Hey everyone -
I have an ibuypower pre-built computer with the following:
CPU: Intel i9-9900k cpu @ 3.60 GHz
GPU: NVIDIA Geforce RTX 2060 Super
Motherboard: PRIME Z390-P
RAM: Two - XPG 8g
Windows 10
I've had this computer for a few years now and It's been perfectly fine up until a few months ago. The screen just freezes where the mouse cannot be moved and the keys/keyboard shortcuts cannot be used, nothing works but holding the power button and restarting the computer and then it acts fine like nothing happened. It actually doesn't happen often, just randomly, maybe once a week (and I use this computer everyday usually 5-6+ hours a day).
What happened: I was cleaning my desk one day and I moved the montior which pulled the display port cord connected to my GPU and it broke one of the display ports on the gpu. I moved the cord to the next display port over on the gpu and it works.
Is that broken dp port causing the freezes on my pc now? Should I just replace my gpu and call it good?
Just curious as to if this is actually why my PC is freezing now.
Any advice is welcome and very much appreciated - thank you!!
RAM: Two - XPG 8g
Windows 10
