i have low fps with a realy good computer
Your machine is running quite hot!
Intel Core i7 @ 3.20GHz: 60 °C
4095MB NVIDIA GeForce GTX 1070 Ti (MSI): 67 °C
I'd suggest a good cleaning with compressed air. Reseat all components while you are inside.
8 now what the problem i think. My gpu gb says only 4 and i have 8. How to fix it?
Your machine is running hot, perhaps replacing the thermal paste is in order, at least make sure that all of your fans are spinning and spinning in the right direction.
Heat is your enemy and will cause major slow downs
Which side the fans needs to go? I cany change my theemal paste i dont know how
without being harsh, it sounds to me like the issue, and its resolution, may be outside your skill set. :)
it's never too late to put your hand up and seek professional help.
take it to your local IT guy to have a look, yes, it will cost you, but it'll be fixed much faster than this thread has been dragging on for.
Reactions: gus and veeg
