Solved Enough sata cables?
this is where you'll have to get the dimension of the card and check them against the case allowance for add-on cards.
the case specs should give a clearance amount for such things. and even if it didn't fit, good cases allow you to remove the drive bays as these are the usual culprits that stop large cards fitting in.
