Help with gpu
Eltorrente
44
Hello, am building a new PC and need a suggestion for a GPU.
If the price is the same for :
ASUS ROG-STRIX-RTX3080TI-O12G-GAMING
SAPPHIRE TOXIC Radeon RX 6900 XT GAMING OC
What is a better choice? Or GIGABYTE nVidia GeForce RTX 3080 MASTER 12GB which cost 400E less.
CPU will be I7 12700K
MB GIGABYTE Z690 AORUS PRO rev. 1.0
PSU Asus ROG Strix 1000W
Either can be fine,
With Nvidia's cards, they usually try to make the in-house models better, this isn't always case.
Gigabyte makes solid products, it looks like their model may be significantly cheaper if that is a factor you are considering.
As far as Asus, I have always been satisfied with their products, their warranty has always treated me well (YMMV) and they seem to release products about on par with everyone else.
Looking into reviews that compare the cards you are looking at will help you make a decision, you will hear about the different warranties, the specs, and how those things impact (or don't impact) the performance.
Reactions: veeg
