Hey guys. This has been causing me issues for years now, and I cannot find the right solution, if there even is one.
My issue: I have multiple webcams plugged into a PC, windows 10 and 11 both have the same issue…
I have some software that requires a specific webcam to be used. If the inbuilt webcam is not disabled in device manager, that camera is what shows in the app. Not ideal, but I disable that inbuilt camera and then it is fine.
The main issue is I also need a Microsoft Kinect v2.0 to be used. This also overrides the app, and that’s what I see. There isn’t a camera selector within the app to state use this camera, and only this camera. If I plug in the Kinect after the first camera, it just overrides the webcam I’m wanting to use. I can’t just disable the Kinect camera, as enabling it again just overrides.
So what my question is, is there a way, even if it’s an ad-hoc bit of software, that allows me to not allow access to the inbuilt camera and Kinect from that app, but leaving them enabled, allows them to be used by other apps. Basically forcing only the required webcam to be accessed by my app.
Any guidance would be very much so welcomed!
Paul
Paul
