Solved Download speed
mike13
117
4
75
My Acer desktop is very near my modem and router, so I have it connected to my router with an ethernet cable. The download speed is about 600Mbps, which is what I pay for. My wife's Dell Inspiron (3 years old) is about 14 feet away and connects wirelessly. The download speed is only 70 Mbps. I moved her laptop near the router, and there is no difference in the download speed. Then I connected it to the router with an ethernet cable, like my desktop. Hardley any difference. I set up both computers, so I doubt if a setting is wrong. Any suggestions in the great difference in download speeds ?? Thanks, Mike
Speccy Scan.
  • Upon Completion:
  • Hit File
  • Publish Snap Shot
Please download MiniToolBox and save it to your desktop.
Run the program by right clicking on it and selecting Run as administrator.
When the program opens select the following boxes:
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Please post the log in your next reply
OK, I downloaded that Speccy scan, and ran it. Then it asks if I want to save it to a browser, or the clipboard. I chose clipboard, but I can not find it. I also tried to copy the address to my desktop. It only allowed me to copy a shortcut. I did that but am unable to add it to your site. ??????
No, lets skip the speccy if you are having issues with it.
Get System Info Log.
Include in your next reply a Get System Info log.
Save it to your desktop when complete.
Once you have the file on your desktop, then upload it here.
Copy the URL after your report is loaded.
Then send us the link.
HI, not having much luck with Speccy or that Get System Info. file. It tells me that the one file is too large to upload, and the other message is that the speecy file does not have the proper file extension. I think I will just pass for now. Many thanks for your help and suggestions.
You need to upload te Get system info log here. ========> https://www.getsysteminfo.com/
There is the minitoolbox log, it is much easier. I'll leave that up to you.
Flush DNS
there shouldn't be a Speccy file, you just need to click File > Publish Snapshot > Copy to Clipboard > Close. now you can paste (Ctrl+V) that link into your next post. (y)
Reactions: Malnutrition
I do not know how I got that ABC quote above. Just experimenting. I could not find a way to delete it sorry.
Yes, I would also like to see the mini toolbox log as well, that will show me a little more information I need in order to help you. 👍
