Solved First welcome back?Need your Help with screen freeze and friendly blue screens
Apologies for my absence folks, unforeseen circumstances kept me away from a computer :(
Ouch, unfortunately the only appropriate cause of action has already been suggested by Mal.
Hi Guys Thanks for getting back.....without meaning to question your judgement,may I just say that all blue screens even up to factory reboot all carried similar messages???(ie prior to install of AVG,I had Avast then which did cause many incompatibilty problems.Shown as paging issues as well as BIOS)
After the reboot,I then the installed the full version of AVG,since when the PC has been more stable?
Loath to remove it,as a lot of work alongside the AVG team has been carried out?
Equally years ago when I joined PCHF.com,the recommended downloads were AVG,free Malware,CC cleaner etc which I still do this day.
So with no disrespect intended,unless you are totally certain it is AVG (remembering it wasnt installed prior to reboot when PC was toally unstable),I would rather leave it in place...is there no other area that might cause similar problems,as most blue sceens cropping up now (very occassionally) mentioning BIOS caching and shadowing,suggesting disabling them??
Hello caskin,
We can only go off the info available and AVG is the only thing that is flagged up out of the crash dmps that you have uploaded.
Below is my canned regarding AVG;
AVG is a known hog on system resources and will slow your computer down, it is also not as good an AV protection as it once was and using an alternative free AV that offers very good protection and is also light on system resources is recommended, for operating systems previous to Windows 8.1 Avast or MSE would be what I would suggest, for good quality free protection in Windows 8.1 and Windows 10 use Windows Defender, Windows Firewall or Comodo (free), MBAM and SUPERAntiSpyware.
As your AV protection is a paid for product, please make a note of the product key number and then for testing purposes uninstall it using the removal tool here and then download a good free AV protection to see if the problem is solved;
Avast! free from the Authors site option here or MSE from here
Uninstall AVG using the proper removal tool, once AVG has been uninstalled it is important that you follow the free AV suggestion previously made by Mal.
There is no need to take my word for how bad AVG both free and retail are, see Top 186 Complaints and Reviews about AVG Antivirus
"most blue sceens kept mentioning BIOS caching and shadowing,suggesting disabling them??"
This doesn't really affect modern hardware but was sometimes suggested as a last resort on older computers that had minimal specs such as 1GB of RAM and integrated graphics, you have 3GB of RAM + an add on video card so I cant see disabling the cache or shadowing in the BIOS will actually help.
Just a thought, have you checked the Action Centre to see if Windows identifies any hardware that has issue/s, copy/paste info from MS below;
Check for solutions
  1. Open Action Center by clicking the Start button
    11899_en-us_8
    , clicking Control Panel, and then, under System and Security, clicking Review your computer's status.
  2. Click Maintenance.
  3. Under Check for solutions to problem reports, click Check for solutions. Windows will notify you if there are any solutions to problems available for your computer.
Note
Some problems and solutions can only be viewed and fixed by an administrator. Log on using an administrator account to view these problems.
Reactions: caskin
Sysytem and security all running 100%.no problems noted or stored.maintenance :no action needed.
Have began uninstalling AVG,will be able to get refund so not too heavy on the purse
Already have superantispyware (not running),use as a extra scan occasionally.
Will reinstall Avast,found them to be OK,will use as default Anti Virus.(Have always acted on advice frrom PCHF,never failed)
Will get back if system becomes unstable as at the moment its been behaving itself admirably!
Thanks for looking over system for me....reassurring no large obvious problems..Thank you once again:thumbsup:
Reactions: veeg
Tip, to avoid possible browser problems and unwanted pop ups, do a custom install of Avast, uncheck the SafeZone browser plug in and be sure to use the Silent Mode option.
You are welcome btw :)
Reactions: caskin and veeg
Thanks once again for advice will do as suggested,just as soon as full AVG uninstalled and refund safely in pocket...!!!I guess for time being we can mark this as solved?
