i have low fps with a realy good computer
sqwarli
34
27
OK so i want first to say thank you if your gonna help right no ok lets get to the point so i have a beast pc with great specs
+i7 8700
+msi gtx 1070 ti
+16 gigs of ram
and corsair vs650 power supply
and ive being getting low fps in games manly fortnite i used to have over 160 fps on epic settings and now im getting 100 pubg the same i have all the drivers for my graphics card and i even re install windows 10 to chek for viruses and
got nun please help me guys please tou guys are my only hope i did every thing nothing helped me
Hi @sqwarli and welcome to PCHF :)
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Flush DNS
Thank you for the answer il try it asoon as i get of work
You are missing your chipset driver, which happens to be one of the most important drivers.
Exact make and model of your machine??
Name: SM Bus Controller
Description: SM Bus Controller
Class Guid:
Manufacturer:
Service:
Device ID: PCI\VEN_8086&DEV_A323&SUBSYS_86941043&REV_10\3&11583659&0&FC
Problem: : The drivers for this device are not installed. (Code 28)
Resolution: To install the drivers for this device, click "Update Driver", which starts the Hardware Update wizard.
Class Guid:
Manufacturer:
Service:
Il try
I can tell you the vram model 16gigs of g skil i dont remmber the name of the model
Class Guid:
Manufacturer:
Service:
It did not work
Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
Thanks to @phillpower2 for the following instructions.
Download Speedfan and install it. Once it's installed, run the program and post here the information it shows. The information I want you to post is the stuff that is circled in the example picture I have attached.
(this is a screenshot from a vista machine)
So that we have a comparison to Speedfan, download, run and grab a screenshot of HWMonitor (free).
Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
thats helps ? i did not understand what you said in your commend so i sent all of the information
