Faulty pc, need help
jofara
21
I just finished building my pc, but when I went to turn on the power supply, only my motherboard lights up, and it only lights up halfway.
My total watt usage is 372 and my power supply is 750, so that isnt the issue.
I checked all the cables a million times but nothing is unplugged or half plugged. Any suggestions?
So other can assist
COMPLETE system specs including make and model of the PSU
Operating System Version , Release, and Desktop Environment
Build the system outside of the case bare-bones on THICK cardboard and see if it still happens.
Reactions: georgeks
