So my hard drive about a month ago had been making clicking noises for a while and I thought nothing of it, until it completely died and stopped getting read. Now, 2 drives later, still facing the same problem where it’ll work for a bit then start clicking, and then eventually stop getting read. I’m confused on what could be causing this. Could it be the power supply? Or maybe the cables or motherboard? I don’t really know what to replace or if I should just replace everything honestly. Until then I can’t really buy another hard drive as it’ll probably just die again so I’ll be stuck without a pc. I’ll appreciate any tips or advice I can get. Thank you!
