Solved Disable all RGB Lights on CPU Fans
an alter boy
25
Hi,
I've spent way too long trying to disable the RGB lights on my fans. It really shouldn't be this difficult. I want to use Signal RGB when the PC is on and I want lights, and I can disable it whenever I want. But there's a built-in light that's always blue if I disable Signal RGB, and if I shut down the PC, there's a rainbow color unless I turn off the PSU, which is really annoying when I just want to put it to sleep. It's also constantly fighting with Signal RGB and creates spark flashes of light which are very irritating. Every YouTube video has been completely useless can anyone tell me how to completely get rid of the RGB lights on the fans? Once it's gone I will use signal rgb.
Motherboard: GIGABYTE Z790 AORUS ELITE AX
GPU: GIGABYTE GeForce RTX 4060 Ti Eagle
CPU: Intel Core i5-13600K
What is the app that controls it? I think it's a BIOS thing I never installed any rgb apps, it's on even when I shut down the PC
SignalRGB
The BIOS carries out the power on self test ( POST ) which is a test of the hardware + a check for a bootable OS such as Windows, if a an OS is found the BIOS hands over control to the OS and plays no further part, short version, it is nothing to do with the BIOS.
Being that the OP revisited the forum but chose not to reply this thread will be marked and closed.
