Solved Help pls!!!
Teheo
16
21
Okay so i bought a 3060 but I keep getting a bsod at the same point through the driver install, I have tried now with 2 different 3060’s and I’m seriously at a loss here, did a ddu, before trying to install the driver, I downloaded a new motherboard bios, tried to download the driver through device manager, and it crashed, I don’t know what to do…
Specs
I7-7400
16 gb ddr4 2400 Corsair
Prime z270m-plus
3060 Ventus 3x
750w Corsair
Plsss help me there is nothing online about this
Get System Info Log.
Include in your next reply a Get System Info log.
Save it to your desktop when complete.
Once you have the file on your desktop, then upload it here, and Here.
Copy the URL after your report is loaded.
Then send us the link.
Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
Upload your dump files.
You need to shut down your computer and clean the dust and or reapply the thermal paste before you do anything else. Before your computer catches on fire!! That temperature is absolutely unacceptable!!
Anything under 60 degrees C (140 degrees F) is perfect. Just above this temperature is okay, but as you creep above 70 degrees C (158 degrees F), you need to look at how to cool your PC down.
These old motherboards cant read the temperature it says that for anyone who has these, have loads of freinds with the same degree on speecy, my cpu temp is fine its idle's at about 33 to 35, and underload its like 60...
Make sure that everything is connected securely inside your machine.
Uninstall the following with GeekUninstaller.
NVIDIA Graphics Driver 527.56 - 527.56
Disable winodws update to ensure that it does not install a driver for the graphics card.
I know you said you did a DDU already, but do it again. Boot into Safe Mode and remove any remnants of the display driver.
Now reboot back into normal mode, then go here and get the lastest driver for your card. Let me know the outcome.
Dump: 121022-22625-01.dmp (10.12.2022 07:10:30)
Code: 0x1000007E - SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Process: System, probably caused by: memory_corruption
Third-party modules in the stack: nvlddmkm.sys
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_LARGE
Dump: 121022-22687-01.dmp (10.12.2022 07:49:52)
Dump: 121022-22781-01.dmp (10.12.2022 07:38:06)
Process: System, probably caused by: nvlddmkm.sys
FAILURE_BUCKET_ID: AV_nvlddmkm!unknown_function
Dump: 121222-77515-01.dmp (11.12.2022 20:50:01)
When i turn off Windows updates, the graphics card does not get a “temporary” driver from windows so when I try to download drivers from nvidia, it says that no nvidia gpu can be found, also does not show up in device manager
I would say yes, that would be the next logical step, perhaps there is an issue with the current one. I know you know, but make sure to power down the machine and unplug it first, or you will fry the card.
yeah, at this point im thinking there has to be some sort of hardware issue, the fact that it works with all other graphics card but not any 30 series is odd
This doesn't sound right, but I am no hardware expert. Let me tag some help for you. There is no guarantee that these people will reply, I am just trying to reach out to them to see if they have any ideas on your issue.
@Pyro @phillpower2 @PeterOz @Bastet @Rustys
Are you over clocking in the bios?
Have you installed any performance or OC software such as MSI Afterburner, AMDRyzenMaster. Intel's Extreme Tuning or Performance Maximizer, or CPU-Z? Even iCUE or other RGB hardware and/or software
I have no overclocking software, my bios is set to normal, it’s pcie gen 3 it should be no problem comparability wise…
I tried game ready drivers, the device manager drivers, the one without GeForce experience, it allways stops at about 35% freezing my system and the bsod… and then goes into a boot loop for like 3 minutes, then turns on again, but when it turns on again it has reverted to the state with no drivers…
I also did a bunch of memtests, but came out on the other side with no errors found
