When was the last time you reset and or rebooted the Modem and Router (if you have one).
I used to reset it whenever the connection would drop on my PC but it never made a difference or made the issues fix any faster. It has probably been a few weeks now.
jmarket, just ran the tool and here is the log (note my internet seems to be working fine currently)
Ran by Jason (administrator) on 08-12-2016 at 13:20:02
Running from "C:\Users\Jason\Downloads"
Microsoft Windows 10 Pro (X64)
Model: To be filled by O.E.M. Manufacturer: Gigabyte Technology Co., Ltd.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
127.0.0.1 localhost127.0.0.1 3dns.adobe.com 3dns-1.adobe.com 3dns-2.adobe.com 3dns-3.adobe.com 3dns-4.adobe.com activate.adobe.com activate-sea.adobe.com activate-sjc0.adobe.com activate.wip.adobe.com
127.0.0.1 activate.wip1.adobe.com activate.wip2.adobe.com activate.wip3.adobe.com activate.wip4.adobe.com adobe-dns.adobe.com adobe-dns-1.adobe.com adobe-dns-2.adobe.com adobe-dns-3.adobe.com adobe-dns-4.adobe.com
127.0.0.1 adobeereg.com practivate.adobe practivate.adobe.com practivate.adobe.newoa practivate.adobe.ntp practivate.adobe.ipp ereg.adobe.com ereg.wip.adobe.com ereg.wip1.adobe.com
127.0.0.1 ereg.wip2.adobe.com ereg.wip3.adobe.com ereg.wip4.adobe.com hl2rcv.adobe.com wip.adobe.com wip1.adobe.com wip2.adobe.com wip3.adobe.com wip4.adobe.com
127.0.0.1
www.adobeereg.com wwis-dubc1-vip60.adobe.com
www.wip.adobe.com www.wip1.adobe.com
127.0.0.1
www.wip2.adobe.com www.wip3.adobe.com www.wip4.adobe.com wwis-dubc1-vip60.adobe.com crl.verisign.net CRL.VERISIGN.NET ood.opsource.net# Any other entries you had go here (new line no # no space);
Realtek RTL8192CU Wireless LAN 802.11n USB 2.0 Network Adapter = Wi-Fi (Connected)
Xbox Wireless Adapter for Windows = Ethernet 3 (Connected)
Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30) = Ethernet (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled taskoffload=enabled
add route prefix=169.254.0.0/16 interface="iftype0_0" nexthop=10.0.0.38 metric=1 publish=Yes
set interface interface="Local Area Connection* 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 1" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="ethernet_3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="other_0" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="ethernet_11" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet-WFP Native MAC Layer LightWeight Filter-0000" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : JASONSBIGPC
DNS Suffix Search List. . . . . . : telstra.com.au
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : This Qualcomm Atheros network Controller connects you to the network.
Physical Address. . . . . . . . . : 90-2B-34-32-A2-FD
Wireless LAN adapter Local Area Connection* 2:
Physical Address. . . . . . . . . : E8-DE-27-A2-72-4A
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : telstra.com.au
Description . . . . . . . . . . . : Realtek RTL8192CU Wireless LAN 802.11n USB 2.0 Network Adapter
Link-local IPv6 Address . . . . . : fe80::ecce:9db6:f9f8:b36a%4(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
Lease Obtained. . . . . . . . . . : Thursday, 8 December 2016 1:09:59 PM
Lease Expires . . . . . . . . . . : Thursday, 8 December 2016 2:09:59 PM
DHCPv6 IAID . . . . . . . . . . . : 233365031
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-C7-A3-52-90-2B-34-32-A2-FD
DNS Servers . . . . . . . . . . . : 8.8.8.8
8.8.4.4
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:3ca0:23fa:862e:7341(Preferred)
Link-local IPv6 Address . . . . . : fe80::3ca0:23fa:862e:7341%2(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 419430400
Tunnel adapter isatap.telstra.com.au:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Server: google-public-dns-a.google.com
Address: 8.8.8.8
Addresses: 2404:6800:4006:802::200e
172.217.25.46
Pinging google.com [172.217.25.46] with 32 bytes of data:
Reply from 172.217.25.46: bytes=32 time=15ms TTL=53
Reply from 172.217.25.46: bytes=32 time=12ms TTL=53
Ping statistics for 172.217.25.46:
Minimum = 12ms, Maximum = 15ms, Average = 13ms
Address: 8.8.8.8
Addresses: 2001:4998:44:204::a7
2001:4998:c:a06::2:4008
2001:4998:58:c02::a9
98.138.253.109
98.139.183.24
206.190.36.45
Pinging yahoo.com [206.190.36.45] with 32 bytes of data:
Reply from 206.190.36.45: bytes=32 time=489ms TTL=44
Reply from 206.190.36.45: bytes=32 time=321ms TTL=44
Ping statistics for 206.190.36.45:
Minimum = 321ms, Maximum = 489ms, Average = 405ms
Interface List
15...90 2b 34 32 a2 fd ......This Qualcomm Atheros network Controller connects you to the network.
16...e8 de 27 a2 72 4a ......Microsoft Wi-Fi Direct Virtual Adapter
4...e8 de 27 a2 72 4a ......Realtek RTL8192CU Wireless LAN 802.11n USB 2.0 Network Adapter
2...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
17...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.2 50
169.254.0.0 255.255.0.0 On-link 192.168.0.2 331
169.254.255.255 255.255.255.255 On-link 192.168.0.2 306
192.168.0.0 255.255.255.0 On-link 192.168.0.2 306
192.168.0.2 255.255.255.255 On-link 192.168.0.2 306
192.168.0.255 255.255.255.255 On-link 192.168.0.2 306
224.0.0.0 240.0.0.0 On-link 192.168.0.2 306
255.255.255.255 255.255.255.255 On-link 192.168.0.2 306
Persistent Routes:
Network Address Netmask Gateway Address Metric
169.254.0.0 255.255.0.0 10.0.0.38 1
IPv6 Route Table
Active Routes:
2 331 ::/0 On-link
1 331 ::1/128 On-link
2 331 2001::/32 On-link
2 331 2001:0:9d38:6ab8:3ca0:23fa:862e:7341/128
On-link
4 306 fe80::/64 On-link
2 331 fe80::/64 On-link
2 331 fe80::3ca0:23fa:862e:7341/128
On-link
4 306 fe80::ecce:9db6:f9f8:b36a/128
On-link
1 331 ff00::/8 On-link
4 306 ff00::/8 On-link
2 331 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\WINDOWS\SysWoW64\napinsp.dll [55808] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWoW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWoW64\NLAapi.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWoW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog5 07 C:\Program Files (x86)\Bonjour\mdnsNSP.dll [122128] (Apple Inc.)
Catalog9 01 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWoW64\mswsock.dll [306016] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67584] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31744] (Microsoft Corporation)
x64-Catalog5 07 C:\Program Files\Bonjour\mdnsNSP.dll [133392] (Apple Inc.)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [357216] (Microsoft Corporation)
Application errors:
Error: (12/08/2016 01:12:00 PM) (Source: Application Error) (User: )
Description: Faulting application name: TWCU.exe, version: 0.0.0.0, time stamp: 0x516270de
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00000000
Faulting process id: 0x2518
Faulting application start time: 0xTWCU.exe0
Faulting application path: TWCU.exe1
Faulting module path: TWCU.exe2
Report Id: TWCU.exe3
Faulting package full name: TWCU.exe4
Faulting package-relative application ID: TWCU.exe5
Error: (12/08/2016 03:28:09 AM) (Source: Microsoft-Windows-Immersive-Shell) (User: JASONSBIGPC)
Description: Activation of app Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy!App failed with error: -2144927141 See the Microsoft-Windows-TWinUI/Operational log for additional information.
Error: (12/07/2016 09:23:58 PM) (Source: Application Error) (User: )
Description: Faulting application name: microsoftedgecp.exe, version: 11.0.14393.82, time stamp: 0x57a55786
Exception code: 0xc0000604
Fault offset: 0x0000000000000000
Faulting process id: 0x1f9c
Faulting application start time: 0xmicrosoftedgecp.exe0
Faulting application path: microsoftedgecp.exe1
Faulting module path: microsoftedgecp.exe2
Report Id: microsoftedgecp.exe3
Faulting package full name: microsoftedgecp.exe4
Faulting package-relative application ID: microsoftedgecp.exe5
Error: (12/07/2016 09:23:55 PM) (Source: Application Error) (User: )
Error: (12/07/2016 07:10:24 PM) (Source: Bonjour Service) (User: )
Description: ERROR: handle_resolve_request bad interfaceIndex 12
Error: (12/06/2016 05:51:27 PM) (Source: Bonjour Service) (User: )
Error: (12/05/2016 11:49:07 PM) (Source: Perflib) (User: )
Description: BITSC:\Windows\System32\bitsperf.dll8
Error: (12/05/2016 06:26:51 PM) (Source: Bonjour Service) (User: )
Description: ERROR: handle_resolve_request bad interfaceIndex 3
System errors:
Error: (12/08/2016 01:15:24 PM) (Source: Service Control Manager) (User: )
Description: The Steam Client Service service failed to start due to the following error:
%%1053 = The service did not respond to the start or control request in a timely fashion.
Description: A timeout was reached (30000 milliseconds) while waiting for the Steam Client Service service to connect.
Error: (12/08/2016 01:12:07 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: {784E29F4-5EBE-4279-9948-1E8FE941646D}
Error: (12/08/2016 01:09:07 PM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalActivation{8D8F4F83-3594-4F07-8369-FC3C3CAE4919}{F72671A9-012C-4725-9D2F-2A4D32D65169}NT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
Error: (12/08/2016 03:28:09 AM) (Source: DCOM) (User: JASONSBIGPC)
Description: App.AppXwdz8g2fxr36xz0tdtagygnvemf85s7gg.mca
Error: (12/08/2016 03:28:08 AM) (Source: DCOM) (User: JASONSBIGPC)
Description: {0002DF02-0000-0000-C000-000000000046}
Error: (12/07/2016 06:52:53 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/07/2016 06:49:52 PM) (Source: DCOM) (User: NT AUTHORITY)
Error: (12/07/2016 01:03:45 AM) (Source: DCOM) (User: JASONSBIGPC)
Description: {4AA0A5C4-1B9B-4F2E-99D7-99C6AEC83474}
Microsoft Office Sessions:
Error: (12/08/2016 01:12:00 PM) (Source: Application Error)(User: )
Description: TWCU.exe0.0.0.0516270deunknown0.0.0.000000000c000000500000000251801d250f81f38688bC:\Program Files (x86)\TP-LINK\TP-LINK Wireless Configuration Utility\TWCU.exeunknownb4bb6ef7-5237-4783-919a-ee18c02d9fa4
Error: (12/08/2016 03:28:09 AM) (Source: Microsoft-Windows-Immersive-Shell)(User: JASONSBIGPC)
Description: Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy!App-2144927141
Error: (12/07/2016 09:23:58 PM) (Source: Application Error)(User: )
Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0.0.000000000c000060400000000000000001f9c01d2507400b50502C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\microsoftedgecp.exeunknownc2ee6d87-6163-4cd0-aa82-c8ac436272cfMicrosoft.MicrosoftEdge_38.14393.0.0_neutral__8wekyb3d8bbweMicrosoftEdge
Error: (12/07/2016 09:23:55 PM) (Source: Application Error)(User: )
Description: microsoftedgecp.exe11.0.14393.8257a55786unknown0.0.0.000000000c000060400000000000000001f9c01d2507400b50502C:\Windows\SystemApps\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\microsoftedgecp.exeunknowne9baae85-9b4a-4903-83ff-492b7320cc00Microsoft.MicrosoftEdge_38.14393.0.0_neutral__8wekyb3d8bbweMicrosoftEdge
Error: (12/07/2016 07:10:24 PM) (Source: Bonjour Service)(User: )
Error: (12/06/2016 05:51:27 PM) (Source: Bonjour Service)(User: )
Error: (12/05/2016 11:49:07 PM) (Source: Perflib)(User: )
Error: (12/05/2016 06:26:51 PM) (Source: Bonjour Service)(User: )
CodeIntegrity Errors:
Date: 2016-12-08 13:17:46.400
Description: Code Integrity determined that a process (\Device\HarddiskVolume1\Program Files\Windows Defender\MsMpEng.exe) attempted to load \Device\HarddiskVolume1\Program Files\Bonjour\mdnsNSP.dll that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2016-12-08 13:17:46.399
Date: 2016-12-08 13:17:45.899
Description: Code Integrity determined that a process (\Device\HarddiskVolume1\Program Files\Windows Defender\MsMpEng.exe) attempted to load \Device\HarddiskVolume1\Program Files\Microsoft Silverlight\xapauthenticodesip.dll that did not meet the Custom 3 / Antimalware signing level requirements.
Date: 2016-12-08 13:17:45.897
Date: 2016-12-08 13:17:45.894
Date: 2016-12-08 13:14:43.258
Date: 2016-12-08 13:14:43.254
Date: 2016-12-08 13:14:43.246
Date: 2016-12-08 13:10:17.797
Date: 2016-12-08 13:10:17.796
4Videosoft MKV Video Converter (HKLM-x32\...\4Videosoft MKV Video Converter_is1) (Version: - )
A Bird Story (HKLM\...\Steam App 327410) (Version: - Freebird Games)
ActivePerl 5.16.3 Build 1604 (64-bit) (HKLM\...\{A7915697-1675-433D-AD07-759E8550582F}) (Version: 5.16.1604 - ActiveState)
Adobe Acrobat Reader DC (HKLM-x32\...\{AC76BA86-7AD7-1033-7B44-AC0F074E4100}) (Version: 15.020.20042 - Adobe Systems Incorporated)
Adobe AIR (HKLM-x32\...\Adobe AIR) (Version: 3.4.0.2540 - Adobe Systems Incorporated)
Adobe Community Help (HKLM-x32\...\chc.4875E02D9FB21EE389F73B8D1702B320485DF8CE.1) (Version: 3.4.980 - Adobe Systems Incorporated.)
Adobe Flash Player 23 NPAPI (HKLM-x32\...\Adobe Flash Player NPAPI) (Version: 23.0.0.207 - Adobe Systems Incorporated)
Adobe Shockwave Player 11.6 (HKLM-x32\...\Adobe Shockwave Player) (Version: 11.6.6.636 - Adobe Systems, Inc.)
Android Commander version 0.7.9.11 (HKLM-x32\...\Android Commander_is1) (Version: 0.7.9.11 - )
Ansel (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Ansel) (Version: 376.19 - NVIDIA Corporation) Hidden
Apple Application Support (32-bit) (HKLM-x32\...\{F2871C89-C8A5-42EE-8D45-0F02506385A6}) (Version: 5.1 - Apple Inc.)
Apple Application Support (64-bit) (HKLM\...\{9BC93467-75D1-4AA4-BD58-D9C51D88DFAB}) (Version: 5.1 - Apple Inc.)
Apple Mobile Device Support (HKLM\...\{55BB2110-FB43-49B3-93F4-945A0CFB0A6C}) (Version: 10.0.1.3 - Apple Inc.)
Apple Software Update (HKLM-x32\...\{56EC47AA-5813-4FF6-8E75-544026FBEA83}) (Version: 2.2.0.150 - Apple Inc.)
Assassins Creed IV Black Flag (HKLM-x32\...\Uplay Install 273) (Version: - Ubisoft)
AutoHotkey 1.1.22.09 (HKLM\...\AutoHotkey) (Version: 1.1.22.09 - Lexikos)
BattleBlock Theater (HKLM-x32\...\Steam App 238460) (Version: - The Behemoth)
BioShock Remastered (HKLM\...\Steam App 409710) (Version: - 2K Boston)
BitMeter OS (HKLM-x32\...\BitMeterOS) (Version: - )
BitX (HKLM-x32\...\BitX) (Version: 2.1.5 - )
Brothers - A Tale of Two Sons (HKLM-x32\...\Steam App 225080) (Version: - Starbreeze Studios AB)
Camtasia Studio 8 (HKLM-x32\...\{2EB28256-1D66-49F1-AF66-691BF9A27C79}) (Version: 8.0.2.918 - TechSmith Corporation)
Canon IJ Network Scanner Selector EX (HKLM-x32\...\Canon_IJ_Network_Scanner_Selector_EX) (Version: - Canon Inc.)
Canon IJ Network Tool (HKLM-x32\...\Canon_IJ_Network_UTILITY) (Version: 3.2.0 - Canon Inc.)
Canon IJ Scan Utility (HKLM-x32\...\Canon_IJ_Scan_Utility) (Version: - Canon Inc.)
Canon MP830 MP Drivers (HKLM\...\{0D25F7CC-B99C-44ee-9945-B14532B2BB7B}) (Version: - Canon Inc.)
Canon MX720 series MP Drivers (HKLM\...\{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MX720_series) (Version: 1.00 - Canon Inc.)
CCleaner (HKLM\...\CCleaner) (Version: 5.19 - Piriform)
Cheat Engine 6.6 (HKLM-x32\...\Cheat Engine 6.6_is1) (Version: - Cheat Engine)
Chrome Remote Desktop Host (HKLM-x32\...\{D669DC52-B1A4-4933-878D-CB80F660D95D}) (Version: 55.0.2883.17 - Google Inc.)
Content Manager Assistant for PlayStation(R) (HKLM-x32\...\{4AC85673-668B-4CC4-8800-D28E29B77A90}) (Version: 2.10.6402.20 - Sony Computer Entertainment Inc.)
Counter-Strike: Global Offensive (HKLM-x32\...\Steam App 730) (Version: - )
CPUID CPU-Z 1.76 (HKLM\...\CPUID CPU-Z_is1) (Version: - )
Curse Client (HKCU\...\101a9f93b8f0bb6f) (Version: 5.1.1.810 - Curse)
D3DX10 (HKLM-x32\...\{E09C4DB7-630C-4F06-A631-8EA7239923AF}) (Version: 15.4.2368.0902 - Microsoft) Hidden
DARK SOULS III (HKLM\...\Steam App 374320) (Version: - FromSoftware, Inc.)
Dark Souls: Prepare to Die Edition (HKLM-x32\...\Steam App 211420) (Version: - )
Discord (HKCU\...\Discord) (Version: 0.0.296 - Hammer & Chisel, Inc.)
Dishonored 2 (HKLM\...\Steam App 403640) (Version: - Arkane Studios)
DisplayFusion (HKLM-x32\...\Steam App 227260) (Version: - Binary Fortress Software)
DisplayFusion 8.1.1 (HKLM-x32\...\B076073A-5527-4f4f-B46B-B10692277DA2_is1) (Version: 8.1.1.0 - Binary Fortress Software)
DivX Setup (HKLM-x32\...\DivX Setup) (Version: 2.7.0.64 - DivX, LLC)
Don't Starve Together Beta (HKLM-x32\...\Steam App 322330) (Version: - Klei Entertainment)
Dota 2 (HKLM\...\Steam App 570) (Version: - Valve)
Droid Explorer 0.8.8.11 (x64) (HKLM\...\{5876342E-8D21-4ED6-AA03-549AB3170BC4}) (Version: 0.8.8.11 - Ryan Conrad)
DS4Windows (HKLM-x32\...\{120A83BA-E2E4-4A67-9E53-C4C9213997E4}) (Version: 1.5.22.0 - DSDCS)
DSSpectate (HKLM-x32\...\{2C5368A6-BFC0-4A63-904A-8C70DAB553EE}_is1) (Version: 1.2.0.0 - DSSpectate)
DVD Shrink 3.2 (HKLM-x32\...\DVD Shrink_is1) (Version: - DVD Shrink)
DVDFab 8.2.0.8 (29/08/2012) Qt (HKLM-x32\...\DVDFab 8 Qt_is1) (Version: - Fengtao Software Inc.)
Dying Light (HKLM-x32\...\Steam App 239140) (Version: - Techland)
EndNote X7 (HKLM-x32\...\{86B3F2D6-AC2B-0017-8AE1-F2F77F781B0C}) (Version: 17.5.0.9325 - Thomson Reuters)
EZ Setup B12.0509.01 (HKLM-x32\...\{DA6AF673-AD91-4AC7-B2F4-FE0C8A3A7E99}) (Version: 1.00.0000 - GIGABYTE)
Ezvid (HKLM-x32\...\{F96D619D-99D6-4C9C-A393-0CD22DE1CA66}_is1) (Version: 0.8.9.5 - Ezvid, inc.)
f.lux (HKCU\...\Flux) (Version: - )
Fallout 4 (HKLM-x32\...\Steam App 377160) (Version: - Bethesda Game Studios)
Far Cry 4 (HKLM-x32\...\Uplay Install 420) (Version: - Ubisoft)
Fiddler (HKLM-x32\...\Fiddler2) (Version: 4.4.9.7 - Telerik)
Flashtool (HKLM-x32\...\Flashtool) (Version: 0.9.15.0 - Androxyde)
Flawless Widescreen version 1.0.15 (HKLM-x32\...\{7348D82E-8C68-48FF-BA2D-8C97B5B4B3D8}_is1) (Version: 1.0.15 - Flawless Widescreen)
Fraps (remove only) (HKLM-x32\...\Fraps) (Version: - )
Freemake Video Converter version 4.1.4 (HKLM-x32\...\Freemake Video Converter_is1) (Version: 4.1.4 - Ellora Assets Corporation)
GOG Galaxy (HKLM-x32\...\{7258BA11-600C-430E-A759-27E2C691A335}_is1) (Version: - GOG.com)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 55.0.2883.75 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.31.5 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
Gpg4win (2.2.6) (HKLM-x32\...\GPG4Win) (Version: 2.2.6 - The Gpg4win Project)
GPU Temp version 1.0 (HKLM-x32\...\{8C8711FD-0FC8-4801-B33E-ED19BB0350B1}_is1) (Version: 1.0 - gputemp.com)
Grand Theft Auto V (HKLM-x32\...\{E01FA564-2094-4833-8F2F-1FFEC6AFCC46}) (Version: "1.00.0000" - Rockstar Games)
Half-Life 2 (HKLM-x32\...\Steam App 220) (Version: - Valve)
Half-Life 2: Lost Coast (HKLM-x32\...\Steam App 340) (Version: - Valve)
HandBrake 0.9.8 (HKLM-x32\...\HandBrake) (Version: 0.9.8 - )
Heroes of the Storm (HKLM-x32\...\Heroes of the Storm) (Version: - Blizzard Entertainment)
Hitman: Absolution (HKLM-x32\...\Steam App 203140) (Version: - )
ibb & obb (HKLM-x32\...\Steam App 95400) (Version: - Sparpweed)
iFunbox (v3.0.3109.1352) (HKLM-x32\...\iFunbox_is1) (Version: v3.0.3109.1352 - iFunbox DevTeam)
InfraRecorder 0.53 (x64 edition) (HKLM\...\{2C22EA92-CB30-4932-0053-000001000000}) (Version: 0.53.00.00 - Christian Kindahl)
Inside (HKLM-x32\...\{9BD4503F-F711-491D-984A-AB4ABD66B8C2}_is1) (Version: - Playdead)
Intel(R) Chipset Device Software (HKLM-x32\...\{619e726e-d2b4-4e28-9568-c964fd81ee6c}) (Version: 10.1.1.14 - Intel(R) Corporation) Hidden
Intel(R) Driver Update Utility 2.5 (HKLM-x32\...\{8EF465B2-1D08-4CA2-8ACC-1911B573725D}) (Version: 2.5.0.22 - Intel) Hidden
Intel(R) Product Improvement Program (HKLM-x32\...\{5859045D-9DED-4776-9930-C9461AB2FF12}) (Version: 2.1.27.3 - Intel) Hidden
Intel(R) Rapid Start Technology (HKLM-x32\...\3D073343-CEEB-4ce7-85AC-A69A7631B5D6) (Version: 1.0.0.1022 - Intel Corporation)
Intel(R) Rapid Storage Technology (HKLM-x32\...\{3E29EE6C-963A-4aae-86C1-DC237C4A49FC}) (Version: 11.5.0.1207 - Intel Corporation)
Intel® Driver Update Utility (HKLM-x32\...\{aa1dec3b-dc4b-4db0-8c18-9157457eff1f}) (Version: 2.5.0.22 - Intel)
iTunes (HKLM\...\{554C62C7-E6BB-40F1-892B-F0AE02D3C135}) (Version: 12.5.3.17 - Apple Inc.)
Java 8 Update 101 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F32180101F0}) (Version: 8.0.1010.13 - Oracle Corporation)
Java SE Development Kit 7 Update 6 (HKLM-x32\...\{32A3A4F4-B792-11D6-A78A-00B0D0170060}) (Version: 1.7.0.60 - Oracle)
Java SE Development Kit 7 Update 7 (64-bit) (HKLM\...\{64A3A4F4-B792-11D6-A78A-00B0D0170070}) (Version: 1.7.0.70 - Oracle)
Java SE Development Kit 7 Update 7 (HKLM-x32\...\{32A3A4F4-B792-11D6-A78A-00B0D0170070}) (Version: 1.7.0.70 - Oracle)
JDiskReport 1.4.1 (HKLM-x32\...\JDiskReport 1.4.1) (Version: 1.4.1 (2014-02-26 11:50:44) - JGoodies Karsten Lentzsch)
Junk Mail filter update (HKLM-x32\...\{FECB76C1-1C1D-4A84-8D47-5754C74B5A5E}) (Version: 16.4.3503.0728 - Microsoft Corporation) Hidden
Lagarith lossless video codec (Remove Only) (HKLM-x32\...\LAGARITH) (Version: - )
LG United Mobile Driver (HKLM-x32\...\{2A3A4BD6-6CE0-4e2a-80D2-1D0FF6ACBFBA}) (Version: 3.12.3.0 - LG Electronics)
Life Is Strange™ (HKLM\...\Steam App 319630) (Version: - DONTNOD Entertainment)
LIMBO (HKLM-x32\...\Steam App 48000) (Version: - )
Macro Recorder 5.8.0 (HKLM-x32\...\Macro Recorder_is1) (Version: 5.8.0 - Jitbit Software)
Mark of the Ninja (HKLM-x32\...\Steam App 214560) (Version: - )
Max Payne 3 (HKLM-x32\...\Steam App 204100) (Version: - Rockstar)
Microsoft .NET Framework 4 Multi-Targeting Pack (HKLM-x32\...\{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}) (Version: 4.0.30319 - Microsoft Corporation)
Microsoft ASP.NET MVC 4 Runtime (HKLM-x32\...\{3FE312D5-B862-40CE-8E4E-A6D8ABF62736}) (Version: 4.0.40804.0 - Microsoft Corporation)
Microsoft Expression Blend 3 SDK (HKLM-x32\...\{256E7DAC-9BE8-494E-8DE7-7857BF96B774}) (Version: 1.0.1343.0 - Microsoft Corporation)
Microsoft Expression Blend SDK for .NET 4 (HKLM-x32\...\{9B3A1C97-A361-463E-8817-444F9F88CDFE}) (Version: 2.0.20525.0 - Microsoft Corporation)
Microsoft Expression Blend SDK for Silverlight 4 (HKLM-x32\...\{1C997E1C-5CE9-4AF3-AAA9-DC65E6090827}) (Version: 2.0.20525.0 - Microsoft Corporation)
Microsoft Expression Encoder 4 (HKLM-x32\...\Encoder_4.0.1639.0) (Version: 4.0.1639.0 - Microsoft Corporation)
Microsoft Expression Encoder 4 Screen Capture Codec (HKLM-x32\...\{BF127B80-CFD5-4379-9752-E8AF1A5D0141}) (Version: 4.0.1639.0 - Microsoft Corporation)
Microsoft Expression Studio 4 (HKLM-x32\...\ExpressionStudio_4.0.20525.0) (Version: 4.0.20525.0 - Microsoft Corporation)
Microsoft Games for Windows - LIVE Redistributable (HKLM-x32\...\{832D9DE0-8AFC-4689-9819-4DBBDEBD3E4F}) (Version: 3.5.92.0 - Microsoft Corporation)
Microsoft Games for Windows Marketplace (HKLM-x32\...\{4CB0307C-565E-4441-86BE-0DF2E4FB828C}) (Version: 3.5.50.0 - Microsoft Corporation)
Microsoft Office 365 ProPlus - en-us (HKLM\...\O365ProPlusRetail - en-us) (Version: 16.0.6965.2105 - Microsoft Corporation)
Microsoft Online Services Sign-in Assistant (HKLM\...\{46E637E2-AC34-4B45-B5DF-D20903A3DB61}) (Version: 7.250.4303.0 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.50901.0 - Microsoft Corporation)
Microsoft Silverlight 3 SDK (HKLM-x32\...\{2012098D-EEE9-4769-8DD3-B038050854D4}) (Version: 3.0.40818.0 - Microsoft Corporation)
Microsoft Silverlight 4 SDK (HKLM-x32\...\{801B0DA3-A3FF-46CC-B97F-D76D510AF5AE}) (Version: 4.0.50401.0 - Microsoft Corporation)
Microsoft SQL Server 2005 Compact Edition [ENU] (HKLM-x32\...\{F0B430D1-B6AA-473D-9B06-AA3DD01FD0B8}) (Version: 3.1.0000 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24210 (HKLM-x32\...\{f144e08f-9cbe-4f09-9a8c-f2b858b7ee7f}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24210 (HKLM-x32\...\{23658c02-145e-483d-ba6b-1eb82c580529}) (Version: 14.0.24210.0 - Microsoft Corporation)
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
Microsoft XNA Framework Redistributable 4.0 Refresh (HKLM-x32\...\{D69C8EDE-BBC5-436B-8E0E-C5A6D311CF4F}) (Version: 4.0.30901.0 - Microsoft Corporation)
Middle-earth: Shadow of Mordor (HKLM-x32\...\Steam App 241930) (Version: - Monolith Productions, Inc.)
MKV TO AVI CONVERTER version 3.32 (HKLM-x32\...\MKV TO AVI CONVERTER_is1) (Version: - )
Movie Maker (HKLM-x32\...\{40F55150-F43D-4C9F-9A00-1A0A6F1EB7F0}) (Version: 16.4.3503.0728 - Microsoft Corporation) Hidden
Movie Maker (HKLM-x32\...\{D71BC54E-A4E6-4E06-866C-FD6EE16EA187}) (Version: 16.4.3503.0728 - Microsoft Corporation) Hidden
Music Manager (HKCU\...\MusicManager) (Version: - Google, Inc.)
MyHarmony (HKCU\...\036a0e4fc6a247ec) (Version: 1.0.1.257 - Logitech)
Notepad++ (HKLM-x32\...\Notepad++) (Version: 6.8.6 - Notepad++ Team)
NVIDIA 3D Vision Controller Driver 369.04 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 369.04 - NVIDIA Corporation)
NVIDIA 3D Vision Driver 376.19 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 376.19 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.1.2.31 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.1.2.31 - NVIDIA Corporation)
NVIDIA Graphics Driver 376.19 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 376.19 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.34.17 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.17 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.16.0318 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.16.0318 - NVIDIA Corporation)
NvNodejs (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvNodejs) (Version: 3.1.2.31 - NVIDIA Corporation) Hidden
NvTelemetry (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_NvTelemetry) (Version: 1.2.0.0 - NVIDIA Corporation) Hidden
Office 16 Click-to-Run Extensibility Component (HKLM\...\{90160000-008C-0000-1000-0000000FF1CE}) (Version: 16.0.6965.2105 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Licensing Component (HKLM\...\{90160000-007E-0000-1000-0000000FF1CE}) (Version: 16.0.6965.2105 - Microsoft Corporation) Hidden
Office 16 Click-to-Run Localization Component (HKLM\...\{90160000-008C-0409-1000-0000000FF1CE}) (Version: 16.0.6965.2105 - Microsoft Corporation) Hidden
OpenOffice.org 3.4.1 (HKLM-x32\...\{9F1F2AEA-C72A-4DD6-991E-C5506A5625E4}) (Version: 3.41.9593 - Apache Software Foundation)
Origin (HKLM-x32\...\Origin) (Version: 10.3.2.64936 - Electronic Arts, Inc.)
Overwatch (HKLM-x32\...\Overwatch) (Version: - Blizzard Entertainment)
Overwolf (HKLM-x32\...\Overwolf) (Version: 0.100.9.0 - Overwolf Ltd.)
PAYDAY: The Heist (HKLM-x32\...\Steam App 24240) (Version: - Overkill)
PixelJunk™ Monsters Ultimate (HKLM\...\Steam App 243780) (Version: - Double Eleven)
Platform (HKLM-x32\...\{20D4A895-748C-4D88-871C-FDB1695B0169}) (Version: 1.39 - VIA Technologies, Inc.) Hidden
Prison Architect (HKLM-x32\...\Steam App 233450) (Version: - Introversion Software)
PS3 Media Server (HKLM-x32\...\PS3 Media Server) (Version: 1.90.1 - PS3 Media Server)
PunkBuster Services (HKLM-x32\...\PunkBusterSvc) (Version: 0.991 - Even Balance, Inc.)
puush (HKLM-x32\...\{C3592426-531E-4110-911D-BFECE2CE284B}) (Version: 1.0.0.0 - Dean Herbert)
qBittorrent 3.2.0 (HKLM-x32\...\qBittorrent) (Version: 3.2.0 - The qBittorrent project)
QuickTime 7 (HKLM-x32\...\{3D2CBC2C-65D4-4463-87AB-BB2C859C1F3E}) (Version: 7.76.80.95 - Apple Inc.)
Razer Synapse (HKLM-x32\...\{0D78BEE2-F8FF-4498-AF1A-3FF81CED8AC6}) (Version: 2.20.15.804 - Razer Inc.)
rebox.NET 1.9.6.1 (HKLM-x32\...\rebox.NET 1.9.6.1) (Version: 1.9.6.1 - clone.AD)
ResearchSoft Direct Export Helper (HKLM-x32\...\ResearchSoft Direct Export Helper) (Version: - Thomson Reuters)
Rockstar Games Social Club (HKLM-x32\...\Rockstar Games Social Club) (Version: 1.1.6.5 - Rockstar Games)
Samsung Kies3 (HKLM-x32\...\{88547073-C566-4895-9005-EBE98EA3F7C7}) (Version: 3.2.15041.2 - Samsung Electronics Co., Ltd.) Hidden
Samsung Kies3 (HKLM-x32\...\InstallShield_{88547073-C566-4895-9005-EBE98EA3F7C7}) (Version: 3.2.15041.2 - Samsung Electronics Co., Ltd.)
Samsung Magician (HKLM-x32\...\{29AE3F9F-7158-4ca7-B1ED-28A73ECDB215}_is1) (Version: 4.5.1 - Samsung Electronics)
SAMSUNG USB Driver for Mobile Phones (HKLM\...\{D0795B21-0CDA-4a92-AB9E-6E92D8111E44}) (Version: 1.5.49.0 - SAMSUNG Electronics Co., Ltd.)
Secure Download Manager (HKLM-x32\...\{4A5667B2-5D13-46C2-85B5-9D46A6096F61}) (Version: 3.1.0 - Kivuto Solutions Inc.)
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 7.1.0340 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 3.1.2.31 - NVIDIA Corporation) Hidden
Shutdown8 (HKCU\...\Shutdown8) (Version: 1.0 - Bandisoft.com)
Sid Meier's Civilization VI (HKLM\...\Steam App 289070) (Version: - Firaxis)
Sid Meier's Civilization: Beyond Earth (HKLM-x32\...\Steam App 65980) (Version: - Firaxis Games)
SimCity 2000 Special Edition (HKLM-x32\...\{59D2C751-F7BE-4E9F-9C8C-1F16013802C7}) (Version: 2.0.0.1 - Electronic Arts)
Simple Port Forwarding (HKLM-x32\...\Simple Port Forwarding) (Version: 3.8.5 - PcWinTech.com)
Skulls of the Shogun (HKLM-x32\...\Steam App 228960) (Version: - 17-BIT)
Skype™ 7.27 (HKLM-x32\...\{FC965A47-4839-40CA-B618-18F486F042C6}) (Version: 7.27.101 - Skype Technologies S.A.)
SlimDX Runtime .NET 4.0 x86 (January 2012) (HKLM-x32\...\{7EBD0E43-6AC0-4CA8-9990-00E50069AD29}) (Version: 2.0.13.43 - SlimDX Group)
Smartflix (HKCU\...\smartflix) (Version: 1.3.1 - Smartflix)
Sony Mobile Update Engine (HKLM-x32\...\Update Engine) (Version: 2.14.12.201408250841 - Sony Mobile Communications AB)
Sony PC Companion 2.10.221 (HKLM-x32\...\{F09EF8F2-0976-42C1-8D9D-8DF78337C6E3}) (Version: 2.10.221 - Sony)
Source SDK Base 2007 (HKLM-x32\...\Steam App 218) (Version: - Valve)
Spotflux (HKLM-x32\...\Spotflux) (Version: 2.9.11 - Spotflux)
StarCraft II (HKLM-x32\...\StarCraft II) (Version: - Blizzard Entertainment)
Steam (HKLM-x32\...\{048298C9-A4D3-490B-9FF9-AB023A9238F3}) (Version: 1.0.0.0 - Valve Corporation)
SteamTool 1.1 (HKLM-x32\...\{B442D7D6-5153-4DBC-954D-BFFAACACDFDC}_is1) (Version: 1.1 - Stefan Jones)
swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
SymMover (HKLM-x32\...\SymMover) (Version: - )
System Requirements Lab CYRI (HKLM-x32\...\{705216C1-BA52-4B16-AFE4-4143B340D62D}) (Version: 6.0.12.6 - Husdawg, LLC)
TeamSpeak 3 Client (HKLM\...\TeamSpeak 3 Client) (Version: 3.0.9.2 - TeamSpeak Systems GmbH)
The Sims™ 4 (HKLM-x32\...\{48EBEBBF-B9F8-4520-A3CF-89A730721917}) (Version: 1.3.33.1010 - Electronic Arts Inc.)
The Stanley Parable (HKLM-x32\...\Steam App 221910) (Version: - Galactic Cafe)
The Wolf Among Us (HKLM-x32\...\Steam App 250320) (Version: - Telltale Games)
Titanfall™ 2 (HKLM-x32\...\{4BD80373-FEE7-45B6-8249-6E8E98717405}) (Version: 1.0.0.3 - Electronic Arts, Inc.)
Tom Clancy's Splinter Cell Blacklist (HKLM-x32\...\Steam App 235600) (Version: - Ubisoft Toronto)
Tom Clancy's The Division (HKLM-x32\...\Uplay Install 568) (Version: - Ubisoft)
TP-LINK TL-WN821N(C)_TL-WN822N_TL-WN823N Driver (HKLM-x32\...\{852E893E-E4FD-45BB-8B17-72ADDF686974}) (Version: 1.3.1 - TP-LINK)
TP-LINK Wireless Configuration Utility (HKLM-x32\...\{319D91C6-3D44-436C-9F79-36C0D22372DC}) (Version: 1.3.1 - TP-LINK)
Tune Sweeper (HKLM-x32\...\{5E1E4C7A-A7D6-42F0-BDBA-DF20200E144E}) (Version: 2.001 - Wide Angle Software)
Unity Web Player (HKCU\...\UnityWebPlayer) (Version: - Unity Technologies ApS)
Universal Adb Driver (HKLM-x32\...\{D9C4202E-6D51-4B06-A8F1-22316E654BCA}) (Version: 1.0.0 - ClockworkMod)
Uplay (HKLM-x32\...\Uplay) (Version: 15.0 - Ubisoft)
VC80CRTRedist - 8.0.50727.6195 (HKLM-x32\...\{933B4015-4618-4716-A828-5289FC03165F}) (Version: 1.2.0 - DivX, Inc) Hidden
VIA Platform Device Manager (HKLM-x32\...\InstallShield_{20D4A895-748C-4D88-871C-FDB1695B0169}) (Version: 1.39 - VIA Technologies, Inc.)
VLC media player (HKLM-x32\...\VLC media player) (Version: 2.2.4 - VideoLAN)
VLC Setup Helper (HKLM-x32\...\VLC Setup Helper_is1) (Version: - Hobbyist Software)
Vulkan Run Time Libraries 1.0.26.0 (HKLM\...\VulkanRT1.0.26.0) (Version: 1.0.26.0 - LunarG, Inc.)
Windows Live Essentials (HKLM-x32\...\WinLiveSuite) (Version: 16.4.3503.0728 - Microsoft Corporation)
WinPcap 4.1.2 (HKLM-x32\...\WinPcapInst) (Version: 4.1.0.2001 - CACE Technologies)
WinRAR 4.20 (64-bit) (HKLM\...\WinRAR archiver) (Version: 4.20.0 - win.rar GmbH)
WinX DVD Ripper Platinum 6.9.2 (HKLM-x32\...\WinX DVD Ripper Platinum_is1) (Version: - Digiarty Software, Inc.)
WizTree v1.07 (HKLM-x32\...\WizTree_is1) (Version: - Antibody Software)
World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment)
WPF Toolkit February 2010 (Version 3.5.50211.1) (HKLM-x32\...\{5EE6E987-1B79-4A93-832B-27472C7D1579}) (Version: 3.5.50211.1 - Microsoft Corporation)
Percentage of memory in use: 27%
Total physical RAM: 16344.23 MB
Available physical RAM: 11881.25 MB
Total Virtual: 18776.23 MB
Available Virtual: 13451.72 MB
1 Drive c: (SSD) (Fixed) (Total:100.99 GB) (Free:5.13 GB) NTFS
2 Drive d: (1TB WD Black Caviar) (Fixed) (Total:931.51 GB) (Free:48.85 GB) NTFS
3 Drive e: (Samsung SSD) (Fixed) (Total:465.76 GB) (Free:263.54 GB) NTFS
4 Drive f: (Overwatch 1.0) (CDROM) (Total:4.83 GB) (Free:0 GB) CDFS
5 Drive h: (My Passport) (Fixed) (Total:298.02 GB) (Free:192.63 GB) FAT32
User accounts for \\JASONSBIGPC
Jason
**** End of log ****
