Hi there, i recently bought 5 coolers to my new case, and i noticed they each have molex connectors. I would want to connect them to 1 of 2 molex female cables that are coming out from my psu. The problem is, in order for my gpu to work i have a 8 pin to 2 molex adapter. 8 pin goes to gpu and those 2 molex cables connect with both the ones coming out from psu. Won't it cause any problem if i leave my gpu with only 1 molex connected and the other would go with my coolers. Or will it result a possible tragic result ? So should i just buy a new power supply with integrated 8 pin and 4 or even more molex cables , or just use my current psu but with adapters?
