Solved I wanna upgrade my opitlex 980. Please help
Have absolutely no idea what you mean, what is unavailable, what page and where does whatever it is you are referring to cost 100 euros :unsure:
Way more than what you need and out of stock in any event.
Who told you that you needed such a PSU which btw you can`t select until you have made sure that the GPU you want is available.
cooler master doesnt have poor quality also
Check the PSU links in my sig and you will see that Cooler Master are on the avoid list, take a look here
A GPU and a PSU have been suggested by myself but the final decision is yours to make.
Okay final things and some changes
all of it together is 186.98
Adaptor and GPU are ok, not going to repeat myself regarding the PSU as you are obviously not listening.
Trust me the EVGA is worth paying that little bit more for, on the recommended list, Bronze efficiency rated, 85% efficiency and a three year warranty, this as opposed to the CM being on the avoid list, not being Bronze efficiency rated, only up to 75% efficiency and a shorter two year warranty.
You have as much information and assistance as can be provided from here so anything else you will need to ask a local tech store to help you, you have your list of parts so now it is up to you to purchase and fit them or alternatively have a tech fit them for you.
