About two weeks ago my Benq monitor started having problems keeping its calibration. When it got to the point of needing calibration 4 or 5 times a day, I switched it with a monitor on a different PC. The Benq monitor worked fine on the other PC, but the original PC still wouldn't hold its calibration with the alternative monitor. I decided to try replacing the graphics card.
I bought an ASUS TUF Gaming 3 AMD Radeon RX 5700XT OC Edition Gaming Graphics Card -- the newer one that doesn't have the bad heating problem. I was delighted that this seemed to fix the monitor calibration issue!
Then, another problem. Some graphics functions were TERRIBLY slow! Typing in MS Word, for example, resulted in a significant delay before the letters I typed appeared on the screen. Also, I found that I could no longer use one of my Photoshop plugins. It gave the message, "OpenGL 3.3 and later is required for this application to run. Try updating your graphics drivers." So, I did the following:
1) Updated the graphics driver for my new graphics card -- Problem not fixed.
2) Deleted all nVidia software -- Problem not fixed.
3) Reinstalled Photoshop and the plugin -- Problem not fixed.
Now I don't know what to do. I would really appreciate help!
Thank you!
Thank you!
