramData\Razer
2018-03-04 23:30 - 2017-04-01 06:50 - 000000864 _____ C:\Users\Public\Desktop\TeamSpeak 3 Client.lnk
2018-03-04 23:30 - 2017-04-01 06:50 - 000000814 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamSpeak 3 Client.lnk
2018-03-04 23:00 - 2017-12-17 21:23 - 000000000 ____D C:\Program Files\AutoHotkey
2018-03-04 23:00 - 2017-02-14 18:04 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR
2018-03-04 23:00 - 2017-02-14 18:04 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
2018-03-04 23:00 - 2017-02-14 18:04 - 000000000 ____D C:\Program Files\WinRAR
2018-03-04 22:57 - 2017-02-14 18:51 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack
2018-03-04 22:57 - 2017-02-14 18:51 - 000000000 ____D C:\Program Files (x86)\K-Lite Codec Pack
2018-03-04 22:45 - 2017-09-27 21:31 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
2018-03-04 22:32 - 2017-06-16 22:23 - 000007609 _____ C:\Users\ASUS\AppData\Local\Resmon.ResmonCfg
2018-03-01 15:13 - 2017-03-08 15:19 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\TS3Client
2018-02-24 22:00 - 2017-02-19 02:00 - 000000000 ___RD C:\Users\ASUS\Dropbox
2018-02-24 21:59 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\LiveKernelReports
2018-02-19 23:44 - 2017-10-07 09:17 - 000001738 _____ C:\Users\ASUS\Desktop\diet plan + wifii pass.txt
2018-02-19 22:14 - 2018-02-08 20:31 - 000000132 _____ C:\Users\ASUS\AppData\Roaming\Adobe PNG Format CS6 Prefs
2018-02-16 01:43 - 2017-02-16 14:23 - 000000000 ____D C:\WINDOWS\system32\MRT
2018-02-16 01:24 - 2017-10-11 22:04 - 130067560 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT-KB890830.exe
2018-02-16 01:24 - 2017-02-16 14:23 - 130067560 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2018-02-15 08:37 - 2017-02-15 18:45 - 000000000 __SHD C:\Users\ASUS\wc
2017-04-11 09:08 - 2018-03-06 23:29 - 000001140 _____ () C:\Program Files (x86)\metadata
2017-04-11 09:08 - 2018-03-14 21:50 - 000000040 _____ () C:\Program Files (x86)\settings.dat
2017-12-28 20:10 - 2018-02-08 20:25 - 000000132 _____ () C:\Users\ASUS\AppData\Roaming\Adobe BMP Format CS6 Prefs
2018-02-08 20:31 - 2018-02-19 22:14 - 000000132 _____ () C:\Users\ASUS\AppData\Roaming\Adobe PNG Format CS6 Prefs
2017-04-26 10:44 - 2017-05-11 19:46 - 000000132 _____ () C:\Users\ASUS\AppData\Roaming\Adobe Targa Format CS6 Prefs
2017-04-11 09:11 - 2017-04-11 09:11 - 000000038 ___SH () C:\Users\ASUS\AppData\Local\1754111884ee9ab5277ca00.95260103
2017-07-07 22:36 - 2017-07-07 22:36 - 000000037 ___SH () C:\Users\ASUS\AppData\Local\20986331705021ca58edc424.96250074
2017-04-07 14:17 - 2017-04-26 19:53 - 000000600 _____ () C:\Users\ASUS\AppData\Local\PUTTY.RND
2017-06-16 22:23 - 2018-03-04 22:32 - 000007609 _____ () C:\Users\ASUS\AppData\Local\Resmon.ResmonCfg
Some zero byte size files/folders:
C:\Windows\SysWOW64\wfs.exe
C:\Windows\SysWOW64\WFSR.dll
LastRegBack: 2018-03-13 23:01
We need you to run Malwarebytes Anti-Malware (MBAM) to get a log. Please download the free version of Malwarebytes HERE
Save the file to somewhere you can easily find it. Double click the saved file to start the install, accept any security warnings that may appear and after the install click the new desktop icon
mwb-jpg.481
to start the program. We need to modify a couple of things with MalwareBytes before we use it so please follow the steps below.
  • If the dashboard is not already displayed select it.
  • Then select Update to get the latest definition database.
mwb1-jpg.482
  • Next we need to change a scanning option, select Settings on the main menu
  • Then Detection and Protection on the left.
  • Then select Scan for rootkits in the detection options, as well as the other two options already checked.
mwb2-jpg.483
Now return to Dashboard on the main menu and select Scan Now at the bottom of the screen.
mwb3-jpg.484
  • Allow Malwarebytes to scan your system. It may take some time depending on how much data loaded onto your hard drive. When the scan is finished any threats will be listed for action. Ensure all threats are selected, and click Remove Selected
mwb5-jpg.489
A dialogue box may open and ask to restart the computer, if so select Yes
mwb7cc-jpg.486
Once the computer restarts open Malwarebytes again and select History on the menu bar, Application logs, then click the scan just completed, then click Export, choose text file. Name the text file and select a location, preferably the desktop and close Malwarebytes.
mwb8aa-jpg.492
Please copy and paste the contents of the text file in your next post :)
Malwarebytes
www.malwarebytes.com
-Log Details-
Scan Date: 3/15/18
Scan Time: 7:37 PM
Log File: e360a252-283c-11e8-818e-708bcd918332.json
Administrator: Yes
-Software Information-
Version: 3.4.4.2398
Components Version: 1.0.322
Update Package Version: 1.0.4366
License: Trial
-System Information-
OS: Windows 10 (Build 16299.248)
CPU: x64
File System: NTFS
User: System
-Scan Summary-
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 398559
Threats Detected: 5
Threats Quarantined: 0
(No malicious items detected)
Time Elapsed: 20 min, 10 sec
-Scan Options-
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Detect
PUM: Detect
-Scan Details-
Process: 0
Module: 0
Registry Key: 0
Registry Value: 0
Registry Data: 0
Data Stream: 0
Folder: 0
File: 5
RiskWare.CheatEngine, C:\USERS\ASUS\DESKTOP\EFFECT.EXE, No Action By User, [7864], [497728],1.0.4366
RiskWare.Tool.HCK, C:\PROGRAM FILES (X86)\BANDICAM\KEYMAKER.EXE, No Action By User, [2026], [64690],1.0.4366
PUP.Optional.GameHack, C:\PROGRAM FILES (X86)\CHEAT ENGINE 6.7\STANDALONEPHASE1.DAT, No Action By User, [661], [393793],1.0.4366
PUP.Optional.OpenCandy, C:\USERS\ASUS\DOWNLOADS\CHEATENGINE67.EXE, No Action By User, [478], [101648],1.0.4366
HackTool.Sniffer.WpePro, C:\USERS\ASUS\DOWNLOADS\WPEPRO09MOD (3).ZIP, No Action By User, [13628], [268173],1.0.4366
Physical Sector: 0
(end)
I know these files, and I use them alot. Is it ok to keep them?
You may if you wish, but I wouldn't if I were you.
I also see that your System Restore is disabled. Did you do this? If not, follow this guide to turn it back on and let me know when you have done so. We will proceed after that.
How does your PC run now?
Can you provide a fresh FRST log so I can review it to make sure that System Restore is enabled as well as no other things remain?
somehow after(i think) either zemana or system restore enabled, the memory started going up again. I uninstalled zemana but still remain the same
This is the new logs
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 14.03.2018
Ran by ASUS (administrator) on MAMBA (18-03-2018 09:58:47)
Running from C:\Users\ASUS\Desktop
Loaded Profiles: ASUS (Available Profiles: defaultuser0 & ASUS)
Platform: Windows 10 Enterprise Version 1709 16299.309 (X64) Language: English (United Kingdom)
Internet Explorer Version 11 (Default browser: Edge)
Boot Mode: Normal
Tutorial for Farbar Recovery Scan Tool: http://www.geekstogo.com/forum/topic/335081-frst-tutorial-how-to-use-farbar-recovery-scan-tool/
(NVIDIA Corporation) C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
(QIHU 360 SOFTWARE CO. LIMITED) C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe
(Apple Inc.) C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
(Windows (R) Win 7 DDK provider) C:\Program Files (x86)\Bluetooth Suite\AdminService.exe
(Apple Inc.) C:\Program Files\Bonjour\mDNSResponder.exe
(Intel Corporation) C:\Windows\System32\Intel\DPTF\esif_uf.exe
(Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_463164d40c3d26ce\IntelCpHDCPSvc.exe
(NVIDIA Corporation) C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
(Razer Inc) C:\Program Files (x86)\Razer\Razer Services\GMS\GameManagerService.exe
(Razer Inc.) C:\Program Files (x86)\Razer\Razer Services\Razer Central\RazerCentralService.exe
(Intel Corporation) C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_463164d40c3d26ce\IntelCpHeciSvc.exe
(Razer Inc.) D:\Program Files (x86)\Razer\Razer Cortex\RzKLService.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
(QIHU 360 SOFTWARE CO. LIMITED) C:\Program Files (x86)\360\Total Security\safemon\QHWatchdog.exe
(Microsoft Corporation) C:\Program Files\Common Files\microsoft shared\ClickToRun\OfficeClickToRun.exe
(Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) Security Assist\isa.exe
(Intel Corporation) C:\Windows\Temp\DPTF\esif_assist_64.exe
(ASUSTeK Computer Inc.) C:\Program Files (x86)\ASUS\ASUS Touchpad Handwriting\Exe\x64\AsusHWCenter64.exe
(QIHU 360 SOFTWARE CO. LIMITED) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
() C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
() C:\Program Files\WindowsApps\Microsoft.WindowsCalculator_10.1712.3351.0_x64__8wekyb3d8bbwe\Calculator.exe
(Microsoft Corporation) C:\Program Files\Microsoft Office\root\Office16\msoia.exe
(Microsoft Corporation) C:\Windows\System32\smartscreen.exe
==================== Registry (Whitelisted) ===========================
HKLM\...\Run: [iTunesHelper] => C:\Program Files\iTunes\iTunesHelper.exe [298296 2018-01-22] (Apple Inc.)
HKLM-x32\...\Run: [QHSafeTray] => C:\Program Files (x86)\360\Total Security\safemon\360Tray.exe [345000 2018-03-13] (QIHU 360 SOFTWARE CO. LIMITED)
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\Policies\Explorer: [NoLowDiskSpaceChecks] 1
Tcpip\Parameters: [DhcpNameServer] 122.197.254.7 122.197.254.4
Tcpip\..\Interfaces\{f4d23fd5-4b64-4c07-bed9-ba46ecaf0037}: [DhcpNameServer] 122.197.254.7 122.197.254.4
Internet Explorer:
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\Software\Microsoft\Internet Explorer\Main,Start Page = about:blank
SearchScopes: HKU\S-1-5-21-2746278279-2939389576-4119914495-1001 -> DefaultScope {67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} URL = hxxp://www.bing.com/search?q={searchTerms}&form=MSSEDF&pc=MSE1
SearchScopes: HKU\S-1-5-21-2746278279-2939389576-4119914495-1001 -> {67C334C0-408D-4E6D-B5A7-0ADD6AFFA252} URL = hxxp://www.bing.com/search?q={searchTerms}&form=MSSEDF&pc=MSE1
Handler: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files\Microsoft Office\root\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler-x32: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler-x32: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler-x32: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files\Microsoft Office\root\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Handler-x32: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL [2017-02-14] (Microsoft Corporation)
Edge:
Edge HomeButtonPage: HKU\S-1-5-21-2746278279-2939389576-4119914495-1001 -> hxxp://www.google.com
FireFox:
FF DefaultProfile: 477a178k.default
FF ProfilePath: C:\Users\ASUS\AppData\Roaming\Mozilla\Firefox\Profiles\477a178k.default [2018-03-09]
FF Plugin: @adobe.com/FlashPlayer -> C:\WINDOWS\system32\Macromed\Flash\NPSWF64_29_0_0_113.dll [2018-03-14] ()
FF Plugin: @microsoft.com/SharePoint,version=14.0 -> C:\Program Files\Microsoft Office\root\Office16\NPSPWRAP.DLL [2017-02-14] (Microsoft Corporation)
FF Plugin-x32: @adobe.com/FlashPlayer -> C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_29_0_0_113.dll [2018-03-14] ()
FF Plugin-x32: @Microsoft.com/NpCtrl,version=1.0 -> C:\Program Files (x86)\Microsoft Silverlight\5.1.50907.0\npctrl.dll [2017-05-03] ( Microsoft Corporation)
FF Plugin-x32: @microsoft.com/SharePoint,version=14.0 -> C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\NPSPWRAP.DLL [2017-02-14] (Microsoft Corporation)
FF Plugin-x32: @tools.google.com/Google Update;version=3 -> C:\Program Files (x86)\Google\Update\1.3.33.7\npGoogleUpdate3.dll [2017-11-15] (Google Inc.)
FF Plugin-x32: @tools.google.com/Google Update;version=9 -> C:\Program Files (x86)\Google\Update\1.3.33.7\npGoogleUpdate3.dll [2017-11-15] (Google Inc.)
FF Plugin-x32: Adobe Reader -> C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AIR\nppdf32.dll [2018-02-12] (Adobe Systems Inc.)
Chrome:
CHR DefaultProfile: Default
CHR Profile: C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default [2018-03-18]
CHR Extension: (360 Internet Protection) - C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\glcimepnljoholdmjchkloafkggfoijh [2018-03-12]
CHR Extension: (Chrome Web Store Payments) - C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2018-03-12]
CHR Extension: (Chrome Media Router) - C:\Users\ASUS\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm [2018-03-07]
CHR HKLM-x32\...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
CHR HKLM-x32\...\Chrome\Extension: [glcimepnljoholdmjchkloafkggfoijh] - hxxps://clients2.google.com/service/update2/crx
R2 Apple Mobile Device Service; C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe [83768 2018-01-05] (Apple Inc.)
R2 AtherosSvc; C:\Program Files (x86)\Bluetooth Suite\adminservice.exe [325600 2016-05-20] (Windows (R) Win 7 DDK provider)
R3 ClickToRunSvc; C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeClickToRun.exe [2838760 2016-04-24] (Microsoft Corporation)
R2 esifsvc; C:\WINDOWS\System32\Intel\DPTF\esif_uf.exe [1585784 2016-05-23] (Intel Corporation)
S3 Intel(R) Capability Licensing Service TCP IP Interface; C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe [974632 2016-02-20] (Intel(R) Corporation)
R3 Intel(R) Security Assist; C:\Program Files (x86)\Intel\Intel(R) Security Assist\isa.exe [335872 2016-03-03] (Intel Corporation) [File not signed]
S2 isaHelperSvc; C:\Program Files (x86)\Intel\Intel(R) Security Assist\isaHelperService.exe [8704 2016-03-03] (Intel Corporation) [File not signed]
R2 jhi_service; C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [215328 2016-05-17] (Intel Corporation)
S3 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [6440736 2018-03-03] (Malwarebytes)
S3 ose64; C:\Program Files\Common Files\Microsoft Shared\Source Engine\OSE.EXE [242720 2016-04-23] (Microsoft Corporation) [File not signed]
R2 QHActiveDefense; C:\Program Files (x86)\360\Total Security\safemon\QHActiveDefense.exe [929888 2018-03-13] (QIHU 360 SOFTWARE CO. LIMITED)
R2 Razer Game Manager Service; C:\Program Files (x86)\Razer\Razer Services\GMS\GameManagerService.exe [253776 2017-12-01] (Razer Inc)
S3 Razer Game Scanner Service; C:\Program Files (x86)\Razer\Razer Services\GSS\GameScannerService.exe [189264 2016-09-25] ()
R2 RzActionSvc; C:\Program Files (x86)\Razer\Razer Services\Razer Central\RazerCentralService.exe [532352 2017-11-07] (Razer Inc.)
R2 RzKLService; D:\Program Files (x86)\Razer\Razer Cortex\RzKLService.exe [502144 2018-01-16] (Razer Inc.)
S3 Sense; C:\Program Files\Windows Defender Advanced Threat Protection\MsSense.exe [4329952 2017-11-26] (Microsoft Corporation)
S3 Te.Service; C:\Program Files (x86)\Windows Kits\10\Testing\Runtimes\TAEF\Wex.Services.exe [187904 2017-09-28] (Microsoft Corporation) [File not signed]
S3 VSStandardCollectorService140; C:\Program Files (x86)\Microsoft Visual Studio 14.0\Team Tools\DiagnosticsHub\Collector\StandardCollector.Service.exe [108776 2016-09-06] (Microsoft Corporation)
S3 VSStandardCollectorService150; C:\Program Files (x86)\Microsoft Visual Studio\Shared\Common\DiagnosticsHub.Collection.Service\StandardCollector.Service.exe [142432 2017-11-09] (Microsoft Corporation)
S3 WdNisSvc; C:\ProgramData\Microsoft\Windows Defender\platform\4.12.17007.18022-0\NisSrv.exe [356152 2018-03-09] (Microsoft Corporation)
S3 WinDefend; C:\ProgramData\Microsoft\Windows Defender\platform\4.12.17007.18022-0\MsMpEng.exe [106280 2018-03-09] (Microsoft Corporation)
R2 NVDisplay.ContainerLocalSystem; "C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe" -s NVDisplay.ContainerLocalSystem -f "C:\ProgramData\NVIDIA\NVDisplay.ContainerLocalSystem.log" -l 3 -d "C:\Program Files\NVIDIA Corporation\Display.NvContainer\plugins\LocalSystem" -r -p 30000
R2 NvTelemetryContainer; "C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe" -s NvTelemetryContainer -f "C:\ProgramData\NVIDIA\NvTelemetryContainer.log" -l 3 -d "C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\plugins" -r
R1 360AntiHacker; C:\WINDOWS\System32\Drivers\360AntiHacker64.sys [192176 2018-03-01] (360.cn)
R3 360AvFlt; C:\WINDOWS\System32\DRIVERS\360AvFlt.sys [95232 2018-03-01] (360.cn)
R3 360AvFlt; C:\Windows\SysWOW64\DRIVERS\360AvFlt.sys [95232 2018-03-13] (360.cn)
R1 360Box64; C:\WINDOWS\System32\DRIVERS\360Box64.sys [339456 2018-03-13] (360.cn)
R1 360Camera; C:\WINDOWS\System32\Drivers\360Camera64.sys [57848 2018-03-01] (360.cn)
R1 360FsFlt; C:\WINDOWS\System32\DRIVERS\360FsFlt.sys [442544 2018-03-01] (360.cn)
R1 360netmon; C:\WINDOWS\System32\DRIVERS\360netmon.sys [96424 2018-03-01] (360.cn)
R3 AsusPTPDrv; C:\WINDOWS\System32\drivers\AsusPTPFilter.sys [97784 2018-01-13] (ASUS Corporation)
R3 athr; C:\WINDOWS\System32\drivers\athw10x.sys [4320176 2018-01-13] (Qualcomm Atheros Communications, Inc.)
R1 BAPIDRV; C:\WINDOWS\System32\DRIVERS\BAPIDRV64.sys [210064 2018-03-01] (360.cn)
R3 dptf_cpu; C:\WINDOWS\System32\drivers\dptf_cpu.sys [69560 2018-01-13] (Intel Corporation)
R3 esif_lf; C:\WINDOWS\System32\drivers\esif_lf.sys [343608 2016-05-23] (Intel Corporation)
R3 HIDSwitch; C:\WINDOWS\System32\drivers\AsRadioControl.sys [31112 2018-01-13] (ASUS)
R2 NPF; C:\WINDOWS\System32\drivers\npf.sys [36600 2013-03-01] (Riverbed Technology, Inc.)
R3 nvlddmkm; C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_8892f62aa9f69fbe\nvlddmkm.sys [14458264 2017-05-19] (NVIDIA Corporation)
R0 RAMDiskVE; C:\WINDOWS\System32\Drivers\RAMDiskVE.sys [86680 2018-01-04] (Dataram, Inc.)
R3 rt640x64; C:\WINDOWS\System32\drivers\rt640x64.sys [1010624 2018-01-13] (Realtek )
S3 rzendpt; C:\WINDOWS\System32\drivers\rzendpt.sys [50392 2015-08-14] (Razer Inc)
R2 rzpmgrk; C:\Windows\system32\drivers\rzpmgrk.sys [44144 2016-09-17] (Razer, Inc.)
R2 rzpnk; C:\WINDOWS\system32\drivers\rzpnk.sys [140208 2017-09-29] (Razer, Inc.)
R3 SensorsSimulatorDriver; C:\WINDOWS\System32\drivers\WUDFRd.sys [259584 2017-09-29] (Microsoft Corporation)
S3 tap-tb-0901; C:\WINDOWS\System32\drivers\tap-tb-0901.sys [38656 2018-01-31] (The OpenVPN Project)
S3 tapprotonvpn; C:\WINDOWS\System32\drivers\tapprotonvpn.sys [46040 2017-08-25] (The OpenVPN Project)
S3 VSScanner; C:\WINDOWS\System32\DRIVERS\vsscanner.sys [29808 2016-08-18] (VoodooSoft, LLC)
S3 WdBoot; C:\WINDOWS\system32\drivers\wd\WdBoot.sys [46072 2018-03-09] (Microsoft Corporation)
S3 WdFilter; C:\WINDOWS\system32\drivers\wd\WdFilter.sys [288296 2018-03-09] (Microsoft Corporation)
S3 WdNisDrv; C:\WINDOWS\System32\drivers\wd\WdNisDrv.sys [129568 2018-03-09] (Microsoft Corporation)
R1 ZAM_Guard; C:\WINDOWS\System32\drivers\zamguard64.sys [203680 2017-03-22] (Zemana Ltd.)
S4 nvvhci; \SystemRoot\System32\drivers\nvvhci.sys [X]
S1 ZAM; \??\C:\WINDOWS\System32\drivers\zam64.sys [X]
2018-03-18 09:57 - 2018-03-18 09:57 - 002403328 _____ (Farbar) C:\Users\ASUS\Desktop\FRST64.exe
2018-03-18 09:57 - 2018-03-18 09:57 - 001731872 _____ (Patch My PC, LLC) C:\Users\ASUS\Desktop\PatchMyPC.exe
2018-03-15 23:02 - 2018-03-15 23:02 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\360DrvMgr
2018-03-15 21:56 - 2018-03-18 09:58 - 000584097 _____ C:\WINDOWS\ZAM_Guard.krnl.trace
2018-03-15 21:56 - 2018-03-18 09:55 - 000589508 _____ C:\WINDOWS\ZAM.krnl.trace
2018-03-15 20:03 - 2018-03-15 20:03 - 000001740 _____ C:\Users\ASUS\Desktop\malwarebyte.txt
2018-03-15 00:20 - 2018-03-15 00:20 - 000140800 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakradiag.dll
2018-03-15 00:20 - 2018-03-15 00:20 - 000106496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakradiag.dll
2018-03-15 00:16 - 2018-03-02 12:36 - 017085440 _____ (Microsoft Corporation) C:\WINDOWS\system32\HologramCompositor.dll
2018-03-15 00:16 - 2018-03-01 16:50 - 000270744 _____ (Microsoft Corporation) C:\WINDOWS\system32\acmigration.dll
2018-03-15 00:16 - 2018-03-01 16:48 - 000664472 _____ (Microsoft Corporation) C:\WINDOWS\system32\aeinv.dll
2018-03-15 00:16 - 2018-03-01 16:47 - 000749464 _____ (Microsoft Corporation) C:\WINDOWS\system32\generaltel.dll
2018-03-15 00:16 - 2018-03-01 16:46 - 001568664 _____ (Microsoft Corporation) C:\WINDOWS\system32\appraiser.dll
2018-03-15 00:16 - 2018-03-01 16:37 - 007831760 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d10warp.dll
2018-03-15 00:16 - 2018-03-01 16:31 - 008602520 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntoskrnl.exe
2018-03-15 00:16 - 2018-03-01 16:23 - 000749976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms2.sys
2018-03-15 00:16 - 2018-03-01 16:17 - 002710736 _____ (Microsoft Corporation) C:\WINDOWS\system32\iertutil.dll
2018-03-15 00:16 - 2018-03-01 16:15 - 002574232 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgkrnl.sys
2018-03-15 00:16 - 2018-03-01 16:14 - 007675784 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.storage.dll
2018-03-15 00:16 - 2018-03-01 16:14 - 007384576 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Protection.PlayReady.dll
2018-03-15 00:16 - 2018-03-01 16:14 - 001694224 _____ (Microsoft Corporation) C:\WINDOWS\system32\winmde.dll
2018-03-15 00:16 - 2018-03-01 16:14 - 000147872 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wcifs.sys
2018-03-15 00:16 - 2018-03-01 16:10 - 001779936 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfplat.dll
2018-03-15 00:16 - 2018-03-01 16:09 - 001054272 _____ (Microsoft Corporation) C:\WINDOWS\system32\msvproc.dll
2018-03-15 00:16 - 2018-03-01 15:30 - 005615968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d10warp.dll
2018-03-15 00:16 - 2018-03-01 15:29 - 006092152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\windows.storage.dll
2018-03-15 00:16 - 2018-03-01 15:28 - 006480616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Protection.PlayReady.dll
2018-03-15 00:16 - 2018-03-01 15:28 - 002193168 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iertutil.dll
2018-03-15 00:16 - 2018-03-01 15:26 - 001524776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfplat.dll
2018-03-15 00:16 - 2018-03-01 15:26 - 001057816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msvproc.dll
2018-03-15 00:16 - 2018-03-01 15:21 - 001558856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winmde.dll
2018-03-15 00:16 - 2018-03-01 15:09 - 025251840 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgehtml.dll
2018-03-15 00:16 - 2018-03-01 15:03 - 002902528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\win32kfull.sys
2018-03-15 00:16 - 2018-03-01 15:03 - 000471552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AcSpecfc.dll
2018-03-15 00:16 - 2018-03-01 15:03 - 000344576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgeIso.dll
2018-03-15 00:16 - 2018-03-01 15:01 - 019354624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtml.dll
2018-03-15 00:16 - 2018-03-01 14:57 - 000369152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msIso.dll
2018-03-15 00:16 - 2018-03-01 14:56 - 018922496 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edgehtml.dll
2018-03-15 00:16 - 2018-03-01 14:56 - 000559104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9diag.dll
2018-03-15 00:16 - 2018-03-01 14:54 - 003664384 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kfull.sys
2018-03-15 00:16 - 2018-03-01 14:54 - 001296896 _____ (Microsoft Corporation) C:\WINDOWS\system32\usocore.dll
2018-03-15 00:16 - 2018-03-01 14:54 - 000665088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript.dll
2018-03-15 00:16 - 2018-03-01 14:54 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vbscript.dll
2018-03-15 00:16 - 2018-03-01 14:53 - 000536576 _____ (Microsoft Corporation) C:\WINDOWS\system32\edgeIso.dll
2018-03-15 00:16 - 2018-03-01 14:53 - 000092160 _____ (Microsoft Corporation) C:\WINDOWS\system32\usoapi.dll
2018-03-15 00:16 - 2018-03-01 14:53 - 000056320 _____ (Microsoft Corporation) C:\WINDOWS\system32\AcSpecfc.dll
2018-03-15 00:16 - 2018-03-01 14:52 - 011923968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieframe.dll
2018-03-15 00:16 - 2018-03-01 14:52 - 006030336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Chakra.dll
2018-03-15 00:16 - 2018-03-01 14:51 - 000034816 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\BasicRender.sys
2018-03-15 00:16 - 2018-03-01 14:50 - 003677184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\jscript9.dll
2018-03-15 00:16 - 2018-03-01 14:50 - 002869760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wininet.dll
2018-03-15 00:16 - 2018-03-01 14:49 - 000529408 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\nwifi.sys
2018-03-15 00:16 - 2018-03-01 14:48 - 000431616 _____ (Microsoft Corporation) C:\WINDOWS\system32\msIso.dll
2018-03-15 00:16 - 2018-03-01 14:47 - 023674368 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtml.dll
2018-03-15 00:16 - 2018-03-01 14:46 - 000770048 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\WdiWiFi.sys
2018-03-15 00:16 - 2018-03-01 14:45 - 000708096 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9diag.dll
2018-03-15 00:16 - 2018-03-01 14:45 - 000594944 _____ (Microsoft Corporation) C:\WINDOWS\system32\vbscript.dll
2018-03-15 00:16 - 2018-03-01 14:44 - 008030720 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Data.Pdf.dll
2018-03-15 00:16 - 2018-03-01 14:43 - 012830208 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieframe.dll
2018-03-15 00:16 - 2018-03-01 14:42 - 002084352 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32kbase.sys
2018-03-15 00:16 - 2018-03-01 14:41 - 008103936 _____ (Microsoft Corporation) C:\WINDOWS\system32\Chakra.dll
2018-03-15 00:16 - 2018-03-01 14:41 - 004745728 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript9.dll
2018-03-15 00:16 - 2018-03-01 14:41 - 003334144 _____ (Microsoft Corporation) C:\WINDOWS\system32\wininet.dll
2018-03-15 00:16 - 2018-03-01 14:41 - 001548288 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsasrv.dll
2018-03-15 00:16 - 2018-03-01 14:41 - 000812032 _____ (Microsoft Corporation) C:\WINDOWS\system32\jscript.dll
2018-03-15 00:16 - 2018-03-01 14:39 - 000899584 _____ (Microsoft Corporation) C:\WINDOWS\system32\samsrv.dll
2018-03-15 00:16 - 2018-03-01 14:38 - 000726016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srv2.sys
2018-03-15 00:16 - 2018-02-22 11:10 - 000285080 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdbus.sys
2018-03-15 00:16 - 2018-02-22 11:08 - 001206688 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvix64.exe
2018-03-15 00:16 - 2018-02-22 11:08 - 001055648 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvax64.exe
2018-03-15 00:16 - 2018-02-22 11:08 - 000571288 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\spaceport.sys
2018-03-15 00:16 - 2018-02-22 11:03 - 000712600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vhdmp.sys
2018-03-15 00:16 - 2018-02-22 11:03 - 000082848 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\volmgr.sys
2018-03-15 00:16 - 2018-02-22 11:02 - 000149400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storahci.sys
2018-03-15 00:16 - 2018-02-22 11:00 - 000187296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dumpsd.sys
2018-03-15 00:16 - 2018-02-22 10:59 - 021351624 _____ (Microsoft Corporation) C:\WINDOWS\system32\shell32.dll
2018-03-15 00:16 - 2018-02-22 10:54 - 000437144 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\USBXHCI.SYS
2018-03-15 00:16 - 2018-02-22 10:51 - 000555424 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\USBHUB3.SYS
2018-03-15 00:16 - 2018-02-22 10:51 - 000045472 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storufs.sys
2018-03-15 00:16 - 2018-02-22 10:50 - 000362904 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\pci.sys
2018-03-15 00:16 - 2018-02-22 09:41 - 020286120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shell32.dll
2018-03-15 00:16 - 2018-02-22 09:31 - 000057344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\UcmUcsi.sys
2018-03-15 00:16 - 2018-02-22 09:26 - 001015296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bthport.sys
2018-03-15 00:15 - 2018-03-02 12:02 - 000037888 _____ C:\WINDOWS\system32\SpectrumSyncClient.dll
2018-03-15 00:15 - 2018-03-02 12:01 - 000640000 _____ (Microsoft Corporation) C:\WINDOWS\system32\HeadTrackerStorage.dll
2018-03-15 00:15 - 2018-03-02 12:00 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Feedback.Analog.dll
2018-03-15 00:15 - 2018-03-02 12:00 - 000248320 _____ (Microsoft Corporation) C:\WINDOWS\system32\svf.dll
2018-03-15 00:15 - 2018-03-02 12:00 - 000230912 _____ (Microsoft Corporation) C:\WINDOWS\system32\HoloShellRuntime.dll
2018-03-15 00:15 - 2018-03-02 11:59 - 000956416 _____ (Microsoft Corporation) C:\WINDOWS\system32\Spectrum.exe
2018-03-15 00:15 - 2018-03-02 05:28 - 000181760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\HoloShellRuntime.dll
2018-03-15 00:15 - 2018-03-01 16:49 - 000389536 _____ (Microsoft Corporation) C:\WINDOWS\system32\invagent.dll
2018-03-15 00:15 - 2018-03-01 16:47 - 000035224 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceCensus.exe
2018-03-15 00:15 - 2018-03-01 16:46 - 002003352 _____ (Microsoft Corporation) C:\WINDOWS\system32\aitstatic.exe
2018-03-15 00:15 - 2018-03-01 16:46 - 000609176 _____ (Microsoft Corporation) C:\WINDOWS\system32\devinv.dll
2018-03-15 00:15 - 2018-03-01 16:46 - 000138144 _____ (Microsoft Corporation) C:\WINDOWS\system32\CompatTelRunner.exe
2018-03-15 00:15 - 2018-03-01 16:45 - 000070040 _____ (Microsoft Corporation) C:\WINDOWS\system32\win32appinventorycsp.dll
2018-03-15 00:15 - 2018-03-01 16:40 - 002514936 _____ (Microsoft Corporation) C:\WINDOWS\system32\KernelBase.dll
2018-03-15 00:15 - 2018-03-01 16:40 - 000461720 _____ (Microsoft Corporation) C:\WINDOWS\system32\dcntel.dll
2018-03-15 00:15 - 2018-03-01 16:40 - 000273304 _____ (Microsoft Corporation) C:\WINDOWS\system32\aepic.dll
2018-03-15 00:15 - 2018-03-01 16:30 - 000540064 _____ (Microsoft Corporation) C:\WINDOWS\system32\pcasvc.dll
2018-03-15 00:15 - 2018-03-01 16:30 - 000264040 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotifyIcon.exe
2018-03-15 00:15 - 2018-03-01 16:29 - 000733592 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\acpi.sys
2018-03-15 00:15 - 2018-03-01 16:27 - 001173576 _____ (Microsoft Corporation) C:\WINDOWS\system32\rpcrt4.dll
2018-03-15 00:15 - 2018-03-01 16:26 - 000170912 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ksecpkg.sys
2018-03-15 00:15 - 2018-03-01 16:25 - 000377752 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\msrpc.sys
2018-03-15 00:15 - 2018-03-01 16:19 - 000710768 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVideoDSP.dll
2018-03-15 00:15 - 2018-03-01 16:17 - 000519152 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthService.exe
2018-03-15 00:15 - 2018-03-01 16:17 - 000408984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\dxgmms1.sys
2018-03-15 00:15 - 2018-03-01 16:14 - 005105664 _____ (Microsoft Corporation) C:\WINDOWS\system32\AuthFWSnapin.dll
2018-03-15 00:15 - 2018-03-01 16:14 - 000356952 _____ (Microsoft Corporation) C:\WINDOWS\system32\wintrust.dll
2018-03-15 00:15 - 2018-03-01 16:14 - 000128928 _____ (Microsoft Corporation) C:\WINDOWS\system32\offlinelsa.dll
2018-03-15 00:15 - 2018-03-01 16:12 - 000677272 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cng.sys
2018-03-15 00:15 - 2018-03-01 16:12 - 000250264 _____ (Microsoft Corporation) C:\WINDOWS\system32\offlinesam.dll
2018-03-15 00:15 - 2018-03-01 16:12 - 000189344 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthAgent.dll
2018-03-15 00:15 - 2018-03-01 16:11 - 000093600 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpudd.dll
2018-03-15 00:15 - 2018-03-01 16:10 - 000075168 _____ (Microsoft Corporation) C:\WINDOWS\system32\SecurityHealthProxyStub.dll
2018-03-15 00:15 - 2018-03-01 16:10 - 000022936 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\isapnp.sys
2018-03-15 00:15 - 2018-03-01 15:51 - 000777904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rpcrt4.dll
2018-03-15 00:15 - 2018-03-01 15:48 - 001930736 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\KernelBase.dll
2018-03-15 00:15 - 2018-03-01 15:39 - 000213400 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aepic.dll
2018-03-15 00:15 - 2018-03-01 15:29 - 000574960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVideoDSP.dll
2018-03-15 00:15 - 2018-03-01 15:28 - 000115096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offlinelsa.dll
2018-03-15 00:15 - 2018-03-01 15:27 - 000284112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wintrust.dll
2018-03-15 00:15 - 2018-03-01 15:27 - 000221592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\offlinesam.dll
2018-03-15 00:15 - 2018-03-01 15:23 - 005105664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AuthFWSnapin.dll
2018-03-15 00:15 - 2018-03-01 15:03 - 000162304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IndexedDbLegacy.dll
2018-03-15 00:15 - 2018-03-01 15:03 - 000065536 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\usoapi.dll
2018-03-15 00:15 - 2018-03-01 15:01 - 006575616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Data.Pdf.dll
2018-03-15 00:15 - 2018-03-01 15:01 - 000155648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EdgeManager.dll
2018-03-15 00:15 - 2018-03-01 15:01 - 000019456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\credssp.dll
2018-03-15 00:15 - 2018-03-01 15:00 - 000098304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TSpkg.dll
2018-03-15 00:15 - 2018-03-01 14:59 - 000220672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MicrosoftAccountWAMExtension.dll
2018-03-15 00:15 - 2018-03-01 14:58 - 004839424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dbgeng.dll
2018-03-15 00:15 - 2018-03-01 14:58 - 000459776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webplatstorageserver.dll
2018-03-15 00:15 - 2018-03-01 14:58 - 000405504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Payments.dll
2018-03-15 00:15 - 2018-03-01 14:58 - 000368128 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\daxexec.dll
2018-03-15 00:15 - 2018-03-01 14:55 - 000346112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\zipfldr.dll
2018-03-15 00:15 - 2018-03-01 14:54 - 003181568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cdp.dll
2018-03-15 00:15 - 2018-03-01 14:54 - 000496128 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatehandlers.dll
2018-03-15 00:15 - 2018-03-01 14:53 - 000863232 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusUpdateHandlers.dll
2018-03-15 00:15 - 2018-03-01 14:53 - 000399872 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotification.exe
2018-03-15 00:15 - 2018-03-01 14:53 - 000246272 _____ (Microsoft Corporation) C:\WINDOWS\system32\MusNotificationUx.exe
2018-03-15 00:15 - 2018-03-01 14:53 - 000206848 _____ (Microsoft Corporation) C:\WINDOWS\system32\IndexedDbLegacy.dll
2018-03-15 00:15 - 2018-03-01 14:53 - 000107520 _____ (Microsoft Corporation) C:\WINDOWS\system32\musdialoghandlers.dll
2018-03-15 00:15 - 2018-03-01 14:53 - 000097792 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatecsp.dll
2018-03-15 00:15 - 2018-03-01 14:53 - 000039424 _____ (Microsoft Corporation) C:\WINDOWS\system32\UsoClient.exe
2018-03-15 00:15 - 2018-03-01 14:51 - 002329088 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVidCtl.dll
2018-03-15 00:15 - 2018-03-01 14:51 - 000201728 _____ (Microsoft Corporation) C:\WINDOWS\system32\EdgeManager.dll
2018-03-15 00:15 - 2018-03-01 14:51 - 000023552 _____ (Microsoft Corporation) C:\WINDOWS\system32\credssp.dll
2018-03-15 00:15 - 2018-03-01 14:50 - 000526336 _____ (Microsoft Corporation) C:\WINDOWS\system32\daxexec.dll
2018-03-15 00:15 - 2018-03-01 14:50 - 000118272 _____ (Microsoft Corporation) C:\WINDOWS\system32\TSpkg.dll
2018-03-15 00:15 - 2018-03-01 14:50 - 000075264 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wcnfs.sys
2018-03-15 00:15 - 2018-03-01 14:49 - 000675328 _____ (Microsoft Corporation) C:\WINDOWS\system32\webplatstorageserver.dll
2018-03-15 00:15 - 2018-03-01 14:49 - 000301056 _____ (Microsoft Corporation) C:\WINDOWS\system32\MicrosoftAccountWAMExtension.dll
2018-03-15 00:15 - 2018-03-01 14:49 - 000066048 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsrv.dll
2018-03-15 00:15 - 2018-03-01 14:48 - 000543232 _____ (Microsoft Corporation) C:\WINDOWS\system32\HolographicExtensions.dll
2018-03-15 00:15 - 2018-03-01 14:47 - 000579584 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Payments.dll
2018-03-15 00:15 - 2018-03-01 14:47 - 000484352 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdpusersvc.dll
2018-03-15 00:15 - 2018-03-01 14:46 - 004051968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msi.dll
2018-03-15 00:15 - 2018-03-01 14:46 - 000026624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msisip.dll
2018-03-15 00:15 - 2018-03-01 14:45 - 000386560 _____ (Microsoft Corporation) C:\WINDOWS\system32\zipfldr.dll
2018-03-15 00:15 - 2018-03-01 14:44 - 005195776 _____ (Microsoft Corporation) C:\WINDOWS\system32\cdp.dll
2018-03-15 00:15 - 2018-03-01 14:42 - 003505664 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVidCtl.dll
2018-03-15 00:15 - 2018-03-01 14:40 - 005833216 _____ (Microsoft Corporation) C:\WINDOWS\system32\dbgeng.dll
2018-03-15 00:15 - 2018-03-01 14:39 - 002222592 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlidsvc.dll
2018-03-15 00:15 - 2018-03-01 14:39 - 002035712 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpcorets.dll
2018-03-15 00:15 - 2018-03-01 14:39 - 000666624 _____ (Microsoft Corporation) C:\WINDOWS\system32\DbgModel.dll
2018-03-15 00:15 - 2018-03-01 14:38 - 000963072 _____ (Microsoft Corporation) C:\WINDOWS\system32\StorSvc.dll
2018-03-15 00:15 - 2018-03-01 14:36 - 004050432 _____ (Microsoft Corporation) C:\WINDOWS\system32\msi.dll
2018-03-15 00:15 - 2018-03-01 14:36 - 000030208 _____ (Microsoft Corporation) C:\WINDOWS\system32\msisip.dll
2018-03-15 00:15 - 2018-03-01 14:35 - 000568320 _____ (Microsoft Corporation) C:\WINDOWS\system32\msra.exe
2018-03-15 00:15 - 2018-03-01 14:35 - 000128000 _____ (Microsoft Corporation) C:\WINDOWS\system32\racpldlg.dll
2018-03-15 00:15 - 2018-03-01 14:35 - 000050176 _____ (Microsoft Corporation) C:\WINDOWS\system32\pcalua.exe
2018-03-15 00:15 - 2018-02-22 11:23 - 001092016 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.efi
2018-03-15 00:15 - 2018-02-22 11:23 - 000924648 _____ (Microsoft Corporation) C:\WINDOWS\system32\winresume.exe
2018-03-15 00:15 - 2018-02-22 11:13 - 000279456 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\msiscsi.sys
2018-03-15 00:15 - 2018-02-22 11:13 - 000077216 _____ (Microsoft Corporation) C:\WINDOWS\system32\hvloader.dll
2018-03-15 00:15 - 2018-02-22 11:11 - 000109984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbus.sys
2018-03-15 00:15 - 2018-02-22 11:07 - 001415296 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.efi
2018-03-15 00:15 - 2018-02-22 11:07 - 001209248 _____ (Microsoft Corporation) C:\WINDOWS\system32\winload.exe
2018-03-15 00:15 - 2018-02-22 11:07 - 000194456 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ataport.sys
2018-03-15 00:15 - 2018-02-22 10:52 - 000103328 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\stornvme.sys
2018-03-15 00:15 - 2018-02-22 10:51 - 000097176 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\sdstor.sys
2018-03-15 00:15 - 2018-02-22 10:50 - 000229272 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tpm.sys
2018-03-15 00:15 - 2018-02-22 09:30 - 000192512 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netvsc.sys
2018-03-15 00:15 - 2018-02-22 09:30 - 000046080 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hidparse.sys
2018-03-15 00:15 - 2018-02-22 09:30 - 000043008 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\RfxVmt.sys
2018-03-15 00:15 - 2018-02-22 09:27 - 001282048 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVPXENC.dll
2018-03-15 00:15 - 2018-02-22 09:26 - 000441344 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\HdAudio.sys
2018-03-15 00:15 - 2018-02-22 09:25 - 000086528 _____ (Microsoft Corporation) C:\WINDOWS\system32\cldapi.dll
2018-03-15 00:15 - 2018-02-22 09:16 - 001286144 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVPXENC.dll
2018-03-15 00:15 - 2018-02-22 09:12 - 000076288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\cldapi.dll
2018-03-14 22:02 - 2018-03-03 06:09 - 000834552 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerApp.exe
2018-03-14 22:02 - 2018-03-03 06:09 - 000179704 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\FlashPlayerCPLApp.cpl
2018-03-14 21:37 - 2018-03-18 09:56 - 000000000 ____D C:\Program Files (x86)\Zemana AntiMalware
2018-03-14 21:37 - 2018-03-14 21:37 - 006625600 _____ (Zemana Ltd. ) C:\Users\ASUS\Downloads\Zemana.AntiMalware.Setup.exe
2018-03-14 21:33 - 2018-03-14 21:33 - 000001234 _____ C:\Users\Public\Desktop\360 Total Security.lnk
2018-03-14 21:33 - 2018-03-13 20:15 - 000339456 _____ (360.cn) C:\WINDOWS\system32\Drivers\360Box64.sys
2018-03-14 21:30 - 2018-03-14 21:33 - 000003048 _____ C:\WINDOWS\System32\Tasks\CCleaner Update
2018-03-14 21:28 - 2018-03-14 21:28 - 000004556 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player NPAPI Notifier
2018-03-14 19:36 - 2018-03-14 19:36 - 000002018 _____ C:\Users\ASUS\Desktop\ZHPFix.txt
2018-03-14 19:33 - 2018-03-14 19:34 - 000000000 ____D C:\Users\ASUS\Downloads\geek (3)
2018-03-14 19:33 - 2018-02-21 17:29 - 006086080 _____ (Geek Unіnstaller) C:\Users\ASUS\Desktop\geek.exe
2018-03-14 19:28 - 2018-03-14 19:28 - 000000000 ____D C:\Users\ASUS\Desktop\Quarantine
2018-03-14 19:26 - 2018-03-14 19:26 - 003061760 _____ (Nicolas Coolman) C:\Users\ASUS\Desktop\ZHPFix.exe
2018-03-14 19:24 - 2018-03-14 19:24 - 001274216 _____ (Microsoft Corporation) C:\Users\ASUS\Downloads\NetFxRepairTool.exe
2018-03-13 21:01 - 2018-03-15 21:57 - 004883368 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2018-03-13 19:40 - 2018-03-13 19:41 - 000461442 _____ C:\Users\ASUS\Desktop\ZHPDiag3.txt
2018-03-13 17:45 - 2018-03-13 17:45 - 000296736 _____ C:\Users\ASUS\Desktop\ZHPDiag.html
2018-03-13 17:45 - 2018-03-13 17:45 - 000214430 _____ C:\Users\ASUS\Desktop\ZHPDiag.txt
2018-03-13 17:13 - 2018-03-18 09:57 - 000000000 ____D C:\Users\ASUS\Desktop\FRST-OlderVersion
2018-03-12 19:01 - 2018-03-12 19:01 - 000002156 _____ C:\Users\ASUS\Desktop\Cleanup.lnk
2018-03-12 18:51 - 2018-03-18 09:51 - 000000000 ____D C:\Users\ASUS\AppData\LocalLow\360WD
2018-03-12 18:51 - 2018-03-14 21:43 - 000000000 _RSHD C:\360SANDBOX
2018-03-12 18:51 - 2018-03-14 21:33 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\360 Security Center
2018-03-12 18:51 - 2018-03-14 19:24 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\360safe
2018-03-12 18:51 - 2018-03-12 18:52 - 000000000 ____D C:\ProgramData\360safe
2018-03-12 18:51 - 2018-03-12 18:51 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\360 Security Center
2018-03-12 18:51 - 2018-03-12 18:51 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\360TotalSecurity
2018-03-12 18:51 - 2018-03-12 18:51 - 000000000 ____D C:\ProgramData\360TotalSecurity
2018-03-12 18:51 - 2018-03-01 18:37 - 000442544 _____ (360.cn) C:\WINDOWS\system32\Drivers\360FsFlt.sys
2018-03-12 18:51 - 2018-03-01 18:37 - 000210064 _____ (360.cn) C:\WINDOWS\system32\Drivers\BAPIDRV64.sys
2018-03-12 18:51 - 2018-03-01 18:37 - 000192176 _____ (360.cn) C:\WINDOWS\system32\Drivers\360AntiHacker64.sys
2018-03-12 18:51 - 2018-03-01 18:37 - 000096424 _____ (360.cn) C:\WINDOWS\system32\Drivers\360netmon.sys
2018-03-12 18:51 - 2018-03-01 18:37 - 000095232 _____ (360.cn) C:\WINDOWS\system32\Drivers\360AvFlt.sys.tmp
2018-03-12 18:51 - 2018-03-01 18:37 - 000057848 _____ (360.cn) C:\WINDOWS\system32\Drivers\360Camera64.sys
2018-03-12 18:48 - 2018-03-12 18:48 - 075346024 _____ C:\Users\ASUS\Downloads\360TS_Setup.exe
2018-03-12 18:47 - 2018-03-12 18:48 - 001497696 _____ (QIHU 360 SOFTWARE CO. LIMITED) C:\Users\ASUS\Downloads\360TS_Setup_Mini.exe
2018-03-12 17:48 - 2018-03-12 17:48 - 000001920 _____ C:\Users\Public\Desktop\Malwarebytes.lnk
2018-03-12 17:48 - 2018-03-12 17:48 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes
2018-03-12 17:48 - 2018-03-12 17:48 - 000000000 ____D C:\ProgramData\Malwarebytes
2018-03-12 17:48 - 2018-01-18 08:03 - 000076200 _____ C:\WINDOWS\system32\Drivers\mbae64.sys
2018-03-12 17:46 - 2018-03-14 21:24 - 000002920 _____ C:\WINDOWS\System32\Tasks\OneDrive Standalone Update Task-S-1-5-21-2746278279-2939389576-4119914495-1001
2018-03-12 17:46 - 2018-03-12 17:46 - 000002364 _____ C:\Users\ASUS\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2018-03-11 19:53 - 2018-03-11 19:53 - 000000402 _____ C:\Users\ASUS\Desktop\ROClientEnhancement-master.zip
2018-03-11 19:24 - 2018-03-11 19:26 - 000242326 _____ C:\Users\ASUS\Desktop\¸ùÅ©_h_³².spr
2018-03-11 18:52 - 2018-03-11 19:26 - 000048276 _____ C:\Users\ASUS\Desktop\¸ùÅ©_h_³².act
2018-03-11 18:46 - 2018-03-11 18:46 - 000000000 ____D C:\Users\ASUS\Desktop\stateicon
2018-03-11 09:11 - 2018-03-11 19:25 - 000000000 ____D C:\Users\ASUS\Desktop\Original Sura Sprite
2018-03-11 09:11 - 2018-03-11 19:08 - 000000000 ____D C:\Users\ASUS\Desktop\Edited Sura Sprite Color
2018-03-10 21:41 - 2018-02-10 15:15 - 001954048 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntdll.dll
2018-03-10 21:41 - 2018-02-10 15:15 - 000471968 _____ (Microsoft Corporation) C:\WINDOWS\system32\hal.dll
2018-03-10 21:41 - 2018-02-10 15:13 - 000373656 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\clfs.sys
2018-03-10 21:41 - 2018-02-10 15:09 - 000755712 _____ (Microsoft Corporation) C:\WINDOWS\system32\evr.dll
2018-03-10 21:41 - 2018-02-10 15:08 - 003010248 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d11.dll
2018-03-10 21:41 - 2018-02-10 15:06 - 000494488 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mrxsmb.sys
2018-03-10 21:41 - 2018-02-10 15:04 - 000603920 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiodg.exe
2018-03-10 21:41 - 2018-02-10 14:21 - 001615712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntdll.dll
2018-03-10 21:41 - 2018-02-10 14:17 - 000597160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dnsapi.dll
2018-03-10 21:41 - 2018-02-10 14:06 - 000982528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioSes.dll
2018-03-10 21:41 - 2018-02-10 14:05 - 001246432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AudioEng.dll
2018-03-10 21:41 - 2018-02-10 14:05 - 001149272 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsvr.dll
2018-03-10 21:41 - 2018-02-10 14:05 - 000662208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\evr.dll
2018-03-10 21:41 - 2018-02-10 13:49 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\system32\AcGenral.dll
2018-03-10 21:41 - 2018-02-10 13:47 - 017160704 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.dll
2018-03-10 21:41 - 2018-02-10 13:47 - 013704192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Xaml.dll
2018-03-10 21:41 - 2018-02-10 13:46 - 002393600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AcGenral.dll
2018-03-10 21:41 - 2018-02-10 13:46 - 000169472 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhosdeployment.dll
2018-03-10 21:41 - 2018-02-10 13:46 - 000018432 _____ (Microsoft Corporation) C:\WINDOWS\system32\PCShellCommonProxyStub.dll
2018-03-10 21:41 - 2018-02-10 13:44 - 001498112 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebRuntimeManager.dll
2018-03-10 21:41 - 2018-02-10 13:43 - 000394752 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ks.sys
2018-03-10 21:41 - 2018-02-10 13:42 - 000236032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\FSClient.dll
2018-03-10 21:41 - 2018-02-10 13:41 - 000815616 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieproxy.dll
2018-03-10 21:41 - 2018-02-10 13:41 - 000365568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieproxy.dll
2018-03-10 21:41 - 2018-02-10 13:40 - 001312256 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d11_3SDKLayers.dll
2018-03-10 21:41 - 2018-02-10 13:40 - 001064448 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d11_3SDKLayers.dll
2018-03-10 21:41 - 2018-02-10 13:38 - 000462336 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuuhext.dll
2018-03-10 21:41 - 2018-02-10 13:37 - 001488384 _____ (Microsoft Corporation) C:\WINDOWS\system32\audiosrv.dll
2018-03-10 21:41 - 2018-02-10 13:36 - 002464768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dwmcore.dll
2018-03-10 21:41 - 2018-02-10 13:36 - 000685056 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEndpointBuilder.dll
2018-03-10 21:41 - 2018-02-10 13:34 - 004249600 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MFMediaEngine.dll
2018-03-10 21:41 - 2018-01-01 21:45 - 000398744 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fltMgr.sys
2018-03-10 21:41 - 2018-01-01 21:39 - 000902416 _____ (Microsoft Corporation) C:\WINDOWS\system32\winhttp.dll
2018-03-10 21:41 - 2018-01-01 21:36 - 000166296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\partmgr.sys
2018-03-10 21:41 - 2018-01-01 21:26 - 000428952 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\rdbss.sys
2018-03-10 21:41 - 2018-01-01 20:34 - 000703568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winhttp.dll
2018-03-10 21:41 - 2018-01-01 20:18 - 000374784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\FirewallAPI.dll
2018-03-10 21:41 - 2018-01-01 20:18 - 000261632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\actxprxy.dll
2018-03-10 21:41 - 2018-01-01 20:17 - 000542208 _____ (Microsoft Corporation) C:\WINDOWS\system32\FirewallAPI.dll
2018-03-10 21:41 - 2018-01-01 20:13 - 003121664 _____ (Microsoft Corporation) C:\WINDOWS\system32\Microsoft.Bluetooth.Profiles.Gatt.dll
2018-03-10 21:41 - 2018-01-01 20:12 - 002633216 _____ (Microsoft Corporation) C:\WINDOWS\system32\diagtrack.dll
2018-03-10 21:41 - 2018-01-01 20:08 - 000424448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\srv.sys
2018-03-10 21:40 - 2018-02-10 15:18 - 000319864 _____ (Microsoft Corporation) C:\WINDOWS\system32\wow64.dll
2018-03-10 21:40 - 2018-02-10 15:16 - 002406456 _____ (Microsoft Corporation) C:\WINDOWS\system32\msmpeg2vdec.dll
2018-03-10 21:40 - 2018-02-10 15:16 - 000739696 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsapi.dll
2018-03-10 21:40 - 2018-02-10 15:14 - 004504464 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppsvc.exe
2018-03-10 21:40 - 2018-02-10 15:14 - 002395032 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ntfs.sys
2018-03-10 21:40 - 2018-02-10 15:14 - 001002592 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase.dll
2018-03-10 21:40 - 2018-02-10 15:12 - 001277848 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndis.sys
2018-03-10 21:40 - 2018-02-10 15:11 - 000711432 _____ (Microsoft Corporation) C:\WINDOWS\system32\ci.dll
2018-03-10 21:40 - 2018-02-10 15:10 - 002447768 _____ (Microsoft Corporation) C:\WINDOWS\system32\UpdateAgent.dll
2018-03-10 21:40 - 2018-02-10 15:10 - 000614160 _____ (Microsoft Corporation) C:\WINDOWS\system32\StateRepository.Core.dll
2018-03-10 21:40 - 2018-02-10 15:09 - 003904296 _____ (Microsoft Corporation) C:\WINDOWS\explorer.exe
2018-03-10 21:40 - 2018-02-10 15:09 - 000525208 _____ (Microsoft Corporation) C:\WINDOWS\system32\wimserv.exe
2018-03-10 21:40 - 2018-02-10 15:08 - 000048112 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuauclt.exe
2018-03-10 21:40 - 2018-02-10 15:07 - 004506576 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfcore.dll
2018-03-10 21:40 - 2018-02-10 15:07 - 000705944 _____ (Microsoft Corporation) C:\WINDOWS\system32\wimgapi.dll
2018-03-10 21:40 - 2018-02-10 15:07 - 000436632 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHostCommon.dll
2018-03-10 21:40 - 2018-02-10 15:06 - 004486904 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepository.dll
2018-03-10 21:40 - 2018-02-10 15:06 - 000819096 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVClient.exe
2018-03-10 21:40 - 2018-02-10 15:04 - 006791984 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001778584 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntVirtualization.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001628056 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVIntegration.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001426672 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioEng.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001254144 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsvr.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 001170008 _____ (Microsoft Corporation) C:\WINDOWS\system32\AudioSes.dll
2018-03-10 21:40 - 2018-02-10 15:04 - 000374032 _____ (Microsoft Corporation) C:\WINDOWS\system32\vac.exe
2018-03-10 21:40 - 2018-02-10 15:03 - 001619808 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppobjs.dll
2018-03-10 21:40 - 2018-02-10 15:03 - 000722616 _____ (Microsoft Corporation) C:\WINDOWS\system32\sppwinob.dll
2018-03-10 21:40 - 2018-02-10 15:03 - 000404888 _____ (Microsoft Corporation) C:\WINDOWS\system32\CloudExperienceHost.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 002220952 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntSubsystems64.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 001420696 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntSubsystemController.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000831384 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVOrchestration.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000813976 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVEntStreamingManager.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000744856 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVReporting.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000670104 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVCatalog.dll
2018-03-10 21:40 - 2018-02-10 15:02 - 000645528 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVPublishing.dll
2018-03-10 21:40 - 2018-02-10 14:17 - 002255112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msmpeg2vdec.dll
2018-03-10 21:40 - 2018-02-10 14:15 - 001145624 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ucrtbase.dll
2018-03-10 21:40 - 2018-02-10 14:09 - 003485392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\explorer.exe
2018-03-10 21:40 - 2018-02-10 14:09 - 002338776 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d11.dll
2018-03-10 21:40 - 2018-02-10 14:09 - 000354200 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudExperienceHostCommon.dll
2018-03-10 21:40 - 2018-02-10 14:08 - 000592792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wimgapi.dll
2018-03-10 21:40 - 2018-02-10 14:07 - 000527864 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\StateRepository.Core.dll
2018-03-10 21:40 - 2018-02-10 14:06 - 006014688 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.dll
2018-03-10 21:40 - 2018-02-10 14:06 - 004670728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfcore.dll
2018-03-10 21:40 - 2018-02-10 14:04 - 001491352 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppVEntSubsystems32.dll
2018-03-10 21:40 - 2018-02-10 13:50 - 001313792 _____ (Microsoft Corporation) C:\WINDOWS\system32\InstallService.dll
2018-03-10 21:40 - 2018-02-10 13:48 - 002890240 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Xaml.Resources.dll
2018-03-10 21:40 - 2018-02-10 13:46 - 001008640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InstallService.dll
2018-03-10 21:40 - 2018-02-10 13:45 - 007545344 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.dll
2018-03-10 21:40 - 2018-02-10 13:45 - 000115200 _____ (Microsoft Corporation) C:\WINDOWS\system32\updatepolicy.dll
2018-03-10 21:40 - 2018-02-10 13:43 - 006466560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinui.dll
2018-03-10 21:40 - 2018-02-10 13:43 - 000570368 _____ (Microsoft Corporation) C:\WINDOWS\system32\TileDataRepository.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 001425408 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettings.Handlers.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 000813568 _____ (Microsoft Corporation) C:\WINDOWS\system32\bisrv.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 000403968 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpAXHolder.dll
2018-03-10 21:40 - 2018-02-10 13:42 - 000098304 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\updatepolicy.dll
2018-03-10 21:40 - 2018-02-10 13:41 - 001495552 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.desktop.dll
2018-03-10 21:40 - 2018-02-10 13:41 - 000721408 _____ (Microsoft Corporation) C:\WINDOWS\system32\LogonController.dll
2018-03-10 21:40 - 2018-02-10 13:41 - 000451072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TileDataRepository.dll
2018-03-10 21:40 - 2018-02-10 13:40 - 004498432 _____ (Microsoft Corporation) C:\WINDOWS\system32\xpsrchvw.exe
2018-03-10 21:40 - 2018-02-10 13:40 - 004113408 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_nt.dll
2018-03-10 21:40 - 2018-02-10 13:40 - 003405824 _____ (Microsoft Corporation) C:\WINDOWS\system32\tquery.dll
2018-03-10 21:40 - 2018-02-10 13:40 - 000601088 _____ (Microsoft Corporation) C:\WINDOWS\system32\ipnathlp.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 004592640 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsThresholdAdminFlowUI.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 002976256 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinui.pcshell.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 002741248 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssrch.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 002209280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentExtensions.onecore.dll
2018-03-10 21:40 - 2018-02-10 13:39 - 001669120 _____ (Microsoft Corporation) C:\WINDOWS\system32\Wpc.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 004815360 _____ (Microsoft Corporation) C:\WINDOWS\system32\MFMediaEngine.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 003169280 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentServer.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 002857984 _____ (Microsoft Corporation) C:\WINDOWS\system32\dwmcore.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 002771968 _____ (Microsoft Corporation) C:\WINDOWS\system32\d3d12SDKLayers.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 001353728 _____ (Microsoft Corporation) C:\WINDOWS\system32\usercpl.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 001167360 _____ (Microsoft Corporation) C:\WINDOWS\system32\ISM.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 001057792 _____ (Microsoft Corporation) C:\WINDOWS\system32\comdlg32.dll
2018-03-10 21:40 - 2018-02-10 13:38 - 000556544 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockAppBroker.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 004772352 _____ (Microsoft Corporation) C:\WINDOWS\system32\ExplorerFrame.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 003578368 _____ (Microsoft Corporation) C:\WINDOWS\system32\SRH.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 002784256 _____ (Microsoft Corporation) C:\WINDOWS\system32\wuaueng.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 001822208 _____ (Microsoft Corporation) C:\WINDOWS\system32\urlmon.dll
2018-03-10 21:40 - 2018-02-10 13:37 - 000456704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LockAppBroker.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 002859520 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SRH.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 001739264 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Immersive.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 001559552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\urlmon.dll
2018-03-10 21:40 - 2018-02-10 13:36 - 001230848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\usercpl.dll
2018-03-10 21:40 - 2018-02-10 13:35 - 004384768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ExplorerFrame.dll
2018-03-10 21:40 - 2018-02-10 13:35 - 002216960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\d3d12SDKLayers.dll
2018-03-10 21:40 - 2018-02-10 13:35 - 000842240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\comdlg32.dll
2018-03-10 21:40 - 2018-02-10 13:34 - 002983936 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcndmgr.dll
2018-03-10 21:40 - 2018-02-10 13:33 - 001570816 _____ (Microsoft Corporation) C:\WINDOWS\system32\RecoveryDrive.exe
2018-03-10 21:40 - 2018-02-10 13:33 - 001509888 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Immersive.dll
2018-03-10 21:40 - 2018-02-09 12:35 - 004959688 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmpltfm.dll
2018-03-10 21:40 - 2018-02-02 12:36 - 003903944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmpltfm.dll
2018-03-10 21:40 - 2018-01-01 21:50 - 005905752 _____ (Microsoft Corporation) C:\WINDOWS\system32\StartTileData.dll
2018-03-10 21:40 - 2018-01-01 21:50 - 000780464 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontdrvhost.exe
2018-03-10 21:40 - 2018-01-01 21:42 - 000184984 _____ (Microsoft Corporation) C:\WINDOWS\system32\sspicli.dll
2018-03-10 21:40 - 2018-01-01 21:41 - 000559512 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\storport.sys
2018-03-10 21:40 - 2018-01-01 21:39 - 000129432 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\hvsocket.sys
2018-03-10 21:40 - 2018-01-01 21:25 - 000615768 _____ (Microsoft Corporation) C:\WINDOWS\system32\services.exe
2018-03-10 21:40 - 2018-01-01 21:03 - 000650328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontdrvhost.exe
2018-03-10 21:40 - 2018-01-01 21:03 - 000123512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sspicli.dll
2018-03-10 21:40 - 2018-01-01 20:25 - 000097792 _____ C:\WINDOWS\system32\runexehelper.exe
2018-03-10 21:40 - 2018-01-01 20:23 - 000250368 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxAllUserStore.dll
2018-03-10 21:40 - 2018-01-01 20:20 - 000204288 _____ (Microsoft Corporation) C:\WINDOWS\system32\provisioningcsp.dll
2018-03-10 21:40 - 2018-01-01 20:19 - 000461312 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansec.dll
2018-03-10 21:40 - 2018-01-01 20:19 - 000334848 _____ (Microsoft Corporation) C:\WINDOWS\system32\dusmsvc.dll
2018-03-10 21:40 - 2018-01-01 20:19 - 000073216 _____ (Microsoft Corporation) C:\WINDOWS\system32\provtool.exe
2018-03-10 21:40 - 2018-01-01 20:18 - 000432640 _____ (Microsoft Corporation) C:\WINDOWS\system32\provengine.dll
2018-03-10 21:40 - 2018-01-01 20:18 - 000427008 _____ (Microsoft Corporation) C:\WINDOWS\system32\provhandlers.dll
2018-03-10 21:40 - 2018-01-01 20:15 - 012687872 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wmp.dll
2018-03-10 21:40 - 2018-01-01 20:15 - 000588800 _____ (Microsoft Corporation) C:\WINDOWS\system32\actxprxy.dll
2018-03-10 21:40 - 2018-01-01 20:13 - 013657600 _____ (Microsoft Corporation) C:\WINDOWS\system32\wmp.dll
2018-03-10 21:40 - 2018-01-01 20:12 - 001424896 _____ (Microsoft Corporation) C:\WINDOWS\system32\wwansvc.dll
2018-03-10 21:40 - 2018-01-01 20:11 - 000880640 _____ (Microsoft Corporation) C:\WINDOWS\system32\schedsvc.dll
2018-03-10 21:40 - 2018-01-01 20:09 - 000925184 _____ (Microsoft Corporation) C:\WINDOWS\system32\MPSSVC.dll
2018-03-10 21:40 - 2018-01-01 20:05 - 002510848 _____ (Microsoft Corporation) C:\WINDOWS\system32\ResetEngine.dll
2018-03-10 21:40 - 2018-01-01 20:05 - 001160704 _____ (Microsoft Corporation) C:\WINDOWS\system32\reseteng.dll
2018-03-10 21:39 - 2018-02-10 15:21 - 000479912 _____ (Microsoft Corporation) C:\WINDOWS\system32\ucrtbase_enclave.dll
2018-03-10 21:39 - 2018-02-10 15:20 - 000599448 _____ (Microsoft Corporation) C:\WINDOWS\system32\securekernel.exe
2018-03-10 21:39 - 2018-02-10 15:19 - 001133888 _____ (Microsoft Corporation) C:\WINDOWS\system32\MSVP9DEC.dll
2018-03-10 21:39 - 2018-02-10 15:18 - 001193192 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryPS.dll
2018-03-10 21:39 - 2018-02-10 15:18 - 000098272 _____ (Microsoft Corporation) C:\WINDOWS\system32\FsIso.exe
2018-03-10 21:39 - 2018-02-10 15:18 - 000022400 _____ (Microsoft Corporation) C:\WINDOWS\system32\wow64cpu.dll
2018-03-10 21:39 - 2018-02-10 15:13 - 001416392 _____ (Microsoft Corporation) C:\WINDOWS\system32\D3D12.dll
2018-03-10 21:39 - 2018-02-10 15:13 - 000535960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netio.sys
2018-03-10 21:39 - 2018-02-10 15:12 - 004537040 _____ (Microsoft Corporation) C:\WINDOWS\system32\setupapi.dll
2018-03-10 21:39 - 2018-02-10 15:12 - 001313016 _____ (Microsoft Corporation) C:\WINDOWS\system32\Taskmgr.exe
2018-03-10 21:39 - 2018-02-10 15:11 - 001029528 _____ (Microsoft Corporation) C:\WINDOWS\system32\efscore.dll
2018-03-10 21:39 - 2018-02-10 15:10 - 000246168 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserbroker.dll
2018-03-10 21:39 - 2018-02-10 15:10 - 000154520 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryClient.dll
2018-03-10 21:39 - 2018-02-10 15:09 - 000491264 _____ (Microsoft Corporation) C:\WINDOWS\system32\policymanager.dll
2018-03-10 21:39 - 2018-02-10 15:08 - 000687552 _____ (Microsoft Corporation) C:\WINDOWS\system32\StructuredQuery.dll
2018-03-10 21:39 - 2018-02-10 15:08 - 000398824 _____ (Microsoft Corporation) C:\WINDOWS\system32\SystemSettingsAdminFlows.exe
2018-03-10 21:39 - 2018-02-10 15:08 - 000096200 _____ (Microsoft Corporation) C:\WINDOWS\system32\winbrand.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000824896 _____ (Microsoft Corporation) C:\WINDOWS\system32\ClipSVC.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000727448 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fvevol.sys
2018-03-10 21:39 - 2018-02-10 15:06 - 000594048 _____ (Microsoft Corporation) C:\WINDOWS\system32\mf.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000100248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryBroker.dll
2018-03-10 21:39 - 2018-02-10 15:06 - 000087384 _____ (Microsoft Corporation) C:\WINDOWS\system32\remoteaudioendpoint.dll
2018-03-10 21:39 - 2018-02-10 15:05 - 000688064 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppXDeploymentClient.dll
2018-03-10 21:39 - 2018-02-10 15:05 - 000413888 _____ (Microsoft Corporation) C:\WINDOWS\system32\AUDIOKSE.dll
2018-03-10 21:39 - 2018-02-10 15:05 - 000070856 _____ (Microsoft Corporation) C:\WINDOWS\system32\wldp.dll
2018-03-10 21:39 - 2018-02-10 15:04 - 001430760 _____ (Microsoft Corporation) C:\WINDOWS\system32\WpcMon.exe
2018-03-10 21:39 - 2018-02-10 15:04 - 000614296 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\afd.sys
2018-03-10 21:39 - 2018-02-10 15:04 - 000339872 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkBindingEngineMigPlugin.dll
2018-03-10 21:39 - 2018-02-10 15:04 - 000260896 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfps.dll
2018-03-10 21:39 - 2018-02-10 15:04 - 000212880 _____ (Microsoft Corporation) C:\WINDOWS\system32\mfsensorgroup.dll
2018-03-10 21:39 - 2018-02-10 15:03 - 000849304 _____ (Microsoft Corporation) C:\WINDOWS\system32\LicensingWinRT.dll
2018-03-10 21:39 - 2018-02-10 15:03 - 000706600 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeManagerObj.dll
2018-03-10 21:39 - 2018-02-10 15:03 - 000098712 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeviceReactivation.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 002773400 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\tcpip.sys
2018-03-10 21:39 - 2018-02-10 15:02 - 001103768 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\http.sys
2018-03-10 21:39 - 2018-02-10 15:02 - 000628632 _____ (Microsoft Corporation) C:\WINDOWS\system32\msvcp_win.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 000617304 _____ (Microsoft Corporation) C:\WINDOWS\system32\TextInputFramework.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 000495000 _____ (Microsoft Corporation) C:\WINDOWS\system32\TransportDSA.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 000397720 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVScripting.dll
2018-03-10 21:39 - 2018-02-10 15:02 - 000231320 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVShNotify.exe
2018-03-10 21:39 - 2018-02-10 15:02 - 000040352 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppVClientPS.dll
2018-03-10 21:39 - 2018-02-10 14:18 - 001384288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\MSVP9DEC.dll
2018-03-10 21:39 - 2018-02-10 14:18 - 000022424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hvsicontainerservice.dll
2018-03-10 21:39 - 2018-02-10 14:17 - 000542856 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryPS.dll
2018-03-10 21:39 - 2018-02-10 14:12 - 004382032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setupapi.dll
2018-03-10 21:39 - 2018-02-10 14:11 - 001250528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Taskmgr.exe
2018-03-10 21:39 - 2018-02-10 14:10 - 000422592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\policymanager.dll
2018-03-10 21:39 - 2018-02-10 14:09 - 001123456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\D3D12.dll
2018-03-10 21:39 - 2018-02-10 14:09 - 000559976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\StructuredQuery.dll
2018-03-10 21:39 - 2018-02-10 14:08 - 003980720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepository.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000543920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppXDeploymentClient.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000123808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryClient.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000089504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryBroker.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000083216 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winbrand.dll
2018-03-10 21:39 - 2018-02-10 14:07 - 000061024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wldp.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000718232 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\LicensingWinRT.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000654456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EditionUpgradeManagerObj.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000551672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mf.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000386424 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AUDIOKSE.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000193248 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfsensorgroup.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000129184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mfps.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000079256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DeviceReactivation.dll
2018-03-10 21:39 - 2018-02-10 14:05 - 000077552 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CloudNotifications.exe
2018-03-10 21:39 - 2018-02-10 14:05 - 000074992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\remoteaudioendpoint.dll
2018-03-10 21:39 - 2018-02-10 14:04 - 000027032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppVClientPS.dll
2018-03-10 21:39 - 2018-02-10 14:03 - 000505160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msvcp_win.dll
2018-03-10 21:39 - 2018-02-10 13:50 - 000849920 _____ (Microsoft Corporation) C:\WINDOWS\system32\uDWM.dll
2018-03-10 21:39 - 2018-02-10 13:49 - 001664512 _____ (Microsoft Corporation) C:\WINDOWS\system32\GdiPlus.dll
2018-03-10 21:39 - 2018-02-10 13:49 - 000385536 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\cldflt.sys
2018-03-10 21:39 - 2018-02-10 13:49 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\system32\convertvhd.exe
2018-03-10 21:39 - 2018-02-10 13:48 - 000033280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\mskssrv.sys
2018-03-10 21:39 - 2018-02-10 13:48 - 000025088 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAppMgmtClient.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000331264 _____ (Microsoft Corporation) C:\WINDOWS\system32\browserexport.exe
2018-03-10 21:39 - 2018-02-10 13:47 - 000201216 _____ (Microsoft Corporation) C:\WINDOWS\system32\SharedPCCSP.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000143872 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssprxy.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000055808 _____ (Microsoft Corporation) C:\WINDOWS\system32\virtdisk.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000043520 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcimage.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000033792 _____ (Microsoft Corporation) C:\WINDOWS\system32\wups2.dll
2018-03-10 21:39 - 2018-02-10 13:47 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\system32\tzres.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 001470976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\GdiPlus.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000225792 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\winnat.sys
2018-03-10 21:39 - 2018-02-10 13:46 - 000199168 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDeviceRegistration.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000173568 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.StateRepositoryUpgrade.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000135680 _____ (Microsoft Corporation) C:\WINDOWS\system32\shsetup.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000082432 _____ (Microsoft Corporation) C:\WINDOWS\system32\MshtmlDac.dll
2018-03-10 21:39 - 2018-02-10 13:46 - 000026112 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\setup16.exe
2018-03-10 21:39 - 2018-02-10 13:46 - 000004608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\user.exe
2018-03-10 21:39 - 2018-02-10 13:45 - 000306688 _____ (Microsoft Corporation) C:\WINDOWS\system32\FSClient.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000288768 _____ (Microsoft Corporation) C:\WINDOWS\system32\authz.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000288256 _____ (Microsoft Corporation) C:\WINDOWS\system32\winsku.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\mshtmled.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000079872 _____ (Microsoft Corporation) C:\WINDOWS\system32\nlaapi.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000043008 _____ (Microsoft Corporation) C:\WINDOWS\system32\nshhttp.dll
2018-03-10 21:39 - 2018-02-10 13:45 - 000016384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EnterpriseAppMgmtClient.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000800768 _____ (Microsoft Corporation) C:\WINDOWS\system32\Magnify.exe
2018-03-10 21:39 - 2018-02-10 13:44 - 000503296 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingsHandlers_User.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000427008 _____ (Microsoft Corporation) C:\WINDOWS\system32\OneCoreCommonProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000388608 _____ (Microsoft Corporation) C:\WINDOWS\system32\Search.ProtocolHandler.MAPI2.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000336896 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppLockerCSP.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000302592 _____ (Microsoft Corporation) C:\WINDOWS\system32\EnterpriseAppMgmtSvc.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000276992 _____ (Microsoft Corporation) C:\WINDOWS\system32\shutdownux.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000276480 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtrans.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000208384 _____ (Microsoft Corporation) C:\WINDOWS\system32\tetheringservice.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000059392 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssprxy.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000048640 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\virtdisk.dll
2018-03-10 21:39 - 2018-02-10 13:44 - 000002560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tzres.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 003756032 _____ (Microsoft Corporation) C:\WINDOWS\system32\bootux.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000580608 _____ (Microsoft Corporation) C:\WINDOWS\system32\webio.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000566272 _____ (Microsoft Corporation) C:\WINDOWS\system32\DevicePairing.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000456704 _____ (Microsoft Corporation) C:\WINDOWS\system32\dxtmsft.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000391168 _____ (Microsoft Corporation) C:\WINDOWS\system32\iedkcs32.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000311808 _____ (Microsoft Corporation) C:\WINDOWS\system32\DeveloperOptionsSettingsHandlers.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000268288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtrans.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000247296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\winsku.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000181248 _____ (Microsoft Corporation) C:\WINDOWS\system32\twext.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000150528 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppManagementConfiguration.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000147456 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.StateRepositoryUpgrade.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000110080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\shsetup.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000084480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppCapture.dll
2018-03-10 21:39 - 2018-02-10 13:43 - 000013312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PCShellCommonProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 001216000 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Networking.Vpn.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 001113600 _____ (Microsoft Corporation) C:\WINDOWS\system32\bcastdvr.exe
2018-03-10 21:39 - 2018-02-10 13:42 - 000975872 _____ (Microsoft Corporation) C:\WINDOWS\system32\wbiosrvc.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000950784 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasgcw.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000837632 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Security.Authentication.Web.Core.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000792064 _____ (Microsoft Corporation) C:\WINDOWS\system32\mssvp.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000731136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Magnify.exe
2018-03-10 21:39 - 2018-02-10 13:42 - 000634880 _____ (Microsoft Corporation) C:\WINDOWS\system32\efswrt.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000397824 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\dxtmsft.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000286720 _____ (Microsoft Corporation) C:\WINDOWS\system32\dnsrslvr.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000270336 _____ (Microsoft Corporation) C:\WINDOWS\system32\ListSvc.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000234496 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetworkDesktopSettings.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000233984 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppLockerCSP.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000228352 _____ (Microsoft Corporation) C:\WINDOWS\system32\ie4uinit.exe
2018-03-10 21:39 - 2018-02-10 13:42 - 000225280 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchFilterHost.exe
2018-03-10 21:39 - 2018-02-10 13:42 - 000184832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authz.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000160768 _____ (Microsoft Corporation) C:\WINDOWS\system32\LockScreenContent.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000160256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserDeviceRegistration.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000130048 _____ (Microsoft Corporation) C:\WINDOWS\system32\rshx32.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\IdCtrls.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000078336 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mshtmled.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000035328 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nshhttp.dll
2018-03-10 21:39 - 2018-02-10 13:42 - 000024064 _____ (Microsoft Corporation) C:\WINDOWS\system32\regsvr32.exe
2018-03-10 21:39 - 2018-02-10 13:41 - 000859648 _____ (Microsoft Corporation) C:\WINDOWS\system32\appwiz.cpl
2018-03-10 21:39 - 2018-02-10 13:41 - 000820224 _____ (Microsoft Corporation) C:\WINDOWS\system32\netlogon.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000504832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\DevicePairing.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000466432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\efswrt.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000401408 _____ (Microsoft Corporation) C:\WINDOWS\system32\ncsi.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000377856 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchProtocolHost.exe
2018-03-10 21:39 - 2018-02-10 13:41 - 000288768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Search.ProtocolHandler.MAPI2.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000255488 _____ (Microsoft Corporation) C:\WINDOWS\system32\edputil.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000221184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netplwiz.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000133120 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppManagementConfiguration.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000124928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sendmail.dll
2018-03-10 21:39 - 2018-02-10 13:41 - 000063488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\nlaapi.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 003367936 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncCenter.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 002873344 _____ (Microsoft Corporation) C:\WINDOWS\system32\themeui.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 001234432 _____ (Microsoft Corporation) C:\WINDOWS\system32\SEMgrSvc.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 001002496 _____ (Microsoft Corporation) C:\WINDOWS\system32\modernexecserver.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000940544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Networking.Vpn.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000939520 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasdlg.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000930816 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasmans.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000886784 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\bcastdvr.exe
2018-03-10 21:39 - 2018-02-10 13:40 - 000856576 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasgcw.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000800256 _____ (Microsoft Corporation) C:\WINDOWS\system32\cscui.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000756736 _____ (Microsoft Corporation) C:\WINDOWS\system32\msfeeds.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000691200 _____ (Microsoft Corporation) C:\WINDOWS\system32\dsreg.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000526336 _____ (Microsoft Corporation) C:\WINDOWS\system32\authui.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000508416 _____ (Microsoft Corporation) C:\WINDOWS\system32\timedate.cpl
2018-03-10 21:39 - 2018-02-10 13:40 - 000499200 _____ (Microsoft Corporation) C:\WINDOWS\system32\rastls.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000463360 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\timedate.cpl
2018-03-10 21:39 - 2018-02-10 13:40 - 000421376 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputSwitch.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000366080 _____ (Microsoft Corporation) C:\WINDOWS\system32\nlasvc.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000343040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iedkcs32.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000298496 _____ (Microsoft Corporation) C:\WINDOWS\system32\netplwiz.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000232960 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\edputil.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000195072 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\OneCoreCommonProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:40 - 000177152 _____ (Microsoft Corporation) C:\WINDOWS\system32\EditionUpgradeHelper.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 005500928 _____ (Microsoft Corporation) C:\WINDOWS\system32\aclui.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 002677760 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\tquery.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 002490880 _____ (Microsoft Corporation) C:\WINDOWS\system32\themecpl.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000908800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontext.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000721920 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssvp.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000680960 _____ (Microsoft Corporation) C:\WINDOWS\system32\sud.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000658432 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\netlogon.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000648704 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserLanguagesCpl.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000621056 _____ (Microsoft Corporation) C:\WINDOWS\system32\hgcpl.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000462848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webio.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000447488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rastls.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000315904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sysdm.cpl
2018-03-10 21:39 - 2018-02-10 13:39 - 000157696 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twext.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000096256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\IdCtrls.dll
2018-03-10 21:39 - 2018-02-10 13:39 - 000020992 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\regsvr32.exe
2018-03-10 21:39 - 2018-02-10 13:38 - 006722560 _____ (Microsoft Corporation) C:\WINDOWS\system32\mspaint.exe
2018-03-10 21:39 - 2018-02-10 13:38 - 003125760 _____ (Microsoft Corporation) C:\WINDOWS\system32\InputService.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 002184192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mssrch.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 002082304 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcpl.cpl
2018-03-10 21:39 - 2018-02-10 13:38 - 001968640 _____ (Microsoft Corporation) C:\WINDOWS\system32\FntCache.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 001597952 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieapfltr.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 001228800 _____ (Microsoft Corporation) C:\WINDOWS\system32\TokenBroker.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 001166336 _____ (Microsoft Corporation) C:\WINDOWS\system32\localspl.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000982016 _____ (Microsoft Corporation) C:\WINDOWS\system32\SearchIndexer.exe
2018-03-10 21:39 - 2018-02-10 13:38 - 000939520 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasapi32.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000885248 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Search.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000863744 _____ (Microsoft Corporation) C:\WINDOWS\system32\ntshrui.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000755712 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\appwiz.cpl
2018-03-10 21:39 - 2018-02-10 13:38 - 000699904 _____ (Microsoft Corporation) C:\WINDOWS\system32\lsm.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000668160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msfeeds.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000653312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sud.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000598528 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Security.Authentication.Web.Core.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000524800 _____ (Microsoft Corporation) C:\WINDOWS\system32\windows.immersiveshell.serviceprovider.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000509440 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingSync.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000506880 _____ (Microsoft Corporation) C:\WINDOWS\system32\twinapi.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000401920 _____ (Microsoft Corporation) C:\WINDOWS\system32\rascustom.dll
2018-03-10 21:39 - 2018-02-10 13:38 - 000324608 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchProtocolHost.exe
2018-03-10 21:39 - 2018-02-10 13:38 - 000174592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EditionUpgradeHelper.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 003419136 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\xpsrchvw.exe
2018-03-10 21:39 - 2018-02-10 13:37 - 003287040 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SyncCenter.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 002523648 _____ (Microsoft Corporation) C:\WINDOWS\system32\gameux.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000965632 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontext.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000862208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasdlg.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000417792 _____ (Microsoft Corporation) C:\WINDOWS\system32\stobject.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000365568 _____ (Microsoft Corporation) C:\WINDOWS\system32\srchadmin.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000308224 _____ (Microsoft Corporation) C:\WINDOWS\system32\NetSetupSvc.dll
2018-03-10 21:39 - 2018-02-10 13:37 - 000199680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchFilterHost.exe
2018-03-10 21:39 - 2018-02-10 13:37 - 000198656 _____ (Microsoft Corporation) C:\WINDOWS\system32\SettingMonitor.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 002462208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\themecpl.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 001759744 _____ (Microsoft Corporation) C:\WINDOWS\system32\wpncore.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 001342464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Wpc.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000915968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\TokenBroker.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000695296 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Search.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000599552 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.UI.Core.TextInput.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000576512 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\hgcpl.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000559104 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\UserLanguagesCpl.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000403968 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\sppcomapi.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000383488 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\stobject.dll
2018-03-10 21:39 - 2018-02-10 13:36 - 000141824 _____ (Microsoft Corporation) C:\WINDOWS\system32\FontProvider.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 005388800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\aclui.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 002814976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\themeui.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 002413568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\gameux.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 002349568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputService.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 002013184 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcpl.cpl
2018-03-10 21:39 - 2018-02-10 13:35 - 001474560 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieapfltr.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000943104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.BackgroundMediaPlayback.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000941568 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.BackgroundMediaPlayer.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000918528 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.MediaPlayer.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000862208 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rasapi32.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000826880 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SearchIndexer.exe
2018-03-10 21:39 - 2018-02-10 13:35 - 000796160 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ntshrui.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000667136 _____ (Microsoft Corporation) C:\WINDOWS\system32\FrameServer.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000455680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\authui.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000433664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\twinapi.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000402944 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\SettingSync.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000332288 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\srchadmin.dll
2018-03-10 21:39 - 2018-02-10 13:35 - 000329728 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\InputSwitch.dll
2018-03-10 21:39 - 2018-02-10 13:34 - 006532096 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mspaint.exe
2018-03-10 21:39 - 2018-02-10 13:34 - 000624640 _____ (Microsoft Corporation) C:\WINDOWS\system32\WMVXENCD.DLL
2018-03-10 21:39 - 2018-02-10 13:34 - 000464384 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.UI.Core.TextInput.dll
2018-03-10 21:39 - 2018-02-10 13:34 - 000433152 _____ (Microsoft Corporation) C:\WINDOWS\system32\WMVSENCD.DLL
2018-03-10 21:39 - 2018-02-10 13:34 - 000111104 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Media.Playback.ProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 001936384 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmc.exe
2018-03-10 21:39 - 2018-02-10 13:33 - 001661440 _____ (Microsoft Corporation) C:\WINDOWS\system32\vssapi.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 001557504 _____ (Microsoft Corporation) C:\WINDOWS\system32\VSSVC.exe
2018-03-10 21:39 - 2018-02-10 13:33 - 000621568 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.BackgroundMediaPlayback.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000620544 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.BackgroundMediaPlayer.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000604672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.MediaPlayer.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000482816 _____ (Microsoft Corporation) C:\WINDOWS\system32\srcore.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000341504 _____ (Microsoft Corporation) C:\WINDOWS\system32\mmcbase.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000266752 _____ (Microsoft Corporation) C:\WINDOWS\system32\rstrui.exe
2018-03-10 21:39 - 2018-02-10 13:33 - 000217088 _____ (Microsoft Corporation) C:\WINDOWS\system32\WebClnt.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000125952 _____ (Microsoft Corporation) C:\WINDOWS\system32\AppxSysprep.dll
2018-03-10 21:39 - 2018-02-10 13:33 - 000093696 _____ (Microsoft Corporation) C:\WINDOWS\system32\davclnt.dll
2018-03-10 21:39 - 2018-02-10 13:32 - 002427904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcndmgr.dll
2018-03-10 21:39 - 2018-02-10 13:32 - 000681472 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WMVXENCD.DLL
2018-03-10 21:39 - 2018-02-10 13:32 - 000392704 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WMVSENCD.DLL
2018-03-10 21:39 - 2018-02-10 13:32 - 000073216 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\npfs.sys
2018-03-10 21:39 - 2018-02-10 13:32 - 000056832 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Media.Playback.ProxyStub.dll
2018-03-10 21:39 - 2018-02-10 13:31 - 001488896 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmc.exe
2018-03-10 21:39 - 2018-02-10 13:31 - 001159680 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\vssapi.dll
2018-03-10 21:39 - 2018-02-10 13:31 - 000301056 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\mmcbase.dll
2018-03-10 21:39 - 2018-02-10 13:31 - 000190464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WebClnt.dll
2018-03-10 21:39 - 2018-02-10 13:31 - 000078848 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\davclnt.dll
2018-03-10 21:39 - 2018-02-10 11:59 - 000804240 _____ C:\WINDOWS\SysWOW64\locale.nls
2018-03-10 21:39 - 2018-02-10 11:59 - 000804240 _____ C:\WINDOWS\system32\locale.nls
2018-03-10 21:39 - 2018-02-09 12:35 - 001234888 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmpal.dll
2018-03-10 21:39 - 2018-02-09 12:35 - 001002952 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmcodecs.dll
2018-03-10 21:39 - 2018-02-09 12:35 - 000892872 _____ (Microsoft Corporation) C:\WINDOWS\system32\ortcengine.dll
2018-03-10 21:39 - 2018-02-09 12:35 - 000065992 _____ (Microsoft Corporation) C:\WINDOWS\system32\rtmmvrortc.dll
2018-03-10 21:39 - 2018-02-02 12:36 - 000921032 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmpal.dll
2018-03-10 21:39 - 2018-02-02 12:36 - 000854976 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmcodecs.dll
2018-03-10 21:39 - 2018-02-02 12:36 - 000649672 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ortcengine.dll
2018-03-10 21:39 - 2018-02-02 12:36 - 000054720 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rtmmvrortc.dll
2018-03-10 21:39 - 2018-01-01 21:52 - 000066712 _____ (Microsoft Corporation) C:\WINDOWS\system32\iumcrypt.dll
2018-03-10 21:39 - 2018-01-01 21:51 - 000191816 _____ (Microsoft Corporation) C:\WINDOWS\system32\skci.dll
2018-03-10 21:39 - 2018-01-01 21:51 - 000059800 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\bam.sys
2018-03-10 21:39 - 2018-01-01 21:49 - 000292376 _____ (Microsoft Corporation) C:\WINDOWS\system32\wscapi.dll
2018-03-10 21:39 - 2018-01-01 21:48 - 000382360 _____ (Adobe Systems Incorporated) C:\WINDOWS\system32\atmfd.dll
2018-03-10 21:39 - 2018-01-01 21:47 - 000649304 _____ (Microsoft Corporation) C:\WINDOWS\system32\advapi32.dll
2018-03-10 21:39 - 2018-01-01 21:46 - 000898216 _____ (Microsoft Corporation) C:\WINDOWS\system32\CoreMessaging.dll
2018-03-10 21:39 - 2018-01-01 21:43 - 000367336 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Storage.ApplicationData.dll
2018-03-10 21:39 - 2018-01-01 21:43 - 000062872 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\fsdepends.sys
2018-03-10 21:39 - 2018-01-01 21:41 - 000549552 _____ (Microsoft Corporation) C:\WINDOWS\system32\WWanAPI.dll
2018-03-10 21:39 - 2018-01-01 21:39 - 000508264 _____ (Microsoft Corporation) C:\WINDOWS\system32\systemreset.exe
2018-03-10 21:39 - 2018-01-01 21:38 - 000038808 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Diskdump.sys
2018-03-10 21:39 - 2018-01-01 21:37 - 000461720 _____ (Microsoft Corporation) C:\WINDOWS\system32\wifitask.exe
2018-03-10 21:39 - 2018-01-01 21:36 - 000113560 _____ (Microsoft Corporation) C:\WINDOWS\system32\icfupgd.dll
2018-03-10 21:39 - 2018-01-01 21:36 - 000057752 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbios.sys
2018-03-10 21:39 - 2018-01-01 21:34 - 001336344 _____ (Microsoft Corporation) C:\WINDOWS\system32\ole32.dll
2018-03-10 21:39 - 2018-01-01 21:27 - 000163736 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wfplwfs.sys
2018-03-10 21:39 - 2018-01-01 21:26 - 000081304 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmcl.sys
2018-03-10 21:39 - 2018-01-01 21:06 - 000311192 _____ (Adobe Systems Incorporated) C:\WINDOWS\SysWOW64\atmfd.dll
2018-03-10 21:39 - 2018-01-01 21:03 - 000566664 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CoreMessaging.dll
2018-03-10 21:39 - 2018-01-01 20:49 - 000481464 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\advapi32.dll
2018-03-10 21:39 - 2018-01-01 20:49 - 000258808 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wscapi.dll
2018-03-10 21:39 - 2018-01-01 20:46 - 000289816 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Storage.ApplicationData.dll
2018-03-10 21:39 - 2018-01-01 20:45 - 000450928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WWanAPI.dll
2018-03-10 21:39 - 2018-01-01 20:42 - 001003152 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ole32.dll
2018-03-10 21:39 - 2018-01-01 20:25 - 000475648 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\ieui.dll
2018-03-10 21:39 - 2018-01-01 20:24 - 000240640 _____ (Microsoft Corporation) C:\WINDOWS\system32\AboutSettingsHandlers.dll
2018-03-10 21:39 - 2018-01-01 20:24 - 000202240 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\AppxAllUserStore.dll
2018-03-10 21:39 - 2018-01-01 20:24 - 000096256 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fontsub.dll
2018-03-10 21:39 - 2018-01-01 20:24 - 000038912 _____ (Adobe Systems) C:\WINDOWS\SysWOW64\atmlib.dll
2018-03-10 21:39 - 2018-01-01 20:23 - 000561152 _____ (Microsoft Corporation) C:\WINDOWS\system32\ieui.dll
2018-03-10 21:39 - 2018-01-01 20:23 - 000121344 _____ (Microsoft Corporation) C:\WINDOWS\system32\fontsub.dll
2018-03-10 21:39 - 2018-01-01 20:23 - 000080384 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\vmbkmclr.sys
2018-03-10 21:39 - 2018-01-01 20:23 - 000047104 _____ (Adobe Systems) C:\WINDOWS\system32\atmlib.dll
2018-03-10 21:39 - 2018-01-01 20:22 - 000032768 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rfxvmt.dll
2018-03-10 21:39 - 2018-01-01 20:22 - 000031744 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Management.Provisioning.ProxyStub.dll
2018-03-10 21:39 - 2018-01-01 20:22 - 000025600 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\Dumpstorport.sys
2018-03-10 21:39 - 2018-01-01 20:22 - 000017408 _____ (Microsoft Corporation) C:\WINDOWS\system32\VmApplicationHealthMonitorProxy.dll
2018-03-10 21:39 - 2018-01-01 20:21 - 000133632 _____ (Microsoft Corporation) C:\WINDOWS\system32\wificonnapi.dll
2018-03-10 21:39 - 2018-01-01 20:21 - 000097280 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\WcnApi.dll
2018-03-10 21:39 - 2018-01-01 20:21 - 000097280 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\raspptp.sys
2018-03-10 21:39 - 2018-01-01 20:21 - 000080896 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\wanarp.sys
2018-03-10 21:39 - 2018-01-01 20:21 - 000062976 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\ndproxy.sys
2018-03-10 21:39 - 2018-01-01 20:21 - 000040448 _____ (Microsoft Corporation) C:\WINDOWS\system32\rfxvmt.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000215552 _____ (Microsoft Corporation) C:\WINDOWS\system32\fwpolicyiomgr.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000212992 _____ (Microsoft Corporation) C:\WINDOWS\system32\container.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000186368 _____ (Microsoft Corporation) C:\WINDOWS\system32\ACPBackgroundManagerPolicy.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000175616 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\fwpolicyiomgr.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000134656 _____ (Microsoft Corporation) C:\WINDOWS\system32\WcnApi.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000133632 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\iepeers.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000104960 _____ (Microsoft Corporation) C:\WINDOWS\system32\rasauto.dll
2018-03-10 21:39 - 2018-01-01 20:20 - 000082432 _____ (Microsoft Corporation) C:\WINDOWS\system32\SCardDlg.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000795136 _____ (Microsoft Corporation) C:\WINDOWS\system32\NaturalAuth.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000430080 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Windows.Internal.Bluetooth.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000416768 _____ (Microsoft Corporation) C:\WINDOWS\system32\html.iec
2018-03-10 21:39 - 2018-01-01 20:19 - 000340480 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\html.iec
2018-03-10 21:39 - 2018-01-01 20:19 - 000316928 _____ (Microsoft Corporation) C:\WINDOWS\system32\Drivers\netbt.sys
2018-03-10 21:39 - 2018-01-01 20:19 - 000188416 _____ (Microsoft Corporation) C:\WINDOWS\system32\PimIndexMaintenance.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000174592 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\P2P.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000149504 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\container.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000142848 _____ (Microsoft Corporation) C:\WINDOWS\system32\iepeers.dll
2018-03-10 21:39 - 2018-01-01 20:19 - 000097792 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\msoert2.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000748032 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneProviders.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000699904 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\CPFilters.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000588800 _____ (Microsoft Corporation) C:\WINDOWS\system32\SmsRouterSvc.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000465920 _____ (Microsoft Corporation) C:\WINDOWS\system32\wcncsvc.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000436224 _____ (Microsoft Corporation) C:\WINDOWS\system32\PsmServiceExtHost.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000425984 _____ (Microsoft Corporation) C:\WINDOWS\system32\vmrdvcore.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000380928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\EncDec.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000369664 _____ (Microsoft Corporation) C:\WINDOWS\system32\APHostService.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000259072 _____ (Microsoft Corporation) C:\WINDOWS\system32\SCardSvr.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000210944 _____ (Microsoft Corporation) C:\WINDOWS\system32\P2P.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000144896 _____ (Microsoft Corporation) C:\WINDOWS\system32\appinfo.dll
2018-03-10 21:39 - 2018-01-01 20:18 - 000082944 _____ (Microsoft Corporation) C:\WINDOWS\system32\provdatastore.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 001485312 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpserverbase.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000791552 _____ (Microsoft Corporation) C:\WINDOWS\system32\PhoneService.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000616960 _____ (Microsoft Corporation) C:\WINDOWS\system32\Windows.Internal.Bluetooth.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000555520 _____ (Microsoft Corporation) C:\WINDOWS\system32\SensorService.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000423936 _____ (Microsoft Corporation) C:\WINDOWS\system32\p2psvc.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000341504 _____ (Microsoft Corporation) C:\WINDOWS\system32\pnrpsvc.dll
2018-03-10 21:39 - 2018-01-01 20:17 - 000112640 _____ (Microsoft Corporation) C:\WINDOWS\system32\msoert2.dll
2018-03-10 21:39 - 2018-01-01 20:16 - 000966656 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\Unistore.dll
2018-03-10 21:39 - 2018-01-01 20:16 - 000956928 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\rdpbase.dll
2018-03-10 21:39 - 2018-01-01 20:16 - 000624128 _____ (Microsoft Corporation) C:\WINDOWS\system32\SyncController.dll
2018-03-10 21:39 - 2018-01-01 20:16 - 000235008 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\webcheck.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 001657856 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpserverbase.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 001245184 _____ (Microsoft Corporation) C:\WINDOWS\system32\Unistore.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 000970240 _____ (Microsoft Corporation) C:\WINDOWS\system32\sysmain.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 000951808 _____ (Microsoft Corporation) C:\WINDOWS\system32\usermgr.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 000434176 _____ (Microsoft Corporation) C:\WINDOWS\system32\EncDec.dll
2018-03-10 21:39 - 2018-01-01 20:15 - 000258560 _____ (Microsoft Corporation) C:\WINDOWS\system32\webcheck.dll
2018-03-10 21:39 - 2018-01-01 20:14 - 001097728 _____ (Microsoft Corporation) C:\WINDOWS\system32\rdpbase.dll
2018-03-10 21:39 - 2018-01-01 20:14 - 000985600 _____ (Microsoft Corporation) C:\WINDOWS\system32\inetcomm.dll
2018-03-10 21:39 - 2018-01-01 20:14 - 000870912 _____ (Microsoft Corporation) C:\WINDOWS\system32\CPFilters.dll
2018-03-10 21:39 - 2018-01-01 20:13 - 000897024 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\inetcomm.dll
2018-03-10 21:39 - 2018-01-01 20:12 - 001573376 _____ (Microsoft Corporation) C:\WINDOWS\system32\UserDataService.dll
2018-03-10 21:39 - 2018-01-01 20:12 - 000760320 _____ (Microsoft Corporation) C:\WINDOWS\system32\spoolsv.exe
2018-03-10 21:39 - 2018-01-01 20:11 - 001955328 _____ (Microsoft Corporation) C:\WINDOWS\system32\PeerDistSvc.dll
2018-03-10 21:39 - 2018-01-01 20:11 - 001816576 _____ (Microsoft Corporation) C:\WINDOWS\system32\wevtsvc.dll
2018-03-10 21:39 - 2018-01-01 20:11 - 001343488 _____ (Microsoft Corporation) C:\WINDOWS\system32\wifinetworkmanager.dll
2018-03-10 21:39 - 2018-01-01 20:11 - 000715776 _____ (Microsoft Corporation) C:\WINDOWS\system32\winlogon.exe
2018-03-10 21:39 - 2018-01-01 20:10 - 002528256 _____ (Microsoft Corporation) C:\WINDOWS\system32\wlansvc.dll
2018-03-10 21:39 - 2018-01-01 20:10 - 000012800 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\wscproxystub.dll
2018-03-10 21:39 - 2018-01-01 20:08 - 000505344 _____ (Microsoft Corporation) C:\WINDOWS\system32\taskcomp.dll
2018-03-10 21:39 - 2018-01-01 20:06 - 000018944 _____ (Microsoft Corporation) C:\WINDOWS\system32\wscproxystub.dll
2018-03-09 20:08 - 2018-03-09 20:19 - 000000000 ____D C:\WINDOWS\system32\Drivers\wd
2018-03-09 20:07 - 2018-03-09 20:07 - 003034496 _____ C:\Users\ASUS\Desktop\ZHPDiag3.exe
2018-03-09 20:05 - 2018-03-09 20:05 - 000000008 __RSH C:\ProgramData\ntuser.pol
2018-03-09 20:03 - 2018-03-09 20:03 - 000033163 ____H C:\Users\ASUS\AppData\Local\IconCache.db.backup
2018-03-09 20:00 - 2018-03-14 21:43 - 000010122 _____ C:\Users\ASUS\Desktop\Fixlog.txt
2018-03-08 20:22 - 2018-03-08 21:08 - 001146880 _____ C:\Users\ASUS\Desktop\for dig.exe
2018-03-07 18:38 - 2018-03-07 18:38 - 008222496 _____ (Malwarebytes) C:\Users\ASUS\Desktop\adwcleaner_7.0.8.0.exe
2018-03-07 17:23 - 2018-03-07 17:23 - 000000072 ___SH C:\bootTel.dat
2018-03-07 16:29 - 2018-03-07 16:29 - 000298670 _____ C:\Users\ASUS\Downloads\RAMMap.zip
2018-03-07 16:07 - 2018-03-14 21:52 - 000052171 _____ C:\Users\ASUS\Desktop\Addition.txt
2018-03-07 16:02 - 2018-03-18 09:59 - 000015336 _____ C:\Users\ASUS\Desktop\FRST.txt
2018-03-05 00:19 - 2017-09-29 04:36 - 000140208 _____ (Razer, Inc.) C:\WINDOWS\system32\Drivers\rzpnk.sys
2018-03-04 23:52 - 2018-03-04 23:52 - 000002317 _____ C:\Users\Default\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2018-03-04 23:52 - 2018-03-04 23:52 - 000002317 _____ C:\Users\Default User\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\OneDrive.lnk
2018-03-04 23:52 - 2018-03-04 23:52 - 000000000 ____D C:\Program Files (x86)\Microsoft OneDrive
2018-03-04 23:00 - 2018-03-04 23:00 - 000002848 _____ C:\WINDOWS\System32\Tasks\CCleanerSkipUAC
2018-03-04 23:00 - 2018-03-04 23:00 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AutoHotkey
2018-03-04 22:57 - 2018-01-28 19:00 - 000794112 _____ C:\WINDOWS\system32\xvidcore.dll
2018-03-04 22:57 - 2018-01-28 19:00 - 000694784 _____ C:\WINDOWS\SysWOW64\xvidcore.dll
2018-03-04 22:57 - 2018-01-28 19:00 - 000311296 _____ C:\WINDOWS\system32\xvidvfw.dll
2018-03-04 22:57 - 2018-01-28 19:00 - 000284672 _____ C:\WINDOWS\SysWOW64\xvidvfw.dll
2018-03-04 22:57 - 2017-07-30 20:50 - 003850240 _____ (x264vfw project) C:\WINDOWS\SysWOW64\x264vfw.dll
2018-03-04 22:57 - 2017-07-30 20:50 - 003799552 _____ (x264vfw project) C:\WINDOWS\system32\x264vfw64.dll
2018-03-04 22:55 - 2018-03-04 22:55 - 000001816 _____ C:\Users\Public\Desktop\iTunes.lnk
2018-03-04 22:55 - 2018-03-04 22:55 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\iTunes
2018-03-04 22:55 - 2018-03-04 22:55 - 000000000 ____D C:\Program Files\iPod
2018-03-04 22:54 - 2018-03-04 22:55 - 000000000 ____D C:\Program Files\iTunes
2018-03-04 22:52 - 2018-03-04 22:52 - 000002579 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Apple Software Update.lnk
2018-03-04 22:52 - 2018-03-04 22:52 - 000000000 ____D C:\WINDOWS\System32\Tasks\Apple
2018-03-04 22:52 - 2018-03-04 22:52 - 000000000 ____D C:\Program Files (x86)\Apple Software Update
2018-03-04 22:51 - 2018-03-14 19:29 - 000000000 ____D C:\Program Files\Bonjour
2018-03-04 22:51 - 2018-03-14 19:29 - 000000000 ____D C:\Program Files (x86)\Bonjour
2018-03-04 22:50 - 2018-03-04 22:51 - 000000000 ____D C:\Program Files\Common Files\Apple
2018-03-04 22:44 - 2018-03-14 21:28 - 000004424 _____ C:\WINDOWS\System32\Tasks\Adobe Flash Player Updater
2018-03-04 22:42 - 2018-03-07 07:57 - 000000000 ____D C:\Users\ASUS\AppData\Local\Patch_My_PC,_LLC
2018-03-04 22:18 - 2018-03-04 22:18 - 000000000 ____D C:\Users\ASUS\Desktop\autorun
2018-03-04 22:17 - 2018-03-04 22:17 - 001652843 _____ C:\Users\ASUS\Downloads\Autoruns.zip
2018-02-26 22:22 - 2018-02-26 22:22 - 000002487 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Acrobat Reader DC.lnk
2018-02-19 23:59 - 2018-02-19 23:59 - 001102336 _____ C:\Users\ASUS\Desktop\Otterly.exe
2018-02-17 22:15 - 2018-02-17 22:15 - 000000000 ____D C:\Users\ASUS\Downloads\Murder On The Orient Express (2017) [YTS.AG]
2018-02-17 21:49 - 2018-02-17 21:49 - 000033970 _____ C:\Users\ASUS\Downloads\Murder on the Orient Express (2017) [BluRay] [720p] [YTS.AM].torrent
2018-02-17 21:37 - 2018-02-17 21:37 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\TunnelBear
2018-02-17 21:34 - 2018-02-17 21:34 - 067791208 _____ (TunnelBear) C:\Users\ASUS\Downloads\TunnelBear-Installer.exe
2018-02-17 19:42 - 2018-02-17 19:45 - 178509109 _____ C:\Users\ASUS\Downloads\War server.7z
2018-02-16 21:48 - 2018-02-16 21:52 - 190639422 _____ C:\Users\ASUS\Downloads\[Decoshoot] Kera Sakti II - 03.mp4
2018-02-16 20:28 - 2018-02-16 20:31 - 188188000 _____ C:\Users\ASUS\Downloads\[Decoshoot] Kera Sakti II - 02.mp4
2018-03-18 09:58 - 2017-07-14 18:49 - 000000000 ____D C:\ProgramData\NVIDIA
2018-03-18 09:58 - 2017-04-01 02:14 - 000000000 ____D C:\FRST
2018-03-18 09:19 - 2017-11-26 02:54 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
2018-03-18 08:23 - 2017-11-26 03:27 - 000004146 _____ C:\WINDOWS\System32\Tasks\User_Feed_Synchronization-{60208B48-6CA6-4424-8E02-7F65C7F3A413}
2018-03-18 08:01 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\rescache
2018-03-18 05:43 - 2018-02-08 20:31 - 000000132 _____ C:\Users\ASUS\AppData\Roaming\Adobe PNG Format CS6 Prefs
2018-03-17 22:17 - 2017-02-15 00:47 - 000068056 _____ C:\Users\ASUS\Desktop\Ragnarok.xlsx
2018-03-17 21:55 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\DeliveryOptimization
2018-03-17 21:00 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\AppReadiness
2018-03-17 16:06 - 2017-04-11 09:08 - 000000040 _____ C:\Program Files (x86)\settings.dat
2018-03-16 04:26 - 2017-09-29 22:44 - 000000000 ____D C:\WINDOWS\INF
2018-03-15 22:03 - 2017-11-26 03:00 - 001345208 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2018-03-15 21:59 - 2017-11-26 03:32 - 000000000 ___RD C:\Users\ASUS\3D Objects
2018-03-15 21:59 - 2016-08-15 16:19 - 000000000 __RHD C:\Users\Public\AccountPictures
2018-03-15 21:56 - 2017-11-26 03:27 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
2018-03-15 21:55 - 2017-09-29 17:45 - 000524288 _____ C:\WINDOWS\system32\config\BBI
2018-03-15 21:54 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\TextInput
2018-03-15 21:54 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\en-GB
2018-03-15 21:54 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\appraiser
2018-03-15 21:54 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\ShellExperiences
2018-03-15 21:54 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\PolicyDefinitions
2018-03-15 16:20 - 2017-03-08 15:19 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\TS3Client
2018-03-15 10:04 - 2017-02-15 00:36 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\MPC-HC
2018-03-15 00:25 - 2017-09-29 22:37 - 000000000 ____D C:\WINDOWS\CbsTemp
2018-03-14 22:02 - 2017-02-16 14:23 - 000000000 ____D C:\WINDOWS\system32\MRT
2018-03-14 21:55 - 2017-10-11 22:04 - 130364688 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT-KB890830.exe
2018-03-14 21:55 - 2017-02-16 14:23 - 130364688 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2018-03-14 21:43 - 2017-11-26 03:01 - 000000000 ____D C:\Users\defaultuser0
2018-03-14 21:43 - 2017-11-26 03:01 - 000000000 ____D C:\Users\ASUS
2018-03-14 21:31 - 2016-08-15 16:22 - 000000000 ____D C:\ProgramData\Package Cache
2018-03-14 21:30 - 2017-04-01 06:50 - 000000863 _____ C:\Users\Public\Desktop\CCleaner.lnk
2018-03-14 21:29 - 2017-04-01 06:50 - 000002379 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
2018-03-14 21:28 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\SysWOW64\Macromed
2018-03-14 21:28 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\Macromed
2018-03-14 21:27 - 2017-04-11 09:10 - 000000000 __SHD C:\ProgramData\360Quarant
2018-03-14 21:27 - 2017-04-02 15:08 - 000000000 __SHD C:\$360Section
2018-03-14 21:19 - 2017-05-05 13:56 - 000000000 ____D C:\Program Files (x86)\Bandicam
2018-03-14 19:57 - 2017-02-15 00:01 - 000000000 ____D C:\Users\ASUS\AppData\Local\CrashDumps
2018-03-14 19:37 - 2017-04-01 08:03 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\ZHP
2018-03-13 20:15 - 2017-04-07 08:15 - 000095232 _____ (360.cn) C:\WINDOWS\SysWOW64\Drivers\360AvFlt.sys
2018-03-12 21:26 - 2018-02-14 23:47 - 000000000 ____D C:\Users\ASUS\Desktop\AHK
2018-03-12 19:01 - 2017-11-21 22:16 - 000000000 ___DC C:\WINDOWS\Panther
2018-03-12 19:00 - 2017-07-29 23:41 - 000000000 ____D C:\ProgramData\TEMP
2018-03-12 19:00 - 2017-05-06 18:52 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\Mumble
2018-03-12 19:00 - 2017-02-15 14:57 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\Skype
2018-03-12 18:32 - 2016-08-15 16:34 - 000000000 __SHD C:\Users\ASUS\IntelGraphicsProfiles
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ___SD C:\WINDOWS\SysWOW64\F12
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ___SD C:\WINDOWS\system32\F12
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\SysWOW64\Dism
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\oobe
2018-03-12 18:23 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\system32\migwiz
2018-03-12 18:23 - 2017-09-29 17:45 - 000000000 ____D C:\WINDOWS\system32\Dism
2018-03-12 18:22 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\Provisioning
2018-03-12 18:22 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\bcastdvr
2018-03-12 17:46 - 2016-08-15 16:21 - 000000000 ___RD C:\Users\ASUS\OneDrive
2018-03-09 20:19 - 2017-09-29 22:46 - 000000000 ___RD C:\Program Files\Windows Defender
2018-03-09 20:12 - 2017-04-02 15:16 - 000000000 ____D C:\Users\ASUS\AppData\Local\ZHP
2018-03-09 20:11 - 2017-02-15 12:40 - 000548000 ____N (Microsoft Corporation) C:\WINDOWS\system32\MpSigStub.exe
2018-03-09 20:00 - 2017-06-19 20:44 - 000000000 ___HD C:\WINDOWS\system32\GroupPolicy
2018-03-07 18:40 - 2017-04-01 08:27 - 000000000 ____D C:\AdwCleaner
2018-03-07 18:34 - 2017-09-27 21:31 - 000000000 ____D C:\Program Files (x86)\Microsoft Silverlight
2018-03-07 08:16 - 2017-11-26 03:02 - 000000000 ____D C:\Users\ASUS\AppData\Local\Packages
2018-03-07 08:16 - 2017-09-29 22:46 - 000000000 ___HD C:\Program Files\WindowsApps
2018-03-07 08:12 - 2017-10-22 21:28 - 000000000 ____D C:\Program Files\CyberGhost 6
2018-03-07 08:11 - 2017-09-29 18:41 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Kits
2018-03-07 08:08 - 2017-10-21 15:02 - 000000000 ____D C:\Program Files\TAP-Windows
2018-03-07 08:06 - 2017-05-06 20:06 - 000000000 ___RD C:\Program Files (x86)\Skype
2018-03-07 08:06 - 2017-02-15 14:56 - 000000000 ____D C:\ProgramData\Skype
2018-03-06 23:29 - 2017-04-11 09:08 - 000001140 _____ C:\Program Files (x86)\metadata
2018-03-06 23:28 - 2017-04-11 09:08 - 000000000 ____D C:\Program Files (x86)\reports
2018-03-05 00:19 - 2017-02-15 16:12 - 000000000 ____D C:\Users\ASUS\AppData\Local\Razer
2018-03-05 00:19 - 2017-02-15 16:12 - 000000000 ____D C:\ProgramData\Razer
2018-03-04 23:30 - 2017-04-01 06:50 - 000000864 _____ C:\Users\Public\Desktop\TeamSpeak 3 Client.lnk
2018-03-04 23:30 - 2017-04-01 06:50 - 000000814 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\TeamSpeak 3 Client.lnk
2018-03-04 23:00 - 2017-12-17 21:23 - 000000000 ____D C:\Program Files\AutoHotkey
2018-03-04 23:00 - 2017-02-14 18:04 - 000000000 ____D C:\Users\ASUS\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR
2018-03-04 23:00 - 2017-02-14 18:04 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
2018-03-04 23:00 - 2017-02-14 18:04 - 000000000 ____D C:\Program Files\WinRAR
2018-03-04 22:57 - 2017-02-14 18:51 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\K-Lite Codec Pack
2018-03-04 22:57 - 2017-02-14 18:51 - 000000000 ____D C:\Program Files (x86)\K-Lite Codec Pack
2018-03-04 22:45 - 2017-09-27 21:31 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
2018-03-04 22:32 - 2017-06-16 22:23 - 000007609 _____ C:\Users\ASUS\AppData\Local\Resmon.ResmonCfg
2018-02-24 22:00 - 2017-02-19 02:00 - 000000000 ___RD C:\Users\ASUS\Dropbox
2018-02-24 21:59 - 2017-09-29 22:46 - 000000000 ____D C:\WINDOWS\LiveKernelReports
2018-02-19 23:44 - 2017-10-07 09:17 - 000001738 _____ C:\Users\ASUS\Desktop\diet plan + wifii pass.txt
2018-02-19 22:38 - 2018-02-14 23:51 - 001138688 _____ C:\Users\ASUS\Desktop\AutoPot.exe
2017-04-11 09:08 - 2018-03-06 23:29 - 000001140 _____ () C:\Program Files (x86)\metadata
2017-04-11 09:08 - 2018-03-17 16:06 - 000000040 _____ () C:\Program Files (x86)\settings.dat
2017-12-28 20:10 - 2018-02-08 20:25 - 000000132 _____ () C:\Users\ASUS\AppData\Roaming\Adobe BMP Format CS6 Prefs
2018-02-08 20:31 - 2018-03-18 05:43 - 000000132 _____ () C:\Users\ASUS\AppData\Roaming\Adobe PNG Format CS6 Prefs
2017-04-26 10:44 - 2017-05-11 19:46 - 000000132 _____ () C:\Users\ASUS\AppData\Roaming\Adobe Targa Format CS6 Prefs
2017-04-11 09:11 - 2017-04-11 09:11 - 000000038 ___SH () C:\Users\ASUS\AppData\Local\1754111884ee9ab5277ca00.95260103
2017-07-07 22:36 - 2017-07-07 22:36 - 000000037 ___SH () C:\Users\ASUS\AppData\Local\20986331705021ca58edc424.96250074
2017-04-07 14:17 - 2017-04-26 19:53 - 000000600 _____ () C:\Users\ASUS\AppData\Local\PUTTY.RND
2017-06-16 22:23 - 2018-03-04 22:32 - 000007609 _____ () C:\Users\ASUS\AppData\Local\Resmon.ResmonCfg
Some zero byte size files/folders:
C:\Windows\SysWOW64\wfs.exe
C:\Windows\SysWOW64\WFSR.dll
LastRegBack: 2018-03-13 23:01
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 14.03.2018
Ran by ASUS (18-03-2018 10:01:06)
Running from C:\Users\ASUS\Desktop
Windows 10 Enterprise Version 1709 16299.309 (X64) (2017-11-25 18:31:33)
Boot Mode: Normal
Administrator (S-1-5-21-2746278279-2939389576-4119914495-500 - Administrator - Disabled)
ASUS (S-1-5-21-2746278279-2939389576-4119914495-1001 - Administrator - Enabled) => C:\Users\ASUS
DefaultAccount (S-1-5-21-2746278279-2939389576-4119914495-503 - Limited - Disabled)
defaultuser0 (S-1-5-21-2746278279-2939389576-4119914495-1000 - Limited - Disabled) => C:\Users\defaultuser0
Guest (S-1-5-21-2746278279-2939389576-4119914495-501 - Limited - Disabled)
WDAGUtilityAccount (S-1-5-21-2746278279-2939389576-4119914495-504 - Limited - Disabled)
AV: Malwarebytes (Disabled - Up to date) {23007AD3-69FE-687C-2629-D584AFFAF72B}
AV: 360 Total Security (Enabled - Up to date) {0371CA44-3F80-A1D3-BECE-910620B58D50}
AS: Malwarebytes (Disabled - Up to date) {98619B37-4FC4-67F2-1C99-EEF6D47DBD96}
AS: 360 Total Security (Enabled - Up to date) {B8102BA0-19BA-AE5D-847E-AA745B32C7ED}
360 Total Security (HKLM-x32\...\360TotalSecurity) (Version: 9.6.0.1270 - 360 Security Center)
ACDSee Pro 3 (HKLM-x32\...\{1B280FAF-AE10-4E31-A41A-DB3917D651DC}) (Version: 3.0.355 - ACD Systems International Inc.)
Active Directory Authentication Library for SQL Server (HKLM\...\{32C0D7B2-1046-43AC-98AD-B748E1910916}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
Active Directory Authentication Library for SQL Server (x86) (HKLM-x32\...\{F40FA676-46B1-4609-85EF-D2F1F79E0C0E}) (Version: 13.0.1601.5 - Microsoft Corporation) Hidden
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 18.011.20038 - Adobe Systems Incorporated)
Adobe Flash Player 29 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 29.0.0.113 - Adobe Systems Incorporated)
Adobe Photoshop CS6 (HKLM-x32\...\{74EB3499-8B95-4B5C-96EB-7B342F3FD0C6}) (Version: 13.0 - Adobe Systems Incorporated)
Alcor Micro USB Card Reader Driver (HKLM-x32\...\{9D569A6E-C9DF-490E-93E0-7AFD28D1F9BB}) (Version: 20.23.401.14519 - Alcor Micro Corp.) Hidden
Alcor Micro USB Card Reader Driver (HKLM-x32\...\InstallShield_{9D569A6E-C9DF-490E-93E0-7AFD28D1F9BB}) (Version: 20.23.401.14519 - Alcor Micro Corp.)
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 382.33 - NVIDIA Corporation) Hidden
Apple Application Support (32-bit) (HKLM-x32\...\{D4C80B0C-CF67-43A7-90C3-466853543B54}) (Version: 6.3 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{B2A2E8AF-BC48-4191-B2C4-3846A19835CA}) (Version: 6.3 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{AA7D90D2-2387-4FA5-A3AF-96811BE49BFD}) (Version: 11.0.5.14 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{19589375-5C58-4AFA-842F-8B34744CCEAD}) (Version: 2.5.0.1 - Apple Inc.)
Application Insights Tools for Visual Studio 2015 (HKLM-x32\...\{0E4C791E-B78E-477D-BD5A-CDD0985BA6EC}) (Version: 7.0.20622.1 - Microsoft Corporation)
ArcSoft WebCam Companion 3 (HKLM-x32\...\{34985F59-8F6F-46F4-9AD5-53E2714294D2}) (Version: 3.0.189 - ArcSoft)
ASUS PTP Driver (HKLM-x32\...\{7618E419-9124-4E6C-9AF4-487A6DDEC1C5}) (Version: 11.0.11 - ASUS)
ASUS Touchpad Handwriting (HKLM-x32\...\{F3ED910A-9041-49D0-9C70-BD9E1DC5B08E}) (Version: 1.0.2 - ASUS)
ATK Package (HKLM-x32\...\{AB5C933E-5C7D-4D30-B314-9C83A49B94BE}) (Version: 1.0.0043 - ASUS)
AudioWizard (HKLM-x32\...\{57E770A2-2BAF-4CAA-BAA3-BD896E2254D3}) (Version: 1.0.0.157 - ICEpower a/s)
AutoHotkey 1.1.28.00 (HKLM\...\AutoHotkey) (Version: 1.1.28.00 - Lexikos)
AutoIt v3.3.14.2 (HKLM-x32\...\AutoItv3) (Version: 3.3.14.2 - AutoIt Team)
Azure AD Authentication Connected Service (HKLM-x32\...\{8A1AD070-269F-4A15-AAB5-76AB896EF195}) (Version: 14.0.25420 - Microsoft Corporation) Hidden
AzureTools.Notifications (HKLM-x32\...\{1E5CA362-39B6-4BD0-B9C0-69CF15F0FEA2}) (Version: 2.7.30611.1601 - Microsoft Corporation) Hidden
Bandicam (HKLM-x32\...\Bandicam) (Version: 3.3.3.1209 - Bandisoft)
Bandicam MPEG-1 Decoder (HKLM-x32\...\BandiMPEG1) (Version: - Bandicam.com)
BattlePing (HKLM-x32\...\{DB480AC3-1578-B8DC-3F8F-786A2A4E3BC7}) (Version: 1.4.3 - BattlePing)
Blend for Visual Studio SDK for .NET 4.5 (HKLM-x32\...\{37E53780-3944-4A6A-842F-727128E8616E}) (Version: 3.0.40218.0 - Microsoft Corporation) Hidden
CCleaner (HKLM\...\CCleaner) (Version: 5.41 - Piriform)
Cheat Engine 6.7 (HKLM-x32\...\Cheat Engine 6.7_is1) (Version: - Cheat Engine)
ClickOnce Bootstrapper Package for Microsoft .NET Framework (HKLM-x32\...\{D1844DC3-B378-47CC-AB40-7FC16C79A2CD}) (Version: 4.7.02558 - Microsoft Corporation) Hidden
Conexant HD Audio (HKLM\...\CNXT_AUDIO_HDA) (Version: 8.66.34.55 - Conexant)
DiagnosticsHub_CollectionService (HKLM\...\{A5DD0731-C724-4037-B35B-B80782AACE00}) (Version: 15.0.27128 - Microsoft Corporation) Hidden
Dotfuscator and Analytics Community Edition 5.22.0 (HKLM-x32\...\{60018889-9E0F-43E8-9B89-29E8C828B40A}) (Version: 5.22.0.3788 - PreEmptive Solutions) Hidden
Entity Framework 6.1.3 Tools for Visual Studio 15 (HKLM-x32\...\{F8C0447E-D45C-4E52-94E8-C6340AAC9DB8}) (Version: 6.1.60104.0 - Microsoft Corporation) Hidden
Entity Framework 6.1.3 Tools for Visual Studio 2015 Update 1 (HKLM-x32\...\{2A56910C-69C8-495D-8ED8-9080F0A14E58}) (Version: 14.0.41103.0 - Microsoft Corporation)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 65.0.3325.162 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.7 - Google Inc.) Hidden
Hotspot Shield 6.5.2 (HKLM-x32\...\{AF599C42-A2E5-4251-B7EE-4925B177CBA7}) (Version: 6.5.2.10372 - AnchorFree Inc.) Hidden
Hotspot Shield 6.5.2 (HKLM-x32\...\HotspotShield) (Version: 6.5.2 - AnchorFree Inc.) Hidden
HxD Hex Editor version 1.7.7.0 (HKLM-x32\...\HxD Hex Editor_is1) (Version: 1.7.7.0 - Maël Hörz)
icecap_collection_neutral (HKLM-x32\...\{9149432D-3BEE-4869-B6F5-7A5CF843A612}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
icecap_collection_x64 (HKLM\...\{D0C9796E-CB35-4440-885D-9630A0153D1E}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
icecap_collectionresources (HKLM-x32\...\{B96B62E4-2EE4-45EC-8082-246FFC1B12E3}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
icecap_collectionresourcesx64 (HKLM-x32\...\{262EE643-72FF-406D-9776-C6B65443DA5B}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
IDA Pro v6.8 and Hex-Rays Decompiler (ARM,x64,x86) (HKLM-x32\...\IDA Pro_6.8_is1) (Version: - Hex-Rays SA)
Intel(R) Chipset Device Software (HKLM-x32\...\{aaa7f0fb-02dc-4576-beef-7d24842c5fbe}) (Version: 10.1.1.32 - Intel(R) Corporation) Hidden
Intel(R) Dynamic Platform and Thermal Framework (HKLM-x32\...\{654EE65D-FAA4-4EA6-8C07-DC94E6A304D4}) (Version: 8.2.10900.330 - Intel Corporation)
Intel(R) Management Engine Components (HKLM\...\{1CEAC85D-2590-4760-800F-8DE5E91F3700}) (Version: 11.5.0.1015 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 21.20.16.4550 - Intel Corporation)
Intel(R) Serial IO (HKLM\...\{9FD91C5C-44AE-4D9D-85BE-AE52816B0294}) (Version: 30.63.1620.3 - Intel Corporation)
Intel® Security Assist (HKLM-x32\...\{8B08DDA1-FDE7-4897-8EB6-E0B048A6D88B}) (Version: 1.0.1.618 - Intel Corporation)
IntelliTraceProfilerProxy (HKLM-x32\...\{0A2EDF2C-9A71-43D7-964A-696BB7CEAC65}) (Version: 15.0.25.0 - Microsoft Corporation) Hidden
iTunes (HKLM\...\{1D7D1271-5258-4F5A-B8C1-7176BF398782}) (Version: 12.7.3.46 - Apple Inc.)
K-Lite Mega Codec Pack 14.0.0 (HKLM-x32\...\KLiteCodecPack_is1) (Version: 14.0.0 - KLCP)
Malwarebytes version 3.4.4.2398 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 3.4.4.2398 - Malwarebytes)
Microsoft .NET Framework 4.5 Multi-Targeting Pack (HKLM-x32\...\{56E962F0-4FB0-3C67-88DB-9EAA6EEFC493}) (Version: 4.5.50710 - Microsoft Corporation)
Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (ENU) (HKLM-x32\...\{D3517C62-68A5-37CF-92F7-93C029A89681}) (Version: 4.5.50932 - Microsoft Corporation)
Microsoft .NET Framework 4.5.1 Multi-Targeting Pack (HKLM-x32\...\{6A0C6700-EA93-372C-8871-DCCF13D160A4}) (Version: 4.5.50932 - Microsoft Corporation)
Microsoft .NET Framework 4.5.1 SDK (HKLM-x32\...\{19A5926D-66E1-46FC-854D-163AA10A52D3}) (Version: 4.5.51641 - Microsoft Corporation)
Microsoft .NET Framework 4.5.2 Multi-Targeting Pack (ENU) (HKLM-x32\...\{290FC320-2F5A-329E-8840-C4193BD7A9EE}) (Version: 4.5.51209 - Microsoft Corporation)
Microsoft .NET Framework 4.5.2 Multi-Targeting Pack (HKLM-x32\...\{19E8AE59-4D4A-3534-B567-6CC08FA4102E}) (Version: 4.5.51651 - Microsoft Corporation)
Microsoft .NET Framework 4.6 SDK (HKLM-x32\...\{B5915D37-0637-4A26-A3AA-C5DC9F856370}) (Version: 4.6.00081 - Microsoft Corporation)
Microsoft .NET Framework 4.6 Targeting Pack (ENU) (HKLM-x32\...\{034547E9-D8FA-49E7-8B9C-4C9861FB9146}) (Version: 4.6.00127 - Microsoft Corporation)
Microsoft .NET Framework 4.6 Targeting Pack (HKLM-x32\...\{2CC6A4A7-AAC2-46C9-9DBB-3727B5954F65}) (Version: 4.6.00081 - Microsoft Corporation)
Microsoft .NET Framework 4.6.1 SDK (HKLM-x32\...\{2F0ECC80-B9E4-4485-8083-CD32F22ABD92}) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft .NET Framework 4.6.1 Targeting Pack (ENU) (HKLM-x32\...\{8EEB28EE-5141-411C-9CF0-9952264FE4AF}) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft .NET Framework 4.6.1 Targeting Pack (HKLM-x32\...\{8BC3EEC9-090F-4C53-A8DA-1BEC913040F9}) (Version: 4.6.01055 - Microsoft Corporation)
Microsoft .NET Version Manager (x64) 1.0.0-beta5 (HKLM\...\{c5a4aba3-1aba-3ef8-b2d5-c3fa37f59738}) (Version: 1.0.10609.0 - Microsoft Corporation)
Microsoft DirectX SDK (August 2007) (HKLM-x32\...\{F0A4913F-46A5-48F2-BC73-EE41A6C81EB3}) (Version: 9.20.1057 - Microsoft® Corporation)
Microsoft Office Professional Plus 2016 - en-us (HKLM\...\ProplusRetail - en-us) (Version: 16.0.6769.2040 - Microsoft Corporation)
Microsoft OneDrive (HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\OneDriveSetup.exe) (Version: 18.025.0204.0009 - Microsoft Corporation)
Microsoft Project Professional 2016 - en-us (HKLM\...\ProjectProRetail - en-us) (Version: 16.0.6769.2040 - Microsoft Corporation)
Microsoft Silverlight (HKLM-x32\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50907.0 - Microsoft Corporation)
Microsoft SQL Server 2012 Command Line Utilities (HKLM\...\{9D573E71-1077-4C7E-B4DB-4E22A5D2B48B}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft SQL Server 2012 Native Client (HKLM\...\{49D665A2-4C2A-476E-9AB8-FCC425F526FC}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft SQL Server 2014 Management Objects (HKLM-x32\...\{2774595F-BC2A-4B12-A25B-0C37A37049B0}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2014 Management Objects (x64) (HKLM\...\{1F9EB3B6-AED7-4AA7-B8F1-8E314B74B2A5}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2014 Transact-SQL ScriptDom (HKLM\...\{020CDFE0-C127-4047-B571-37C82396B662}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2014 T-SQL Language Service (HKLM-x32\...\{47D08E7A-92A1-489B-B0BF-415516497BCE}) (Version: 12.0.2000.8 - Microsoft Corporation)
Microsoft SQL Server 2016 LocalDB (HKLM\...\{E359515A-92E6-4FA3-A2C9-E1BA02D8DE6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft SQL Server 2016 Management Objects (HKLM-x32\...\{0F1C8E2F-199A-4946-B3BF-0906DACFD032}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft SQL Server 2016 Management Objects (x64) (HKLM\...\{20EA85AA-2A1D-4F11-B09F-4BA2BF3C8989}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft SQL Server 2016 T-SQL Language Service (HKLM-x32\...\{8BFDE775-C5B8-46DB-84EF-43FFC8A2E8AD}) (Version: 13.0.14500.10 - Microsoft Corporation)
Microsoft SQL Server 2016 T-SQL ScriptDom (HKLM\...\{D091DE8C-EA0F-49AF-8DE3-BD6C79737C6E}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft SQL Server Compact 4.0 SP1 x64 ENU (HKLM\...\{78909610-D229-459C-A936-25D92283D3FD}) (Version: 4.0.8876.1 - Microsoft Corporation)
Microsoft SQL Server Data Tools - enu (14.0.60519.0) (HKLM-x32\...\{4E27B0EF-7BAB-432A-AF3D-3FC8F3F7353F}) (Version: 14.0.60519.0 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2014 (HKLM\...\{FC3BB979-AA54-4B60-BBA3-2C4DA6E08D80}) (Version: 12.0.2402.29 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2014 (HKLM-x32\...\{091CE6AA-2753-4F6E-AD1C-0E875744EB54}) (Version: 12.0.2402.29 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2016 (HKLM\...\{96EB5054-C775-4BEF-B7B9-AA96A295EDCD}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2016 (HKLM-x32\...\{84C23ECA-FE4D-494F-9247-3EBAD57E7F0C}) (Version: 13.0.1601.5 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2017 CTP2.1 (HKLM\...\{9BAD8F82-A221-42CE-AFF0-7CAB825790C9}) (Version: 14.0.600.250 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2017 CTP2.1 (HKLM-x32\...\{F0DD1AA8-44D7-4ACE-AF65-7378EA5D884C}) (Version: 14.0.600.250 - Microsoft Corporation)
Microsoft Visio Professional 2016 - en-us (HKLM\...\VisioProRetail - en-us) (Version: 16.0.6769.2040 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.30319 (HKLM\...\{DA5E371C-6333-3D8A-93A4-6FD5B20BCC6E}) (Version: 10.0.30319 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32\...\{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.60610 (HKLM-x32\...\{95716cce-fc71-413f-8ad5-56c2892d4b3a}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32\...\{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 (HKLM-x32\...\{ce085a78-074e-4823-8dc1-8a721b94b76d}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x64) - 14.12.25810 (HKLM-x32\...\{e2ee15e2-a480-4bc5-bfb7-e9803d1d9823}) (Version: 14.12.25810.0 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x86) - 14.12.25810 (HKLM-x32\...\{56e11d69-7cc9-40a5-a4f9-8f6190c4d84d}) (Version: 14.12.25810.0 - Microsoft Corporation)
Microsoft Visual Studio Community 2015 with Updates (HKLM-x32\...\{79b486b9-c5f0-4096-a00c-8351f59587c2}) (Version: 14.0.25420.1 - Microsoft Corporation)
Microsoft Visual Studio Installer (HKLM\...\{6F320B93-EE3C-4826-85E0-ADF79F8D4C61}) (Version: 1.14.164.111 - Microsoft Corporation)
Microsoft Web Deploy 3.6 (HKLM\...\{94E1227C-08A9-4962-B388-1F05D89AEA75}) (Version: 3.1238.1962 - Microsoft Corporation)
MSBuild/NuGet Integration 14.0 (x86) (HKLM-x32\...\{128C1654-3B9E-4959-8BFB-CE6F09C0A01D}) (Version: 14.0.25420 - Microsoft Corporation) Hidden
Multi-Device Hybrid Apps using C# - Templates - ENU (HKLM-x32\...\{12D99739-FFD3-3761-8AA6-F929E0FE407E}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
Mumble 1.2.19 (HKLM-x32\...\{F62A874F-2354-49B1-87BE-CAAD7C8FA084}) (Version: 1.2.19 - Thorvald Natvig)
NovaRO (HKLM-x32\...\NovaRO_is1) (Version: 1.1.0 - NovaRO)
NVIDIA PhysX System Software 9.17.0524 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.17.0524 - NVIDIA Corporation)
Office 16 Click-to-Run Extensibility Component (HKLM\...\{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.6729.1019 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.6729.1019 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (HKLM\...\{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.6729.1019 - Microsoft Corporation) Hidden
PDF Settings CS6 (HKLM-x32\...\{BFEAAE77-BD7F-4534-B286-9C5CB4697EB1}) (Version: 11.0 - Adobe Systems Incorporated) Hidden
PreEmptive Analytics Visual Studio Components (HKLM-x32\...\{436A18DD-5F2C-4B3C-985E-AD3C13B0CC25}) (Version: 1.2.5134.1 - PreEmptive Solutions) Hidden
Prerequisites for SSDT (HKLM-x32\...\{21373064-AD95-48DB-A32E-0D9E08EF7355}) (Version: 12.0.2000.8 - Microsoft Corporation)
Prerequisites for SSDT (HKLM-x32\...\{B7E94916-7AE6-4F7F-A377-7A410A42BA19}) (Version: 13.0.1601.5 - Microsoft Corporation)
Python 2.7.12 (HKLM-x32\...\{9DA28CE5-0AA5-429E-86D8-686ED898C665}) (Version: 2.7.12150 - Python Software Foundation)
Qualcomm Atheros Bluetooth Suite (64) (HKLM\...\{A84A4FB1-D703-48DB-89E0-68B6499D2801}) (Version: 10.0.1.7 - Qualcomm Atheros)
Qualcomm Atheros Client Installation Program (HKLM-x32\...\{28006915-2739-4EBE-B5E8-49B25D32EB33}) (Version: 10.0 - Qualcomm Atheros)
Ragnarok Online (HKLM-x32\...\{181579B5-0028-4E01-AC27-97ED80352279}) (Version: 15.2.2 - Gravity Interactive, Inc.)
Ragnarok Restart (HKLM-x32\...\{06A73F7C-3719-4664-89DC-21FB0B3D7C9D}) (Version: 1.0.2 - Gravity Interactive, Inc.) Hidden
Ragnarok Restart (HKLM-x32\...\Ragnarok Restart 1.0.2) (Version: 1.0.2 - Gravity Interactive, Inc.)
RAMDisk (HKLM-x32\...\{08051769-4EA7-48EA-BB07-8BB683433F62}) (Version: 4.4.0.36 - Dataram, Inc.)
Razer Cortex (HKLM-x32\...\Razer Cortex_is1) (Version: 8.5.11.584 - Razer Inc.)
Razer Synapse (HKLM-x32\...\{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.20.17.116 - Razer Inc.)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 10.9.422.2016 - Realtek)
Roslyn Language Services - x86 (HKLM-x32\...\{6970C7E1-F99D-388D-8903-DF8FCE677FED}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
Roslyn Language Services - x86 (HKLM-x32\...\{6C1985E7-E1C5-3A95-86EF-2C62465F15C3}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
SciTE4AutoHotkey v3.0.06.01 (HKLM-x32\...\SciTE4AutoHotkey) (Version: v3.0.06.01 - fincs)
Speccy (HKLM\...\Speccy) (Version: 1.30 - Piriform)
Spotify (HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\Spotify) (Version: 1.0.58.573.g57c9cd87 - Spotify AB)
SWFPlayer 2.6.2.0 (HKLM-x32\...\SWFPlayer_is1) (Version: 2.6.2.0 - Michael Faust, Alpha Interactive)
Team Explorer for Microsoft Visual Studio 2015 Update 3.1 (HKLM-x32\...\{7A95671A-759E-3B83-B763-4289D1D24D73}) (Version: 14.102.25619 - Microsoft) Hidden
TeamSpeak 3 Client (HKLM\...\TeamSpeak 3 Client) (Version: 3.1.8 - TeamSpeak Systems GmbH)
Test Tools for Microsoft Visual Studio 2015 (HKLM-x32\...\{9EABBFE1-7EED-47D9-8FB8-21D7E4808057}) (Version: 14.0.23107 - Microsoft Corporation) Hidden
TypeScript Power Tool (HKLM-x32\...\{465ACA24-B8D6-4FEC-A42D-9EFCB92CD560}) (Version: 1.8.34.0 - Microsoft Corporation) Hidden
TypeScript Tools for Microsoft Visual Studio 2015 (HKLM-x32\...\{BA5762C7-D35F-4725-A4BD-525854127018}) (Version: 1.8.36.0 - Microsoft Corporation) Hidden
Universal CRT Extension SDK (HKLM-x32\...\{1FBCBC17-4527-2340-0832-B1D49C41FF67}) (Version: 10.0.26624 - Microsoft Corporation) Hidden
Universal CRT Extension SDK (HKLM-x32\...\{284FA9A0-CEDD-81D3-5A19-5858E95FD0C4}) (Version: 10.0.10150 - Microsoft Corporation) Hidden
Universal CRT Headers Libraries and Sources (HKLM-x32\...\{8BFBEC30-33CC-13B4-849F-3B036F27466A}) (Version: 10.0.26624 - Microsoft Corporation) Hidden
Universal CRT Headers Libraries and Sources (HKLM-x32\...\{ABD37F71-FC3F-F525-C7B3-BDD95F684C51}) (Version: 10.0.10150 - Microsoft Corporation) Hidden
Universal CRT Redistributable (HKLM-x32\...\{A9D6F52C-694E-3E41-7AB8-5BEB644742A5}) (Version: 10.1.16299.15 - Microsoft Corporation) Hidden
Universal CRT Tools x64 (HKLM\...\{E053089E-7953-3219-814F-F485FC151C54}) (Version: 10.1.16299.15 - Microsoft Corporation) Hidden
Universal CRT Tools x86 (HKLM-x32\...\{B9424F08-0617-C4F6-A798-5A9250C1A738}) (Version: 10.1.16299.15 - Microsoft Corporation) Hidden
Update for (KB2504637) (HKLM-x32\...\{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}.KB2504637) (Version: 1 - Microsoft Corporation)
vcpp_crt.redist.clickonce (HKLM-x32\...\{0074562E-F896-4994-9086-79F8BC8DE02C}) (Version: 14.12.25830 - Microsoft Corporation) Hidden
Vegas Pro 13.0 (64-bit) (HKLM-x32\...\Vegas Pro 13.0 (64-bit)) (Version: 13.0 (64-bit) - Exµs ™)
Visual Studio 2012 x64 Redistributables (HKLM\...\{8C775E70-A791-4DA8-BCC3-6AB7136F4484}) (Version: 14.0.0.1 - AVG Technologies)
Visual Studio 2015 Update 3 (KB3022398) (HKLM-x32\...\{7a68448b-9cf2-4049-bd73-5875f1aa7ba2}) (Version: 14.0.25420 - Microsoft Corporation)
Visual Studio Community 2017 (HKLM\...\e145a82c) (Version: 15.5.27130.2024 - Microsoft Corporation)
VLC media player (HKLM-x32\...\VLC media player) (Version: 3.0.1 - VideoLAN)
VS Immersive Activate Helper (HKLM-x32\...\{8A2BDA07-3417-46C1-9058-CB32BC63E30E}) (Version: 16.0.76.0 - Microsoft Corporation) Hidden
VS JIT Debugger (HKLM\...\{F8F52853-A1A7-42C7-A082-5A6D5853BB0B}) (Version: 16.0.76.0 - Microsoft Corporation) Hidden
VS Script Debugging Common (HKLM\...\{0EE5749D-2DC0-460F-AB1C-06B3EDB42426}) (Version: 16.0.76.0 - Microsoft Corporation) Hidden
VS Update core components (HKLM-x32\...\{B2918D01-1D89-34D3-87EF-A28121BC6EB7}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
vs_BlendMsi (HKLM-x32\...\{18640789-304F-40B5-884B-130B4A97D83B}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_clickoncebootstrappermsi (HKLM-x32\...\{A68D7884-F036-4A0D-AE1A-410E0311E135}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_clickoncebootstrappermsires (HKLM-x32\...\{91DDDFB5-1782-48C2-BA2A-8F4D9DE39D27}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_clickoncesigntoolmsi (HKLM-x32\...\{6A1ECF65-2CBF-4B33-9D4A-D1C0A0E5FE45}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_communitymsi (HKLM-x32\...\{595F5D63-8773-4182-A1E0-EC9ECF4B6EA4}) (Version: 15.0.27102 - Microsoft Corporation) Hidden
vs_communitymsires (HKLM-x32\...\{40040E64-50EB-4FCF-B209-DA0B20821759}) (Version: 15.0.26621 - Microsoft Corporation) Hidden
vs_devenvmsi (HKLM-x32\...\{BFFA2FFB-1095-4ADD-A352-368806D2412B}) (Version: 15.0.26621 - Microsoft Corporation) Hidden
vs_filehandler_amd64 (HKLM-x32\...\{9414C260-D479-49EB-B0BF-01C1F5076EA0}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_filehandler_x86 (HKLM-x32\...\{A57BD1C0-42AD-42F8-AFEB-FAC7E6ABB005}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_FileTracker_Singleton (HKLM-x32\...\{70F69B4F-7950-4841-8139-5D0C7EDD2FE6}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_Graphics_Singletonx64 (HKLM\...\{B11D79C6-332C-47B6-B58C-2F88A4911C7C}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_Graphics_Singletonx86 (HKLM-x32\...\{2497054A-0269-4F45-98AE-F469F89CC45F}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_minshellinteropmsi (HKLM-x32\...\{231C8ADB-BF59-458E-A909-CFA825F46388}) (Version: 15.0.27102 - Microsoft Corporation) Hidden
vs_minshellmsi (HKLM-x32\...\{9CDD69A2-765A-4970-AB6B-595A740C614F}) (Version: 15.0.27019 - Microsoft Corporation) Hidden
vs_minshellmsires (HKLM-x32\...\{6DFE6F8D-B61D-4348-AB70-4ABF1210DFD5}) (Version: 15.0.26621 - Microsoft Corporation) Hidden
vs_SQLClickOnceBootstrappermsi (HKLM-x32\...\{5779B6DD-604A-41CE-BC3D-9D4BDDA22AD2}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_tipsmsi (HKLM-x32\...\{1AC6CC3D-7724-4D84-9270-798A2191AB1C}) (Version: 15.0.27005 - Microsoft Corporation) Hidden
vs_update3notification (HKLM-x32\...\{AB3DF932-C990-34D4-BF43-970F760DA3CD}) (Version: 14.0.25431 - Microsoft Corporation) Hidden
Vulkan Run Time Libraries 1.0.42.1 (HKLM\...\VulkanRT1.0.42.1) (Version: 1.0.42.1 - LunarG, Inc.)
WCF Data Services 5.6.4 Runtime (HKLM-x32\...\{DB85E7BD-B2DD-43D4-B3C0-23D7B527B597}) (Version: 5.6.62175.4 - Microsoft Corporation) Hidden
WCF Data Services Tools for Microsoft Visual Studio 2015 (HKLM-x32\...\{0A3B508E-5638-4471-BCC9-954E1868CB86}) (Version: 5.6.62175.4 - Microsoft Corporation) Hidden
Windows Driver Package - ASUS (AsusPTPDrv) HIDClass (06/03/2016 11.0.0.11) (HKLM\...\0B4533347E894EFA3F8DC5D4B35CF2D1B1BF756F) (Version: 06/03/2016 11.0.0.11 - ASUS)
WinFlash (HKLM-x32\...\{8F21291E-0444-4B1D-B9F9-4370A73E346D}) (Version: 3.2.1 - ASUS)
WinPcap 4.1.3 (HKLM-x32\...\WinPcapInst) (Version: 4.1.0.2980 - Riverbed Technology, Inc.)
WinRAR 5.50 (64-bit) (HKLM\...\WinRAR archiver) (Version: 5.50.0 - win.rar GmbH)
WOERO (HKLM-x32\...\WOERO_is1) (Version: 20171206 - WOERO)
ContextMenuHandlers1: [SD360] -> {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-03-13] ()
ContextMenuHandlers3: [MBAMShlExt] -> [CC]{57CE581A-0CB6-4266-9CA0-19364C90A0B3} => -> No File
ContextMenuHandlers4: [SD360] -> {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-03-13] ()
ContextMenuHandlers5: [igfxDTCM] -> {9B5F5829-A529-4B12-814A-E81BCB8D93FC} => C:\WINDOWS\System32\DriverStore\FileRepository\igdlh64.inf_amd64_463164d40c3d26ce\igfxDTCM.dll [2016-11-30] (Intel Corporation)
ContextMenuHandlers5: [NvCplDesktopContext] -> {3D1975AF-48C6-4f8e-A182-BE0E08FA86A9} => C:\WINDOWS\system32\nvshext.dll [2017-05-18] (NVIDIA Corporation)
ContextMenuHandlers6: [MBAMShlExt] -> [CC]{57CE581A-0CB6-4266-9CA0-19364C90A0B3} => -> No File
ContextMenuHandlers6: [SD360] -> {086F171D-5ED1-4ED2-B736-CFF3AD6A128E} => C:\Program Files (x86)\360\Total Security\MenuEx64.dll [2018-03-13] ()
Task: {24B7B055-D882-4EA8-8DCD-C8D0230D6D57} - System32\Tasks\Microsoft\VisualStudio\VSIX Auto Update 14 => C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\VSIXAutoUpdate.exe [2016-06-20] (Microsoft Corporation)
Task: {8688567E-8102-4D27-933A-9E759A314CCD} - System32\Tasks\CCleaner Update => C:\Program Files\CCleaner\CCUpdate.exe [2018-03-07] (Piriform Ltd)
Task: {8FA86C41-F674-466C-B102-C41673D92761} - System32\Tasks\Microsoft\Office\Office ClickToRun Service Monitor => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2016-04-24] (Microsoft Corporation)
Task: {99AC7774-A7D4-48EB-B1A4-DC2622F0AB58} - System32\Tasks\Microsoft\Office\Office Automatic Updates => C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe [2016-04-24] (Microsoft Corporation)
Task: {9E1E8147-710E-4510-87D0-FFBA9E04817B} - System32\Tasks\Apple\AppleSoftwareUpdate => C:\Program Files (x86)\Apple Software Update\SoftwareUpdate.exe [2017-10-12] (Apple Inc.)
Task: {A325DA10-9C1F-43F4-BE04-697633F99F34} - System32\Tasks\GoogleUpdateTaskMachineCore => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2017-04-01] (Google Inc.)
Task: {A365C2D0-3A4C-4008-838E-2B38D48CA98D} - System32\Tasks\Intel PTT EK Recertification => C:\Program Files\Intel\iCLS Client\IntelPTTEKRecertification.exe [2016-02-20] (Intel(R) Corporation)
Task: {A48B624F-9686-454B-977E-AF581340E27A} - System32\Tasks\Adobe Flash Player NPAPI Notifier => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_29_0_0_113_Plugin.exe [2018-03-14] (Adobe Systems Incorporated)
Task: {A59F0840-F079-4D2A-B2B8-A23C6ABFD5FF} - System32\Tasks\Adobe Flash Player Updater => C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [2018-03-14] (Adobe Systems Incorporated)
Task: {AD0E0F2C-6881-4714-A7DF-58956934C44F} - System32\Tasks\ASUS Touchpad Handwriting (x64) => C:\Program Files (x86)\ASUS\ASUS Touchpad Handwriting\Exe\x64\AsusHWLaunch64.exe [2016-06-20] (ASUSTeK Computer Inc.)
Task: {C2A4DE53-B0EB-42AE-8991-E8E8E3BF10EB} - System32\Tasks\GoogleUpdateTaskMachineUA => C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [2017-04-01] (Google Inc.)
Task: {C4BBAEA8-0A0A-4AAD-A85D-D6B007C20383} - System32\Tasks\CCleanerSkipUAC => C:\Program Files\CCleaner\CCleaner.exe [2018-03-07] (Piriform Ltd)
Task: {CED1D1E4-8EF4-4635-940D-F63260CFFCC6} - System32\Tasks\Microsoft\Office\OfficeTelemetryAgentLogOn2016 => C:\Program Files\Microsoft Office\root\Office16\msoia.exe [2017-02-14] (Microsoft Corporation)
Task: {D105CB65-FB62-4DEF-8CA1-1AFBD26C4358} - System32\Tasks\Microsoft\Office\OfficeTelemetryAgentFallBack2016 => C:\Program Files\Microsoft Office\root\Office16\msoia.exe [2017-02-14] (Microsoft Corporation)
Task: {DF1EB0D6-4DDD-42E9-9E01-DBE3F09E9C81} - System32\Tasks\DropboxUpdateTaskMachineCore => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
Task: {DF9A8A99-4703-4106-B209-7ABA0D8AFEB3} - System32\Tasks\DropboxUpdateTaskMachineUA => C:\Program Files (x86)\Dropbox\Update\DropboxUpdate.exe
ShortcutWithArgument: C:\Users\ASUS\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) -> --disk-cache-dir=G:\
ShortcutWithArgument: C:\Users\ASUS\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\ImplicitAppShortcuts\5d696d521de238c3\Google Chrome.lnk -> C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google Inc.) -> --profile-directory=Default
2018-01-05 00:14 - 2018-01-05 00:14 - 000088888 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\zlib1.dll
2018-01-05 00:13 - 2018-01-05 00:13 - 001356088 _____ () C:\Program Files\Common Files\Apple\Apple Application Support\libxml2.dll
2017-02-14 18:28 - 2016-04-24 16:24 - 000172224 _____ () C:\Program Files\Common Files\Microsoft Shared\ClickToRun\ApiClient.dll
2017-09-29 22:41 - 2017-09-29 22:41 - 000184432 _____ () C:\WINDOWS\SYSTEM32\inputhost.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 000477184 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
2017-12-14 18:25 - 2017-12-14 18:26 - 058590720 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\Microsoft.Photos.dll
2017-09-30 16:04 - 2017-09-30 16:05 - 002523136 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\UnityEngineDelegates.dll
2017-11-14 20:00 - 2017-11-14 20:01 - 000164864 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\VideoPlugin.dll
2017-09-30 16:04 - 2017-09-30 16:05 - 000675328 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\IPPNativePlugin.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 003727360 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\MediaEngineCSWrapper.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 002270720 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\TrackingDLLUWP.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 016395264 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\PhotosApp.Windows.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 003579904 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\MediaEngine.dll
2017-12-14 18:25 - 2017-12-14 18:25 - 003204096 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\AppCore.Windows.dll
2017-08-29 21:46 - 2017-08-29 21:46 - 003553704 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\Microsoft.UI.Xaml.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 000043520 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\Microsoft.Photos.Edit.Services.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 004038144 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\Microsoft.People.PeoplePicker.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 001367040 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\Microsoft.RichMedia.Ink.Controls.dll
2017-12-14 18:25 - 2017-12-14 18:26 - 000214528 _____ () C:\Program Files\WindowsApps\Microsoft.Windows.Photos_2017.39101.16720.0_x64__8wekyb3d8bbwe\SKU.dll
2017-12-15 18:15 - 2017-12-15 18:16 - 004307968 _____ () C:\Program Files\WindowsApps\Microsoft.WindowsCalculator_10.1712.3351.0_x64__8wekyb3d8bbwe\Calculator.exe
2018-03-15 00:16 - 2018-02-22 09:26 - 011044864 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\CortanaApi.dll
2018-03-15 00:16 - 2018-02-22 09:21 - 001804288 _____ () C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\Cortana.Core.dll
2018-03-14 21:33 - 2018-03-13 20:15 - 000099240 _____ () C:\Program Files (x86)\360\Total Security\deepscan\qutmload.dll
2016-05-17 13:50 - 2016-05-17 13:50 - 001243936 _____ () C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\ACE.dll
2018-03-14 21:33 - 2018-03-13 20:15 - 000567392 _____ () C:\Program Files (x86)\360\Total Security\safemon\wdui2.dll
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
2018-03-14 21:42 - 2018-03-14 21:42 - 000000027 _____ C:\WINDOWS\system32\Drivers\etc\hosts
127.0.0.1 localhost
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\Control Panel\Desktop\\Wallpaper -> C:\Windows\web\wallpaper\Windows\img0.jpg
DNS Servers: 122.197.254.7 - 122.197.254.4
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer => (SmartScreenEnabled: RequireAdmin)
Windows Firewall is enabled.
HKLM\...\StartupApproved\Run: => "SecurityHealth"
HKLM\...\StartupApproved\Run: => "WindowsDefender"
HKLM\...\StartupApproved\Run: => "AdobeAAMUpdater-1.0"
HKLM\...\StartupApproved\Run: => "ShadowPlay"
HKLM\...\StartupApproved\Run: => "iTunesHelper"
HKLM\...\StartupApproved\Run: => "ZAM"
HKLM\...\StartupApproved\Run32: => "VoodooShield"
HKLM\...\StartupApproved\Run32: => "Dropbox"
HKLM\...\StartupApproved\Run32: => "AdobeAAMUpdater-1.0"
HKLM\...\StartupApproved\Run32: => "SmartAudio"
HKLM\...\StartupApproved\Run32: => "SecurityHealth"
HKLM\...\StartupApproved\Run32: => "WindowsDefender"
HKLM\...\StartupApproved\Run32: => "GrpConv"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\StartupFolder: => "hide.me VPN.lnk"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "CCleaner"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "Spotify Web Helper"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "Steam"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "uTorrent"
HKU\S-1-5-21-2746278279-2939389576-4119914495-1001\...\StartupApproved\Run: => "CyberGhost"
FirewallRules: [{C89AD21E-3AE8-4E56-B8E7-D02DEB6F3E6B}] => (Allow) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
FirewallRules: [{99B5E8A9-1A58-47EB-B117-73A24A909ECD}] => (Allow) C:\Program Files (x86)\360\Total Security\safemon\QHSafeTray.exe
Application errors:
Error: (03/17/2018 04:41:16 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
Description: License Activation (slui.exe) failed with the following error code:
hr=0xC004F074
Command-line arguments:
RuleId=eeba1977-569e-4571-b639-7623d8bfecc0;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=73111121-5638-40f6-bc11-f1d7b0d64300;NotificationInterval=1440;Trigger=TimerEvent
Error: (03/16/2018 04:41:14 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
RuleId=eeba1977-569e-4571-b639-7623d8bfecc0;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=73111121-5638-40f6-bc11-f1d7b0d64300;NotificationInterval=1440;Trigger=NetworkAvailable
Error: (03/16/2018 04:40:49 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
RuleId=eeba1977-569e-4571-b639-7623d8bfecc0;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=73111121-5638-40f6-bc11-f1d7b0d64300;NotificationInterval=1440;Trigger=UserLogon;SessionId=2
Error: (03/15/2018 10:00:28 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
Error: (03/15/2018 10:00:26 PM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
RuleId=eeba1977-569e-4571-b639-7623d8bfecc0;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=73111121-5638-40f6-bc11-f1d7b0d64300;NotificationInterval=1440;Trigger=UserLogon;SessionId=1
Error: (03/15/2018 06:14:13 AM) (Source: Software Protection Platform Service) (EventID: 8198) (User: )
hr=0xC004F074
Error: (03/15/2018 06:10:46 AM) (Source: Bonjour Service) (EventID: 100) (User: )
Description: Task Scheduling Error: m->NextScheduledSPRetry 10561641
Description: Task Scheduling Error: m->NextScheduledEvent 10561641
System errors:
Error: (03/18/2018 10:02:00 AM) (Source: DCOM) (EventID: 10016) (User: MAMBA)
and APPID
to the user MAMBA\ASUS SID (S-1-5-21-2746278279-2939389576-4119914495-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Error: (03/18/2018 04:52:37 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
and APPID
to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Error: (03/18/2018 04:11:31 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
and APPID
Error: (03/17/2018 04:52:28 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
and APPID
Error: (03/17/2018 04:06:48 PM) (Source: DCOM) (EventID: 10016) (User: MAMBA)
and APPID
Error: (03/17/2018 04:52:09 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
and APPID
Error: (03/17/2018 04:07:58 AM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
and APPID
Error: (03/16/2018 04:52:00 PM) (Source: DCOM) (EventID: 10016) (User: NT AUTHORITY)
and APPID
Windows Defender:
Date: 2018-03-12 18:34:39.999
Description:
Windows Defender Antivirus has detected malware or other potentially unwanted software.
For more information please see the following:
https://go.microsoft.com/fwlink/?li...2/WpePro!rfn&threatid=2147692509&enterprise=0
Severity: Medium
Category: Tool
Path: file:_C:\Users\ASUS\Desktop\wpe pro - modified - Shortcut.lnk;file:_F:\wpepro09mod (3)\wpe pro - modified.exe
Detection Origin: Local machine
Detection Type: Concrete
Detection Source: Real-Time Protection
Process Name: C:\Windows\explorer.exe
Signature Version: AV: 1.263.443.0, AS: 1.263.443.0, NIS: 118.5.0.0
Engine Version: AM: 1.1.14600.4, NIS: 2.1.14202.0
Date: 2018-03-12 18:33:47.399
Description:
Severity: Medium
Category: Tool
Path: file:_F:\wpepro09mod (3)\wpe pro - modified.exe
Date: 2018-03-12 18:21:23.941
Description:
Severity: Medium
Category: Tool
Detection Source: System
Date: 2018-03-12 18:00:25.066
Description:
Severity: Medium
Category: Tool
Date: 2018-03-12 17:28:46.891
Description:
Severity: Medium
Category: Tool
Process Name: C:\Users\ASUS\Desktop\ZHPDiag3.exe
Date: 2018-01-01 11:27:08.344
Description:
Windows Defender Antivirus has encountered an error trying to update signatures.
New Signature Version:
Previous Signature Version: 1.259.923.0
Update Source: Microsoft Malware Protection Center
Signature Type: AntiVirus
Update Type: Full
Current Engine Version:
Previous Engine Version: 1.1.14405.2
Error code: 0x80070645
Error description: This action is only valid for products that are currently installed.
Description:
Signature Type: AntiSpyware
Update Type: Full
Description:
Update Type: Full
Date: 2018-01-01 10:57:13.344
Description:
Update Type: Full
Description:
Update Type: Full
CodeIntegrity:
Date: 2018-03-18 09:57:28.546
Description:
Code Integrity determined that a process (\Device\HarddiskVolume3\Windows\System32\svchost.exe) attempted to load \Device\HarddiskVolume3\Program Files\Bonjour\mdnsNSP.dll that did not meet the Microsoft signing level requirements.
Date: 2018-03-18 09:57:28.545
Description:
Date: 2018-03-18 09:56:28.488
Description:
Code Integrity determined that a process (\Device\HarddiskVolume3\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\MicrosoftEdgeCP.exe) attempted to load \Device\HarddiskVolume3\Program Files (x86)\360\Total Security\I18N64.dll that did not meet the Store signing level requirements.
Date: 2018-03-18 09:56:28.327
Description:
Date: 2018-03-18 09:51:43.547
Description:
Date: 2018-03-18 09:51:43.544
Description:
Date: 2018-03-18 09:39:21.268
Description:
Date: 2018-03-18 09:39:21.266
Description:
Processor: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
Percentage of memory in use: 90%
Total physical RAM: 3979.04 MB
Available physical RAM: 377.85 MB
Total Virtual: 7576.05 MB
Available Virtual: 3141.71 MB
Drive c: () (Fixed) (Total:124.09 GB) (Free:42.79 GB) NTFS
Drive d: () (Fixed) (Total:687.37 GB) (Free:310.2 GB) NTFS
Drive f: (F) (Fixed) (Total:119.56 GB) (Free:108.49 GB) NTFS
Drive g: (RAMDISK) (Fixed) (Total:0.78 GB) (Free:0.78 GB) FAT32
\\?\Volume{d89045d1-0000-0000-0000-100000000000}\ (System Reserved) (Fixed) (Total:0.49 GB) (Free:0.45 GB) NTFS
Disk: 0 (Size: 800 MB) (Disk ID: CA82D378)
Partition 1: (Active) - (Size=800 MB) - (Type=0B)
Disk: 1 (MBR Code: Windows 7/8/10) (Size: 931.5 GB) (Disk ID: D89045D1)
Partition 1: (Active) - (Size=500 MB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=124.1 GB) - (Type=07 NTFS)
Partition 3: (Not Active) - (Size=119.6 GB) - (Type=0F Extended)
Partition 4: (Not Active) - (Size=687.4 GB) - (Type=07 NTFS)
One thing I want to know is, I rarely close my laptop, is it why it causes high memory usaged?
I see that you're using 90% of available memory. I will need a speccy report to figure out what's running
Please go HERE and download the portable version of Speccy. Save it to somewhere you can find, locate the file and as it comes as a Zip file use your favorite unzip application to decompress it. Open the newly created folder and double left click Speccy.exe if you have a 32 bit system or Speccy64.exe if yours is 64bit. If you are not sure what your system is click HERE.
Speccy will open and after a short wait will display a summary of your system specs.
[*]Click on the file menu.
[*]Then click Publish snapshot.
A dialogue box will ask you to confirm, select yes.
Another dialogue box will open
[*]Click Copy to Clipboard.
[*]Then click Close.
Now that your link has been copied please paste it into your next post. It should look something like the example below :)
http://speccy.piriform.com/results/6waAHapcLrZIVPakgxXXXXXXX
BTW: once you have finished with speccy and no longer want it removing it is easy because it is a portable app with no install. Simply delete the downloaded file and folder you created when you decompressed it. Gone:thumbsup:
If your W10 is non-genuine, then I'm afraid we can't continue any further.
PCHF has very strict rules about providing help to those with counterfeit and non-genuine versions of Windows.
I would severely advise you to get a genuine copy of Windows. Now that you mention this, that is most likely the culprit, as fake versions of Windows contain malicious scripts, files, garbage, etc.
I see, and I understand that.
When I get the chance to upgrade this to a genuine one, I would definitely come back here.
Thank you tho for all the supports!
Reactions: jmarket
