From my router I have a cat5e cable that runs through the attic to my room and then connects to a wall port. Whenever I plug in an ethernet cable into the port and then directly into my laptop, is does not connect. And the light on the router blinks orange instead of white, or just not at all. However, when I connect an Ethernet cable from the wall port to an Ethernet switch and then add another cable from the switch going to my laptop, it connects and works no problem. I don't mind using the switch, but I can't figure out why it works one way but not the other. Previously this was not an issue as I could connect directly from the wall port. Any thoughts or insight?
