Low FPS / performance on games
imig
29
My gaming PC, I believe, should be getting good performance on games that I am playing (Arma 3, Empire: total war, MOWAS2, and Call of duty: Modern Warfare 2019) I thought the low performance was due to game engines on the mostly older games but since playing COD: MW I have noticed that even then I'm getting around 17-21 FPS during game play. I have used my GeForce app on my PC and set the game to optimized, plus have the I game settings well below the "max" VRAM usage line that it provides. I am a %100 noob when it comes to PCs and know nothing about anything.
Except that I have made sure everything is updated and should have the proper drivers based off of the GeForce app for my GPU on the PC
Here is my build, and thank you for the help!
CAS: DEEPCOOL MATREXX 55 RGB Mid Tower ATX Gaming Case w/ Tempered Glass Front and Side
CPU: Intel® Core™ Processor i9-9900K 3.60GHZ 16MB Intel Smart Cache LGA1151
CS_FAN: Default case fans
FAN: CyberpowerPC Asetek 550LC 120mm Liquid Cooling CPU Cooler (Dual (Push-Pull) Standard 120MM Fans)
HDD: 240GB WD Green SSD + 2TB SATA III Hard Drive Combo (Combo Drive)
IUSB: Built-in USB 2.0 Ports
MEMORY: 16GB (8GBx2) RGB Lightning DDR4/3000MHz Memory Module (GEIL Super Luce RGB)
MOTHERBOARD: MSI Z390-A PRO ATX w/ USB 3.1, 2 PCIe x16, 4 PCIe x1, 6 SATA3, 1 M.2 (Key E) 1 M.2 SATA/PCIe
NETWORK: Onboard Gigabit LAN Network
NOISEREDUCE1: Anti-Vibration Fan Mounts
OS: Windows 10 Home (64-bit Edition)
OVERCLOCK: Pro OC (Performance Overclock 10% or more)
POWERSUPPLY: 700 Watts - Enermax Revo DUO series 700Watts 80 Plus Gold high-efficient airflow w/ Dual Fans Power Supply
INTERNET: Intel® Wireless-AC 3168 Wi-Fi 802.11ac Dual Band 2.4 GHz, 5 GHz up to 433Gbps + BT 4.2 w/ PCI-E Adapter & Dual Antennas
VIDEO: ASUS GeForce® RTX 2070 DUAL 8GB GDDR6 (Turing) [VR Ready] (Single Card)
