You should update these software.
OpenOffice 4.1.2 v.4.12.9782 Warning! Download Update
JavaFX 2.1.1 v.2.1.1 Please uninstall it and use Java SE 8 (jre-8u112-windows-i586.exe)
.QuickTime v.7.72.80.56 Warning! This software is no longer supported.
Adobe Shockwave Player 11.6 v.11.6.8.638 Uninstall this software.
Reset your hosts file, FRST was unable.
Reset Host File
Keep 9-Lab and Zemana -- Scan with them once every couple of weeks. The other tools we used will be cleaned up with the Delfix tool below.
Your machine is clean.
Glad to have helped!! Please tell a friend ...... or two about us.
Optimize your internet connection.
Click here for instructions.
Suggest the following in place of adblock.
Alternate DNS Server. Ad Blocking DNS.
Ublock Origin.
Anti Ad Block Killer.
Also, keep your browsing private with these tools:
Self Destructing Cookies.
Self Destructing Cookies Chrome.
Some items to keep you safe on the internet.
VooDoo Shield. control of what is running on your machine
Qualys BrowserCheck To update plugins.
Web Of Trust To Avoid Shady Websites.
Unchecky To Avoid Bundled Software.
Privazer To Clean up your mahcine.
Now Lets Clean up the tools we used and remove old restore points.
Download DelFix by "Xplode" to your Desktop.
Right Click the tool and Run as Admin ( Xp Users Double Click)
Put a check mark next the items below:
Remove disinfection tools
Create registry backup
Purge System Restore
Now click on "Run" button.
allow the program to complete its work.
all the tools we used will be removed.
Tool will create and open a log report (DelFix.txt)
Note: The report can be located at the following location C:\DelFix.txt
Code:
"C:\Windows\System32\Drivers\etc\hosts" => Could not move.
Could not restore Hosts.
Reset Host File
- Click here to download RstHosts v2.0
- Save the file to your desktop.
- Right Click and Run as Administrator.
- Click on Restaurer, then click OK at the prompt.
- This will restore the default host file.
- Next Click on Creer Un Rapport.
- This will open a logfile, post that in your next reply.
which of these programs should I be running regularly and how often?
Ublock Origin.
