I get no signal when i connect two monitors.
Mack3
28
Hello. I was using two monitors. A 32'' msi with displayport, and a asus 24'' with HDMI. They worked as intended, but once i moved to a new apartment, i started having issues with it. So i can connect my 32'' with DP on its own and its working like a charm. I can also do the same on the 24'' HDMI. But once i connect both, the 32'' gets a signal but shows no picture. Just a very dark blue static image. The 24'' gets no signal at all. I always use the 32'' straight into the GPU since its my main monitor, and i've tried to swap the 24'' into both motherboard and gpu, doesnt change the problem.
