Game stuttering constantly but I have low ping and high fps
yama
22
So I just upgraded my PC to a Gtx 1650 super, Ryzen 3 3100 and 16GB of DDR4, this problem was already happening just before I upgraded but when I play CSGO and Battlefield 4, I have very high fps on high and low graphics and all resolutions and still experience this stuttering which feels like I have low fps but at the same time I can see my fps count is still very high and it lags rapidly on and off like every second. I keep the frame counter on so I can see that it will say almost 100+fps which is weird because it keeps doing it. I have installed all new drivers for CPU and GPU, gone through all the settings in nvidia and in game, rebooted, added launch options etc. I even checked to see if my CPU was being bottlenecked in CSGO but it was around 90% usage while my GPU was at 30% usage which seems normal. I also play Rust and Arma 3 which both run perfect with the new PC and I never have any stutter. Any help would be much appreciated!!
Gtx 1650 Super 4GB
AMD Ryzen 3 3100 3.59GHz
Raidmax 535W 80+ Bronze Certified Semi Modular ATX
Asus TUF B450M-PLUS GAMING Micro ATX AM4 Motherboard
G.Skill Flare X 16GB (2 x 8GB) DDR4-3200 CL16 Memory
