Here it is. Was able to get it to work and it should have the .dmp file in itThat .zip file you uploaded is empty.
Which driver would you want me to install? Or is it the NVIDIA auto-installer? I'm unsure which one to download and you mention getting the exe first and I want to have it ready before I do the DDU.Run DDU and install a fresh set of drivers from here.
An important note: You MUST download the driver executable and disconnect your computer from the internet before running DDU, otherwise Windows will automatically download drivers (which you don't want).
Below is a laundry list of good housekeeping, it wouldn't hurt to try them as well.
1. Try running the following programs, also try to keep at least 20-25% of your disks as free space.
Run Disk Cleanup (check all the boxes) this will delete things such as your recycling bin, so make sure you don't have any files you want to keep.
Run Defragment and Optimize Drives, run this on your drives.
2. Disable any overclocking or changes to power/performance settings
Turn off XMP/any overclocking you may have done (if any)
Settings > System > Power and sleep > Additional power settings
Make sure your power plan is set to balanced, anything else could tamper with the wrong settings and cause issues.
3. Check for Operating System Corruption
Right click on the Windows logo in the bottom left and select Windows Powershell (Admin)
Run these three commands separately:
sfc /scannow
Dism /Online /Cleanup-Image /CheckHealth
Dism /Online /Cleanup-Image /RestoreHealth
These will take a while to run, do not close out of Powershell while they are running, if one fails then move onto the next and then loop back around.
Note: It doesn't hurt to make a system backup before you make all these changes, save any important files of folders. While these changes shouldn't cause any issues, better to be safe than sorry.
4. Unplug unnecessary devices.
If you have a gamepad, extra monitor, external hard drive/flash drive, or anything that is not essential to using the computer plugged in, unplug it. You should be left with your monitor, mouse and keyboard.
Once you have completed all of these tasks, restart it (using the restart option in the power menu) and re-test.
Gotcha! From what I can tell for now the freezes aren't happening when they usually do. I'll keep this updated for a little bit in case it does happen again.The auto-installer will not work as it needs an internet connection to install the drivers.
I'd go for the first "Game Ready" drivers for your make and model.
The filters are as follows:
GeForce
GeForce 16 Series
GeForce GTX 1660 Super
Windows 11
Your Language
All
My apologies for the tardy response, PCHF has been particularly bad about giving me notifications as of late.
Just experienced another freeze. Though it's not as inevitable as it was with the first bootup, sleep mode, or Napoleon: Total War, it does also happen more often if I am streaming, in case that helps.Great! Let's hope that's all it was.
Keep us updated.
@veeg can mark this as pending in the meantime.
Here's the .dmp of the latest crash. For better or worse, I can now reliably recreate the crashes in the same way I used to again.Great! Let's hope that's all it was.
Keep us updated.
Code: 0x133 - DPC_WATCHDOG_VIOLATION
Process: System, probably caused by: memory_corruption
Third-party modules in the stack: usbvideo.sysw
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_LARGE
Reseated the graphics card and unplugged mic and second monitor. Still froze. Here's the .dmp for the latest crashOn top of the graphics card, I'd hit the ram too while you're in there.
The mic and second monitor can go for testing.
Also reseated the ram, just to be clearReseated graphics card and used minimal a
Third-party modules in the Raw Stack: nvlddmkm.sys
The install definitely happened while off the internet. I'll try pulling out the GPUWe've got a new error, so that's a good start.
This runs back to your video drivers, when you reinstalled them did you run DDU and install the new drivers before connecting to the internet?
Let's try pulling the graphics card out and running the system without it. Unplug the GPU and set it on an anti-static workspace, wooden tables or cardboard boxes work great.
Boot the system up, does the error still occur without the GPU installed?
Just realized I don't think I can test that. The only HDMI or displayport ports are on the GPU, and I don't have any USB monitors. I might grab an HDMI to USB adapter and try that, thoughWe've got a new error, so that's a good start.
