Hello,
I have run into an issue with my LG 32in (144hz) monitor occasionally going black for a few seconds while playing games. Watching videos, and using web browsers I don't have an issue. I'd say that it was a problem with my gpu, but my gpu doesn't have a problem playing the same games with my old 24inch monitor. I have reinstalled windows, graphics drivers, swapped out DP cable, and changed the cable on my other monitor from DVI to HDMI, also even lowered settings in games to the lowest possible setting, with framerate to 60hz and resolution to 1920x1080p. Any help would be much appreciated or if anyone has any suggestions.
My specs are
AMD Ryzen 5 3600 cpu
Amd rx 580 gpu
b450 max tomahawk mbo
Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz
LG 32GK650F-B 32 monitor (the problem monitor)
Asus VG248QE 24 monitor (dual monitor setup)
My specs are
Amd rx 580 gpu
