Hi,
please, i need you help.
ive recently get BSOD with: PAGE FAULT IN NONPAGED AREA. with NTFS.sys fault.
so what i did was remove and put back rams, but find out, that the problem was in my HDD. i wanted to reinstal OS via USB, but only what i get was bootloop with BSOD with no possibility to enter safety mode or reinstall OS.
i removed HDD and put in another NTB. and in the moment ive plug USB to another NTB ( ive used usb from my external HDD and connect it to another NTB) the same BSOD appeared on the second NTB. ive unplugged the HDD, restarted NTB and it worked again. So there is something wrong with my HDD. and to my question - is there a way to repaire (or somehow delete the windows files in the HDD) so i can save my files? ive managed to plug it to PS4, and there is a option to format the HDD, but i want to use it as a last chance.
My os is win10. laptop is Lenovo y510P (i know, that its old NTB, but it worked great, until now)
Thanks a lot for help
have a nice day
have a nice day
