Laptop not charging & now not turning on at all
but please read the first review there.
That was my exact point, even a charger that should work didn`t and despite the fact that it was direct from Lenovo, I will mention though that we have no idea whether or not that persons computer had other issues.
Ah, okay. I see your point. There are so many variables, it’s exhausting 😅 Hopefully the tech will be able to figure it out, or at least tell me for certain if it’s beyond help or not. Thanks!
@Bruce I took it to a tech at the weekend. They tried a few quick things (I’d already tried them all myself) but weren’t able to fix it. I left it with them for a few days. Picking it up tomorrow so hopefully they’ll let me know if it’s fixable or not :)
The tech couldn’t fix it, unfortunately. They were very kind not to charge me anything though. I was expecting this outcome so I’m not overly disappointed. I have everything I need backed up on my old laptop, which is working well enough for my needs at the moment; I only upgraded to help me through uni, but I’ve now graduated and don’t use my laptop as much anymore. I think I’ve learned my lesson to a) not buy a refurbished laptop for the sake of saving some money, and b) always triple check the specs before buying any accessories. Thank you so much for all your help. If the issue were fixable, I’m sure you would’ve solved it for me!
So what are your plans for the laptop now?
Getting it fixed, or assigning it to the trash pile?
I ask because if getting rid of it, you could at least remove its drive and put that into an external enclosure.
That will give you a backup device.
It seems that getting it fixed would involve replacing the MB, which would cost more than I bought it for. I will definitely look into recovering my data, even though most of it is still on the old laptop, and then using the hard drive as a backup. Thanks!
