Solved I think I might be infected, I'm not sure exactly of the symptoms and problems however.
Most common when playing rainbow six seige but event viewer is showing many instances of errors
Error:
Unable to start a DCOM Server: MicrosoftWindows.Client.WebExperience_424.1301.170.0_x64__cw5n1h2txyewy!WindowsUdk.UI.Shell.Dashboard.DashboardExtension as Unavailable/Unavailable. The error:
"2147942402"
Happened while starting this command:
"C:\Program Files\WindowsApps\MicrosoftWindows.Client.WebExperience_424.1301.170.0_x64__cw5n1h2txyewy\Dashboard\Widgets.exe" -ServerName:Microsoft.Windows.DashboardServer
Warning:
The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID
{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}
and APPID
{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}
to the user NT AUTHORITY\LOCAL SERVICE SID (S-1-5-19) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Warning:
{2593F8B9-4EAF-457C-B68A-50F6B8EA6B54}
and APPID
{15C20B67-12E7-4BB6-92BB-7AFF07997402}
to the user SamsPC\leuma SID (S-1-5-21-2137828512-2473441878-3475286344-1001) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Or I can close this thread and mark solved since there is no malware and you can create a new thread here.
