Solved Does someone, other than me, have control of my pc?
Running good. I'll know more in the morning after waking it from sleep and see if curser acts strange or not. Did you see anything fishy going on in the logs? And also, I never did run a repair scan on Zhp cleaner. Should I, or not?
I'll no more in the morning after waking it from sleep
(y)
Just trash/clutter.
Not needed, based on what was detected by it, nothing serious.
You can run an eset scan, to make sure I did not miss anything, but I am fairly certain this is not a malware issue, probably a bad mouse.
Make sure and disable your antivirus/defender prior to the scan.
  • Download ESET Online Scanner from herea nd save it to your Desktop.
  • Right click the esetonlinescanner.exe file you downloaded and select Run as administrator.
  • Click Get started.
  • In the Terms of use screen, click Accept if you agree to the Terms of use.
  • Click Get started in the welcome screen.
  • Select your preference for the Customer Experience Improvement Program and the Detection feedback system.Click Continue.
  • Click Computer scan, in the Welcome back screen.
  • Choose Full scan on the next screen.
  • Select Enable ESET to detect and quarantine potentially unwanted applications.Then click Start scan
  • When the scan is finished click Save scan log and save it to your Desktop as ESETScan.txt. Click Continue.
  • ESET Online Scanner will now ask if you wish to turn on the Periodic Scan feature.Click Continue
  • You will now be offered a trial version of ESET Internet Security.Click continue
  • On the next screen, you can leave feedback about the program if you wish.
  • Select Delete application's data on closing, if you are short of disk space or do not wish to retain the program for future use.
  • If you left feedback, click Submit and continue. If not, Close without feedback.
  • Copy and paste the contents of the ESETScan.txt file in your next reply.
Well, as you said. After I ran, ESETS, nothing more was detected.
Again, thx for all the help on this issue. Now on to the next issue. :p,
dOc
@jUstcAllmEdOc Anymore problems with the computer? Or should we clean up the tools we used, and close this thread?
