DirectX Issue after upgrading 980 ti -> 1080 ti
Staygold
36
Hello all,
Registered out of frustration. I have only been able to find old solutions to this, that don't work. I don't know if the issue is the GPU drivers or what. I get this error when trying to launch a video game. A restart fixes it temporarily, but after a day or two it returns. I will post the screencap of the error with this thread.
Hi @Staygold and welcome to PCHF :)
I'm sorry to hear you're having issues.
Before we get started, we need more information about the PC in question and its hardware. This is a necessary step in diagnostics.
Please go HERE and download the portable version of Speccy. Save it to somewhere you can find, locate the file and as it comes as a Zip file use your favorite unzip application to decompress it. Open the newly created folder and double left click Speccy.exe if you have a 32 bit system or Speccy64.exe if yours is 64bit. If you are not sure what your system is click HERE.
Speccy will open and after a short wait will display a summary of your system specs.
[*]Click on the file menu.
[*]Then click Publish snapshot.
A dialogue box will ask you to confirm, select yes.
Another dialogue box will open
[*]Click Copy to Clipboard.
[*]Then click Close.
Now that your link has been copied please paste it into your next post. It should look something like the example below :)
http://speccy.piriform.com/results/6waAHapcLrZIVPakgxXXXXXXX
BTW: once you have finished with speccy and no longer want it removing it is easy because it is a portable app with no install. Simply delete the downloaded file and folder you created when you decompressed it. Gone:thumbsup:
