Issues w/ ram and monitor “no signal”
mayannaised
19
I’m having issues with my PC only booting when I put in one stick of ram, if I put in two it stays on a solid orange light. I switched them around as much as possible and it only boots with one. Even when it does boot there still no monitor signal. I have reinserted / cleaned my ram and GPU more times than I can count, checked every monitor input and checked DP cable, not sure what to do now. heard it could be the CMOS battery but I haven't had this motherboard that long. I ordered new ram sticks because they seem to very faulty but not sure if that will fix it. Any help is appreciated 🙏
It sounds like either one stick is dead or one of your memory slots are bad.
