Installed a new GPU and my PC is still not performing well
This is Minecraft: Java Edition, it comes with it installed. I don't have the Windows 10 edition of Minecraft. Is that what you are suggesting I get?
I downloaded windows 10 edition and it does get way better fps, however its like mixing a console with a pc. The movements feel slower and because of that fighting isn't as effective as it is on the java edition. I appreciate all your help, its okay if you don't wanna help me anymore. I'll most likely buy more ram for the computer, that is what I suspected was the cause of this, and that is what you said as well.
I never give up on a thread and not about to do so now, as long as you help me to help you I will be here.
More RAM is not the answer to your problem, getting rid of the resource hog is what we need to do and in this instance Java is the culprit.
What would happen if you added say another 8GB of RAM, as long as Java is on the computer the exact same thing would happen, it would hog most of the first 8GB of RAM and the other 8GB would be left unused.
Not a gamer myself so not much help when it comes to FPS but over the years through helping people I have found that when it comes to online gaming there are two things that hinder gaming, a poor internet connection and browser security plug ins, sort them and you are usually good to go.
Something for you to do to see how your present set up handles video when not online gaming;
Use the free versions at the following two links.
Check your FPS with Valley
Looks like the OP may have disregarded the guidance that adding more RAM was not the answer so the following post for the record;
