I'm currently trying to get my 3080 to work, however prior to any driver updates I get flicker. Once I start the driver updates it gets a partial way and crashes which leads to it no longer loading beyond the ASUS screen. It also gets hot as it doesn't seem to want to run the fans, only on initi hooting of the system.
I previously had a GTX 980 Installed and it worked flawlessly. I also had the 3080 in my other build and it also worked flawlessly....and still does. But the new build doesn't appear to want to accept the 3080. First I assumed maybe it was the PSU, So I tried my Seasonic 750W from my other PC and no result change. I've tried different monitors and HDMI/display port cables. Swapped back to the 980 and again, fired up no problem. I've reseated everything multiple times, though it should all be fine as it's works with the 980.
So, I'm stuck, my only thought is maybe the Gen3 PCIe capable riser cable might be the issue, though in my research it apparently should not be an issue.
Any help here would be amazing, I've spent hours cable managing then pulling it all out, just to have to do it all over and over in this tiny case .
Specs of issue build:
Windows 10
Tower: Raijintech Ophion
Motherboard: ASRock B550 Phantom Gaming-ITX/ax ATX
CPU: AMD Ryzen 5 5600
GPU: EVGA GeForce RTX 3080 FTW3 Ultra Gaming
Ram: Corsair Vengance RGB Pro 16GB (2 X 8GB)
PSU: Corsair CX-F RGB Series CX750F 80 Plus Bronze
Storage: Team Group MP33 M.2 2280 1 TB
Thanks!!
Windows 10
Thanks!!
