Well basically the link I provided to the build wasn't working so I sent you my pcpartpicker username so you can find the build thru my profile. I'll try once again to send the linkNot sure what you mean sirprize10
https://pcpartpicker.com/list/8YvcKZWell basically the link I provided to the build wasn't working so I sent you my pcpartpicker username so you can find the build thru my profile. I'll try once again to send the link
Up to you but if me I would stick with the stock cooler and put some of the cash saved towards a better screen, gaming on a screen any less than 24" is awful imoYour aftermarket cooler, a very important thing I must make you aware of, if you use it you will void your AMD CPU warranty, AMD are clear on this, see below;
This Limited Warranty shall be null and void if the AMD microprocessor which is the subject of this Limited Warranty is used with any heatsink/fan other than the one provided herewith.
Full AMD article here
Yes. I am currently moving but I have made a part list with my American friends who built something similar to me.Any updates for us?
Well I checked alot of different fan gpu coolers, most of which had incompatibility issues, I do not want to spend alot of money on water cooling, and I doubt that matters in smaller builds. As for the PSU, I wanted one from the same brand so that my case would have no problems with fitting it. As for the Monitor, I have chose to avoid 4k and to use my old VIZIO tv, which is larger than most monitors. But I would like some advice on which monitor to chose between my used VIZIO tv or a monitor from best buy, where screen prices have gone down by hundreds.Not a bad list of parts but wouldnt use the PSU anywhere near any computer.
You should also note the compatibility issue with the aftermarket cooler and keep in mind that by using it you wil void your AMD CPU warranty.
I'm trying to keep it under budget, and I think I will use my AOC monitor and my tvI'd suggest you look at Amazon. I have two Asus monitors from Amazon and they have been flawless.
You do not need a third party cooler, your CPU ships with a perfectly good one and as previously advised if you use anything else and your CPU fails you have no warranty, in case you ask, yes it is possible to identify the use of a third party cooler, they have rather expensive equiptment to help them do so.Well I checked alot of different fan gpu coolers, most of which had incompatibility issues
Any generic ATX PSU will fit in your case and being honest I wouldnt trust the Thermaltake - Smart 530W PSU as a doorstop, expensive junk that is not even Bronze efficiency ratedAs for the PSU, I wanted one from the same brand so that my case would have no problems with fitting it.
Thanks , as always for your pc help. I think that finalised the build, I hope I can run games decentleyYou do not need a third party cooler, your CPU ships with a perfectly good one and as previously advised if you use anything else and your CPU fails you have no warranty, in case you ask, yes it is possible to identify the use of a third party cooler, they have rather expensive equiptment to help them do so.
Any generic ATX PSU will fit in your case and being honest I wouldnt trust the Thermaltake - Smart 530W PSU as a doorstop, expensive junk that is not even Bronze efficiency rateddescribed on Toms PSU Tier list here as the following;
Tier Four
Built down to a low price. Not exactly the most stable units ever created. Very basic safety circuitry or even thin gauge wiring used. Not for gaming rigs or overclocking systems of any kind. Avoid unless your budget dictates your choice.
A much better, less expensive and far safer PSU is the SeaSonic G Series SSR-550RM
