Laptop Wi-Fi card issue.
Merabah
7
24
Lima, Perú.
My Wi-Fi is weird, the router is fine, it's my laptop. The Wi-Fi card (I think?) is rare, the Wi-Fi suddenly went off once and the connection is slow/unstable. For example I used to play League with 50ms without problems but now it's just unplayable/inconsistent. Even at few meters from the router. But if I use the UTP cable it will be as fast as ever. It's clearly my laptop's Wi-Fi, other devices work well. Help, please :( A similar problem happened with my laptop a while back. Sometimes it goes ok though.
Run this tool on the system.
Download to your desktop and right click on it and Run as Administrator.
Once the program has completed Copy the contents for the Text file that it produces and Paste into your next post.
Welcome to PCHF Lets get some info from your machine, to get things rolling.
Step 1: Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
Step 2: MiniToolBox Scan
Checkmark following boxes:
Flush DNS
Reset FF proxy Settings
Reset Ie Proxy Settings
Report IE Proxy Settings
Report FF Proxy Settings
List content of Hosts
List IP configuration
List Winsock Entries
List last 10 Event Viewer log
List Installed Programs
List Devices (problems only)
Click Go post the result.
Step 3: Autoruns Scan.
Step 4: HijackThis.
2- Run the program.
5- Copy paste the log here.
Sorry about it being in Spanish, it's my first language :( When this was done I was closer to the modem than where I normally are, idk if it matters.
Configuraci¢n IP de Windows
Nombre de host. . . . . . . . . : HP-PC
Sufijo DNS principal . . . . . :
Tipo de nodo. . . . . . . . . . : h¡brido
Enrutamiento IP habilitado. . . : no
Proxy WINS habilitado . . . . . : no
Lista de b£squeda de sufijos DNS: cpe.tdp.com
Adaptador de Ethernet Ethernet:
Estado de los medios. . . . . . . . . . . : medios desconectados
Sufijo DNS espec¡fico para la conexi¢n. . : cpe.tdp.com
Descripci¢n . . . . . . . . . . . . . . . : Realtek PCIe FE Family Controller
Direcci¢n f¡sica. . . . . . . . . . . . . : 5C-B9-01-FA-41-17
DHCP habilitado . . . . . . . . . . . . . : s¡
Configuraci¢n autom tica habilitada . . . : s¡
Adaptador de LAN inal mbrica Conexi¢n de rea local* 4:
Descripci¢n . . . . . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Direcci¢n f¡sica. . . . . . . . . . . . . : C6-8E-8F-C4-8F-CD
Adaptador de LAN inal mbrica Wi-Fi:
Descripci¢n . . . . . . . . . . . . . . . : Realtek RTL8723BE 802.11 bgn Wi-Fi Adapter
Direcci¢n f¡sica. . . . . . . . . . . . . : C4-8E-8F-C4-8F-CD
Direcci¢n IPv4. . . . . . . . . . . . . . : 192.168.1.5(Preferido)
M scara de subred . . . . . . . . . . . . : 255.255.255.0
Concesi¢n obtenida. . . . . . . . . . . . : domingo, 11 de diciembre de 2016 02:25:36 p.m.
La concesi¢n expira . . . . . . . . . . . : domingo, 11 de diciembre de 2016 03:25:36 p.m.
Puerta de enlace predeterminada . . . . . : 192.168.1.1
Servidor DHCP . . . . . . . . . . . . . . : 192.168.1.1
Servidores DNS. . . . . . . . . . . . . . : 200.48.225.130
200.48.225.146
NetBIOS sobre TCP/IP. . . . . . . . . . . : habilitado
Nombre de interfaz : Wi-Fi
Actualmente hay 1 redes visibles.
SSID 1 : WLAN_AC11
Tipo de red : Infraestructura
Autenticaci¢n : WPA-Personal
Cifrado : CCMP
Perfiles en la interfaz Wi-Fi:
Perfiles de directiva de grupo (solo lectura)
<Ninguno>
Perfiles de usuario
Perfil de todos los usuarios : WLAN_AC11
Haciendo ping a 194.119.131.66 con 32 bytes de datos:
Respuesta desde 194.119.131.66: bytes=32 tiempo=180ms TTL=53
Respuesta desde 194.119.131.66: bytes=32 tiempo=207ms TTL=53
Respuesta desde 194.119.131.66: bytes=32 tiempo=229ms TTL=53
Respuesta desde 194.119.131.66: bytes=32 tiempo=205ms TTL=53
Estad¡sticas de ping para 194.119.131.66:
Paquetes: enviados = 4, recibidos = 4, perdidos = 0
(0% perdidos),
Tiempos aproximados de ida y vuelta en milisegundos:
M¡nimo = 180ms, M ximo = 229ms, Media = 205ms
Haciendo ping a plus.net [212.159.9.2] con 32 bytes de datos:
Tiempo de espera agotado para esta solicitud.
Estad¡sticas de ping para 212.159.9.2:
Paquetes: enviados = 4, recibidos = 0, perdidos = 4
(100% perdidos),
Traza a la direcci¢n cns1.uk.vianw.net [194.119.131.66]
sobre un m ximo de 30 saltos:
1 1 ms 1 ms 2 ms 192.168.1.1
2 15 ms 59 ms 15 ms 10.37.0.1
3 18 ms 12 ms 43 ms 10.226.252.157
4 * * * Tiempo de espera agotado para esta solicitud.
5 * 21 ms 61 ms 10.111.2.133
6 70 ms 10 ms 90 ms grtlurem6-0-1-0-1-110.net.telefonicaglobalsolutions.com [5.53.0.149]
7 112 ms 101 ms 107 ms hu0-9-0-0-grtmiana4.net.telefonicaglobalsolutions.com [5.53.3.155]
8 109 ms 106 ms 104 ms ix-ae-15-0.tcore1.MLN-Miami.as6453.net [63.243.152.141]
9 225 ms 204 ms 204 ms if-ae-7-2.tcore1.AEQ-Ashburn.as6453.net [66.198.154.177]
10 * 238 ms 215 ms if-ae-2-2.tcore2.AEQ-Ashburn.as6453.net [216.6.87.1]
11 216 ms 176 ms 231 ms if-ae-11-2.thar2.NJY-Newark.as6453.net [216.6.87.138]
12 * * 294 ms if-ae-1-3.thar1.NJY-Newark.as6453.net [216.6.57.1]
13 180 ms 237 ms 206 ms if-ae-8-2.tcore1.LDN-London.as6453.net [66.198.70.174]
14 229 ms 208 ms 202 ms if-ae-28-2.thar1.LY9-London.as6453.net [80.231.60.110]
15 275 ms 214 ms 200 ms tengige0-0-0-2-t40-mse1.router.uk.clara.net [195.219.92.46]
16 254 ms 210 ms 201 ms tengige0-1-1-0-t6-ar14.router.uk.clara.net [195.157.3.110]
17 179 ms 214 ms 194 ms cns1.uk.vianw.net [194.119.131.66]
Traza completa.
Se han iniciado estos servicios de Windows:
Administrador de conexiones de acceso remoto
Administrador de conexiones de Windows
Administrador de credenciales
Administrador de cuentas de seguridad
Administrador de sesi¢n local
Administrador de usuarios
Adquisici¢n de im genes de Windows (WIA)
Agente de conexi¢n de red
Agente de eventos de tiempo
Agente de eventos del sistema
Aislamiento de claves CNG
Aplicaci¢n auxiliar de NetBIOS sobre TCP/IP
Aplicaci¢n auxiliar IP
Asignador de extremos de RPC
Audio de Windows
Avira Programador
Avira Real-Time Protection
Avira Service Host
Ayudante para el inicio de sesi¢n de cuenta Microsoft
Centro de seguridad
Cliente de directiva de grupo
Cliente de seguimiento de v¡nculos distribuidos
Cliente DHCP
Cliente DNS
Cola de impresi¢n
Compilador de extremo de audio de Windows
Conexiones de red
Configuraci¢n autom tica de dispositivos conectados a la red
Configuraci¢n autom tica de WLAN
Copias de seguridad de Windows
CoreMessaging
Detecci¢n de hardware shell
Detecci¢n SSDP
Energ¡a
Estaci¢n de trabajo
Experiencia de calidad de audio y v¡deo de Windows (qWave)
Firewall de Windows
Host de proveedor de detecci¢n de funci¢n
Host de sistema de diagn¢stico
Host del servicio de diagn¢stico
HP Support Solutions Framework Service
Informaci¢n de la aplicaci¢n
Iniciador de procesos de servidor DCOM
Inicio de sesi¢n secundario
Instrumental de administraci¢n de Windows
Llamada a procedimiento remoto (RPC)
Motor de filtrado de base
Optimizaci¢n de entrega
Plug and Play
Programador de tareas
Proveedor de Grupo Hogar
Proveedor de instant neas de software de Microsoft
Publicaci¢n de recurso de detecci¢n de funci¢n
Reconoc. ubicaci¢n de red
Registrador de configuraci¢n de Windows Connect Now
Registro de eventos de Windows
Servicio Asistente para la compatibilidad de programas
Servicio auxiliar de host para aplicaciones
Servicio de administrador de licencias de Windows
Servicio de almacenamiento
Servicio de asociaci¢n de dispositivos
Servicio de cach‚ de fuentes de Windows
Servicio de detecci¢n autom tica de proxy web WinHTTP
Servicio de directivas de diagn¢stico
Servicio de dispositivo de interfaz humana
Servicio de geolocalizaci¢n
Servicio de infraestructura de tareas en segundo plano
Servicio de lista de redes
Servicio de notificaci¢n de eventos de sistema
Servicio de perfil de usuario
Servicio de protocolo de t£nel de sockets seguros
Servicio de repositorio de estado
Servicio de sensores
Servicio de transferencia inteligente en segundo plano (BITS)
Servicio de uso compartido de datos
Servicio Hacer clic y ejecutar de Microsoft Office
Servicio Interfaz de almacenamiento en red
Servicios de cifrado
Servidor
Servidor del modelo de datos del mosaico
Sistema de cifrado de archivos (EFS)
Sistema de eventos COM+
Superfetch
Telefon¡a
Telemetr¡a y experiencias del usuario conectado
Temas
Windows Driver Foundation - User-mode Driver Framework
Windows Search
Se ha completado el comando correctamente.
Microsoft Windows [Versi¢n 10.0.10586]
Nombre de imagen PID Nombre de sesi¢n N£m. de ses Uso de memor
System Idle Process 0 Services 0 4 KB
System 4 Services 0 359,980 KB
smss.exe 368 Services 0 192 KB
csrss.exe 524 Services 0 3,840 KB
csrss.exe 624 Console 1 4,968 KB
wininit.exe 648 Services 0 420 KB
services.exe 696 Services 0 8,436 KB
lsass.exe 720 Services 0 10,620 KB
svchost.exe 836 Services 0 13,988 KB
winlogon.exe 864 Console 1 3,848 KB
svchost.exe 944 Services 0 9,372 KB
svchost.exe 348 Services 0 119,444 KB
dwm.exe 408 Console 1 41,988 KB
svchost.exe 692 Services 0 44,380 KB
svchost.exe 964 Services 0 8,096 KB
svchost.exe 984 Services 0 24,028 KB
svchost.exe 1188 Services 0 24,592 KB
svchost.exe 1240 Services 0 25,760 KB
svchost.exe 1408 Services 0 21,588 KB
spoolsv.exe 1508 Services 0 6,464 KB
sched.exe 1704 Services 0 4,976 KB
svchost.exe 1672 Services 0 2,864 KB
svchost.exe 1648 Services 0 16,420 KB
dasHost.exe 2128 Services 0 12,632 KB
svchost.exe 2316 Services 0 4,564 KB
svchost.exe 2324 Services 0 13,940 KB
officeclicktorun.exe 2432 Services 0 12,024 KB
Avira.ServiceHost.exe 2452 Services 0 23,568 KB
taskhostw.exe 3912 Console 1 12,900 KB
sihost.exe 3920 Console 1 25,780 KB
RuntimeBroker.exe 3608 Console 1 58,112 KB
Avira.SystemSpeedup.UI.Sy 4320 Console 1 3,652 KB
YouCamService.exe 4760 Console 1 1,472 KB
SearchIndexer.exe 2512 Services 0 41,444 KB
Apoint.exe 4300 Console 1 3,668 KB
RtkNGUI64.exe 5008 Console 1 4,552 KB
RAVBg64.exe 4184 Console 1 5,028 KB
ApMsgFwd.exe 5376 Console 1 1,124 KB
secureline.exe 5464 Console 1 2,368 KB
CCleaner64.exe 5504 Console 1 12,200 KB
ApntEx.exe 5628 Console 1 2,068 KB
conhost.exe 5656 Console 1 2,108 KB
hidfind.exe 5684 Console 1 1,948 KB
HPMSGSVC.exe 5732 Console 1 1,556 KB
Lightshot.exe 5812 Console 1 2,484 KB
Avira.Systray.exe 5836 Console 1 5,168 KB
jusched.exe 5884 Console 1 3,404 KB
avgnt.exe 5912 Console 1 3,908 KB
svchost.exe 5588 Console 1 11,896 KB
SettingSyncHost.exe 10020 Console 1 1,408 KB
fontdrvhost.exe 9112 Console 1 336 KB
ApplicationFrameHost.exe 9476 Console 1 17,836 KB
svchost.exe 5364 Services 0 356 KB
SpotifyWebHelper.exe 6988 Console 1 1,836 KB
jucheck.exe 9544 Console 1 3,392 KB
SkypeHost.exe 10608 Console 1 528 KB
HelpPane.exe 5904 Console 1 4,068 KB
SystemSettings.exe 7140 Console 1 764 KB
avguard.exe 7944 Services 0 45,136 KB
avshadow.exe 12412 Services 0 544 KB
Music.UI.exe 2428 Console 1 24,924 KB
taskhostw.exe 7264 Console 1 18,680 KB
explorer.exe 13628 Console 1 133,840 KB
ShellExperienceHost.exe 10520 Console 1 81,812 KB
Video.UI.exe 12488 Console 1 21,052 KB
Microsoft.Photos.exe 5972 Console 1 62,328 KB
WWAHost.exe 12796 Console 1 61,004 KB
SystemSettingsBroker.exe 13728 Console 1 15,356 KB
HPSupportSolutionsFramewo 2144 Services 0 76,428 KB
wlanext.exe 17312 Services 0 5,468 KB
conhost.exe 17328 Services 0 4,684 KB
chrome.exe 4208 Console 1 166,256 KB
chrome.exe 17276 Console 1 5,936 KB
chrome.exe 14048 Console 1 6,916 KB
chrome.exe 13896 Console 1 66,264 KB
chrome.exe 14244 Console 1 88,112 KB
chrome.exe 2584 Console 1 27,224 KB
chrome.exe 6512 Console 1 25,864 KB
chrome.exe 4400 Console 1 220,812 KB
audiodg.exe 6860 Services 0 21,680 KB
svchost.exe 3408 Services 0 6,760 KB
SearchUI.exe 4472 Console 1 88,820 KB
chrome.exe 3280 Console 1 94,104 KB
chrome.exe 10680 Console 1 26,576 KB
SearchProtocolHost.exe 4604 Services 0 10,924 KB
wireless.exe 15852 Console 1 10,748 KB
SearchFilterHost.exe 14980 Services 0 6,688 KB
backgroundTaskHost.exe 6020 Console 1 13,232 KB
cmd.exe 16804 Console 1 3,680 KB
conhost.exe 15492 Console 1 7,912 KB
tasklist.exe 9360 Console 1 7,312 KB
WmiPrvSE.exe 13036 Services 0 8,124 KB
MTU MediaSenseState Bytes ent. Bytes sal. Interfaz
1500 2 26759765815 2031781316 Ethernet
1500 1 609214916 11805830 Wi-Fi
4294967295 1 0 5295985 Loopback Pseudo-Interface 1
1500 5 0 0 Conexi¢n de rea local* 4
Consultando el estado activo...
Par metros TCP globales
Estado de ajuste de escala en lado de recepci¢n : enabled
Estado de descarga Chimney : disabled
Estado de NetDMA : disabled
Acceso directo a cach‚ (DCA) : disabled
Nivel de ajuste autom tico de ventana de recepci¢n : normal
Proveedor de control de congesti¢n de complementos : none
Capacidad ECN : disabled
Marcas de tiempo RFC 1323 : disabled
RTO inicial : 3000
Estado de fusi¢n de segmentos de recepci¢n : disabled
Resistencia de RTT no SACK : disabled
Retransmisiones SYN m ximas : 2
ILista de interfaces
11...5c b9 01 fa 41 17 ......Realtek PCIe FE Family Controller
23...c6 8e 8f c4 8f cd ......Microsoft Wi-Fi Direct Virtual Adapter
14...c4 8e 8f c4 8f cd ......Realtek RTL8723BE 802.11 bgn Wi-Fi Adapter
IPv4 Tabla de enrutamiento
Rutas activas:
Destino de red M scara de red Puerta de enlace Interfaz M‚trica
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.5 25
127.0.0.0 255.0.0.0 En v¡nculo 127.0.0.1 306
127.0.0.1 255.255.255.255 En v¡nculo 127.0.0.1 306
127.255.255.255 255.255.255.255 En v¡nculo 127.0.0.1 306
192.168.1.0 255.255.255.0 En v¡nculo 192.168.1.5 281
192.168.1.5 255.255.255.255 En v¡nculo 192.168.1.5 281
192.168.1.255 255.255.255.255 En v¡nculo 192.168.1.5 281
224.0.0.0 240.0.0.0 En v¡nculo 127.0.0.1 306
224.0.0.0 240.0.0.0 En v¡nculo 192.168.1.5 281
255.255.255.255 255.255.255.255 En v¡nculo 127.0.0.1 306
255.255.255.255 255.255.255.255 En v¡nculo 192.168.1.5 281
Rutas persistentes:
Ninguno
IPv6 Tabla de enrutamiento
Rutas activas:
Cuando destino de red m‚trica Puerta de enlace
1 306 ::1/128 En v¡nculo
1 306 ff00::/8 En v¡nculo
Rutas persistentes:
Ninguno
Conexiones activas
Proto Direcci¢n local Direcci¢n remota Estado
TCP 0.0.0.0:135 HP-PC:0 LISTENING
RpcSs
[Sistema]
TCP 0.0.0.0:445 HP-PC:0 LISTENING
No se puede obtener informaci¢n de propiedad
TCP 0.0.0.0:5357 HP-PC:0 LISTENING
TCP 0.0.0.0:7680 HP-PC:0 LISTENING
DoSvc
[Sistema]
TCP 0.0.0.0:49664 HP-PC:0 LISTENING
TCP 0.0.0.0:49665 HP-PC:0 LISTENING
EventLog
[Sistema]
TCP 0.0.0.0:49666 HP-PC:0 LISTENING
[Sistema]
TCP 0.0.0.0:49667 HP-PC:0 LISTENING
Spooler
[Sistema]
TCP 0.0.0.0:49668 HP-PC:0 LISTENING
Schedule
[Sistema]
TCP 0.0.0.0:49669 HP-PC:0 LISTENING
TCP 127.0.0.1:4370 HP-PC:0 LISTENING
[SpotifyWebHelper.exe]
TCP 127.0.0.1:4380 HP-PC:0 LISTENING
TCP 127.0.0.1:8092 HP-PC:0 LISTENING
TCP 192.168.1.5:139 HP-PC:0 LISTENING
TCP 192.168.1.5:57593 msnbot-65-52-108-222:https ESTABLISHED
[Sistema]
TCP 192.168.1.5:57625 108.177.11.188:5228 ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:57670 c:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:57674 a96-6-196-29:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:57820 ec2-54-187-44-157:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:57823 ec2-54-69-119-241:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:57830 ec2-54-68-235-9:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:57834 ec2-54-69-119-241:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:57836 ec2-54-68-136-205:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58108 ec2-54-187-146-157:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58112 mia07s24-in-f78:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58113 mia07s24-in-f3:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58114 mia07s34-in-f14:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58115 va-in-f93:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58116 mia07s24-in-f78:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58117 mia07s24-in-f78:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58118 mia07s24-in-f1:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58119 vk-in-f95:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58120 mia07s25-in-f110:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58121 vk-in-f95:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58123 192.16.58.66:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58129 151.139.240.1:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58135 harlie:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58137 arn09s11-in-f163:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58139 mia07s34-in-f14:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58140 104.244.42.72:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58142 ec2-52-34-226-10:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58143 ec2-54-71-192-238:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58144 ec2-52-35-230-201:https TIME_WAIT
TCP 192.168.1.5:58149 vw-in-f91:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58152 ec2-52-29-218-170:https CLOSE_WAIT
[avguard.exe]
TCP 192.168.1.5:58153 ec2-35-156-58-128:https CLOSE_WAIT
[avguard.exe]
TCP 192.168.1.5:58154 video-edge-7e90d8:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58155 ec2-52-35-251-77:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58156 video-edge-7e90d8:https ESTABLISHED
[chrome.exe]
TCP 192.168.1.5:58157 131.253.61.100:https ESTABLISHED
wlidsvc
[Sistema]
TCP 192.168.1.6:45539 HP-PC:0 LISTENING
[SkypeHost.exe]
TCP [::]:135 HP-PC:0 LISTENING
RpcSs
[Sistema]
TCP [::]:445 HP-PC:0 LISTENING
TCP [::]:5357 HP-PC:0 LISTENING
TCP [::]:7680 HP-PC:0 LISTENING
DoSvc
[Sistema]
TCP [::]:49664 HP-PC:0 LISTENING
TCP [::]:49665 HP-PC:0 LISTENING
EventLog
[Sistema]
TCP [::]:49666 HP-PC:0 LISTENING
[Sistema]
TCP [::]:49667 HP-PC:0 LISTENING
Spooler
[Sistema]
TCP [::]:49668 HP-PC:0 LISTENING
Schedule
[Sistema]
TCP [::]:49669 HP-PC:0 LISTENING
UDP 0.0.0.0:3702 *:*
[Sistema]
[Sistema]
[Sistema]
FDResPub
[Sistema]
[Sistema]
FDResPub
[Sistema]
UDP 0.0.0.0:5353 *:*
Dnscache
[Sistema]
[chrome.exe]
UDP 0.0.0.0:5355 *:*
Dnscache
[Sistema]
UDP 0.0.0.0:49664 *:*
[Avira.ServiceHost.exe]
UDP 0.0.0.0:52787 *:*
FDResPub
[Sistema]
UDP 0.0.0.0:54220 *:*
[chrome.exe]
UDP 0.0.0.0:60815 *:*
[Avira.Systray.exe]
UDP 0.0.0.0:61100 *:*
[Sistema]
UDP 0.0.0.0:61102 *:*
[Sistema]
UDP 127.0.0.1:1900 *:*
SSDPSRV
[Sistema]
UDP 127.0.0.1:61099 *:*
SSDPSRV
[Sistema]
UDP 192.168.1.5:137 *:*
UDP 192.168.1.5:138 *:*
UDP 192.168.1.5:1900 *:*
SSDPSRV
[Sistema]
UDP 192.168.1.5:2177 *:*
QWAVE
[Sistema]
UDP 192.168.1.5:61098 *:*
SSDPSRV
[Sistema]
UDP 192.168.1.6:45539 *:*
[SkypeHost.exe]
UDP [::]:3702 *:*
[Sistema]
UDP [::]:3702 *:*
[Sistema]
UDP [::]:3702 *:*
[Sistema]
UDP [::]:3702 *:*
FDResPub
[Sistema]
UDP [::]:3702 *:*
[Sistema]
UDP [::]:3702 *:*
FDResPub
[Sistema]
UDP [::]:52788 *:*
FDResPub
[Sistema]
UDP [::]:61101 *:*
[Sistema]
UDP [::]:61103 *:*
[Sistema]
UDP [::1]:1900 *:*
SSDPSRV
[Sistema]
UDP [::1]:61097 *:*
SSDPSRV
[Sistema]
Servidor: cachewas.tdp.net.pe
Address: 200.48.225.130
Nombre: www.plus.net.cpe.tdp.com
Address: 69.172.201.153
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HPMessageService REG_SZ C:\Program Files (x86)\Hewlett-Packard\HP System Event\HPMSGSVC.exe
DropboxOEM REG_SZ "C:\Program Files (x86)\Dropbox\DropboxOEM\DropboxOEM.exe" auto
Lightshot REG_SZ C:\Program Files (x86)\Skillbrains\lightshot\Lightshot.exe
Avira SystrayStartTrigger REG_SZ "C:\Program Files (x86)\Avira\Launcher\Avira.SystrayStartTrigger.exe"
Avira System Speedup User Starter REG_SZ "C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Common.Starter.exe"
SunJavaUpdateSched REG_SZ "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
avgnt REG_SZ "C:\Program Files (x86)\Avira\Antivirus\avgnt.exe" /min
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Speedup DelayLoad
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Steam REG_SZ "C:\Program Files (x86)\Steam\steam.exe" -silent
{79F4C512-6430-4835-A988-03325E97EB8F} REG_SZ C:\Windows\system32\WindowsPowerShell\v1.0\powershell.exe -noprofile -windowstyle hidden -executionpolicy bypass iex ([Text.Encoding]::ASCII.GetString([Convert]::FromBase64String((gp 'HKCU:\Software\Classes\JvOApJCKiLgQJSO').vCBs)));
Spotify Web Helper REG_SZ "C:\Users\PROPIETARIO\AppData\Roaming\Spotify\SpotifyWebHelper.exe"
Skype REG_SZ "C:\Program Files (x86)\Skype\Phone\Skype.exe" /minimized /regrun
OneDrive REG_SZ "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\OneDrive.exe" /background
CCleaner Monitoring REG_SZ "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
Spotify REG_SZ "C:\Users\PROPIETARIO\AppData\Roaming\Spotify\Spotify.exe" -autostart -minimized
Discord REG_SZ C:\Users\PROPIETARIO\AppData\Local\Discord\app-0.0.296\Discord.exe
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6281.1202_1\amd64 REG_SZ C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6281.1202_1\amd64"
Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6281.1202_1 REG_SZ C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6281.1202_1"
Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6301.0127\amd64 REG_SZ C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6301.0127\amd64"
Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6302.0225\amd64 REG_SZ C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6302.0225\amd64"
Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6386.0412\amd64 REG_SZ C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6386.0412\amd64"
This is it.
http://speccy.piriform.com/results/rSoiKf4UGRjeRN6up4BpQwi
Ran by PROPIETARIO (administrator) on 11-12-2016 at 15:43:33
Running from "C:\Users\PROPIETARIO\Downloads"
Microsoft Windows 10 Home Single Language (X64)
Model: HP 14 Notebook PC Manufacturer: Hewlett-Packard
Boot Mode: Normal
Configuraci�n IP de Windows
Se vaci� correctamente la cach� de resoluci�n de DNS.
Realtek RTL8723BE 802.11 bgn Wi-Fi Adapter = Wi-Fi (Connected)
Realtek PCIe FE Family Controller = Ethernet (Media disconnected)
# Configuraci¢n de IPv4
pushd interface ipv4
reset
set global icmpredirects=enabled
set interface interface="Conexi¢n de rea local* 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Conexi¢n de rea local* 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Conexi¢n de rea local* 4" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# Fin de la configuraci¢n de IPv4
La concesi¢n expira . . . . . . . . . . . : domingo, 11 de diciembre de 2016 04:34:29 p.m.
200.48.225.146
Nombre: google.com.cpe.tdp.com
Haciendo ping a google.com [216.58.219.174] con 32 bytes de datos:
Respuesta desde 216.58.219.174: bytes=32 tiempo=117ms TTL=55
Respuesta desde 216.58.219.174: bytes=32 tiempo=130ms TTL=55
Estad¡sticas de ping para 216.58.219.174:
Paquetes: enviados = 2, recibidos = 2, perdidos = 0
(0% perdidos),
M¡nimo = 117ms, M ximo = 130ms, Media = 123ms
Nombre: yahoo.com.cpe.tdp.com
Haciendo ping a yahoo.com [206.190.36.45] con 32 bytes de datos:
Respuesta desde 206.190.36.45: bytes=32 tiempo=210ms TTL=47
Respuesta desde 206.190.36.45: bytes=32 tiempo=228ms TTL=47
Estad¡sticas de ping para 206.190.36.45:
(0% perdidos),
M¡nimo = 210ms, M ximo = 228ms, Media = 219ms
Haciendo ping a 127.0.0.1 con 32 bytes de datos:
Respuesta desde 127.0.0.1: bytes=32 tiempo<1m TTL=128
Estad¡sticas de ping para 127.0.0.1:
(0% perdidos),
M¡nimo = 0ms, M ximo = 0ms, Media = 0ms
Rutas activas:
Rutas persistentes:
Ninguno
Rutas activas:
Rutas persistentes:
Ninguno
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [55808] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [23552] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [51712] (Microsoft Corporation)
Catalog5 08 C:\Program Files (x86)\Bonjour\mdnsNSP.dll [121704] (Apple Inc.)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [312160] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [87040] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [87040] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog5 08 C:\Program Files\Bonjour\mdnsNSP.dll [132968] (Apple Inc.)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
Application errors:
Error: (12/11/2016 02:12:01 PM) (Source: Microsoft-Windows-CAPI2) (User: )
Description: Error en Servicios de cifrado mientras se procesaba el objeto "System Writer" de la llamada OnIdentity().
Details:
AddLegacyDriverFiles: Unable to back up image of binary Protocolo de detección de nivel de vínculo de Microsoft.
System Error:
Acceso denegado.
Error: (12/11/2016 02:07:58 PM) (Source: HP Active Health) (User: )
Description: Unable to load HPSA classes properly
Error: (12/11/2016 02:07:48 PM) (Source: Perflib) (User: )
Description: BITSC:\Windows\System32\bitsperf.dll8
Error: (12/11/2016 09:13:56 AM) (Source: Office 2013 Licensing Service) (User: )
Description: Subscription licensing service failed: -1073418154
Error: (12/10/2016 09:33:30 AM) (Source: Application Hang) (User: )
Description: El programa 7zFM.exe, versión 9.20.0.0, dejó de interactuar con Windows y se cerró. Para ver si hay más información disponible acerca del problema, comprueba el historial de problemas en la sección Seguridad y mantenimiento del Panel de control.
Identificador de proceso: 2018
Hora de inicio: 01d252f236f4ed71
Hora de finalización: 4294967295
Ruta de la aplicación: C:\Program Files\7-Zip\7zFM.exe
Identificador de informe: 9d60c5d2-bee5-11e6-82f5-5cb901fa4117
Nombre completo de paquete con errores:
Identificador de aplicación relativa del paquete con errores:
Error: (12/10/2016 09:13:55 AM) (Source: Office 2013 Licensing Service) (User: )
Error: (12/09/2016 09:05:58 PM) (Source: Application Hang) (User: )
Description: El programa Microsoft.Photos.exe, versión 16.526.11240.0, dejó de interactuar con Windows y se cerró. Para ver si hay más información disponible acerca del problema, comprueba el historial de problemas en la sección Seguridad y mantenimiento del Panel de control.
Identificador de proceso: 368
Hora de inicio: 01d25289633b22ec
Ruta de la aplicación: C:\Program Files\WindowsApps\Microsoft.Windows.Photos_16.526.11220.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exe
Identificador de informe: ac6f82eb-be7c-11e6-82f5-5cb901fa4117
Nombre completo de paquete con errores: Microsoft.Windows.Photos_16.526.11220.0_x64__8wekyb3d8bbwe
Identificador de aplicación relativa del paquete con errores: App
Error: (12/09/2016 09:02:19 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: HP-PC)
Description: No se pudo activar la aplicación Microsoft.Windows.Photos_8wekyb3d8bbwe!App debido al error: -2144927142. Consulte el registro Microsoft-Windows-TWinUI/Operational para obtener más información.
Error: (12/09/2016 09:02:11 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: HP-PC)
Description: La aplicación Microsoft.Windows.Photos_16.526.11220.0_x64__8wekyb3d8bbwe+App no se inició dentro del tiempo asignado.
Error: (12/09/2016 02:12:00 PM) (Source: Microsoft-Windows-Immersive-Shell) (User: HP-PC)
System errors:
Error: (12/11/2016 03:07:39 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: específico de la aplicaciónLocalActivación{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}NT AUTHORITYSYSTEMS-1-5-18LocalHost (con LRPC)No disponibleNo disponible
Error: (12/11/2016 12:48:50 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/11/2016 09:58:52 AM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/11/2016 09:45:58 AM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/11/2016 01:03:17 AM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/10/2016 09:11:45 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/10/2016 02:19:31 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/10/2016 10:40:31 AM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/10/2016 09:48:11 AM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/09/2016 11:31:59 PM) (Source: DCOM) (User: NT AUTHORITY)
Microsoft Office Sessions:
Error: (12/11/2016 02:12:01 PM) (Source: Microsoft-Windows-CAPI2)(User: )
Description:
Details:
System Error:
Acceso denegado.
Error: (12/11/2016 02:07:58 PM) (Source: HP Active Health)(User: )
Error: (12/11/2016 02:07:48 PM) (Source: Perflib)(User: )
Error: (12/11/2016 09:13:56 AM) (Source: Office 2013 Licensing Service)(User: )
Error: (12/10/2016 09:33:30 AM) (Source: Application Hang)(User: )
Description: 7zFM.exe9.20.0.0201801d252f236f4ed714294967295C:\Program Files\7-Zip\7zFM.exe9d60c5d2-bee5-11e6-82f5-5cb901fa4117
Error: (12/10/2016 09:13:55 AM) (Source: Office 2013 Licensing Service)(User: )
Error: (12/09/2016 09:05:58 PM) (Source: Application Hang)(User: )
Description: Microsoft.Photos.exe16.526.11240.036801d25289633b22ec4294967295C:\Program Files\WindowsApps\Microsoft.Windows.Photos_16.526.11220.0_x64__8wekyb3d8bbwe\Microsoft.Photos.exeac6f82eb-be7c-11e6-82f5-5cb901fa4117Microsoft.Windows.Photos_16.526.11220.0_x64__8wekyb3d8bbweApp
Error: (12/09/2016 09:02:19 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: HP-PC)
Description: Microsoft.Windows.Photos_8wekyb3d8bbwe!App-2144927142
Error: (12/09/2016 09:02:11 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: HP-PC)
Description: Microsoft.Windows.Photos_16.526.11220.0_x64__8wekyb3d8bbwe+App
Error: (12/09/2016 02:12:00 PM) (Source: Microsoft-Windows-Immersive-Shell)(User: HP-PC)
CodeIntegrity Errors:
Date: 2016-08-01 22:06:06.609
Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Program Files\Windows Defender\MsMpEng.exe) attempted to load \Device\HarddiskVolume4\Program Files\Bonjour\mdnsNSP.dll that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2016-08-01 22:06:06.587
Date: 2016-08-01 21:22:11.345
Date: 2016-08-01 21:22:11.323
Date: 2016-08-01 21:22:10.385
Date: 2016-08-01 21:22:10.350
Date: 2016-07-30 22:56:33.689
Description: Code Integrity determined that a process (\Device\HarddiskVolume4\Program Files\Windows Defender\MsMpEng.exe) attempted to load \Device\HarddiskVolume4\Program Files\Common Files\microsoft shared\OFFICE15\MSOXMLMF.DLL that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2016-07-29 16:51:50.823
Date: 2016-07-29 16:51:50.792
Date: 2016-07-29 11:21:40.293
µTorrent (HKCU\...\uTorrent) (Version: 3.4.9.42973 - BitTorrent Inc.)
7-Zip 9.20 (x64 edition) (HKLM\...\{23170F69-40C1-2702-0920-000001000000}) (Version: 9.20.00.0 - Igor Pavlov)
Adobe Shockwave Player 12.0 (HKLM-x32\...\Adobe Shockwave Player) (Version: 12.0.4.144 - Adobe Systems, Inc.)
ALPS Touch Pad Driver (HKLM\...\{9F72EF8B-AEC9-4CA5-B483-143980AFD6FD}) (Version: 8.1202.1711.103 - Alps Electric)
Avira Antivirus (HKLM-x32\...\Avira Antivirus) (Version: 15.0.23.58 - Avira Operations GmbH & Co. KG)
Avira Connect (HKLM-x32\...\{707e8edf-9482-4417-ae39-c9b5fe605e87}) (Version: 1.2.76.27124 - Avira Operations GmbH & Co. KG)
Avira Connect (HKLM-x32\...\{827F31DC-A307-4A62-B640-840D1A5D2698}) (Version: 1.2.76.27124 - Avira Operations GmbH & Co. KG) Hidden
Avira Phantom VPN (HKLM-x32\...\Avira Phantom VPN) (Version: 1.3.1.30415 - Avira Operations GmbH & Co. KG)
Avira System Speedup (HKLM-x32\...\Avira System Speedup_is1) (Version: 3.0.0.3502 - Avira Operations GmbH & Co. KG)
Bonjour (HKLM\...\{6E3610B2-430D-4EB0-81E3-2B57E8B9DE8D}) (Version: 3.0.0.10 - Apple Inc.)
Burnout Paradise: The Ultimate Box (HKLM-x32\...\Steam App 24740) (Version: - Criterion Games)
CCleaner (HKLM\...\CCleaner) (Version: 5.14 - Piriform)
Cisco EAP-FAST Module (HKLM-x32\...\{64BF0187-F3D2-498B-99EA-163AF9AE6EC9}) (Version: 2.2.14 - Cisco Systems, Inc.)
Cisco LEAP Module (HKLM-x32\...\{AF312B06-5C5C-468E-89B3-BE6DE2645722}) (Version: 1.0.19 - Cisco Systems, Inc.)
Cisco PEAP Module (HKLM-x32\...\{0A4EF0E6-A912-4CDE-A7F3-6E56E7C13A2F}) (Version: 1.1.6 - Cisco Systems, Inc.)
Curse (HKLM-x32\...\{75080CC9-4C7A-45C4-B149-9C2790FA88F6}) (Version: 6.0.0.0 - Curse)
CyberLink Media Suite 10 (HKLM-x32\...\InstallShield_{1FBF6C24-C1fD-4101-A42B-0C564F9E8E79}) (Version: 10.0.8.4420 - CyberLink Corp.)
Cyberlink PhotoDirector (HKLM\...\{5A454EC5-217A-42a5-8CE1-2DDEC4E70E01}) (Version: 5.0.5.6618 - Nombre de su organización) Hidden
Cyberlink PhotoDirector (HKLM-x32\...\InstallShield_{5A454EC5-217A-42a5-8CE1-2DDEC4E70E01}) (Version: 5.0.5.6618 - CyberLink Corp.)
CyberLink Power Media Player 12 (HKLM-x32\...\InstallShield_{B46BEA36-0B71-4A4E-AE41-87241643FA0A}) (Version: 12.0.5.4505 - CyberLink Corp.)
CyberLink Power2Go 8 (HKLM-x32\...\InstallShield_{2A87D48D-3FDF-41fd-97CD-A1E370EFFFE2}) (Version: 8.0.8.4316 - CyberLink Corp.)
CyberLink PowerBackup 2.6 (HKLM-x32\...\InstallShield_{ADD5DB49-72CF-11D8-9D75-000129760D75}) (Version: 2.6.1.0903 - CyberLink Corp.)
CyberLink PowerDirector 12 (HKLM\...\{E1646825-D391-42A0-93AA-27FA810DA093}) (Version: 12.0.4.4301 - Nombre de su organización) Hidden
CyberLink PowerDirector 12 (HKLM-x32\...\InstallShield_{E1646825-D391-42A0-93AA-27FA810DA093}) (Version: 12.0.4.4301 - CyberLink Corp.)
CyberLink YouCam (HKLM-x32\...\InstallShield_{01FB4998-33C4-4431-85ED-079E3EEFE75D}) (Version: 5.0.5.4523 - CyberLink Corp.)
DisableMSDefender (HKLM\...\{74FE39A0-FB76-47CD-84BA-91E2BBB17EF2}) (Version: 1.0.0 - Hewlett-Packard Company) Hidden
Discord (HKCU\...\Discord) (Version: 0.0.296 - Hammer & Chisel, Inc.)
Dropbox 25 GB (HKLM-x32\...\{597A58EC-42D6-4940-8739-FB94491B013C}) (Version: 0.9.0 - Dropbox, Inc.)
Eines de correcció del Microsoft Office 2013: català (HKLM-x32\...\{90150000-001F-0403-0000-0000000FF1CE}) (Version: 15.0.4420.1017 - Microsoft Corporation) Hidden
Energy Star (HKLM\...\{465CA2B6-98AF-4E77-BE22-A908C34BB9EC}) (Version: 1.0.9 - Hewlett-Packard Company)
Evernote v. 5.5.3 (HKLM-x32\...\{B1A0F908-1448-11E4-8684-00163E98E7D0}) (Version: 5.5.3.4236 - Evernote Corp.)
Ferramentas de verificación de Microsoft Office 2013 - Galego (HKLM-x32\...\{90150000-001F-0456-0000-0000000FF1CE}) (Version: 15.0.4420.1017 - Microsoft Corporation) Hidden
Foxit PhantomPDF (HKLM-x32\...\{89BF1D4D-1D62-451E-9496-B971BDE82720}) (Version: 6.0.33.715 - Foxit Corporation)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 55.0.2883.87 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.31.5 - Google Inc.) Hidden
Hewlett-Packard ACLM.NET v1.2.2.3 (HKLM-x32\...\{6F340107-F9AA-47C6-B54C-C3A19F11553F}) (Version: 1.00.0000 - Hewlett-Packard Company) Hidden
Hextech Repair Tool (HKLM-x32\...\{7F9A97E6-E666-11E5-B582-B88687E82322}) (Version: 1.0.16 - Riot Games, Inc.)
Hotline Miami (HKLM\...\Steam App 219150) (Version: - Dennaton Games)
HP Documentation (HKLM-x32\...\{0166934F-40D5-4B60-944A-09857610804E}) (Version: 1.5.0.0 - Hewlett-Packard)
HP Registration Service (HKLM\...\{D1E8F2D7-7794-4245-B286-87ED86C1893C}) (Version: 1.2.7745.4851 - Hewlett-Packard)
HP SimplePass (HKLM-x32\...\InstallShield_{314FAD12-F785-4471-BCE8-AB506642B9A1}) (Version: 8.01.53 - Hewlett-Packard)
HP Support Assistant (HKLM-x32\...\{78E2C850-ADA6-420D-BA35-2F4A9BE733CC}) (Version: 8.2.8.25 - HP)
HP Support Solutions Framework (HKLM-x32\...\{8EF98706-3C4B-4C5B-B035-01187E17D0E6}) (Version: 12.5.32.37 - HP)
HP System Event Utility (HKLM-x32\...\{F12B17AB-FCDA-4380-9D35-E3F871BF1093}) (Version: 1.2.6 - Hewlett-Packard Company)
HP Wireless Button Driver (HKLM-x32\...\{EFA01423-3857-468C-B7B6-F30AA08E50BC}) (Version: 1.1.5.1 - Hewlett-Packard Company)
Inst5675 (HKLM\...\{2DE6247C-7077-451B-8BA7-FFD1A2ABBB47}) (Version: 8.01.53 - Softex Inc.) Hidden
Inst5676 (HKLM\...\{878F6913-7421-4713-97F7-0A736EE2A188}) (Version: 8.01.53 - Softex Inc.) Hidden
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 9.5.24.1790 - Intel Corporation)
Intel(R) Processor Graphics (HKLM-x32\...\{F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}) (Version: 10.18.10.3960 - Intel Corporation)
Intel(R) Rapid Storage Technology (HKLM\...\{409CB30E-E457-4008-9B1A-ED1B9EA21140}) (Version: 13.2.0.1016 - Intel Corporation)
Java 8 Update 101 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180101F0}) (Version: 8.0.1010.13 - Oracle Corporation)
League of Legends (HKLM-x32\...\{E86FBD55-9636-46A1-ACA7-57F8C09CC322}) (Version: 3.0.1 - Riot Games) Hidden
League of Legends (HKLM-x32\...\League of Legends 3.0.1) (Version: 3.0.1 - Riot Games)
Left 4 Dead 2 (HKLM\...\Steam App 550) (Version: - Valve)
Lightshot-5.4.0.1 (HKLM-x32\...\{30A5B3C9-2084-4063-A32A-628A98DE512B}_is1) (Version: 5.4.0.1 - Skillbrains)
Microsoft Office 365 - es-es (HKLM\...\O365HomePremRetail - es-es) (Version: 15.0.4875.1001 - Microsoft Corporation)
Microsoft Office Professional Plus 2013 (HKLM-x32\...\Office15.PROPLUS) (Version: 15.0.4420.1017 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft XNA Framework Redistributable 4.0 Refresh (HKLM-x32\...\{D69C8EDE-BBC5-436B-8E0E-C5A6D311CF4F}) (Version: 4.0.30901.0 - Microsoft Corporation)
Office 15 Click-to-Run Extensibility Component (HKLM-x32\...\{90150000-008C-0000-0000-0000000FF1CE}) (Version: 15.0.4875.1001 - Microsoft Corporation) Hidden
Office 15 Click-to-Run Licensing Component (HKLM\...\{90150000-008F-0000-1000-0000000FF1CE}) (Version: 15.0.4875.1001 - Microsoft Corporation) Hidden
Office 15 Click-to-Run Localization Component (HKLM-x32\...\{90150000-008C-0C0A-0000-0000000FF1CE}) (Version: 15.0.4875.1001 - Microsoft Corporation) Hidden
OpenAL (HKLM-x32\...\OpenAL) (Version: - )
Outils de vérification linguistique 2013 de Microsoft Office - Français (HKLM-x32\...\{90150000-001F-040C-0000-0000000FF1CE}) (Version: 15.0.4420.1017 - Microsoft Corporation) Hidden
Popcorn Time (HKLM-x32\...\Popcorn Time_is1) (Version: 5.4.9.0 - Popcorn Time)
Portal 2 (HKLM-x32\...\Steam App 620) (Version: - Valve)
REALTEK Bluetooth Driver (HKLM-x32\...\{9D3D8C60-A5EF-4123-B2B9-172095903AB}) (Version: 1.0.0.24 - REALTEK Semiconductor Corp.)
Realtek Card Reader (HKLM-x32\...\{5BC2B5AB-80DE-4E83-B8CF-426902051D0A}) (Version: 6.3.9600.29082 - Realtek Semiconductor Corp.)
Realtek Ethernet Controller All-In-One Windows Driver (HKLM-x32\...\{F7E7F0CB-AA41-4D5A-B6F2-8E6738EB063F}) (Version: 8.35.716.2014 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7564 - Realtek Semiconductor Corp.)
REALTEK Wireless LAN Driver (HKLM-x32\...\{A5107464-AA9B-4177-8129-5FF2F42DD322}) (Version: 1.0.0.59 - REALTEK Semiconductor Corp.)
Revisores de Texto do Microsoft Office 2013 – Português do Brasil (HKLM-x32\...\{90150000-001F-0416-0000-0000000FF1CE}) (Version: 15.0.4420.1017 - Microsoft Corporation) Hidden
Rogue Legacy (HKLM\...\Steam App 241600) (Version: - Cellar Door Games)
Skype™ 7.28 (HKLM-x32\...\{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.28.101 - Skype Technologies S.A.)
Speccy (HKLM\...\Speccy) (Version: 1.30 - Piriform)
Spotify (HKCU\...\Spotify) (Version: 1.0.43.123.g80176796 - Spotify AB)
swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
Terraria (HKLM\...\Steam App 105600) (Version: - Re-Logic)
The Binding of Isaac: Rebirth (HKLM-x32\...\Steam App 250900) (Version: - Nicalis, Inc.)
Uninstall Popcorn Time CE (HKCU\...\{213E23F8-E0EC-436D-8AAE-108345FF4CA0}_is1) (Version: 0.3.9-11 - PopcornTimeCE)
XCOM: Enemy Unknown (HKLM-x32\...\Steam App 200510) (Version: - Firaxis Games)
Percentage of memory in use: 36%
Total physical RAM: 8123.84 MB
Available physical RAM: 5198.18 MB
Total Virtual: 9403.84 MB
Available Virtual: 5901.95 MB
1 Drive c: (Windows) (Fixed) (Total:905.99 GB) (Free:726.58 GB) NTFS
2 Drive d: (RECOVERY) (Fixed) (Total:24.06 GB) (Free:2.67 GB) NTFS
4 Drive z: () (Fixed) (Total:0.25 GB) (Free:0.15 GB) FAT32
Cuentas de usuario de \\HP-PC
Administrador DefaultAccount Invitado
PROPIETARIO
**** End of log ****
You need to post the Hijack This log, and also re-read the instructions for autoruns. It was saved as a .arn instead of .txt
Step 4: HijackThis.
2- Run the program.
There are the two logs that he needs. COPY and PASTE the information form the logs.
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 04:32:39 p.m., on 12/12/2016
Platform: Unknown Windows (WinNT 6.02.1008)
MSIE: Internet Explorer v11.0 (11.00.10586.0420)
Boot mode: Normal
Running processes:
C:\Program Files\AVAST Software\SecureLine\SecureLine.exe
C:\Program Files (x86)\Skillbrains\lightshot\5.4.0.1\Lightshot.exe
C:\Program Files (x86)\Avira\Launcher\Avira.Systray.exe
C:\Program Files (x86)\Common Files\Java\Java Update\jucheck.exe
C:\Program Files\WindowsApps\Microsoft.Messaging_2.15.20002.0_x86__8wekyb3d8bbwe\SkypeHost.exe
C:\Riot Games\League of Legends\RADS\projects\league_client\releases\0.0.0.39\deploy\LeagueClient.exe
C:\Riot Games\League of Legends\RADS\projects\league_client\releases\0.0.0.39\deploy\LeagueClientUx.exe
C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
C:\Users\PROPIETARIO\Downloads\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://hp13.msn.com
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://hp13.msn.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/p/?LinkId=255141
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/p/?LinkId=255141
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=
O2 - BHO: Lync Click to Call BHO - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre1.8.0_101\bin\ssv.dll
O2 - BHO: Evernote extension - {92EF2EAD-A7CE-4424-B0DB-499CF856608E} - C:\Program Files (x86)\Evernote\Evernote\EvernoteIE.dll
O2 - BHO: Microsoft SkyDrive Pro Browser Helper - {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} - C:\PROGRA~2\MICROS~1\Office15\GROOVEEX.DLL
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre1.8.0_101\bin\jp2ssv.dll
O2 - BHO: HP Network Check Helper - {E76FD755-C1BA-4DCB-9F13-99BD91223ADE} - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\HPNetworkCheckPlugin.dll
O4 - HKLM\..\Run: [HPMessageService] C:\Program Files (x86)\Hewlett-Packard\HP System Event\HPMSGSVC.exe
O4 - HKLM\..\Run: [DropboxOEM] "C:\Program Files (x86)\Dropbox\DropboxOEM\DropboxOEM.exe" auto
O4 - HKLM\..\Run: [Lightshot] C:\Program Files (x86)\Skillbrains\lightshot\Lightshot.exe
O4 - HKLM\..\Run: [Avira SystrayStartTrigger] "C:\Program Files (x86)\Avira\Launcher\Avira.SystrayStartTrigger.exe"
O4 - HKLM\..\Run: [Avira System Speedup User Starter] "C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.Core.Common.Starter.exe"
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [avgnt] "C:\Program Files (x86)\Avira\Antivirus\avgnt.exe" /min
O4 - HKCU\..\Run: [Steam] "C:\Program Files (x86)\Steam\steam.exe" -silent
O4 - HKCU\..\Run: [{79F4C512-6430-4835-A988-03325E97EB8F}] C:\Windows\system32\WindowsPowerShell\v1.0\powershell.exe -noprofile -windowstyle hidden -executionpolicy bypass iex ([Text.Encoding]::ASCII.GetString([Convert]::FromBase64String((gp 'HKCU:\Software\Classes\JvOApJCKiLgQJSO').vCBs)));
O4 - HKCU\..\Run: [Spotify Web Helper] "C:\Users\PROPIETARIO\AppData\Roaming\Spotify\SpotifyWebHelper.exe"
O4 - HKCU\..\Run: [Skype] "C:\Program Files (x86)\Skype\Phone\Skype.exe" /minimized /regrun
O4 - HKCU\..\Run: [OneDrive] "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\OneDrive.exe" /background
O4 - HKCU\..\Run: [CCleaner Monitoring] "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
O4 - HKCU\..\Run: [Spotify] "C:\Users\PROPIETARIO\AppData\Roaming\Spotify\Spotify.exe" -autostart -minimized
O4 - HKCU\..\Run: [Discord] C:\Users\PROPIETARIO\AppData\Local\Discord\app-0.0.296\Discord.exe
O4 - HKCU\..\RunOnce: [Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6281.1202_1\amd64] C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6281.1202_1\amd64"
O4 - HKCU\..\RunOnce: [Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6281.1202_1] C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6281.1202_1"
O4 - HKCU\..\RunOnce: [Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6301.0127\amd64] C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6301.0127\amd64"
O4 - HKCU\..\RunOnce: [Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6302.0225\amd64] C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6302.0225\amd64"
O4 - HKCU\..\RunOnce: [Uninstall C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6386.0412\amd64] C:\WINDOWS\system32\cmd.exe /q /c rmdir /s /q "C:\Users\PROPIETARIO\AppData\Local\Microsoft\OneDrive\17.3.6386.0412\amd64"
O4 - Startup: Curse.lnk = C:\Users\PROPIETARIO\AppData\Roaming\Curse Client\Bin\Curse.exe
O4 - Global Startup: avast! SecureLine.lnk = C:\Program Files\AVAST Software\SecureLine\SecureLine.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\Program Files\Microsoft Office 15\Root\Office15\EXCEL.EXE/3000
O8 - Extra context menu item: Se&nd to OneNote - res://C:\Program Files\Microsoft Office 15\Root\Office15\ONBttnIE.dll/105
O9 - Extra button: @C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\HPNetworkCheckPlugin.dll,-103 - {25510184-5A38-4A99-B273-DCA8EEF6CD08} - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\NCLauncherFromIE.exe
O9 - Extra 'Tools' menuitem: @C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\HPNetworkCheckPlugin.dll,-102 - {25510184-5A38-4A99-B273-DCA8EEF6CD08} - C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPNetworkCheck\NCLauncherFromIE.exe
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office 15\root\Office15\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files\Microsoft Office 15\root\Office15\ONBttnIE.dll
O9 - Extra button: Complemento Hacer clic para llamar de Lync - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O9 - Extra 'Tools' menuitem: Complemento Hacer clic para llamar de Lync - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O9 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office 15\root\Office15\ONBttnIELinkedNotes.dll
O9 - Extra 'Tools' menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files\Microsoft Office 15\root\Office15\ONBttnIELinkedNotes.dll
O9 - Extra button: @C:\Program Files (x86)\Evernote\Evernote\Resource.dll,-101 - {A95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\Program Files (x86)\Evernote\Evernote\\EvernoteIERes\AddNote.html
O9 - Extra 'Tools' menuitem: @C:\Program Files (x86)\Evernote\Evernote\Resource.dll,-101 - {A95fe080-8f5d-11d2-a20b-00aa003c157a} - C:\Program Files (x86)\Evernote\Evernote\\EvernoteIERes\AddNote.html
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O18 - Protocol: osf - {D924BDC6-C83A-4BD5-90D0-095128A113D1} - C:\Program Files\Microsoft Office 15\root\Office15\MSOSB.DLL
O18 - Protocol: tbauth - {14654CA6-5711-491D-B89A-58E571679951} - C:\Windows\SysWOW64\tbauth.dll
O18 - Protocol: windows.tbauth - {14654CA6-5711-491D-B89A-58E571679951} - C:\Windows\SysWOW64\tbauth.dll
O18 - Filter hijack: text/xml - {807583E5-5146-11D5-A672-00B0D022E945} - C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\MSOXMLMF.DLL
O23 - Service: @%SystemRoot%\system32\AJRouter.dll,-2 (AJRouter) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\WINDOWS\System32\alg.exe (file missing)
O23 - Service: Avira Mail Protection (AntiVirMailService) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\Antivirus\avmailc7.exe
O23 - Service: Avira Programador (AntiVirSchedulerService) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\Antivirus\sched.exe
O23 - Service: Avira Real-Time Protection (AntiVirService) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\Antivirus\avguard.exe
O23 - Service: Avira Web Protection (AntiVirWebService) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\Antivirus\avwebg7.exe
O23 - Service: @%windir%\system32\inetsrv\iisres.dll,-30011 (AppHostSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\appidsvc.dll,-100 (AppIDSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\appinfo.dll,-100 (Appinfo) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\AppReadiness.dll,-1000 (AppReadiness) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\appxdeploymentserver.dll,-1 (AppXSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\AudioEndpointBuilder.dll,-204 (AudioEndpointBuilder) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\audiosrv.dll,-200 (Audiosrv) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Avira Service Host (Avira.ServiceHost) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\Launcher\Avira.ServiceHost.exe
O23 - Service: Avira Phantom VPN (AviraPhantomVPN) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\VPN\Avira.VpnService.exe
O23 - Service: @%SystemRoot%\system32\AxInstSV.dll,-103 (AxInstSV) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\bdesvc.dll,-100 (BDESVC) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\bfe.dll,-1001 (BFE) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\qmgr.dll,-1000 (BITS) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%windir%\system32\bisrv.dll,-100 (BrokerInfrastructure) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\browser.dll,-100 (Browser) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\BthHFSrv.dll,-103 (BthHFSrv) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\bthserv.dll,-101 (bthserv) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\certprop.dll,-11 (CertPropSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\ClipSVC.dll,-103 (ClipSVC) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\coremessaging.dll,-1 (CoreMessagingRegistrar) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\cryptsvc.dll,-1001 (CryptSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @combase.dll,-5012 (DcomLaunch) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\dcpsvc.dll,-3001 (DcpSvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\defragsvc.dll,-101 (defragsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\das.dll,-100 (DeviceAssociationService) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\umpnpmgr.dll,-100 (DeviceInstall) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\DevQueryBroker.dll,-100 (DevQueryBroker) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\dhcpcore.dll,-100 (Dhcp) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\DiagSvcs\DiagnosticsHub.StandardCollector.ServiceRes.dll,-1000 (diagnosticshub.standardcollector.service) - Unknown owner - C:\WINDOWS\system32\DiagSvcs\DiagnosticsHub.StandardCollector.Service.exe (file missing)
O23 - Service: @%SystemRoot%\system32\diagtrack.dll,-3001 (DiagTrack) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%systemroot%\system32\Windows.Internal.Management.dll,-100 (DmEnrollmentSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\dmwappushsvc.dll,-200 (dmwappushservice) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\dnsapi.dll,-101 (Dnscache) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\dosvc.dll,-100 (DoSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\dot3svc.dll,-1102 (dot3svc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\dps.dll,-500 (DPS) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\DeviceSetupManager.dll,-1000 (DsmSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\dssvc.dll,-10003 (DsSvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%systemroot%\system32\eapsvc.dll,-1 (Eaphost) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\WINDOWS\System32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\embeddedmodesvc.dll,-200 (embeddedmode) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @EnterpriseAppMgmtSvc.dll,-1 (EntAppSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\wevtsvc.dll,-200 (EventLog) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @comres.dll,-2450 (EventSystem) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\WINDOWS\system32\fxssvc.exe (file missing)
O23 - Service: @%systemroot%\system32\fdPHost.dll,-100 (fdPHost) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\fdrespub.dll,-100 (FDResPub) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\fhsvc.dll,-101 (fhsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\FntCache.dll,-100 (FontCache) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @gpapi.dll,-112 (gpsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\hidserv.dll,-101 (hidserv) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\ListSvc.dll,-100 (HomeGroupListener) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\provsvc.dll,-100 (HomeGroupProvider) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: HP Support Solutions Framework Service (HPSupportSolutionsFrameworkService) - HP Inc. - C:\Program Files (x86)\Hewlett-Packard\HP Support Solutions\HPSupportSolutionsFrameworkService.exe
O23 - Service: @%SystemRoot%\System32\tetheringservice.dll,-4097 (icssvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\ieetwcollectorres.dll,-1000 (IEEtwCollectorService) - Unknown owner - C:\WINDOWS\system32\IEEtwCollector.exe (file missing)
O23 - Service: @%SystemRoot%\system32\ikeext.dll,-501 (IKEEXT) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\iphlpsvc.dll,-500 (iphlpsvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: @comres.dll,-2946 (KtmRm) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%systemroot%\system32\srvsvc.dll,-100 (LanmanServer) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\wkssvc.dll,-100 (LanmanWorkstation) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\lfsvc.dll,-1 (lfsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\licensemanagersvc.dll,-200 (LicenseManager) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\lltdres.dll,-1 (lltdsvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\lmhsvc.dll,-101 (lmhosts) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%windir%\system32\lsm.dll,-1001 (LSM) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\moshost.dll,-100 (MapsBroker) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\MessagingService.dll,-100 (MessagingService) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_133e8b01 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_1b953c - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_1d2100 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_1e261a - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_22ed18fd - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_262270 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_2ab6a - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_2bbde0 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_2e285 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_303c8 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_30875 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_30c69 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_31617 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_326ed - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_332ff - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_35323 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_355d9 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_37df1 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_3899f - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_3bbf139 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_3bf49 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_3dac1 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_3defc - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_3e76d - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_3f30e - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_42915 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_4f174 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_5b158 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_5bc0e - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_68344 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_6c26d - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_8952362 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_a92f9 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_b14c2cb3 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_bb5d3 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: MessagingService_dd684e1 - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\FirewallAPI.dll,-23090 (MpsSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\WINDOWS\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\iscsidsc.dll,-5000 (MSiSCSI) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\msimsg.dll,-27 (msiserver) - Unknown owner - C:\WINDOWS\system32\msiexec.exe
O23 - Service: @%SystemRoot%\system32\ncasvc.dll,-3009 (NcaSvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\ncbservice.dll,-500 (NcbService) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\NcdAutoSetup.dll,-100 (NcdAutoSetup) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\netman.dll,-109 (Netman) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\netprofmsvc.dll,-202 (netprofm) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\NetSetupSvc.dll,-3 (NetSetupSvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\NgcCtnrSvc.dll,-1 (NgcCtnrSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\ngcsvc.dll,-100 (NgcSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\nlasvc.dll,-1 (NlaSvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\nsisvc.dll,-200 (nsi) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\APHostRes.dll,-10002 (OneSyncSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_133e8b01 (OneSyncSvc_133e8b01) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_1b953c (OneSyncSvc_1b953c) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_1d2100 (OneSyncSvc_1d2100) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_1e261a (OneSyncSvc_1e261a) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_22ed18fd (OneSyncSvc_22ed18fd) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_262270 (OneSyncSvc_262270) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_2ab6a (OneSyncSvc_2ab6a) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_2bbde0 (OneSyncSvc_2bbde0) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_2e285 (OneSyncSvc_2e285) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_303c8 (OneSyncSvc_303c8) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_30875 (OneSyncSvc_30875) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_30c69 (OneSyncSvc_30c69) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_31617 (OneSyncSvc_31617) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_326ed (OneSyncSvc_326ed) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_332ff (OneSyncSvc_332ff) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_35323 (OneSyncSvc_35323) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_355d9 (OneSyncSvc_355d9) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_37df1 (OneSyncSvc_37df1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_3899f (OneSyncSvc_3899f) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_3bbf139 (OneSyncSvc_3bbf139) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_3bf49 (OneSyncSvc_3bf49) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_3dac1 (OneSyncSvc_3dac1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_3defc (OneSyncSvc_3defc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_3e76d (OneSyncSvc_3e76d) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_3f30e (OneSyncSvc_3f30e) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_42915 (OneSyncSvc_42915) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_4f174 (OneSyncSvc_4f174) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_5b158 (OneSyncSvc_5b158) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_5bc0e (OneSyncSvc_5bc0e) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_68344 (OneSyncSvc_68344) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_6c26d (OneSyncSvc_6c26d) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_8952362 (OneSyncSvc_8952362) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_a92f9 (OneSyncSvc_a92f9) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_b14c2cb3 (OneSyncSvc_b14c2cb3) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_bb5d3 (OneSyncSvc_bb5d3) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Sincronizar host_dd684e1 (OneSyncSvc_dd684e1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\pnrpsvc.dll,-8004 (p2pimsvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\p2psvc.dll,-8006 (p2psvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\pcasvc.dll,-1 (PcaSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\sysWow64\perfhost.exe,-2 (PerfHost) - Unknown owner - C:\WINDOWS\SysWow64\perfhost.exe
O23 - Service: @%SystemRoot%\system32\PhoneserviceRes.dll,-10000 (PhoneSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\UserDataAccessRes.dll,-15001 (PimIndexMaintenanceSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_133e8b01 (PimIndexMaintenanceSvc_133e8b01) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_1b953c (PimIndexMaintenanceSvc_1b953c) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_1d2100 (PimIndexMaintenanceSvc_1d2100) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_1e261a (PimIndexMaintenanceSvc_1e261a) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_22ed18fd (PimIndexMaintenanceSvc_22ed18fd) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_262270 (PimIndexMaintenanceSvc_262270) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_2ab6a (PimIndexMaintenanceSvc_2ab6a) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_2bbde0 (PimIndexMaintenanceSvc_2bbde0) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_2e285 (PimIndexMaintenanceSvc_2e285) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_303c8 (PimIndexMaintenanceSvc_303c8) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_30875 (PimIndexMaintenanceSvc_30875) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_30c69 (PimIndexMaintenanceSvc_30c69) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_31617 (PimIndexMaintenanceSvc_31617) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_326ed (PimIndexMaintenanceSvc_326ed) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_332ff (PimIndexMaintenanceSvc_332ff) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_35323 (PimIndexMaintenanceSvc_35323) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_355d9 (PimIndexMaintenanceSvc_355d9) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_37df1 (PimIndexMaintenanceSvc_37df1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_3899f (PimIndexMaintenanceSvc_3899f) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_3bbf139 (PimIndexMaintenanceSvc_3bbf139) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_3bf49 (PimIndexMaintenanceSvc_3bf49) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_3dac1 (PimIndexMaintenanceSvc_3dac1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_3defc (PimIndexMaintenanceSvc_3defc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_3e76d (PimIndexMaintenanceSvc_3e76d) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_3f30e (PimIndexMaintenanceSvc_3f30e) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_42915 (PimIndexMaintenanceSvc_42915) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_4f174 (PimIndexMaintenanceSvc_4f174) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_5b158 (PimIndexMaintenanceSvc_5b158) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_5bc0e (PimIndexMaintenanceSvc_5bc0e) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_68344 (PimIndexMaintenanceSvc_68344) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_6c26d (PimIndexMaintenanceSvc_6c26d) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_8952362 (PimIndexMaintenanceSvc_8952362) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_a92f9 (PimIndexMaintenanceSvc_a92f9) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_b14c2cb3 (PimIndexMaintenanceSvc_b14c2cb3) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_bb5d3 (PimIndexMaintenanceSvc_bb5d3) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Datos de contactos_dd684e1 (PimIndexMaintenanceSvc_dd684e1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\pla.dll,-500 (pla) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\umpnpmgr.dll,-200 (PlugPlay) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\pnrpauto.dll,-8002 (PNRPAutoReg) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\pnrpsvc.dll,-8000 (PNRPsvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\polstore.dll,-5010 (PolicyAgent) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\umpo.dll,-100 (Power) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @C:\WINDOWS\system32\spool\drivers\x64\3\PrintConfig.dll,-1 (PrintNotify) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\profsvc.dll,-300 (ProfSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\qwave.dll,-1 (QWAVE) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%Systemroot%\system32\rasauto.dll,-200 (RasAuto) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%Systemroot%\system32\rasmans.dll,-200 (RasMan) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\RDXService.dll,-256 (RetailDemo) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%windir%\system32\RpcEpMap.dll,-1001 (RpcEptMapper) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\WINDOWS\system32\locator.exe (file missing)
O23 - Service: @combase.dll,-5010 (RpcSs) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\System32\ScDeviceEnum.dll,-100 (ScDeviceEnum) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\schedsvc.dll,-100 (Schedule) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\certprop.dll,-13 (SCPolicySvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\sdrsvc.dll,-107 (SDRSVC) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\seclogon.dll,-7001 (seclogon) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\Sens.dll,-200 (SENS) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\SensorDataService.exe,-101 (SensorDataService) - Unknown owner - C:\WINDOWS\System32\SensorDataService.exe (file missing)
O23 - Service: @%SystemRoot%\System32\sensorservice.dll,-1000 (SensorService) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\sensrsvc.dll,-1000 (SensrSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\SessEnv.dll,-1026 (SessionEnv) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\shsvcs.dll,-12288 (ShellHWDetection) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Skype Updater (SkypeUpdate) - Skype Technologies - C:\Program Files (x86)\Skype\Updater\Updater.exe
O23 - Service: @%SystemRoot%\System32\smphost.dll,-102 (smphost) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\SmsRouterSvc.dll,-10001 (SmsRouter) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\WINDOWS\System32\snmptrap.exe (file missing)
O23 - Service: Avira System Speedup (SpeedupService) - Avira Operations GmbH & Co. KG - C:\Program Files (x86)\Avira\System Speedup\Avira.SystemSpeedup.SpeedupService.exe
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\WINDOWS\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\WINDOWS\system32\sppsvc.exe (file missing)
O23 - Service: @%systemroot%\system32\ssdpsrv.dll,-100 (SSDPSRV) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\sstpsvc.dll,-200 (SstpSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\windows.staterepository.dll,-1 (StateRepository) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\SteamService.exe
O23 - Service: @%SystemRoot%\system32\wiaservc.dll,-9 (stisvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\StorSvc.dll,-100 (StorSvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\svsvc.dll,-101 (svsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\swprv.dll,-103 (swprv) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\sysmain.dll,-1000 (SysMain) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%windir%\system32\SystemEventsBrokerServer.dll,-1001 (SystemEventsBroker) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\TabSvc.dll,-100 (TabletInputService) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\tapisrv.dll,-10100 (TapiSrv) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\termsrv.dll,-268 (TermService) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\themeservice.dll,-8192 (Themes) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\TieringEngineService.exe,-702 (TieringEngineService) - Unknown owner - C:\WINDOWS\system32\TieringEngineService.exe (file missing)
O23 - Service: @%SystemRoot%\system32\tileobjserver.dll,-1 (tiledatamodelsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%windir%\system32\TimeBrokerServer.dll,-1001 (TimeBroker) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\trkwks.dll,-1 (TrkWks) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\servicing\TrustedInstaller.exe,-100 (TrustedInstaller) - Unknown owner - C:\WINDOWS\servicing\TrustedInstaller.exe
O23 - Service: @%SystemRoot%\system32\tzautoupdate.dll,-200 (tzautoupdate) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\WINDOWS\system32\UI0Detect.exe (file missing)
O23 - Service: @%SystemRoot%\system32\umrdp.dll,-1000 (UmRdpService) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\UserDataAccessRes.dll,-10003 (UnistoreSvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_133e8b01 (UnistoreSvc_133e8b01) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_1b953c (UnistoreSvc_1b953c) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_1d2100 (UnistoreSvc_1d2100) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_1e261a (UnistoreSvc_1e261a) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_22ed18fd (UnistoreSvc_22ed18fd) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_262270 (UnistoreSvc_262270) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_2ab6a (UnistoreSvc_2ab6a) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_2bbde0 (UnistoreSvc_2bbde0) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_2e285 (UnistoreSvc_2e285) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_303c8 (UnistoreSvc_303c8) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_30875 (UnistoreSvc_30875) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_30c69 (UnistoreSvc_30c69) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_31617 (UnistoreSvc_31617) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_326ed (UnistoreSvc_326ed) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_332ff (UnistoreSvc_332ff) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_35323 (UnistoreSvc_35323) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_355d9 (UnistoreSvc_355d9) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_37df1 (UnistoreSvc_37df1) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_3899f (UnistoreSvc_3899f) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_3bbf139 (UnistoreSvc_3bbf139) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_3bf49 (UnistoreSvc_3bf49) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_3dac1 (UnistoreSvc_3dac1) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_3defc (UnistoreSvc_3defc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_3e76d (UnistoreSvc_3e76d) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_3f30e (UnistoreSvc_3f30e) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_42915 (UnistoreSvc_42915) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_4f174 (UnistoreSvc_4f174) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_5b158 (UnistoreSvc_5b158) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_5bc0e (UnistoreSvc_5bc0e) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_68344 (UnistoreSvc_68344) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_6c26d (UnistoreSvc_6c26d) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_8952362 (UnistoreSvc_8952362) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_a92f9 (UnistoreSvc_a92f9) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_b14c2cb3 (UnistoreSvc_b14c2cb3) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_bb5d3 (UnistoreSvc_bb5d3) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: Almacenamiento de datos de usuarios_dd684e1 (UnistoreSvc_dd684e1) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%systemroot%\system32\upnphost.dll,-213 (upnphost) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\UserDataAccessRes.dll,-14001 (UserDataSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_133e8b01 (UserDataSvc_133e8b01) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_1b953c (UserDataSvc_1b953c) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_1d2100 (UserDataSvc_1d2100) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_1e261a (UserDataSvc_1e261a) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_22ed18fd (UserDataSvc_22ed18fd) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_262270 (UserDataSvc_262270) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_2ab6a (UserDataSvc_2ab6a) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_2bbde0 (UserDataSvc_2bbde0) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_2e285 (UserDataSvc_2e285) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_303c8 (UserDataSvc_303c8) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_30875 (UserDataSvc_30875) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_30c69 (UserDataSvc_30c69) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_31617 (UserDataSvc_31617) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_326ed (UserDataSvc_326ed) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_332ff (UserDataSvc_332ff) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_35323 (UserDataSvc_35323) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_355d9 (UserDataSvc_355d9) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_37df1 (UserDataSvc_37df1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_3899f (UserDataSvc_3899f) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_3bbf139 (UserDataSvc_3bbf139) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_3bf49 (UserDataSvc_3bf49) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_3dac1 (UserDataSvc_3dac1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_3defc (UserDataSvc_3defc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_3e76d (UserDataSvc_3e76d) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_3f30e (UserDataSvc_3f30e) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_42915 (UserDataSvc_42915) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_4f174 (UserDataSvc_4f174) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_5b158 (UserDataSvc_5b158) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_5bc0e (UserDataSvc_5bc0e) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_68344 (UserDataSvc_68344) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_6c26d (UserDataSvc_6c26d) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_8952362 (UserDataSvc_8952362) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_a92f9 (UserDataSvc_a92f9) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_b14c2cb3 (UserDataSvc_b14c2cb3) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_bb5d3 (UserDataSvc_bb5d3) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: Acceso a datos de usuarios_dd684e1 (UserDataSvc_dd684e1) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\usermgr.dll,-100 (UserManager) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\usocore.dll,-102 (UsoSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\WINDOWS\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\icsvc.dll,-801 (vmicguestinterface) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\icsvc.dll,-101 (vmicheartbeat) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\icsvc.dll,-201 (vmickvpexchange) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\icsvc.dll,-601 (vmicrdv) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\icsvc.dll,-301 (vmicshutdown) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\icsvc.dll,-401 (vmictimesync) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\icsvc.dll,-901 (vmicvmsession) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\icsvc.dll,-501 (vmicvss) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\WINDOWS\system32\vssvc.exe (file missing)
O23 - Service: @%windir%\system32\inetsrv\iisres.dll,-30014 (w3logsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\WalletService.dll,-1000 (WalletService) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%windir%\system32\inetsrv\iisres.dll,-30001 (WAS) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\WINDOWS\system32\wbengine.exe (file missing)
O23 - Service: @%systemroot%\system32\wbiosrvc.dll,-100 (WbioSrvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\wcmsvc.dll,-4097 (Wcmsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\wcncsvc.dll,-3 (wcncsvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\WcsPlugInService.dll,-200 (WcsPlugInService) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\wdi.dll,-502 (WdiServiceHost) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%systemroot%\system32\wdi.dll,-500 (WdiSystemHost) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%ProgramFiles%\Windows Defender\MpAsDesc.dll,-320 (WdNisSvc) - Unknown owner - C:\Program Files (x86)\Windows Defender\NisSrv.exe (file missing)
O23 - Service: @%systemroot%\system32\webclnt.dll,-100 (WebClient) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\wecsvc.dll,-200 (Wecsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\wephostsvc.dll,-100 (WEPHOSTSVC) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\wercplsupport.dll,-101 (wercplsupport) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\wersvc.dll,-100 (WerSvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\wiarpc.dll,-2 (WiaRpc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%ProgramFiles%\Windows Defender\MpAsDesc.dll,-310 (WinDefend) - Unknown owner - C:\Program Files (x86)\Windows Defender\MsMpEng.exe (file missing)
O23 - Service: @%SystemRoot%\system32\winhttp.dll,-100 (WinHttpAutoProxySvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%Systemroot%\system32\wbem\wmisvc.dll,-205 (Winmgmt) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%Systemroot%\system32\wsmsvc.dll,-101 (WinRM) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\System32\wlansvc.dll,-257 (WlanSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\wlidsvc.dll,-100 (wlidsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\WINDOWS\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
O23 - Service: @%systemroot%\system32\workfolderssvc.dll,-102 (workfolderssvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\wpdbusenum.dll,-100 (WPDBusEnum) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\system32\wpnservice.dll,-1 (WpnService) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\wscsvc.dll,-200 (wscsvc) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%systemroot%\system32\SearchIndexer.exe,-103 (WSearch) - Unknown owner - C:\WINDOWS\system32\SearchIndexer.exe
O23 - Service: @%SystemRoot%\system32\WSService.dll,-103 (WSService) - Unknown owner - C:\WINDOWS\System32\svchost.exe
O23 - Service: @%SystemRoot%\system32\wudfsvc.dll,-1000 (wudfsvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%SystemRoot%\System32\wwansvc.dll,-257 (WwanSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\XblAuthManager.dll,-100 (XblAuthManager) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\XblGameSave.dll,-100 (XblGameSave) - Unknown owner - C:\WINDOWS\system32\svchost.exe
O23 - Service: @%systemroot%\system32\XboxNetApiSvc.dll,-100 (XboxNetApiSvc) - Unknown owner - C:\WINDOWS\system32\svchost.exe
End of file - 55638 bytes
Step 1: Disable useless items.
Download easy service optmizer, save it to your desktop and unzip it there. Right click it and run as admin, then select tweaked at the bottom. Then click on the rocket, this will turn off a lot of useless items.
service-png.1067
You will however need to change one setting. Right Click on Wlansvc — WLAN AutoConfig, then select start service, the edit service. Make sure it is automatic across the board, as per the picture.
11-png.1068
Step 2: Reset Host File
  • Click here to download RstHosts v2.0
  • Right Click and Run as Administrator.
  • Click on Restaurer, then click OK at the prompt.
  • This will restore the default host file.
  • Next Click on Creer Un Rapport.
  • This will open a logfile, post that in your next reply.
Step 3: Run Batch File.
Download and unzip internet Flush.zip to your desktop right click it run as Administrator.
Step 4: Disable Tunnel Adapters.
Now disable tunnel adapters with this tool.
Step 5: Set A Strong DNS Server
Set your DNS to Google or Open DNS with this tool.
Step 6: Disable Telemetry
Another thing to consider is that you are on windows 10. There is always some sort of inbound or outbound connection going on with all of the Telemetry.
I suggest that you run one of the following tools.
O&O Shut Up.
Destroy Windows Spying.
Both of these tools will add items to your hosts file, which can increase ping so I would suggest you disable the DNS Client Service.
  • Open
  • Control Panel
  • Double click Administrative Tools
  • Double click Services
  • Select the DNS Client Service from the list and right click on it
  • Select Stop
  • Right click Properties
  • In Startup type select Disable
  • Click OK
  • Reboot machine.
  • Perform the same step to stop and disable the Diag Track Service
Step 7: Report On Issue.
Now reboot your machine, and tell me if it stays connected. :)
Do you have an update for us?
In 24 to 48 Hrs this thread will be closed, you will need to PM an Administrator to have the thread reopen and post updated information.
