High graphics usage and temperature in task manager
Thank you again. So, I will wait for them to update me with the drivers from the MB manufacturer, and let you know what happens.
I will put the note of the results as soon as I come back, going out for food.
Okay am back. I thought the intel detect would take time but it was almost instant.
these 3 were found to have updates:
Very strange, was expecting to see more drivers available than that, back to waiting on Ripple I`m afraid.
Reactions: maxim123
Seems like it will take some time, I messaged them but they said they haven't received the updates from the MB manufacturer. Will update here once I receive update.
Sorry to hear that your update is not better news :(
Suggestion, try asking them for the MB details, brand and model name or number, if we have that info we can do our own research.
Reactions: maxim123
I got a reply from them. They said by friday now, but not sure if it will really come at friday. I asked them about MB details, and they said it is classified.
The MB info is classified, what a load of nonsense they are telling you, they are not NASA and it suggests to me that they do not know what is in there, no wonder their customer service is pathetic/almost non existent.
Download and run CPU-z which is a free program that will give you info on all the hardware, download from here
Reactions: maxim123
Hi, here is the report in text file:
Code:
CPU-Z TXT Report
Binaries
CPU-Z version            2.08.0.x64
Processors
CPU Groups            1
CPU Group 0            20 threads, mask=0xFFFFF
Number of sockets        1
Number of threads        20
APICs
Socket 0
    -- Core 0 (ID 0)
        -- Thread 0    0
        -- Thread 1    1
    -- Core 1 (ID 4)
        -- Thread 2    8
        -- Thread 3    9
    -- Core 2 (ID 8)
        -- Thread 4    16
        -- Thread 5    17
    -- Core 3 (ID 12)
        -- Thread 6    24
        -- Thread 7    25
    -- Core 4 (ID 16)
        -- Thread 8    32
        -- Thread 9    33
    -- Core 5 (ID 20)
        -- Thread 10    40
        -- Thread 11    41
    -- Core 6 (ID 24)
        -- Thread 12    48
    -- Core 7 (ID 25)
        -- Thread 13    50
    -- Core 8 (ID 26)
        -- Thread 14    52
    -- Core 9 (ID 27)
        -- Thread 15    54
    -- Core 10 (ID 28)
        -- Thread 16    56
    -- Core 11 (ID 29)
        -- Thread 17    58
    -- Core 12 (ID 30)
        -- Thread 18    60
    -- Core 13 (ID 31)
        -- Thread 19    62
Timers
    ACPI timer        3.580 MHz
    Perf timer        10.000 MHz
    Sys timer        1.000 KHz
Processors Information
Socket 1            ID = 0
    Number of cores        14 (max 14)
    Number of threads    20 (max 20)
    Hybrid            yes, 2 coresets
    Core Set 0        P-Cores, 6 cores, 12 threads
    Core Set 1        E-Cores, 8 cores, 8 threads
    Manufacturer        GenuineIntel
    Name            Intel Core i7 12700H
    Codename        Alder Lake
    Specification        12th Gen Intel(R) Core(TM) i7-12700H
    Package (platform ID)    Socket 1744 FCBGA (0x7)
    CPUID            6.A.3
    Extended CPUID        6.9A
    Core Stepping        L0
    Technology        10 nm
    TDP Limit        45.0 Watts
    Tjmax            100.0  C
    Core Speed        4090.0 MHz
    Multiplier x Bus Speed    41.0 x 99.8 MHz
    Base frequency (cores)    99.8 MHz
    Base frequency (mem.)    99.8 MHz
    Stock frequency        0 MHz
    Max frequency        0 MHz
    Instructions sets    MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, AES, AVX, AVX2, FMA3, SHA
    Microcode Revision    0x414
    L1 Data cache        6 x 48 KB (12-way, 64-byte line) + 8 x 32 KB (8-way, 64-byte line)
    L1 Instruction cache    6 x 32 KB (8-way, 64-byte line) + 8 x 64 KB (8-way, 64-byte line)
    L2 cache        6 x 1.25 MB (10-way, 64-byte line) + 2 x 2 MB (16-way, 64-byte line)
    L3 cache        24 MB (12-way, 64-byte line)
    Max CPUID level        00000020h
    Max CPUID ext. level    80000008h
    FID/VID Control        yes
    Turbo Mode        supported, enabled
    Max non-turbo ratio    27x
    Max turbo ratio        47x
    Max efficiency ratio    4x
    Min operating ratio    4x
    Speedshift        Autonomous
    O/C bins        none
    Ratio 1 P-Core        47x
    Ratio 2 P-Cores        47x
    Ratio 3 P-Cores        44x
    Ratio 4 P-Cores        44x
    Ratio 5 P-Cores        41x
    Ratio 6 P-Cores        41x
    Ratio 7 P-Cores        41x
    Ratio 8 P-Cores        41x
    Ratio 1 E-Core        35x
    Ratio 2 E-Cores        35x
    Ratio 3 E-Cores        35x
    Ratio 4 E-Cores        35x
    Ratio 4 E-Cores        33x
    Ratio 4 E-Cores        33x
    Ratio 4 E-Cores        33x
    Ratio 4 E-Cores        33x
    TDP Level        45.0 W @ 23x
    TDP Level        35.0 W @ 15x
    TDP Level        65.0 W @ 27x
    Temperature 0        63 degC (145 degF) (Package)
    Temperature 1        59 degC (138 degF) (P-Cores (Max))
    Temperature 2        48 degC (118 degF) (E-Cores (Max))
    Temperature 3        56 degC (132 degF) (P-Core #0)
    Temperature 4        48 degC (118 degF) (P-Core #1)
    Temperature 5        54 degC (129 degF) (P-Core #2)
    Temperature 6        55 degC (131 degF) (P-Core #3)
    Temperature 7        53 degC (127 degF) (P-Core #4)
    Temperature 8        45 degC (113 degF) (P-Core #5)
    Temperature 9        48 degC (118 degF) (E-Core #6)
    Temperature 10        48 degC (118 degF) (E-Core #7)
    Temperature 11        48 degC (118 degF) (E-Core #8)
    Temperature 12        48 degC (118 degF) (E-Core #9)
    Temperature 13        46 degC (114 degF) (E-Core #10)
    Temperature 14        46 degC (114 degF) (E-Core #11)
    Temperature 15        47 degC (116 degF) (E-Core #12)
    Temperature 16        47 degC (116 degF) (E-Core #13)
    Voltage 0        1.29 Volts (VID)
    Power 00        21.74 W (Package)
    Power 01        19.74 W (IA Cores)
    Power 02        0.00 W (GT)
    Power 03        n.a. (DRAM)
    Clock Speed 0        4090.00 MHz (P-Core #0)
    Clock Speed 1        4090.00 MHz (P-Core #1)
    Clock Speed 2        4090.00 MHz (P-Core #2)
    Clock Speed 3        4090.00 MHz (P-Core #3)
    Clock Speed 4        4090.00 MHz (P-Core #4)
    Clock Speed 5        4090.00 MHz (P-Core #5)
    Clock Speed 6        3491.46 MHz (E-Core #6)
    Clock Speed 7        3491.46 MHz (E-Core #7)
    Clock Speed 8        3491.46 MHz (E-Core #8)
    Clock Speed 9        3491.46 MHz (E-Core #9)
    Clock Speed 10        3491.46 MHz (E-Core #10)
    Clock Speed 11        3491.46 MHz (E-Core #11)
    Clock Speed 12        3491.46 MHz (E-Core #12)
    Clock Speed 13        3491.46 MHz (E-Core #13)
    Core 0 max ratio    47.00 (effective 46.00)
    Core 1 max ratio    47.00 (effective 44.00)
    Core 2 max ratio    47.00 (effective 47.00)
    Core 3 max ratio    47.00 (effective 47.00)
    Core 4 max ratio    47.00 (effective 46.00)
    Core 5 max ratio    47.00 (effective 44.00)
    Core 6 max ratio    47.00 (effective 35.00)
    Core 7 max ratio    47.00 (effective 35.00)
    Core 8 max ratio    47.00 (effective 35.00)
    Core 9 max ratio    47.00 (effective 35.00)
    Core 10 max ratio    47.00 (effective 35.00)
    Core 11 max ratio    47.00 (effective 35.00)
    Core 12 max ratio    47.00 (effective 35.00)
    Core 13 max ratio    47.00 (effective 35.00)
Thread dumps
CPU Thread 0
    APIC ID            0
    Topology        Processor ID 0, Core ID 0, Thread ID 0
    Cache descriptor    Level 1, D, 48 KB, 2 thread(s)
    Cache descriptor    Level 1, I, 32 KB, 2 thread(s)
    Cache descriptor    Level 2, U, 1280 KB, 8 thread(s)
    Cache descriptor    Level 3, U, 24 MB, 128 thread(s)
    CPUID
    0x00000000        0x00000020    0x756E6547    0x6C65746E    0x49656E69
    0x00000001        0x000906A3    0x00800800    0xFFFAF38B    0xBFCBFBFF
    0x00000002        0x00FEFF01    0x000000F0    0x00000000    0x00000000
    0x00000003        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000004        0xFC004121    0x02C0003F    0x0000003F    0x00000000
    0x00000004        0xFC004122    0x01C0003F    0x0000003F    0x00000000
    0x00000004        0xFC01C143    0x0240003F    0x000007FF    0x00000000
    0x00000004        0xFC1FC163    0x02C0003F    0x00007FFF    0x00000004
    0x00000005        0x00000040    0x00000040    0x00000003    0x00002020
    0x00000006        0x009F8FF3    0x00000002    0x00000409    0x00000003
    0x00000007        0x00000001    0x239CA7A9    0x184007A4    0xBC18C410
    0x00000008        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000009        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000000A        0x07300605    0x00000000    0x00000007    0x00008603
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000000
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000000
    0x0000000C        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000000D        0x00000007    0x00000340    0x00000340    0x00000000
    0x0000000D        0x0000000F    0x00000350    0x00001800    0x00000000
    0x0000000D        0x00000100    0x00000240    0x00000000    0x00000000
    0x0000000E        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000000F        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000010        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000011        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000012        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000013        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000014        0x00000001    0x0000005F    0x00000007    0x00000000
    0x00000015        0x00000002    0x0000008C    0x0249F000    0x00000000
    0x00000016        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000017        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000018        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000019        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000001A        0x40000001    0x00000000    0x00000000    0x00000000
    0x0000001B        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000001C        0x4000000B    0x00000007    0x00000007    0x00000000
    0x0000001D        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000001E        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000000
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000000
    0x00000020        0x00000000    0x00000001    0x00000000    0x00000000
    0x40000000        0x4000000C    0x7263694D    0x666F736F    0x76482074
    0x40000001        0x31237648    0x00000000    0x00000000    0x00000000
    0x40000002        0x0000585D    0x000A0000    0x00000003    0x00000BBF
    0x40000003        0x0000BFFF    0x002BB9FF    0x00000062    0x75FEFBF6
    0x40000004        0x00060E14    0x00000000    0x0000002E    0x00000000
    0x40000005        0x00000400    0x00000400    0x00000EB0    0x00000000
    0x40000006        0x018200AF    0x00000027    0x00000000    0x00000000
    0x40000007        0x80000007    0x0000000B    0x00000000    0x00000000
    0x40000008        0x00000000    0x00000000    0x00000000    0x00000000
    0x40000009        0x00000000    0x00000000    0x00000000    0x00000000
    0x4000000A        0x00000000    0x00000000    0x00000000    0x00000000
    0x4000000B        0x00000000    0x00000000    0x00000000    0x00000000
    0x4000000C        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000000        0x80000008    0x00000000    0x00000000    0x00000000
    0x80000001        0x00000000    0x00000000    0x00000121    0x2C100800
    0x80000002        0x68743231    0x6E654720    0x746E4920    0x52286C65
    0x80000003        0x6F432029    0x54286572    0x6920294D    0x32312D37
    0x80000004        0x48303037    0x00000000    0x00000000    0x00000000
    0x80000005        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000006        0x00000000    0x00000000    0x05007040    0x00000000
    0x80000007        0x00000000    0x00000000    0x00000000    0x00000100
    0x80000008        0x00003027    0x00000000    0x00000000    0x00000000
    MSR 0x0000001B        0x00000000    0xFEE00D00
    MSR 0x00000035        0x00000000    0x000E0014
    MSR 0x000001A0        0x00000000    0x00851889
    MSR 0x00000770        0x00000000    0x00000001
    MSR 0x00000774        0x0000019E    0x72003B01
    MSR 0x000000CE        0x0804043D    0xF0811B00
    MSR 0x00000017        0x001C0000    0x00000000
    MSR 0x000000C1        0x0000FFFF    0xFFF72830
    MSR 0x000000C2        0x000002FE    0xE9F3A007
    MSR 0x000000C3        0x000003EA    0x7386CF98
    MSR 0x000000C4        0x0000031A    0x7212B07A
    MSR 0x00000186        0x00000000    0x0051003C
    MSR 0x00000187        0x00000000    0x00410183
    MSR 0x000001AD        0x29292929    0x2C2C2F2F
    MSR 0x000001AE        0x08070605    0x04030201
    MSR 0x00000650        0x21212121    0x23232323
    MSR 0x00000194        0x00000000    0x00110000
    MSR 0x0000019A        0x00000000    0x00000000
    MSR 0x0000019C        0x00000000    0x88252802
    MSR 0x000001A2        0x00000000    0x05640000
    MSR 0x000001A4        0x00000000    0x00000000
    MSR 0x000001B1        0x00000000    0x88250A82
    MSR 0x000001FC        0x00000000    0x00EC005B
    MSR 0x00000606        0x00000000    0x000A0E03
    MSR 0x00000601        0x00000000    0x000006B8
    MSR 0x00000610        0x00428460    0x00DF8460
    MSR 0x00000611        0x00000000    0x6DAB399D
    MSR 0x00000639        0x00000000    0x316C5285
    MSR 0x00000641        0x00000000    0x00EE051C
    MSR 0x00000619        0x00000000    0x00000000
    MSR 0x00000614        0x00000000    0x00000168
    MSR 0x00000648        0x00000000    0x00000017
    MSR 0x00000649        0x00000000    0x000F0118
    MSR 0x0000064A        0x00000000    0x001B0208
    MSR 0x00000198        0x00002972    0x00002C00
    MSR 0x00000199        0x00000000    0x00001700
CPU Thread 1
    APIC ID            1
    Topology        Processor ID 0, Core ID 0, Thread ID 1
    CPUID
    0x00000001        0x000906A3    0x01800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000001
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000001
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000001
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000001
    MSR 0x0000001B        0x00000000    0xFEE00C00
    MSR 0x000000C1        0x0000FFFF    0xFFE74B65
    MSR 0x000000C2        0x00000097    0xA2E3AA75
    MSR 0x000000C3        0x000000C6    0xFE1DB270
    MSR 0x000000C4        0x000000A0    0x6E9506C2
    MSR 0x0000019C        0x00000000    0x88232802
    MSR 0x000001B1        0x00000000    0x88230A82
    MSR 0x00000611        0x00000000    0x6DAB51F7
    MSR 0x00000639        0x00000000    0x316C6A14
    MSR 0x00000198        0x00002843    0x00002C00
CPU Thread 2
    APIC ID            8
    Topology        Processor ID 0, Core ID 4, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x08800800    0xFFFAF38B    0xBFCBFBFF
    0x00000006        0x009F8FF3    0x00000002    0x00000409    0x00010003
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000008
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000008
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000008
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000008
    MSR 0x000000C1        0x0000FFFF    0xFF4913F9
    MSR 0x000000C2        0x00000473    0xD6EB7A1D
    MSR 0x000000C3        0x00000583    0xF13E1584
    MSR 0x000000C4        0x00000450    0x94730E8E
    MSR 0x0000019C        0x00000000    0x882A2800
    MSR 0x000001B1        0x00000000    0x882A0A82
    MSR 0x00000611        0x00000000    0x6DAB678A
    MSR 0x00000639        0x00000000    0x316C7E9B
    MSR 0x00000198        0x0000283D    0x00002C00
CPU Thread 3
    APIC ID            9
    Topology        Processor ID 0, Core ID 4, Thread ID 1
    CPUID
    0x00000001        0x000906A3    0x09800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000009
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000009
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000009
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000009
    MSR 0x000000C1        0x0000FFFF    0xFFF08583
    MSR 0x000000C2        0x000000CD    0x42F913C4
    MSR 0x000000C3        0x00000105    0xD5D75211
    MSR 0x000000C4        0x000000D0    0xF1588913
    MSR 0x0000019C        0x00000000    0x88262800
    MSR 0x000001B1        0x00000000    0x88260A82
    MSR 0x00000611        0x00000000    0x6DAB7BFF
    MSR 0x00000639        0x00000000    0x316C9179
    MSR 0x00000198        0x00002894    0x00002C00
CPU Thread 4
    APIC ID            16
    Topology        Processor ID 0, Core ID 8, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x10800800    0xFFFAF38B    0xBFCBFBFF
    0x00000006        0x009F8FF3    0x00000002    0x00000409    0x00020003
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000010
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000010
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000010
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000010
    MSR 0x00000774        0x0000019E    0x72003C01
    MSR 0x000000C1        0x0000FFFF    0xFF160F97
    MSR 0x000000C2        0x00000819    0x1AA4DCF8
    MSR 0x000000C3        0x000009ED    0x5BDD5C78
    MSR 0x000000C4        0x000007DE    0xF3F6085E
    MSR 0x0000019C        0x00000000    0x882C2A82
    MSR 0x000001B1        0x00000000    0x882C0A82
    MSR 0x00000611        0x00000000    0x6DAB8100
    MSR 0x00000639        0x00000000    0x316C963B
    MSR 0x00000198        0x00002946    0x00002F00
CPU Thread 5
    APIC ID            17
    Topology        Processor ID 0, Core ID 8, Thread ID 1
    CPUID
    0x00000001        0x000906A3    0x11800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000011
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000011
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000011
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000011
    MSR 0x000000C1        0x0000FFFF    0xFF11183E
    MSR 0x000000C2        0x000002FA    0x588F8257
    MSR 0x000000C3        0x000003A8    0x722697A6
    MSR 0x000000C4        0x000002EE    0x133FF06A
    MSR 0x0000019C        0x00000000    0x88272A82
    MSR 0x000001B1        0x00000000    0x88270A82
    MSR 0x00000611        0x00000000    0x6DAB8AC4
    MSR 0x00000639        0x00000000    0x316C9EF0
    MSR 0x00000198        0x000028AA    0x00002F00
CPU Thread 6
    APIC ID            24
    Topology        Processor ID 0, Core ID 12, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x18800800    0xFFFAF38B    0xBFCBFBFF
    0x00000006        0x009F8FF3    0x00000002    0x00000409    0x00030003
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000018
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000018
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000018
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000018
    MSR 0x000000C1        0x0000FFFF    0xFFFE105B
    MSR 0x000000C2        0x000008B9    0xFAEB4805
    MSR 0x000000C3        0x00000A9C    0x561EAF7C
    MSR 0x000000C4        0x00000869    0x9DE676C6
    MSR 0x0000019C        0x00000000    0x88262A82
    MSR 0x00000611        0x00000000    0x6DAB9C14
    MSR 0x00000639        0x00000000    0x316CAE8C
    MSR 0x00000198        0x00002822    0x00002F00
CPU Thread 7
    APIC ID            25
    Topology        Processor ID 0, Core ID 12, Thread ID 1
    CPUID
    0x00000001        0x000906A3    0x19800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000019
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000019
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000019
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000019
    MSR 0x000000C1        0x0000FFFF    0xFFE56599
    MSR 0x000000C2        0x000002A5    0x62DCAA32
    MSR 0x000000C3        0x00000347    0x28079B4C
    MSR 0x000000C4        0x000002A4    0x9F945190
    MSR 0x0000019C        0x00000000    0x88232A82
    MSR 0x00000611        0x00000000    0x6DABA9B1
    MSR 0x00000639        0x00000000    0x316CCD6F
    MSR 0x00000198        0x000027FC    0x00002F00
CPU Thread 8
    APIC ID            32
    Topology        Processor ID 0, Core ID 16, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x20800800    0xFFFAF38B    0xBFCBFBFF
    0x00000006        0x009F8FF3    0x00000002    0x00000409    0x00040003
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000020
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000020
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000020
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000020
    MSR 0x000000C1        0x0000FFFF    0xFFFF6573
    MSR 0x000000C2        0x00000335    0x1A18BD68
    MSR 0x000000C3        0x0000043F    0xFA884E40
    MSR 0x000000C4        0x00000365    0xE6B9686C
    MSR 0x00000611        0x00000000    0x6DABCBB4
    MSR 0x00000639        0x00000000    0x316CDC9E
    MSR 0x00000198        0x00002980    0x00002E00
CPU Thread 9
    APIC ID            33
    Topology        Processor ID 0, Core ID 16, Thread ID 1
    CPUID
    0x00000001        0x000906A3    0x21800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000021
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000021
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000021
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000021
    MSR 0x000000C1        0x0000FFFF    0xFFF54765
    MSR 0x000000C2        0x000000B0    0x58A0B146
    MSR 0x000000C3        0x000000EB    0xE68BA2FE
    MSR 0x000000C4        0x000000BF    0x44FCA210
    MSR 0x0000019C        0x00000000    0x88272800
    MSR 0x00000611        0x00000000    0x6DABDE5A
    MSR 0x00000639        0x00000000    0x316CEE14
    MSR 0x00000198        0x0000287F    0x00002E00
CPU Thread 10
    APIC ID            40
    Topology        Processor ID 0, Core ID 20, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x28800800    0xFFFAF38B    0xBFCBFBFF
    0x00000006        0x009F8FF3    0x00000002    0x00000409    0x00050003
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000028
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000028
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000028
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000028
    MSR 0x000000C1        0x0000FFFF    0xFFE9F4A5
    MSR 0x000000C2        0x00000331    0xE1E911E4
    MSR 0x000000C3        0x00000436    0x3406E984
    MSR 0x000000C4        0x000003CC    0x6C10A73F
    MSR 0x0000019C        0x00000000    0x882B2802
    MSR 0x000001B1        0x00000000    0x882B0A82
    MSR 0x00000611        0x00000000    0x6DABDF97
    MSR 0x00000639        0x00000000    0x316CFB08
    MSR 0x00000198        0x0000283F    0x00002E00
CPU Thread 11
    APIC ID            41
    Topology        Processor ID 0, Core ID 20, Thread ID 1
    CPUID
    0x00000001        0x000906A3    0x29800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000029
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000029
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000029
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000029
    MSR 0x000000C1        0x0000FFFF    0xFFEB7AA1
    MSR 0x000000C2        0x000000B4    0x72E29214
    MSR 0x000000C3        0x000000E9    0x6D39F23D
    MSR 0x000000C4        0x000000C2    0xE2338F45
    MSR 0x0000019C        0x00000000    0x88282802
    MSR 0x000001B1        0x00000000    0x88280A82
    MSR 0x00000611        0x00000000    0x6DABFBF0
    MSR 0x00000639        0x00000000    0x316D0990
    MSR 0x00000198        0x0000284E    0x00002E00
CPU Thread 12
    APIC ID            48
    Topology        Processor ID 0, Core ID 24, Thread ID 0
    Cache descriptor    Level 1, D, 32 KB, 2 thread(s)
    Cache descriptor    Level 1, I, 64 KB, 2 thread(s)
    Cache descriptor    Level 2, U, 2 MB, 8 thread(s)
    CPUID
    0x00000001        0x000906A3    0x30800800    0xFFFAF38B    0xBFCBFBFF
    0x00000004        0xFC004121    0x01C0003F    0x0000003F    0x00000000
    0x00000004        0xFC004122    0x01C0003F    0x0000007F    0x00000000
    0x00000004        0xFC01C143    0x03C0003F    0x000007FF    0x00000000
    0x00000006        0x009F8FF3    0x00000002    0x00000409    0x00060003
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000030
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000030
    0x00000014        0x00000001    0x0000005F    0x80000007    0x00000000
    0x0000001A        0x20000001    0x00000000    0x00000000    0x00000000
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000030
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000030
    MSR 0x00000774        0x0000019E    0x72002301
    MSR 0x000000C1        0x0000FFFF    0xFFEC7B56
    MSR 0x000000C2        0x00000068    0x1F0C555C
    MSR 0x000000C3        0x00000083    0xF2AFD0C5
    MSR 0x000000C4        0x00000020    0x197E6F94
    MSR 0x00000187        0x00000000    0x004100C4
    MSR 0x0000019C        0x00000000    0x88372800
    MSR 0x000001B1        0x00000000    0x88370A82
    MSR 0x00000611        0x00000000    0x6DAC018F
    MSR 0x00000639        0x00000000    0x316D0DD9
    MSR 0x00000198        0x000024B1    0x00002300
CPU Thread 13
    APIC ID            50
    Topology        Processor ID 0, Core ID 25, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x32800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000032
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000032
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000032
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000032
    MSR 0x000000C1        0x0000FFFF    0xFFED0A16
    MSR 0x000000C2        0x0000004C    0x9A3B555F
    MSR 0x000000C3        0x00000061    0xAAE08E62
    MSR 0x000000C4        0x00000016    0x4823D644
    MSR 0x00000611        0x00000000    0x6DAC0BAB
    MSR 0x00000639        0x00000000    0x316D1785
    MSR 0x00000198        0x00002537    0x00002300
CPU Thread 14
    APIC ID            52
    Topology        Processor ID 0, Core ID 26, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x34800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000034
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000034
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000034
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000034
    MSR 0x000000C1        0x0000FFFF    0xFFF1A8E0
    MSR 0x000000C2        0x00000030    0x87D6F3E2
    MSR 0x000000C3        0x0000003F    0x2BD37A8D
    MSR 0x000000C4        0x0000000E    0xA9FA0176
    MSR 0x0000019C        0x00000000    0x88382800
    MSR 0x00000611        0x00000000    0x6DAC0F3D
    MSR 0x00000639        0x00000000    0x316D1977
    MSR 0x00000198        0x00002558    0x00002300
CPU Thread 15
    APIC ID            54
    Topology        Processor ID 0, Core ID 27, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x36800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000036
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000036
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000036
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000036
    MSR 0x000000C1        0x0000FFFF    0xFFA353BD
    MSR 0x000000C2        0x00000032    0xB23DCA2D
    MSR 0x000000C3        0x00000041    0x59DA76B5
    MSR 0x000000C4        0x0000000E    0xC137671C
    MSR 0x00000611        0x00000000    0x6DAC14D7
    MSR 0x00000639        0x00000000    0x316D1E18
    MSR 0x00000198        0x0000253B    0x00002300
CPU Thread 16
    APIC ID            56
    Topology        Processor ID 0, Core ID 28, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x38800800    0xFFFAF38B    0xBFCBFBFF
    0x00000006        0x009F8FF3    0x00000002    0x00000409    0x00070003
    0x0000000B        0x00000001    0x00000002    0x00000100    0x00000038
    0x0000000B        0x00000007    0x00000014    0x00000201    0x00000038
    0x0000001F        0x00000001    0x00000002    0x00000100    0x00000038
    0x0000001F        0x00000007    0x00000014    0x00000201    0x00000038
    MSR 0x000000C1        0x0000FFFF    0xFFF56D65
    MSR 0x000000C2        0x00000075    0x8AC05CA9
    MSR 0x000000C3        0x00000091    0x1D80C39F
    MSR 0x000000C4        0x00000023    0x2842BA22
    MSR 0x00000611        0x00000000    0x6DAC1B11
    MSR 0x00000639        0x00000000    0x316D2347
    MSR 0x00000198        0x00002549    0x00002300
CPU Thread 17
    APIC ID            58
    Topology        Processor ID 0, Core ID 29, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x3A800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x0000003A
    0x0000000B        0x00000007    0x00000014    0x00000201    0x0000003A
    0x0000001F        0x00000001    0x00000002    0x00000100    0x0000003A
    0x0000001F        0x00000007    0x00000014    0x00000201    0x0000003A
    MSR 0x000000C1        0x0000FFFF    0xFFF4432B
    MSR 0x000000C2        0x00000054    0x3B640CD9
    MSR 0x000000C3        0x0000006A    0x3977312A
    MSR 0x000000C4        0x00000017    0xE382228D
    MSR 0x0000019C        0x00000000    0x88362800
    MSR 0x000001B1        0x00000000    0x88360A82
    MSR 0x00000611        0x00000000    0x6DAC1EE5
    MSR 0x00000639        0x00000000    0x316D25EF
    MSR 0x00000198        0x00002530    0x00002300
CPU Thread 18
    APIC ID            60
    Topology        Processor ID 0, Core ID 30, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x3C800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x0000003C
    0x0000000B        0x00000007    0x00000014    0x00000201    0x0000003C
    0x0000001F        0x00000001    0x00000002    0x00000100    0x0000003C
    0x0000001F        0x00000007    0x00000014    0x00000201    0x0000003C
    MSR 0x000000C1        0x0000FFFF    0xFFF2D175
    MSR 0x000000C2        0x00000042    0x46FEE70B
    MSR 0x000000C3        0x00000054    0x804F5840
    MSR 0x000000C4        0x00000012    0x3258CA07
    MSR 0x00000611        0x00000000    0x6DAC2525
    MSR 0x00000639        0x00000000    0x316D2BE6
    MSR 0x00000198        0x00002896    0x00002300
CPU Thread 19
    APIC ID            62
    Topology        Processor ID 0, Core ID 31, Thread ID 0
    CPUID
    0x00000001        0x000906A3    0x3E800800    0xFFFAF38B    0xBFCBFBFF
    0x0000000B        0x00000001    0x00000002    0x00000100    0x0000003E
    0x0000000B        0x00000007    0x00000014    0x00000201    0x0000003E
    0x0000001F        0x00000001    0x00000002    0x00000100    0x0000003E
    0x0000001F        0x00000007    0x00000014    0x00000201    0x0000003E
    MSR 0x000000C1        0x0000FFFF    0xFFFEFCD6
    MSR 0x000000C2        0x0000003D    0x3AC6CE37
    MSR 0x000000C3        0x0000004D    0x0BC5E00C
    MSR 0x000000C4        0x00000010    0xCF977D37
    MSR 0x00000611        0x00000000    0x6DAC27B4
    MSR 0x00000639        0x00000000    0x316D2C21
    MSR 0x00000198        0x0000251C    0x00002300
BIOS
UEFI                Yes
BIOS Date
Chipset
Northbridge            Intel Alder Lake rev. 02
Southbridge            Intel Alder Lake PCH rev. 01
Bus Specification        PCI-Express 4.0 (16.0 GT/s)
Graphic Interface        PCI-Express
Memory Type            DDR5
Memory Size            32 GBytes
Channels            4 x 32-bit
Memory Frequency        2394.1 MHz (1:24)
Memory Max Frequency        3200.0 MHz
CAS# latency (CL)        40.0
RAS# to CAS# delay (tRCD)    39
RAS# Precharge (tRP)        39
Cycle Time (tRAS)        76
Bank Cycle Time (tRC)        115
Row Refresh Cycle Time (tRFC)    383
Command Rate (CR)        2T
Uncore Frequency        3990.2 MHz
Memory Controller Frequency    1197.1 MHz
Host Bridge            0x4641
Memory SPD
DIMM #                1
    SMBus address        0x50
    Memory type        DDR5
    Module format        SO-DIMM
    Module Manufacturer(ID)    Crucial Technology (7F7F7F7F7F9B0000000000000000)
    SDRAM Manufacturer (ID)    Micron Technology (2C00000000000000000000000000)
    Size            16384 MBytes
    Max bandwidth        DDR5-4800 (2400 MHz)
    Channels        2
    Part number        CT16G48C40S5.C8A1
    Serial number        E816A5B1
    Manufacturing date    Week 26/Year 23
    Nominal Voltage        1.10 Volts
    EPP            no
    XMP            no
    AMP            no
    EXPO            no
JEDEC timings table        CL-tRCD-tRP-tRAS-tRC @ frequency
    JEDEC #1        22.0-22-22-44-66 @ 1366 MHz
    JEDEC #2        26.0-27-27-53-79 @ 1633 MHz
    JEDEC #3        28.0-29-29-57-85 @ 1766 MHz
    JEDEC #4        30.0-30-30-60-90 @ 1866 MHz
    JEDEC #5        32.0-32-32-64-96 @ 2000 MHz
    JEDEC #6        36.0-37-37-73-109 @ 2266 MHz
    JEDEC #7        40.0-39-39-77-116 @ 2400 MHz
    JEDEC #8        42.0-39-39-77-116 @ 2400 MHz
DIMM #                2
    SMBus address        0x52
    Memory type        DDR5
    Size            16384 MBytes
    Channels        2
    Serial number        E816B440
    EPP            no
    XMP            no
    AMP            no
    EXPO            no
DIMM #                1
SPD registers
        00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
    00    30 10 12 03 04 00 20 62 00 00 00 00 A0 01 07 00
    10    00 00 00 00 A0 01 F2 03 7A 0D 00 00 00 00 80 3E
    20    80 3E 80 3E 00 7D 80 BB 30 75 27 01 A0 00 82 00
    30    00 00 00 00 00 00 D4 00 00 00 D4 00 00 00 D4 00
    40    00 00 D4 00 00 00 88 13 08 88 13 08 20 4E 20 10
    50    27 10 15 34 20 10 27 10 C4 09 04 4C 1D 0C 00 00
    60    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    80    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    90    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    A0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    B0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    C0    10 00 86 32 80 15 0B 2A 82 03 00 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    E0    00 00 00 00 00 00 0F 01 00 82 00 22 00 00 00 00
    F0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    100    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    110    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    120    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    130    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    140    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    150    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    160    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    170    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    180    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    190    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1A0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1B0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1C0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1D0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1E0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    1F0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 C3 3B
    200    85 9B 00 23 26 E8 16 A5 B1 43 54 31 36 47 34 38
    210    43 34 30 53 35 2E 43 38 41 31 20 20 20 20 20 20
    220    20 20 20 20 20 20 20 55 80 2C 41 34 32 33 32 38
    230    39 32 38 38 00 00 00 00 00 00 00 00 00 00 00 00
    240    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    250    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    260    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    270    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    280    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    290    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    2A0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    2B0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    2C0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    2D0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    2E0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    2F0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    300    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    310    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    320    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    330    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    340    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    350    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    360    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    370    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    380    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    390    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    3A0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    3B0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    3C0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    3D0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    3E0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    3F0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DIMM #                2
SPD registers
    200    85 9B 00 23 26 E8 16 B4 40 43 54 31 36 47 34 38
Monitoring
Mainboard Model        Standard (0x00000331 - 0x0106E9EC)
LPCIO
Hardware Monitors
Hardware monitor        NVIDIA NVML
    Power 01        18.30 W (GPU)
Hardware monitor        NVIDIA NVAPI
    Power 01        18.36 W (GPU)
    Clock Speed 0        210.00 MHz [0xD2] (Graphics)
    Clock Speed 1        405.00 MHz [0x195] (Memory)
    Clock Speed 2        n.a. (Processor)
Hardware monitor        Intel IGCL
    Clock Speed 0        750.00 MHz [0x2EE] (Graphics)
    Clock Speed 1        n.a. (Memory)
Hardware monitor        Intel oneAPI
PCI Devices
Register space            PCI Express, base address = 0x0C0000000
Description            Host Bridge
Location            bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x8086 (Intel)
    Model ID        0x4641
    Revision ID        0x02
    PI            0x00
    SubClass        0x00
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Subvendor ID        0x1D05 (TONGFANG)
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x00
PCI capability
    Caps class        Vendor Dependant
    Caps offset        0xE0
PCI registers
    00    86 80 41 46 06 00 90 20 02 00 00 06 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 05 1D 74 11
    30    00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
    40    01 10 DA FE 00 00 00 00 01 00 DC FE 00 00 00 00
    50    C1 FE 00 00 F9 A0 03 00 87 00 20 74 07 00 00 6F
    60    01 00 00 C0 00 00 00 00 01 00 DA FE 00 00 00 00
    70    08 02 00 01 00 04 00 00 00 00 65 00 88 86 40 00
    80    00 33 33 33 33 00 00 10 00 00 00 00 00 00 00 00
    A0    01 00 00 00 08 00 00 00 01 00 C0 8B 08 00 00 00
    B0    01 00 80 70 01 00 00 70 01 00 00 6F 01 00 40 74
    D0    1A 02 00 01 00 04 00 00 00 00 00 00 00 00 00 00
    E0    09 00 14 01 20 60 00 62 08 00 21 10 00 02 61 66
    F0    61 06 1E 00 1D 0F 03 00 00 00 00 00 00 00 00 00
Description            PCI to PCI Bridge
Location            bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
    Model ID        0x460D
    Revision ID        0x02
    PI            0x00
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x10
    Latency            0x00
    Header            0x81
PCI header
    Primary bus        0x00
    Secondary bus        0x01
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps class        PCI Express
    Caps offset        0x40
    Device type        Root Port of PCI-E Root Complex
    Port            0
    Caps version        2.0
    Physical slot        #0
    Presence detect        yes
    Link width        8x (max 8x)
    Link speed        2.5 GT/s (max 16.0 GT/s)
PCI capability
    Caps class        Message Signalled Interrupts
    Caps offset        0x80
PCI capability
    Caps class        Subsystem Vendor
    Caps offset        0x98
    SubVendor ID        0x0000
    SubSystem ID        0x0000
PCI capability
    Caps class        Power Management
    Caps offset        0xA0
    Caps version        1.2
PCI extended capability
    Caps class        Advanced Error Reporting
    Caps offset        0x100
    Caps class        0xD
    Caps offset        0x220
    Caps class        0x1F
    Caps offset        0x150
    Caps class        Secondary PCI Express
    Caps offset        0xA30
    Caps class        0x25
    Caps offset        0xA90
    Caps class        0x26
    Caps offset        0xA9C
    Caps class        0x27
    Caps offset        0xEDC
    Caps class        0x2A
    Caps offset        0xADC
    Caps class        0x2B
    Caps offset        0xB0C
PCI registers
    00    86 80 0D 46 07 04 10 00 02 00 04 06 10 00 81 00
    10    00 00 00 00 00 00 00 00 00 01 01 00 40 40 00 20
    20    00 83 00 84 01 00 F1 01 60 00 00 00 62 00 00 00
    30    00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
    40    10 80 42 01 01 80 00 00 20 00 10 00 84 60 72 00
    50    40 00 81 F0 80 25 0C 00 00 00 48 01 08 00 00 00
    60    00 00 00 00 F7 0B BB 00 40 04 00 00 1E 00 00 00
    70    04 00 1F 00 00 00 00 00 00 00 00 00 00 00 00 00
    80    05 98 81 00 30 00 E0 FE 00 00 00 00 00 00 00 00
    90    00 00 00 00 00 00 00 00 0D A0 00 00 00 00 00 00
    A0    01 00 03 C8 00 00 00 00 00 00 00 00 00 00 00 00
    D0    77 80 00 0E 42 58 00 40 48 00 3F 09 00 00 00 00
    E0    00 77 C1 00 FA 88 FA 88 14 80 83 00 00 A0 00 00
    F0    70 07 00 00 00 43 00 40 00 0F 00 00 04 40 05 41
    100    01 00 01 22 00 00 00 00 00 00 01 00 10 00 06 00
    110    00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00
    150    1F 00 01 A3 16 04 00 00 03 00 00 00 00 00 00 00
    1F0    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description            VGA Controller
Location            bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
    Model ID        0x46A6
    Revision ID        0x0C
    PI            0x00
    SubClass        0x00
    BaseClass        0x03
    Cache Line        0x10
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0x000000622C000004
    Address 2 (memory)    0x000000400000000C
    Address 4 (port)    0x00005000
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x40
PCI capability
    Caps offset        0x70
    Device type        Root Complex Integrated Endpoint Device
    Port            0
    Caps version        2.0
PCI capability
    Caps offset        0xAC
PCI capability
    Caps offset        0xD0
    Caps version        1.1
    Caps class        0x1B
    Caps offset        0x100
    Caps class        0xF
    Caps offset        0x200
    Caps class        0x13
    Caps offset        0x300
    Caps class        0x10
    Caps offset        0x320
PCI registers
    00    86 80 A6 46 07 04 10 00 0C 00 00 03 10 00 00 00
    10    04 00 00 2C 62 00 00 00 0C 00 00 00 40 00 00 00
    20    01 50 00 00 00 00 00 00 00 00 00 00 05 1D 74 11
    40    09 70 0C 01 08 00 00 00 00 00 00 00 00 00 00 00
    50    C1 FE 00 00 B9 20 00 00 00 00 00 00 00 00 00 00
    60    00 00 01 00 00 00 00 00 00 00 00 00 01 00 00 00
    70    10 AC 92 00 00 80 00 10 00 00 00 00 00 00 00 00
    A0    00 00 00 00 00 00 00 00 00 00 00 00 05 D0 01 01
    B0    50 06 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
    C0    01 00 80 70 00 00 00 00 01 00 D9 FE 00 00 00 00
    D0    01 00 22 00 00 00 00 00 00 00 00 00 00 00 00 00
    E0    00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00
    F0    87 00 20 74 00 00 00 00 00 00 00 00 18 D0 36 67
    100    1B 00 01 20 00 14 00 00 00 00 00 00 00 00 00 00
Description            Data Aquisition and Signal Processing Device
Location            bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
    Model ID        0x461D
    Revision ID        0x02
    PI            0x00
    SubClass        0x80
    BaseClass        0x11
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0x0000007FFFEC0004
    Subsystem ID        0x1174
    Int. Line        0x10
    Int. Pin        0x01
PCI capability
    Caps offset        0x90
PCI capability
    Caps offset        0xD0
    Caps version        1.2
PCI capability
    Caps offset        0xE0
PCI registers
    00    86 80 1D 46 06 00 90 00 02 00 80 11 00 00 00 00
    10    04 00 EC FF 7F 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 90 00 00 00 00 00 00 00 10 01 00 00
    50    00 00 00 00 DF FC 07 00 00 00 00 00 00 00 00 00
    90    05 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    D0    01 E0 03 00 08 00 00 00 01 00 00 00 00 00 00 00
    E0    09 00 0C 01 00 00 00 00 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
    Model ID        0x464D
    Revision ID        0x02
    PI            0x00
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x10
    Latency            0x00
    Header            0x81
PCI header
    Primary bus        0x00
    Secondary bus        0x02
    Int. Line        0x00
    Int. Pin        0x04
PCI capability
    Caps offset        0x40
    Port            5
    Caps version        2.0
    Physical slot        #0
    Presence detect        no
    Link width        0x (max 4x)
PCI capability
    Caps offset        0x80
PCI capability
    Caps offset        0x90
    SubVendor ID        0x0000
    SubSystem ID        0x0000
PCI capability
    Caps offset        0xA0
    Caps version        1.2
    Caps offset        0x100
    Caps class        0xD
    Caps offset        0x220
    Caps class        0x1E
    Caps offset        0x200
    Caps class        0x1F
    Caps offset        0x150
    Caps class        Virtual Channel
    Caps offset        0x280
    Caps offset        0xA30
    Caps class        0x25
    Caps offset        0xA90
    Caps class        0x26
    Caps offset        0xA9C
    Caps class        0x27
    Caps offset        0xEDC
PCI registers
    00    86 80 4D 46 04 04 10 00 02 00 04 06 10 00 81 00
    10    00 00 00 00 00 00 00 00 00 02 02 00 F0 00 00 00
    20    F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 40 00 00 00 00 00 00 00 00 04 00 00
    40    10 80 42 01 01 80 00 00 20 00 10 00 44 78 72 05
    50    02 00 01 10 80 25 04 00 00 00 00 00 08 00 00 00
    60    00 00 00 00 F7 0B 03 00 C0 00 00 00 1E 00 80 01
    70    01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
    80    05 90 01 00 90 00 E0 FE 00 00 00 00 00 00 00 00
    90    0D A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    D0    77 80 00 0E 40 18 00 40 08 00 3F 09 00 00 00 00
    E0    00 77 63 00 00 00 00 00 04 80 83 00 00 A0 00 00
    F0    70 07 00 00 00 03 00 40 00 0F 00 00 04 00 05 44
    150    1F 00 01 28 16 04 00 00 03 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 6 (0x06), function 2 (0x02)
Common header
    Model ID        0x463D
    Revision ID        0x02
    PI            0x00
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x10
    Latency            0x00
    Header            0x81
PCI header
    Primary bus        0x00
    Secondary bus        0x03
    Int. Line        0x00
    Int. Pin        0x02
PCI capability
    Caps offset        0x40
    Port            5
    Caps version        2.0
    Physical slot        #0
    Presence detect        yes
    Link width        4x (max 4x)
    Link speed        16.0 GT/s (max 16.0 GT/s)
PCI capability
    Caps offset        0x80
PCI capability
    Caps offset        0x90
    SubVendor ID        0x0000
    SubSystem ID        0x0000
PCI capability
    Caps offset        0xA0
    Caps version        1.2
    Caps offset        0x100
    Caps class        0xD
    Caps offset        0x220
    Caps class        0x1E
    Caps offset        0x200
    Caps class        0x1F
    Caps offset        0x150
    Caps offset        0x280
    Caps offset        0xA30
    Caps class        0x25
    Caps offset        0xA90
    Caps class        0x26
    Caps offset        0xA9C
    Caps class        0x27
    Caps offset        0xEDC
PCI registers
    00    86 80 3D 46 06 04 10 00 02 00 04 06 10 00 81 00
    10    00 00 00 00 00 00 00 00 00 03 03 00 F0 00 00 20
    20    30 84 30 84 F1 FF 01 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 40 00 00 00 00 00 00 00 00 02 00 00
    40    10 80 42 01 01 80 00 00 20 00 10 00 44 68 72 05
    50    42 00 44 70 80 25 14 00 00 00 40 00 08 00 00 00
    60    00 00 00 00 F7 0B 03 00 E0 04 00 00 1E 00 80 01
    80    05 90 01 00 50 00 E0 FE 00 00 00 00 00 00 00 00
    D0    77 80 00 0E 42 18 00 40 08 00 3F 09 00 00 00 00
    E0    00 77 63 00 05 90 05 90 14 80 83 00 00 A0 00 00
    F0    70 07 00 00 00 03 00 40 00 0F 00 00 04 00 05 42
Description            System Device
Location            bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
    Model ID        0x464F
    Revision ID        0x02
    PI            0x00
    SubClass        0x80
    BaseClass        0x08
    Cache Line        0x10
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0x0000007FFFEF7004
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x90
PCI capability
    Caps offset        0xA0
PCI capability
    Caps offset        0xDC
    Caps version        1.1
PCI capability
    Caps class        0x13
    Caps offset        0xF0
PCI registers
    00    86 80 4F 46 00 04 10 00 02 00 80 08 10 00 00 00
    10    04 70 EF FF 7F 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 90 00 00 00 00 00 00 00 00 01 00 00
    40    FF 83 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    90    05 A0 00 00 F0 06 E0 FE 00 00 00 00 00 00 00 00
    A0    09 DC 14 F0 10 00 40 01 00 00 00 00 81 0A 00 00
    B0    00 08 28 00 20 18 81 1E 00 00 00 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 00 00 00 00 01 F0 02 00
    E0    03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    F0    13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
Location            bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
    Model ID        0x467D
    Revision ID        0x01
    PI            0x00
    SubClass        0x80
    BaseClass        0x11
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0x000000622D180004
    Subvendor ID        0x0000
    Subsystem ID        0x0000
    Int. Line        0x00
    Int. Pin        0x00
PCI capability
    Caps offset        0x70
    Port            0
    Caps version        2.0
PCI capability
    Caps offset        0xD0
    Caps version        1.2
    Caps class        0x23
    Caps offset        0x100
    Caps class        0x23
    Caps offset        0x110
    Caps class        0x23
    Caps offset        0x120
PCI registers
    00    86 80 7D 46 02 00 10 00 01 00 80 11 00 00 00 00
    10    04 00 18 2D 62 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00
    70    10 D0 92 00 E0 0F 00 00 00 00 00 00 00 00 00 00
    D0    01 00 03 00 08 00 00 00 00 00 00 00 00 00 00 00
    100    23 00 01 11 86 80 01 01 02 00 04 04 C0 26 03 00
    110    23 00 01 12 86 80 01 01 03 00 02 04 80 00 03 00
    120    23 00 01 00 86 80 01 01 04 00 01 0A 80 01 03 00
Description            USB Controller (xHCI)
Location            bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
    Model ID        0x51ED
    Revision ID        0x01
    PI            0x30
    SubClass        0x03
    BaseClass        0x0C
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Address 0 (memory)    0x000000622D160004
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x70
    Caps version        1.1
PCI capability
    Caps offset        0x80
PCI capability
    Caps offset        0x90
PCI capability
    Caps offset        0xB0
PCI registers
    00    86 80 ED 51 06 04 90 02 01 30 03 0C 00 00 80 00
    10    04 00 16 2D 62 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 70 00 00 00 00 00 00 00 00 01 00 00
    40    FD 01 34 A0 89 C2 7F 80 00 00 00 00 00 00 00 00
    50    3F 6D D8 0F 00 00 00 00 00 00 00 00 00 00 00 00
    60    31 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    01 80 C2 C1 08 00 00 00 00 00 00 00 00 00 00 00
    80    05 90 87 00 10 04 E0 FE 00 00 00 00 00 00 00 00
    90    09 B0 14 F0 10 00 40 01 00 00 00 00 C1 0A 08 00
    A0    00 08 0E 00 00 18 00 00 8F 50 02 00 00 01 00 00
    B0    09 00 00 01 86 80 C0 00 09 00 10 14 00 00 00 00
    F0    00 00 00 00 00 00 00 00 B5 0F 10 01 12 00 00 00
Description            RAM Memory Controller
Location            bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
    Model ID        0x51EF
    Revision ID        0x01
    PI            0x00
    SubClass        0x00
    BaseClass        0x05
    Cache Line        0x10
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0x000000622D190004
    Address 2 (memory)    0x000000622D197004
    Subvendor ID        0x0000
    Subsystem ID        0x0000
    Int. Line        0xFF
    Int. Pin        0x00
PCI capability
    Caps offset        0x80
    Caps version        1.2
PCI registers
    00    86 80 EF 51 06 00 10 00 01 00 00 05 10 00 00 00
    10    04 00 19 2D 62 00 00 00 04 70 19 2D 62 00 00 00
    30    00 00 00 00 80 00 00 00 00 00 00 00 FF 00 00 00
    80    01 00 03 00 08 00 00 00 00 00 00 00 00 00 00 00
    F0    00 00 00 00 00 00 00 00 B5 0F 10 01 00 00 00 00
Description            Network Controller
Location            bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
    Model ID        0x51F0
    Revision ID        0x01
    PI            0x00
    SubClass        0x80
    BaseClass        0x02
    Cache Line        0x10
    Latency            0x00
    Header            0x80
PCI header
    Address 0 (memory)    0x0000007FFFEF8004
    Subvendor ID        0x8086 (Intel)
    Subsystem ID        0x0074
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0xC8
    Caps version        1.2
PCI capability
    Caps offset        0xD0
PCI capability
    Caps offset        0x40
    Port            0
    Caps version        2.0
PCI capability
    Caps class        MSI-X
    Caps offset        0x80
    Caps class        0x18
    Caps offset        0x100
    Caps class        Vendor Specific
    Caps offset        0x164
    Vendor            16
    Size            20
PCI registers
    00    86 80 F0 51 06 04 10 00 01 00 80 02 10 00 80 00
    10    04 80 EF FF 7F 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 86 80 74 00
    30    00 00 00 00 C8 00 00 00 00 00 00 00 00 01 00 00
    40    10 80 92 00 C0 0E 00 10 10 0C 10 00 00 00 00 00
    60    00 00 00 00 12 08 08 00 05 04 00 00 00 00 00 00
    80    11 00 0F 80 00 20 00 00 00 30 00 00 00 00 00 00
    C0    00 00 00 00 00 00 00 00 01 D0 23 C8 08 00 00 0D
    D0    05 40 80 00 00 00 00 00 00 00 00 00 00 00 00 00
    100    18 00 41 16 00 00 00 00 00 00 00 00 31 20 46 00
    140    00 00 C0 14 00 00 00 FF FF 00 00 00 00 00 00 00
    150    00 00 00 00 1E 00 01 00 1F 1E 48 00 00 00 00 00
    160    28 00 00 00 0B 00 01 00 10 00 40 01 00 00 00 00
    170    01 00 80 31 00 08 00 00 00 00 00 00 00 00 00 00
Description            Serial Bus Controller
Location            bus 0 (0x00), device 21 (0x15), function 0 (0x00)
Common header
    Model ID        0x51E8
    Revision ID        0x01
    PI            0x00
    SubClass        0x80
    BaseClass        0x0C
    Cache Line        0x10
    Latency            0x00
    Header            0x80
PCI header
    Subsystem ID        0x1174
    Int. Line        0x1B
    Int. Pin        0x01
PCI capability
    Caps offset        0x80
    Caps version        1.2
PCI capability
    Caps offset        0x90
PCI registers
    00    86 80 E8 51 00 04 10 00 01 00 80 0C 10 00 80 00
    10    04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 80 00 00 00 00 00 00 00 1B 01 00 00
    80    01 90 03 00 0B 00 00 00 00 00 00 00 00 00 00 00
    90    09 00 14 F0 10 00 40 01 01 21 00 00 C1 24 00 00
    A0    00 08 0F 00 00 00 00 00 00 00 00 00 00 00 00 00
Description            Communication Device
Location            bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
    Model ID        0x51E0
    Revision ID        0x01
    PI            0x00
    SubClass        0x80
    BaseClass        0x07
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Address 0 (memory)    0x0000007FFFEF6004
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x50
    Caps version        1.2
PCI capability
    Caps offset        0x8C
PCI capability
    Caps offset        0xA4
PCI registers
    00    86 80 E0 51 06 04 10 00 01 00 80 07 00 00 80 00
    10    04 60 EF FF 7F 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
    40    55 02 00 90 00 00 00 80 06 05 F1 00 00 00 00 00
    50    01 8C 03 40 08 00 00 00 00 00 00 00 00 00 00 00
    60    20 00 00 00 00 40 00 00 00 00 00 00 00 00 40 00
    70    00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00
    80    00 00 00 00 00 00 00 00 00 00 00 00 05 A4 81 00
    90    D0 06 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
    A0    04 00 00 00 09 00 14 F0 10 00 40 01 00 00 00 00
    B0    01 80 00 00 38 0D 0E 00 00 00 00 00 00 00 00 C0
Location            bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
    Model ID        0x51BF
    Revision ID        0x01
    PI            0x00
    SubClass        0x04
    BaseClass        0x06
    Cache Line        0x10
    Latency            0x00
    Header            0x81
PCI header
    Primary bus        0x00
    Secondary bus        0x2E
    Int. Line        0x00
    Int. Pin        0x04
PCI capability
    Caps offset        0x40
    Port            8
    Caps version        2.0
    Physical slot        #1
    Presence detect        yes
    Link width        1x (max 1x)
    Link speed        5.0 GT/s (max 8.0 GT/s)
PCI capability
    Caps offset        0x80
PCI capability
    Caps offset        0x90
    SubVendor ID        0x1D05 (TONGFANG)
    SubSystem ID        0x1174
PCI capability
    Caps offset        0xA0
    Caps version        1.2
    Caps offset        0x100
    Caps class        0xD
    Caps offset        0x220
    Caps class        0x1F
    Caps offset        0x150
    Caps class        0x1E
    Caps offset        0x200
    Caps offset        0xA30
PCI registers
    00    86 80 BF 51 07 04 10 00 01 00 04 06 10 00 81 00
    10    00 00 00 00 00 00 00 00 00 2E 2E 00 30 30 00 20
    20    20 84 20 84 F1 FF 01 00 00 00 00 00 00 00 00 00
    40    10 80 42 01 01 80 00 00 20 00 10 00 13 4C 72 08
    50    40 00 12 70 00 B2 5C 00 00 00 40 00 08 00 00 00
    60    00 2E 00 00 37 08 08 00 00 04 00 00 0E 00 00 00
    70    02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    80    05 90 01 00 70 00 E0 FE 00 00 00 00 00 00 00 00
    90    0D A0 00 00 05 1D 74 11 00 00 00 00 00 00 00 00
    D0    11 00 00 06 42 18 01 40 08 00 9E 09 00 00 00 00
    E0    00 03 E3 00 00 00 00 00 06 00 11 00 00 00 00 00
    F0    50 01 00 00 00 00 00 4C B5 0F 10 01 04 00 00 84
    100    01 00 01 22 00 00 00 00 00 00 00 00 11 00 06 00
    150    1F 00 01 20 06 04 00 00 00 00 00 00 00 00 00 00
Description            PCI to ISA Bridge
Location            bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
    Model ID        0x5182
    Revision ID        0x01
    PI            0x00
    SubClass        0x01
    BaseClass        0x06
    Cache Line        0x00
    Latency            0x00
    Header            0x80
PCI header
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x00
PCI registers
    00    86 80 82 51 07 04 00 00 01 00 01 06 00 00 80 00
    80    10 00 03 3C 69 00 04 00 81 05 0C 00 81 00 0C 00
    90    00 00 00 00 10 2F 00 00 01 00 41 FE 00 00 00 00
    D0    00 00 00 00 00 00 00 00 CF FF 00 00 84 00 00 00
Description            High Definition Audio (HDA)
Location            bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
    Model ID        0x51C8
    Revision ID        0x01
    PI            0x00
    SubClass        0x03
    BaseClass        0x04
    Cache Line        0x10
    Latency            0x20
    Header            0x00
PCI header
    Address 0 (memory)    0x0000007FFFEFC004
    Address 4 (memory)    0x0000007FFFF00004
    Subsystem ID        0x1174
    Int. Line        0x10
    Int. Pin        0x01
PCI capability
    Caps offset        0x50
    Caps version        1.2
PCI capability
    Caps offset        0x80
PCI capability
    Caps offset        0x60
PCI registers
    00    86 80 C8 51 06 00 10 00 01 00 03 04 10 20 00 00
    10    04 C0 EF FF 7F 00 00 00 00 00 00 00 00 00 00 00
    20    04 00 F0 FF 7F 00 00 00 00 00 00 00 05 1D 74 11
    30    00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
    40    00 00 00 00 00 00 00 00 FF 09 FB 00 00 00 00 00
    50    01 80 43 C0 08 00 00 00 00 00 00 00 00 00 00 00
    60    05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
    70    10 00 91 00 00 00 00 10 00 28 10 00 00 00 00 00
    80    09 60 14 F0 10 00 40 01 00 00 00 00 A1 04 01 00
    90    00 08 28 00 00 00 00 00 00 00 00 00 00 00 00 00
    C0    02 06 02 31 00 60 80 04 00 0C A5 82 10 00 03 00
    D0    00 0C B5 02 10 00 03 00 00 00 00 00 00 00 00 00
Description            SMBus Controller
Location            bus 0 (0x00), device 31 (0x1F), function 4 (0x04)
Common header
    Model ID        0x51A3
    Revision ID        0x01
    PI            0x00
    SubClass        0x05
    BaseClass        0x0C
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0x000000622D194004
    Address 4 (port)    0x0000EFA0
    Subsystem ID        0x1174
    Int. Line        0xFF
    Int. Pin        0x01
PCI registers
    00    86 80 A3 51 01 00 80 02 01 00 05 0C 00 00 00 00
    10    04 40 19 2D 62 00 00 00 00 00 00 00 00 00 00 00
    20    A1 EF 00 00 00 00 00 00 00 00 00 00 05 1D 74 11
    30    00 00 00 00 00 00 00 00 00 00 00 00 FF 01 00 00
    40    11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    50    01 04 00 00 01 01 00 00 00 00 00 00 00 00 00 00
    60    04 05 05 00 00 00 0A 0A 00 00 00 00 00 00 00 00
    80    24 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    90    00 00 21 01 00 0C 00 00 1F 00 20 01 00 0E 00 00
Location            bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
    Model ID        0x51A4
    Revision ID        0x01
    PI            0x00
    SubClass        0x80
    BaseClass        0x0C
    Cache Line        0x00
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0xFE010000
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x00
PCI registers
    00    86 80 A4 51 02 04 00 00 01 00 80 0C 00 00 00 00
    10    00 00 01 FE 00 00 00 00 00 00 00 00 00 00 00 00
    D0    00 00 00 00 00 00 00 00 CF FF 00 00 88 08 00 10
Location            bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x10DE (NVIDIA)
    Model ID        0x2520
    Revision ID        0xA1
    PI            0x00
    SubClass        0x00
    BaseClass        0x03
    Cache Line        0x10
    Latency            0x00
    Header            0x80
PCI header
    Address 0 (memory)    0x83000000
    Address 1 (memory)    0x000000600000000C
    Address 3 (memory)    0x000000620000000C
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x60
    Caps version        1.2
PCI capability
    Caps offset        0x68
PCI capability
    Caps offset        0x78
    Device type        Legacy PCI-E Endpoint Device
    Port            0
    Caps version        2.0
    Link width        8x (max 16x)
PCI capability
    Caps offset        0xB4
    Caps offset        0x100
    Caps class        0x18
    Caps offset        0x250
    Caps class        0x1E
    Caps offset        0x258
    Caps class        Power Budgeting
    Caps offset        0x128
    Caps offset        0x420
    Caps offset        0x600
    Vendor            1
    Size            36
    Caps offset        0x900
    Caps class        Resizable BAR
    Caps offset        0xBB0
    Resizable BARs        3
    BAR 0 size        16 MB
    BAR 1 size        8 GB
    BAR 2 size        32 MB
    Caps class        0x26
    Caps offset        0xC1C
    Caps class        0x27
    Caps offset        0xD00
    Caps class        0x25
    Caps offset        0xE00
PCI registers
    00    DE 10 20 25 06 00 10 00 A1 00 00 03 10 00 80 00
    10    00 00 00 83 0C 00 00 00 60 00 00 00 0C 00 00 00
    20    62 00 00 00 01 00 00 00 00 00 00 00 05 1D 74 11
    30    00 00 00 00 60 00 00 00 00 00 00 00 00 01 00 00
    40    05 1D 74 11 00 00 00 00 00 00 00 00 00 00 00 00
    50    00 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
    60    01 68 03 48 08 00 00 00 05 78 81 00 10 07 E0 FE
    70    00 00 00 00 00 00 00 00 10 B4 12 00 E1 8D 2C 11
    80    30 29 09 00 04 3D 46 00 40 01 81 10 00 00 00 00
    90    00 00 00 00 00 00 00 00 00 00 00 00 13 08 07 00
    A0    00 04 00 00 1E 00 80 01 04 00 1E 00 00 00 00 00
    B0    00 00 00 00 09 00 14 01 00 00 00 00 00 00 00 00
    C0    00 00 00 00 00 00 00 00 11 00 05 00 00 00 B9 00
    D0    00 00 BA 00 00 00 00 00 00 00 00 00 00 00 00 00
    100    02 00 01 25 00 00 00 00 00 00 00 00 00 00 00 00
    110    00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
    120    00 00 00 00 00 00 00 00 04 00 01 42 00 00 00 00
    130    21 81 07 00 00 00 00 00 00 00 00 00 00 00 00 00
    140    00 00 00 00 30 00 00 01 00 00 00 00 1B 00 00 83
    150    15 00 00 00 40 71 50 06 00 01 00 00 21 81 07 00
    160    21 81 05 00 02 80 03 00 02 80 01 00 06 80 1F 00
    170    06 80 1D 00 01 01 01 00 00 00 00 00 00 00 00 00
Location            bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
    Model ID        0x228E
    Revision ID        0xA1
    PI            0x00
    SubClass        0x03
    BaseClass        0x04
    Cache Line        0x10
    Latency            0x00
    Header            0x80
PCI header
    Address 0 (memory)    0x840FC000
    Subsystem ID        0x1174
    Int. Line        0x11
    Int. Pin        0x02
PCI capability
    Caps offset        0x60
    Caps version        1.2
PCI capability
    Caps offset        0x68
PCI capability
    Caps offset        0x78
    Device type        PCI-E Endpoint Device
    Port            0
    Caps version        2.0
    Caps offset        0x100
    Caps class        0x25
    Caps offset        0x160
PCI registers
    00    DE 10 8E 22 00 04 10 00 A1 00 03 04 10 00 80 00
    10    00 C0 0F 84 00 00 00 00 00 00 00 00 00 00 00 00
    30    00 00 00 00 60 00 00 00 00 00 00 00 11 02 00 00
    50    00 00 00 00 00 00 00 00 CE D6 23 00 00 00 00 00
    60    01 68 03 00 0B 00 00 00 05 78 80 00 00 00 00 00
    70    00 00 00 00 00 00 00 00 10 00 02 00 E1 8D 2C 01
    80    30 21 09 00 04 3D 45 00 40 01 81 10 00 00 00 00
    A0    00 00 00 00 1E 00 80 01 00 00 00 00 00 00 00 00
    100    01 00 02 16 00 00 00 00 00 00 00 00 30 20 46 00
    110    00 20 00 00 00 A0 00 00 00 00 00 00 00 00 00 00
    120    00 00 00 00 00 00 00 00 00 00 00 00 0E 00 01 16
    140    00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 03
    150    00 00 00 80 20 71 10 00 00 00 00 00 08 00 00 00
    160    25 00 01 00 01 00 00 80 01 00 00 80 00 01 00 00
    170    01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description            NVM Express (NVMe) Controller
Location            bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0xC0A9
    Model ID        0x540A
    Revision ID        0x01
    PI            0x02
    SubClass        0x08
    BaseClass        0x01
    Cache Line        0x10
    Latency            0x00
    Header            0x00
PCI header
    Address 0 (memory)    0x0000000084300004
    Subvendor ID        0xC0A9
    Subsystem ID        0x5021
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x80
    Port            1
    Caps version        2.0
PCI capability
    Caps class        MSI-X
    Caps offset        0xD0
PCI capability
    Caps offset        0xE0
PCI capability
    Caps offset        0xF8
    Caps version        1.2
    Caps class        0x18
    Caps offset        0x100
    Caps class        0x1E
    Caps offset        0x110
    Caps class        0xE
    Caps offset        0x128
    Caps class        0x25
    Caps offset        0x1E0
    Caps offset        0x200
    Caps offset        0x300
    Caps class        0x26
    Caps offset        0x340
    Caps class        0x27
    Caps offset        0x378
PCI registers
    00    A9 C0 0A 54 06 04 10 00 01 02 08 01 10 00 00 00
    10    04 00 30 84 00 00 00 00 00 00 00 00 00 00 00 00
    20    00 00 00 00 00 00 00 00 00 00 00 00 A9 C0 21 50
    30    00 00 00 00 80 00 00 00 00 00 00 00 00 01 00 00
    80    10 D0 02 00 E2 8F 2C 11 30 21 09 00 44 F8 43 01
    90    42 00 44 10 00 00 00 00 00 00 00 00 00 00 00 00
    A0    00 00 00 00 1F 08 11 00 00 04 00 00 1E 00 80 01
    B0    04 00 1E 01 00 00 00 00 00 00 00 00 00 00 00 00
    D0    11 E0 08 80 00 20 00 00 00 30 00 00 00 00 00 00
    E0    05 F8 86 01 00 00 00 00 00 00 00 00 00 00 00 00
    F0    00 00 00 00 00 00 00 00 01 00 03 00 08 00 00 00
    100    18 00 01 11 0F 10 0F 10 00 00 00 00 00 00 00 00
    110    1E 00 81 12 1F 0A 1A 00 0F 00 6C 42 2A 00 00 00
    120    00 00 00 00 00 00 00 00 0E 00 01 1E 00 00 00 00
    140    10 00 01 1E 02 00 00 00 00 00 00 00 10 00 10 00
    150    00 00 00 00 00 01 01 00 00 00 21 59 53 05 00 00
    160    01 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00
    1E0    25 00 01 20 01 00 00 80 01 00 00 80 00 00 00 00
Description            Ethernet Controller
Location            bus 46 (0x2E), device 0 (0x00), function 0 (0x00)
Common header
    Vendor ID        0x10EC (Realtek)
    Model ID        0x8125
    Revision ID        0x05
    PI            0x00
    SubClass        0x00
    BaseClass        0x02
    Cache Line        0x10
    Latency            0x00
    Header            0x00
PCI header
    Address 2 (memory)    0x0000000084200004
    Address 4 (memory)    0x0000000084210004
    Subsystem ID        0x1174
    Int. Line        0x00
    Int. Pin        0x01
PCI capability
    Caps offset        0x40
    Caps version        1.2
PCI capability
    Caps offset        0x50
PCI capability
    Caps offset        0x70
    Port            0
    Caps version        2.0
    Link speed        5.0 GT/s (max 5.0 GT/s)
PCI capability
    Caps class        MSI-X
    Caps offset        0xB0
PCI capability
    Caps class        Virtual Product Data
    Caps offset        0xD0
    Caps offset        0x100
    Caps offset        0x148
    Caps class        Device Serial Number
    Caps offset        0x168
    Serial (EUI-64)        1000000-684CE000
    Caps class        0x17
    Caps offset        0x178
    Caps class        0x18
    Caps offset        0x204
    Caps class        0x1E
    Caps offset        0x20C
    Caps offset        0x21C
    Vendor            2
    Size            256
PCI registers
    00    EC 10 25 81 06 04 10 00 05 00 00 02 10 00 00 00
    10    01 00 00 00 00 00 00 00 04 00 20 84 00 00 00 00
    20    04 00 21 84 00 00 00 00 00 00 00 00 05 1D 74 11
    40    01 50 C3 FF 08 00 00 00 00 00 00 00 00 00 00 00
    50    05 70 80 01 00 00 00 00 00 00 00 00 00 00 00 00
    70    10 B0 02 02 C1 8C 90 05 30 20 10 00 12 7C 47 00
    80    40 01 12 10 00 00 00 00 00 00 00 00 00 00 00 00
    90    00 00 00 00 1F 18 0C 00 10 00 00 00 06 00 00 00
    A0    02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    B0    11 D0 1F 80 04 00 00 00 04 08 00 00 00 00 00 00
    D0    03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    100    01 00 82 14 00 00 00 00 00 00 50 00 30 20 46 00
    110    00 00 00 00 00 E0 00 00 A0 00 00 00 00 00 00 00
    140    00 00 00 00 00 00 00 00 02 00 81 16 00 00 00 00
    150    00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 80
    160    00 00 00 00 00 00 00 00 03 00 81 17 00 E0 4C 68
    170    00 00 00 01 00 00 00 00 17 00 41 20 01 00 00 00
DMI
SMBIOS Version            3.4
DMI BIOS
    vendor            American Megatrends International LLC.
    version            N.1.14STD00
    date            09/15/2022
    ROM size        16384 KB
DMI System Information
    manufacturer        Standard
    product            Standard
    version            Standard
    serial            GM5AG0O2232704700
    UUID            {08969480-1F8D-11EE-9292-4535DE196A00}
    SKU            0001
    family            ADL
DMI Baseboard
    vendor            Standard
    model            Standard
    revision        Standard
    serial            Standard
DMI System Enclosure
    chassis type        Notebook
    chassis serial        Standard
DMI Port Connector
    designation        Internal Connector 1 (internal)
    designation        External Connector 1 (external)
DMI Port Connector
    designation        Internal Connector 2 (internal)
    designation        External Connector 2 (external)
DMI Port Connector
    designation        Internal Connector 3 (internal)
    designation        External Connector 3 (external)
DMI Port Connector
    designation        Internal Connector 4 (internal)
    designation        External Connector 4 (external)
DMI Port Connector
    designation        Internal Connector 5 (internal)
    designation        External Connector 5 (external)
DMI Extension Slot
    designation        Slot 1
    type            PCI Express
    width            32 bits
    populated        no
DMI Extension Slot
    designation        Slot 2
    type            PCI Express
    width            32 bits
    populated        no
DMI Extension Slot
    designation        Slot 3
    type            PCI Express
    width            32 bits
    populated        no
DMI Extension Slot
    designation        Slot 4
    type            PCI Express
    width            32 bits
    populated        no
DMI Extension Slot
    designation        Slot 5
    type            PCI Express
    width            32 bits
    populated        no
DMI OEM Strings
    string[0]        Standard
    string[1]        Standard
    string[2]        Standard
    string[3]        Standard
    string[4]        Standard
    string[5]        Standard
    string[6]        Standard
    string[7]        Standard
    string[8]        Standard
    string[9]        Standard
    string[10]        FBM-GM5AG0O0141RTP
    string[11]        GM5AG0O
    string[12]        Standard
    string[13]        Standard
    string[14]        Standard
    string[15]        1D051174O1100600
DMI Physical Memory Array
    location        Motherboard
    usage            System Memory
    correction        None
    max capacity        128 GB
    max# of devices        2
DMI Memory Device
    designation        Controller0-ChannelA-DIMM0
    format            SODIMM
    type            DDR5
    total width        64 bits
    data width        64 bits
    size            16 GB
    speed            4800 MHz
    manufacturer        Crucial Technology
    part number        CT16G48C40S5.C8A1
    serial number        E816A5B1
    voltage            1.100000
    manufacturer id        0x9B85
    product id        0x0
DMI data
    000    0x11 0x5C 0x27 0x00 0x26 0x00 0xFE 0xFF 0x40 0x00
    010    0x40 0x00 0x00 0x40 0x0D 0x00 0x01 0x02 0x22 0x80
    020    0x00 0xC0 0x12 0x03 0x04 0x05 0x06 0x01 0x00 0x00
    030    0x00 0x00 0xC0 0x12 0x4C 0x04 0x4C 0x04 0x4C 0x04
    040    0x03 0x08 0x00 0x00 0x85 0x9B 0x00 0x00 0x00 0x00
    050    0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    060    0x00 0x00 0x00 0x00
DMI Memory Device
    designation        Controller1-ChannelA-DIMM0
    format            SODIMM
    type            DDR5
    total width        64 bits
    data width        64 bits
    size            16 GB
    speed            4800 MHz
    serial number        E816B440
    voltage            1.100000
    product id        0x0
DMI data
    000    0x11 0x5C 0x28 0x00 0x26 0x00 0xFE 0xFF 0x40 0x00
DMI Processor
    manufacturer        Intel(R) Corporation
    model            12th Gen Intel(R) Core(TM) i7-12700H
    clock speed        4059.0 MHz
    FSB speed        100.0 MHz
    multiplier        40.5x
    max clock speed        4700.0 MHz
DMI data
    000    0x04 0x30 0x3A 0x00 0x01 0x03 0xC6 0x02 0xA3 0x06
    010    0x09 0x00 0xFF 0xFB 0xEB 0xBF 0x03 0x8C 0x64 0x00
    020    0x5C 0x12 0xDB 0x0F 0x41 0x01 0x33 0x00 0x34 0x00
    030    0x35 0x00 0x04 0x05 0x06 0x0E
DMI Port Connector
    designation        None (internal)
    designation        Keyboard (external)
    port type        Keyboard Port
    connector        PS/2
DMI Port Connector
    designation        Mouse (external)
    port type        Mouse Port
    connector        PS/2
DMI Port Connector
    designation        COM 1 (external)
    port type        Serial Port 16550A
DMI Port Connector
    designation        J1A2B (internal)
    designation        Video (external)
    port type        Video Port
    connector        DB-15 female
DMI Port Connector
    designation        J3A2 (internal)
    designation        HDMI (external)
DMI Port Connector
    designation        USB1.1 - 1# (external)
    port type        USB
    connector        Access Bus (USB)
DMI Port Connector
    designation        USB1.1 - 2# (external)
    port type        USB
DMI Port Connector
    designation        USB1.1 - 3# (external)
    port type        USB
DMI Port Connector
    designation        USB1.1 - 4# (external)
    port type        USB
DMI Port Connector
    designation        USB1.1 - 5# (external)
    port type        USB
DMI Port Connector
    designation        USB2.0 - 1# (external)
    port type        USB
DMI Port Connector
    designation        USB2.0 - 2# (external)
    port type        USB
DMI Port Connector
    designation        Ethernet (external)
    port type        Network Port
    connector        RJ-45
DMI Port Connector
    designation        J8J1 (internal)
    designation        SATA Port 0 Direct Connect (external)
DMI Port Connector
    designation        J7J1 (internal)
    designation        eSATA Port 4 (external)
DMI Port Connector
    designation        J6J1 (internal)
    designation        eSATA Port 3 (external)
DMI Port Connector
    designation        J7G1 - SATA Port 2 (internal)
    designation        None (external)
DMI Port Connector
    designation        J7G2 - SATA Port 1 (internal)
DMI Port Connector
    designation        J1F2 (internal)
    designation        AC IN (external)
DMI Port Connector
    designation        J5B1 - PCH JTAG (internal)
DMI Port Connector
    designation        J9A1 - TPM/PORT 80 (internal)
DMI Port Connector
    designation        J9E4 - HDA 2X8 Header (internal)
DMI Port Connector
    designation        J9E7 - HDA 8Pin Header (internal)
DMI Port Connector
    designation        J8F1 - HDA HDMI (internal)
DMI Port Connector
    designation        J9E3 - Scan Matrix Keyboard (internal)
DMI Port Connector
    designation        J8E1 - SPI Program (internal)
DMI Port Connector
    designation        J9E5 - LPC Hot Docking (internal)
DMI Port Connector
    designation        J9G2 - LPC SIDE BAND (internal)
DMI Port Connector
    designation        J8F2 - LPC Slot (internal)
DMI Port Connector
    designation        J8H3 - PCH XDP (internal)
DMI Port Connector
    designation        J6H1 - SATA Power (internal)
DMI Port Connector
    designation        J5J1 - FP Header (internal)
DMI Port Connector
    designation        J4H1 - ATX Power (internal)
DMI Port Connector
    designation        J1J3 - AVMC (internal)
DMI Port Connector
    designation        J1H1 - BATT B (internal)
DMI Port Connector
    designation        J1H2 - BATT A (internal)
DMI Port Connector
    designation        J2G1 - CPU Fan (internal)
DMI Port Connector
    designation        J1D3 - XDP (internal)
DMI Port Connector
    designation        J4V1 - Memory Slot 1 (internal)
DMI Port Connector
    designation        J4V2 - Memory Slot 2 (internal)
DMI Port Connector
    designation        J4C1 - FAN PWR (internal)
Storage
Drive    0/0/-1/-1
    Device Path        \\?\scsi#disk&ven_nvme&prod_ct1000p3pssd8#5&7d81a9b&0&000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
    Name            CT1000P3PSSD8
    Revision        P9CR40A
    Serial            2316E6CB7EA0
    Capacity        931.5 GB
    Type            Fixed, SSD
    Bus Type        NVMe (17)
    Features
    Controller        NVM Express (NVMe) Controller at bus 3, device 0, function 0
    Link Speed        PCI-E 4x @ 16.0 GT/s
    Volume            c:\, 247.1 GBytes (74.4 percent available)
    Volume            d:\, 683.6 GBytes (46.0 percent available)
USB Devices
USB Device            USB Composite Device, class=0x00, subclass=0x00, vendor=0x1532, product=0x0257
USB Device            Generic USB Hub, class=0x09, subclass=0x00, vendor=0x2109, product=0x2815
USB Device            USB Composite Device, class=0x00, subclass=0x00, vendor=0x18F8, product=0x1486
USB Device            USB Composite Device, class=0xEF, subclass=0x02, vendor=0x04F2, product=0xB711
USB Device            Intel(R) Wireless Bluetooth(R), class=0xE0, subclass=0x01, vendor=0x8087, product=0x0026
USB Device            Generic SuperSpeed USB Hub, class=0x09, subclass=0x00, vendor=0x2109, product=0x0815
USB Device            USB Attached SCSI (UAS) Mass Storage Device, class=0x00, subclass=0x00, vendor=0x0781, product=0x55BB
USB Device            USB Attached SCSI (UAS) Mass Storage Device, class=0x00, subclass=0x00, vendor=0x152D, product=0x9561
USB Device            Realtek USB 3.0 Card Reader, class=0x00, subclass=0x00, vendor=0x0BDA, product=0x0316
Graphics
Number of adapters        2
Graphic APIs
API                D3D
API                NVIDIA I/O
API                NVIDIA NVML
API                NVIDIA NVAPI
    pwrMask            0x000C1C2B
    pwrTable        [F5 F6 00 F7 00 FA 00 00 00 00 FE E3 F1 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 ]
API                Intel I/O
API                Intel IGCL
API                Intel oneAPI
Display Adapters
Display adapter 0 (primary)
    ID            0x1000000
    Name            NVIDIA GeForce RTX 3060 Laptop GPU
    Board Manufacturer    TONGFANG HONGKONG Ltd
    Revision        A1
    Core family        0x176 (GA106-A)
    Power Limit        115.0 W (default)
    Thermal Limit        87.0  C (max), 102.0  C (slowdown), 105.0  C (shutdown)
    Cores            3840
    ROP Units        48
    RayTracing Cores    30
    Tensor Cores        120
    Memory type        GDDR6 (Hynix)
    Memory size        6 GB
    Memory bus width    192 bits
    Current Link Width    x8
    Current Link Speed    2.5 GT/s
    PCI device        bus 1 (0x1), device 0 (0x0), function 0 (0x0)
        Vendor ID    0x10DE (0x1D05)
        Model ID    0x2520 (0x1174)
        Revision ID    0xA1
    Root device        bus 0 (0x0), device 1 (0x1), function 0 (0x0)
    Performance Level    Base
        Core clock    1387.0 MHz
        Memory clock    7001.0 MHz
    Performance Level    Boost
        Core clock    1702.0 MHz
    Performance Level    Current
        Core clock    210.0 MHz
        Memory clock    405.0 MHz
    Driver version        31.0.15.4629
    WDDM Model        3.1
Display adapter 1
    ID            0x4000000
    Name            Intel(R) Iris(R) Xe Graphics
    Execution Units        96
    PCI device        bus 0 (0x0), device 2 (0x2), function 0 (0x0)
        Vendor ID    0x8086 (0x1D05)
        Model ID    0x46A6 (0x1174)
        Revision ID    0xC
    Performance Level    Max
        Core clock    1400.0 MHz
        Core clock    750.0 MHz
    Driver version        31.0.101.4502
    WDDM Model        3.1
Win32_VideoController        AdapterRAM = 0x40000000 (1073741824)
Win32_VideoController        AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController        DriverVersion = 31.0.101.4502
Win32_VideoController        DriverVersion = 31.0.15.4629
Win32_VideoController        DriverDate = 06/15/2023
Win32_VideoController        DriverDate = 11/29/2023
Monitor 0
    Model             ()
    ID            BOE0974
    Serial
    Manufacturing Date    Week 13, Year 2021
    Size            15.3 inches
    Max Resolution        2560 x 1440 @ 40 Hz
    Horizontal Freq. Range    244-244 kHz
    Vertical Freq. Range    48-165 Hz
    Max Pixel Clock        670 MHz
    Gamma Factor        2.2
Monitor 1
    Model            MSI G244F ()
    ID            MSI3BB4
    Serial            BB4H013701828
    Manufacturing Date    Week 28, Year 2023
    Size            23.8 inches
    Max Resolution        1920 x 1080 @ 60 Hz
    Horizontal Freq. Range    30-200 kHz
    Max Pixel Clock        400 MHz
    Gamma Factor        2.2
Software
Windows Version            Microsoft Windows 11 (10.0) Professional 64-bit   (Build 22631)
DirectX Version            12.0
Register Spaces
Register space            PCI
Register space            PCI #2
Register space            SMBus, base address = 0x0EFA0
for mainboard only
Thanks, I should have mentioned that you only need the mainboard info, sorry about that.
I could be wrong but it looks to me like the board is a replica of a big name brand like Acer, ASUS, Lenovo or MSI etc, a brand that makes gaming type notebooks, the chinese mass produce such boards and then bulk buyers map their own BIOS onto them and then sell them on as custom gaming computers, it is not illegal to purchase such a computer but as you have unfortunately found out aftersales support is very poor.
See what they come back with and then go from there, I know what I would do but that is not relevant here.
Reactions: maxim123
Can't do anything more than wait for the updates they send. no refund possible, so can only accept it.
I think this can be closed until I get the updates. They keep delaying it. Thank you for the help.
they said they didn't get the update from MB, so they are giving this one. I asked them if there is any difference, they said no.
