Conversation help cleaning pc
9-Lab Scan.
  • Download 9-Lab Removal Tool.
  • CLICK HERE to determine whether you're running 32-bit or 64-bit for Windows.
  • Install the program onto your computer, then right click the icon run as administrator.
  • Update the program and then run a full scan!
  • Make sure the program updates, might be better to install it update reboot and check for updates again.
  • You need to make sure the database updates!!!
  • Upon Scan Completion Click on Show Results.
  • Then Click On Clean
  • Then Click on Save Log.
  • Save it to your desktop, copy and paste the contents of the log here in your next reply.
Code:
# AdwCleaner v6.010 - Logfile created 24/08/2016 at 20:28:38
# Updated on 12/08/2016 by ToolsLib
# Database : 2016-08-24.2 [Server]
# Operating System : Windows 8.1 Pro  (X64)
# Username : brad - BATTLESTATION
# Running from : C:\Users\brad\Desktop\adwcleaner_6.010.exe
# Mode: Clean
# Support : https://toolslib.net/forum
***** [ Services ] *****
***** [ Folders ] *****
[-] Folder deleted: C:\Users\brad\AppData\Roaming\acestream
[-] Folder deleted: C:\_acestream_cache_
[-] Folder deleted: C:\Users\brad\AppData\Local\Google\Chrome\User Data\Default\Extensions\nonjdcjchghhkdoolnlbekcfllmednbl
***** [ Files ] *****
[-] File deleted: C:\Users\brad\AppData\Local\Temp\Utils.dll
***** [ DLL ] *****
***** [ WMI ] *****
***** [ Shortcuts ] *****
***** [ Scheduled Tasks ] *****
***** [ Registry ] *****
[-] Key deleted: HKU\S-1-5-21-2731936480-3349034690-3766636756-1001\Software\Classes\.acelive
[-] Key deleted: HKU\S-1-5-21-2731936480-3349034690-3766636756-1001\Software\Classes\.acemedia
[-] Key deleted: HKU\S-1-5-21-2731936480-3349034690-3766636756-1001\Software\Classes\.acestream
[-] Key deleted: HKU\S-1-5-21-2731936480-3349034690-3766636756-1001\Software\Classes\.tslive
[-] Key deleted: HKU\S-1-5-21-2731936480-3349034690-3766636756-1001\Software\Classes\acestream
[-] Key deleted: HKU\S-1-5-21-2731936480-3349034690-3766636756-1001\Software\Classes\AceStream.file
[#] Key deleted on reboot: HKCU\Software\Classes\.acelive
[#] Key deleted on reboot: HKCU\Software\Classes\.acemedia
[#] Key deleted on reboot: HKCU\Software\Classes\.acestream
[#] Key deleted on reboot: HKCU\Software\Classes\.tslive
[#] Key deleted on reboot: HKCU\Software\Classes\acestream
[#] Key deleted on reboot: HKCU\Software\Classes\AceStream.file
[-] Key deleted: HKLM\SOFTWARE\Classes\Amazon1ButtonBrowserHelper.Amazon1ButtonBHO
[-] Key deleted: HKLM\SOFTWARE\Classes\Amazon1ButtonRuntime.Amazon1ButtonRuntime
[-] Key deleted: HKLM\SOFTWARE\Classes\Amazon1ButtonRuntime.AmazonRuntimeServer
[-] Key deleted: HKLM\SOFTWARE\Classes\AmazonAppIE.AppGateway
[-] Key deleted: HKLM\SOFTWARE\Classes\AmazonAppIE.GadgetGateway
[-] Key deleted: [x64] HKLM\SOFTWARE\Classes\CLSID\{BAC72C85-CEC6-4B86-AF06-FA20C259FAB8}
[-] Key deleted: [x64] HKLM\SOFTWARE\Classes\CLSID\{BD6ECB00-7C4A-4F97-B425-44117F2A7AAE}
[-] Key deleted: HKLM\SOFTWARE\Classes\AppID\{7F46C358-270D-4791-A579-AD1DDA1A3F7B}
[-] Key deleted: HKCU\Software\Classes\CLSID\{79690976-ED6E-403C-BBBA-F8928B5EDE17}
[-] Key deleted: HKLM\SOFTWARE\Classes\CLSID\{6E993643-8FBC-44FE-BC85-D318495C4D96}
[-] Key deleted: HKLM\SOFTWARE\Classes\CLSID\{BAC72C85-CEC6-4B86-AF06-FA20C259FAB8}
[-] Key deleted: HKLM\SOFTWARE\Classes\CLSID\{BD6ECB00-7C4A-4F97-B425-44117F2A7AAE}
[-] Key deleted: HKLM\SOFTWARE\Classes\CLSID\{6557DB6C-EFE1-45AC-92A6-FBB1554B7502}
[-] Key deleted: HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{BD6ECB00-7C4A-4F97-B425-44117F2A7AAE}
[-] Key deleted: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{B6DCCCD3-520D-4485-B642-FCC136CE12C3}
[-] Key deleted: [x64] HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\3DCCCD6BD02558446B24CF1C63EC213C
[-] Key deleted: [x64] HKLM\SOFTWARE\Classes\Installer\Products\3DCCCD6BD02558446B24CF1C63EC213C
[-] Key deleted: HKLM\SOFTWARE\Classes\Installer\Features\3DCCCD6BD02558446B24CF1C63EC213C
[#] Key deleted on reboot: HKLM\SOFTWARE\Classes\Installer\Products\3DCCCD6BD02558446B24CF1C63EC213C
[-] Value deleted: HKU\S-1-5-21-2731936480-3349034690-3766636756-1001\Software\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run [AceUpdater]
[-] Key deleted: HKCU\Software\Classes\Applications\ace_player.exe
[-] Key deleted: HKCU\Software\Classes\MIME\Database\Content Type\application/x-acestream-plugin
[-] Key deleted: HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.acelive
[-] Key deleted: HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.acemedia
[-] Key deleted: HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.acestream
[-] Key deleted: HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.tslive
[-] Key deleted: HKCU\Software\MozillaPlugins\@acestream.net/acestreamplugin,version=3.0.12
[#] Key deleted on reboot: HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.acelive
[#] Key deleted on reboot: HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.acemedia
[#] Key deleted on reboot: HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.acestream
[#] Key deleted on reboot: HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.tslive
[#] Key deleted on reboot: HKCU\SOFTWARE\Classes\Applications\ace_player.exe
[#] Key deleted on reboot: HKCU\SOFTWARE\Classes\MIME\Database\Content Type\application/x-acestream-plugin
***** [ Web browsers ] *****
[-] [ask.com] [Search Provider] Deleted: ask.com
[-] [aol.com] [Search Provider] Deleted: aol.com
[-] [infra-recorder.en.softonic.com] [Search Provider] Deleted: infra-recorder.en.softonic.com
[-] [C:\Users\brad\AppData\Local\Google\Chrome\User Data\Default] [extension] Deleted: nonjdcjchghhkdoolnlbekcfllmednbl
:: "Tracing" keys deleted
:: Winsock settings cleared
C:\AdwCleaner\AdwCleaner[C1].txt - [1682 Bytes] - [25/09/2015 12:01:58]
C:\AdwCleaner\AdwCleaner[C2].txt - [5374 Bytes] - [24/08/2016 15:13:12]
C:\AdwCleaner\AdwCleaner[C3].txt - [5527 Bytes] - [24/08/2016 20:28:38]
C:\AdwCleaner\AdwCleaner[S1].txt - [1554 Bytes] - [25/09/2015 12:00:55]
C:\AdwCleaner\AdwCleaner[S2].txt - [5212 Bytes] - [24/08/2016 15:11:59]
C:\AdwCleaner\AdwCleaner[S3].txt - [5295 Bytes] - [24/08/2016 16:44:07]
C:\AdwCleaner\AdwCleaner[S4].txt - [5514 Bytes] - [24/08/2016 20:24:14]
C:\AdwCleaner\AdwCleaner[S5].txt - [5858 Bytes] - [24/08/2016 20:27:22]
########## EOF - C:\AdwCleaner\AdwCleaner[C3].txt - [5965 Bytes] ##########
Code:
# Mode: Clean
***** [ DLL ] *****
***** [ WMI ] *****
Thread locked due to OP abandoning the topic. If you are OP then please contact a Moderator if you wish to have this thread re-opened, all others who may be having a similar issue please start a new topic by clicking here.
