Solved Couple of PC issues...PC running slow and PC will not restart
No problem. I'll be around; glad the computer is running better. :)
Hi,
Just using virustool.com. I've navigated to C:\WINDOWS\System32\drivers\ElRawDsk.sys
but I don't see a scan button to select...
Let's do this, Boot into safe mode and then rename the driver from
To:
C:\WINDOWS\System32\drivers\ElRawDsk.BAK
This will disable the driver without ripping it out of the system since I do not know what program it is appended to.
I am not sure what program that driver is attached to and if this is a false positive it will cause that program to not work, this way you can re enable it if a program breaks or it causes system instability and if it is malicious and there is no ill effect we can remove it after you test the machine for a while.
Hit the windows key and r at the same time to copy and paste C:\WINDOWS\System32\drivers into the run box hit enter then find the ElRawDsk.sys driver, rename it then boot back into normal mode.
You can rename the file with command prompt as well.
You will need to boot into safe mode as mentioned before.
Open an elevated command prompt.
Copy and paste the line blow then hit enter, it will not work in normal mode as it is running.
ren "C:\WINDOWS\System32\drivers\ElRawDsk.sys" "ElRawDsk.BAK"
You recognize these; they are both programs that allow remote support, combined with the file above they could be used in conjunction for malicious activity. Although the programs are legit, it is just a matter of did you install them or not.
CHR Extension: (Bomgar Remote Support) -
C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\ipfljipbjloahhabacnofonhfbddnajm [2021-12-10]
Code:
 Bomgar Remote Support, now known as BeyondTrust Remote Support, is a comprehensive remote access and support solution designed to enable IT support teams to securely connect to and troubleshoot devices from virtually anywhere in the world. This software allows technicians to remotely access and control computers, mobile devices, servers, and other endpoints across various operating systems including Windows, macOS, Linux, iOS, and Android.
FF Plugin HKU\S-1-5-21-3466739526-2485095647-408758403-1009: temasys.com.sg/TemWebRTCPlugin -> C:\Users\chredge\AppData\Roaming\Tem\TemWebRTCPlugin\0.8.902\npTemWebRTCPlugin.dll [2017-10-26] (Temasys Communications Pte Ltd -> Temasys)
StartMenuInternet: FIREFOX.EXE - firefox.exe
Code:
 This plugin allows users to engage in real-time audio and video communication, as well as data sharing directly through their web browsers without the need for additional software installations.
Code:
This driver allows applications to access raw disk data directly, bypassing the standard security restrictions imposed by the Windows operating system. It enables user-mode applications to read and write to hard-drive and flash-disk partitions at a low level, which can be particularly useful for forensic analysis, data recovery, and undelete operations.
Hi,
Apologies. I haven't been able to log into the forum for the past few days, got a message saying that the server was down.
OK, so I need to boot into safe mode in order to change this file name? To log into safe mode, will I need my Windows/PC/Microsoft login details? I've had this PC for years and I only know the password it asks for when it boots up. I'm scared that it will ask me for details that I've not used for years and I'll be locked out if I'm not able to imput these.
Thanks for your patience.
Actually we can just do it with FRST,
If you installed the extensions and or know about and use then let me know I will rewrite the fix for you.
Copy the content of the code box below.
Do not copy the word code!!!
Right Click FRST and run as Administrator.
Click Fix once (!) and wait. The program will create a log file (Fixlog.txt).
Attach it to your next message.
Code:
start::
CreateRestorePoint:
EmptyTemp:
CloseProcesses:
CHR Extension: (Bomgar Remote Support) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\ipfljipbjloahhabacnofonhfbddnajm [2021-12-10]
CMD: ren "C:\WINDOWS\System32\drivers\ElRawDsk.sys" "ElRawDsk.BAK"
Reboot:
End::
Ok, can you post one final set of FRST and Addition.txt logs for review, and tell me if there are any more issues that you need to take care of before we close this thread.
Hi,
Here are the .txts you requested:
Scan result of Farbar Recovery Scan Tool (FRST) (x64) Version: 25.07.2024
Ran by chredge (administrator) on MYSTERYMACHINE (MSI MS-7758) (27-07-2024 23:12:45)
Running from C:\Users\chredge\Desktop\FRST64.exe
Loaded Profiles: chredge & MsDtsServer110 & MSSQLServerOLAPService & ReportServer & MSSQLFDLauncher & MSSQLSERVER
Platform: Microsoft Windows 10 Home Version 22H2 19045.4651 (X64) Language: English (United States)
Default browser: Chrome
Boot Mode: Normal
(Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.) C:\Program Files\AMD\CNext\CNext\RadeonSoftware.exe
(C:\Program Files\AMD\CNext\CNext\AMDRSServ.exe ->) (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.) C:\Program Files\AMD\CNext\CNext\amdow.exe
(C:\Program Files\AMD\CNext\CNext\AMDRSServ.exe ->) (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.) C:\Program Files\AMD\CNext\CNext\AMDRSSrcExt.exe
(C:\Program Files\AMD\CNext\CNext\RadeonSoftware.exe ->) (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.) C:\Program Files\AMD\CNext\CNext\cncmd.exe
(C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe ->) (Malwarebytes Inc. -> Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\Malwarebytes.exe
(C:\Program Files\Microsoft SQL Server\MSSQL11.MSSQLSERVER\MSSQL\Binn\fdlauncher.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft SQL Server\MSSQL11.MSSQLSERVER\MSSQL\Binn\fdhost.exe
(cmd.exe ->) (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.) C:\Program Files\AMD\CNext\CNext\AMDRSServ.exe
(DriverStore\FileRepository\u0390451.inf_amd64_39377efdd62734d1\B390182\atiesrxx.exe ->) (Advanced Micro Devices Inc. -> AMD) C:\Windows\System32\DriverStore\FileRepository\u0390451.inf_amd64_39377efdd62734d1\B390182\atieclxx.exe
(explorer.exe ->) (Google LLC -> Google LLC) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe <9>
(explorer.exe ->) (Realtek Semiconductor Corp. -> Realtek Semiconductor) C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
(Intel Corporation -> Intel Corporation) C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe
(Microsoft Windows -> Microsoft Corporation) C:\Windows\System32\cmd.exe
(Oracle America, Inc. -> Oracle Corporation) C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
(services.exe ->) (Advanced Micro Devices Inc. -> AMD) C:\Windows\System32\DriverStore\FileRepository\u0390451.inf_amd64_39377efdd62734d1\B390182\atiesrxx.exe
(services.exe ->) (Intel® Upgrade Service -> Intel(R) Corporation) C:\Program Files\Intel\iCLS Client\HeciServer.exe
(services.exe ->) (Malwarebytes Inc. -> Malwarebytes) C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
(services.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft SQL Server\110\DTS\Binn\MsDtsSrvr.exe
(services.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft SQL Server\90\Shared\sqlwriter.exe
(services.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft SQL Server\MSAS11.MSSQLSERVER\OLAP\bin\msmdsrv.exe
(services.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft SQL Server\MSRS11.MSSQLSERVER\Reporting Services\ReportServer\bin\ReportingServicesService.exe
(services.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft SQL Server\MSSQL11.MSSQLSERVER\MSSQL\Binn\fdlauncher.exe
(services.exe ->) (Microsoft Corporation -> Microsoft Corporation) C:\Program Files\Microsoft SQL Server\MSSQL11.MSSQLSERVER\MSSQL\Binn\sqlservr.exe
(services.exe ->) (Microsoft Windows Hardware Compatibility Publisher -> Advanced Micro Devices, Inc.) C:\Windows\System32\amdfendrsr.exe
(services.exe ->) (Microsoft Windows Publisher -> Microsoft Corporation) C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MpDefenderCoreService.exe
(services.exe ->) (Microsoft Windows Publisher -> Microsoft Corporation) C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MsMpEng.exe
(services.exe ->) (Microsoft Windows Publisher -> Microsoft Corporation) C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\NisSrv.exe
(services.exe ->) (Samsung Electronics CO., LTD. -> DEVGURU Co., LTD.) C:\Program Files (x86)\Samsung\USB Drivers\27_ssconn\conn\ss_conn_service.exe
(services.exe ->) (Samsung Electronics Co., Ltd. -> DEVGURU Co., LTD.) C:\Program Files (x86)\Samsung\USB Drivers\28_ssconn2\conn\ss_conn_service2.exe
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Windows\System32\dllhost.exe <3>
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Windows\System32\smartscreen.exe
(svchost.exe ->) (Microsoft Windows -> Microsoft Corporation) C:\Windows\SysWOW64\wbem\WmiPrvSE.exe
(svchost.exe ->) (Samsung Electronics Co., Ltd. -> Samsung Electronics Co. Ltd.) C:\Program Files (x86)\Samsung\Samsung Magician\SamsungMagician.exe
==================== Registry (Whitelisted) ===================
HKLM\...\Run: [RTHDVCPL] => C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe [9197568 2017-01-11] (Realtek Semiconductor Corp. -> Realtek Semiconductor)
HKLM-x32\...\Run: [USB3MON] => C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe [291608 2012-03-26] (Intel Corporation -> Intel Corporation)
HKLM-x32\...\Run: [SunJavaUpdateSched] => C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [752208 2024-06-05] (Oracle America, Inc. -> Oracle Corporation)
HKLM Group Policy restriction on software: C:\Windows\SystemApps\Microsoft.MicrosoftEdge_* <==== ATTENTION
HKLM Group Policy restriction on software: C:\Program Files (x86)\Microsoft\Edge* <==== ATTENTION
HKLM Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRoot% <==== ATTENTION
HKLM Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ProgramFilesDir% <==== ATTENTION
HKU\S-1-5-21-3466739526-2485095647-408758403-1009 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRoot% <==== ATTENTION
HKU\S-1-5-21-3466739526-2485095647-408758403-1009 Group Policy restriction on software: %HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\ProgramFilesDir% <==== ATTENTION
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\Run: [appnhost] => C:\Users\chredge\AppData\Local\Mixesoft\AppNHost\appnhost.exe [453176 2014-08-08] (Vladislavas Jarmalis -> Mixesoft Project)
HKLM\...\Windows x64\Print Processors\Canon MG2500 series Print Processor: C:\Windows\System32\spool\prtprocs\x64\CNMPDBX.DLL [30208 2023-07-07] (Microsoft Windows Hardware Compatibility Publisher -> CANON INC.)
HKLM\...\Print\Monitors\Canon BJ Language Monitor MG2500 series: C:\WINDOWS\system32\CNMLMBX.DLL [391168 2023-07-07] (Microsoft Windows Hardware Compatibility Publisher -> CANON INC.)
HKLM\...\Print\Monitors\Canon BJ Language Monitor MG2500 series XPS: C:\WINDOWS\system32\CNMXLMBX.DLL [393728 2013-03-24] (Microsoft Windows Hardware Compatibility Publisher -> CANON INC.)
HKLM\Software\Microsoft\Active Setup\Installed Components: [{8A69D345-D564-463c-AFF1-A69D9E530F96}] -> C:\Program Files (x86)\Google\Chrome\Application\127.0.6533.72\Installer\chrmstp.exe [2024-07-24] (Google LLC -> Google LLC)
HKLM\Software\...\Authentication\Credential Providers: [{503739d0-4c5e-4cfd-b3ba-d881334f0df2}] ->
IFEO\MicrosoftEdge.exe: [Debugger] C:\Windows\System32\systray.exe
IFEO\MicrosoftEdgeUpdate.exe: [Debugger] C:\Windows\System32\systray.exe
IFEO\msedge.exe: [Debugger] C:\Windows\System32\systray.exe
IFEO\msedgewebview2.exe: [Debugger] C:\Windows\System32\systray.exe
Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Watch.lnk [2013-04-10]
ShortcutTarget: Watch.lnk -> C:\Program Files (x86)\MUSTEK 1248UB\Driver\WATCH.exe (Common Group) [File not signed]
Policies: C:\ProgramData\NTUSER.pol: Restriction <==== ATTENTION
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Policies\Google: Restriction <==== ATTENTION
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Policies\Microsoft\Edge: Restriction <==== ATTENTION
==================== Scheduled Tasks (Whitelisted) =================
Task: {30DB77CA-5DFA-4FAB-A208-86176305F836} - System32\Tasks\{6E00ECDE-3602-4FEF-858D-F51BD4482340} => C:\Windows\System32\pcalua.exe [88064 2024-07-09] (Microsoft Windows -> Microsoft Corporation) -> -a E:\install.exe -d E:\
Task: {8FB8BC4D-0E22-466B-9E91-2CDCE1E2E8B5} - System32\Tasks\{6E96E9DF-8C1C-46FE-A88C-B2C62537F979} => C:\Windows\System32\pcalua.exe [88064 2024-07-09] (Microsoft Windows -> Microsoft Corporation) -> -a D:\Setup.exe -d D:\
Task: {BB675DF8-604E-488A-B1CB-03BA53AD9745} - System32\Tasks\{F0CF969B-A4F7-451D-98A9-1462AAEA81F3} => C:\Windows\System32\pcalua.exe [88064 2024-07-09] (Microsoft Windows -> Microsoft Corporation) -> -a C:\Users\Chris\Downloads\mp3gain-win-1_2_5.exe -d C:\Users\Chris\Downloads
Task: {C66C6B2B-38F8-4E2C-8D3E-9324C0DA2F68} - System32\Tasks\AdobeAAMUpdater-1.0-Chris-PC-Chris => C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe [444904 2012-09-20] (Adobe Systems Incorporated -> Adobe Systems Incorporated)
Task: {0FCD2E15-3374-4D9E-860A-6843AA5A867B} - System32\Tasks\AMDInstallLauncher => C:\Program Files\AMD\CIM\Bin64\InstallManagerApp.exe [1030584 2023-07-20] (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.)
Task: {B818C323-F13F-4B91-B70F-FD863BE274DD} - System32\Tasks\Bitdefender Agent WatchDog_65D6944A0EF74FDAB96E31112AD39864 => C:\Program Files\Bitdefender Agent\WatchDog.exe -> C:\Program Files\Bitdefender Agent\repair
Task: {0D35864B-769D-4CA0-926E-88D679FDD1FD} - System32\Tasks\CreateExplorerShellUnelevatedTask => C:\Windows\explorer.exe [5754336 2024-07-09] (Microsoft Windows -> Microsoft Corporation)
Task: {C1AF9FBE-2F4C-4B6D-9F6A-16A35AAF107F} - System32\Tasks\GoogleSystem\GoogleUpdater\GoogleUpdaterTaskSystem128.0.6597.0{FB0D115E-37F7-4F4E-99FA-F612A04431AE} => C:\Program Files (x86)\Google\GoogleUpdater\128.0.6597.0\updater.exe [4889704 2024-07-15] (Google LLC -> Google LLC)
Task: {540BFF73-A7A9-4BC1-803F-6848A7DBA4A7} - System32\Tasks\Hybrid => C:\IORRT\IORRT.bat [855 2014-09-21] () [File not signed]
Task: {F50FA8C1-3647-4AD1-98C4-6DA775D02D12} - System32\Tasks\IORRT => C:\IORRT\IORRT.bat [855 2014-09-21] () [File not signed]
Task: {80A7A0FB-261E-4464-9389-63AB5781B849} - System32\Tasks\Microsoft\Windows\MobilePC\HotStart => {06DA0625-9701-43DA-BFD7-FBEEA2180A1E}
Task: {B0CBAB43-44FC-469B-A4CE-87426761FDCE} - System32\Tasks\Microsoft\Windows\PerfTrack\BackgroundConfigSurveyor => {EA9155A3-8A39-40B4-8963-D3C761B18371}
Task: {5B42DD9C-5A26-4F27-BB95-34603F0997E5} - System32\Tasks\Microsoft\Windows\Shell\WindowsParentalControls => {DFA14C43-F385-4170-99CC-1B7765FA0E4A}
Task: {486D715E-6AA2-44CF-BC48-B6990CBB53C6} - System32\Tasks\Microsoft\Windows\Shell\WindowsParentalControlsMigration => {343D770D-7788-47C2-B62A-B7C4CED925CB}
Task: {CA15F4A5-1954-4DE9-8104-3A5ADB8FB69A} - System32\Tasks\Microsoft\Windows\SideShow\AutoWake => {E51DFD48-AA36-4B45-BB52-E831F02E8316}
Task: {D9436438-987F-4BD3-AE64-BF398DD96936} - System32\Tasks\Microsoft\Windows\SideShow\GadgetManager => {FF87090D-4A9A-4F47-879B-29A80C355D61}
Task: {3807D894-5114-481A-9345-42DFD6847B8F} - System32\Tasks\Microsoft\Windows\SideShow\SessionAgent => {45F26E9E-6199-477F-85DA-AF1EDFE067B1}
Task: {4B65A728-4996-4AE9-AB8B-D2EE2DC3A7C4} - System32\Tasks\Microsoft\Windows\SideShow\SystemDataProviders => {7CCA6768-8373-4D28-8876-83E8B4E3A969}
Task: {7C8C0ABB-6874-4E89-B5E8-1954FE774736} - System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Cache Maintenance => C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MpCmdRun.exe [1678960 2024-07-08] (Microsoft Windows Publisher -> Microsoft Corporation)
Task: {8280ED3F-1830-49C7-B5AB-1E3F3120CF74} - System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Cleanup => C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MpCmdRun.exe [1678960 2024-07-08] (Microsoft Windows Publisher -> Microsoft Corporation)
Task: {61755C47-F846-45B6-B4F4-06B622CB4543} - System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Scheduled Scan => C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MpCmdRun.exe [1678960 2024-07-08] (Microsoft Windows Publisher -> Microsoft Corporation)
Task: {52E0A672-E962-4A65-B734-C78EA0DDF83A} - System32\Tasks\Microsoft\Windows\Windows Defender\Windows Defender Verification => C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MpCmdRun.exe [1678960 2024-07-08] (Microsoft Windows Publisher -> Microsoft Corporation)
Task: {29B11E1E-942E-495C-A69D-97177A8BBAA0} - System32\Tasks\ModifyLinkUpdate => C:\Program Files\AMD\CIM\Bin64\InstallManagerApp.exe [1030584 2023-07-20] (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.)
Task: {EAAB85EA-7B25-4FEF-93F5-A6601DA5DDAC} - System32\Tasks\Mozilla\Firefox Background Update 308046B0AF4A39CB => C:\Program Files\Mozilla Firefox\firefox.exe [677448 2024-07-26] (Mozilla Corporation -> Mozilla Corporation) -> C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38\updates\308046B0AF4A39CB\--MOZ_LOG sync,prependheader,timestamp,append,maxsize:1,Dump:5 --MOZ_LOG_FILE C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38\updates\308046B0AF4A39CB\backgroundupdate.moz_log --backgroundtask background (the data entry has 6 more characters).
Task: {6F09A005-A0C7-43F4-8E49-3C7E9A1F18DA} - System32\Tasks\Mozilla\Firefox Background Update S-1-5-21-3466739526-2485095647-408758403-1009 308046B0AF4A39CB => C:\Program Files\Mozilla Firefox\firefox.exe [677448 2024-07-26] (Mozilla Corporation -> Mozilla Corporation) -> C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38\updates\308046B0AF4A39CB\--MOZ_LOG sync,prependheader,timestamp,append,maxsize:1,Dump:5 --MOZ_LOG_FILE C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38\updates\308046B0AF4A39CB\backgroundupdate.moz_log --backgroundtask background (the data entry has 6 more characters).
Task: {CB257E44-B389-4A65-8E6E-F69344680801} - System32\Tasks\Mozilla\Firefox Default Browser Agent 308046B0AF4A39CB => C:\Program Files\Mozilla Firefox\default-browser-agent.exe [34376 2024-07-26] (Mozilla Corporation -> Mozilla Foundation)
Task: {004FAAF6-7892-4BCD-B089-32C28D7A03EB} - System32\Tasks\PrivaZer_SkipUAC => C:\Program Files (x86)\PrivaZer\PrivaZer.exe [29217248 2024-07-20] (Goversoft LLC -> Goversoft LLC) -> C:\Program Files (x86)\PrivaZer\\$(Arg0)
Task: {3CDE6E07-736F-42F6-A679-A6F29AA5A3EA} - System32\Tasks\SamsungMagician => C:\Program Files (x86)\Samsung\Samsung Magician\SamsungMagician.exe [1112576 2017-05-19] (Samsung Electronics Co., Ltd. -> Samsung Electronics Co. Ltd.) -> C:\Program Files (x86)\Samsung\Samsung Magician\\/AUTOHIDE
Task: {1609267D-B0C1-4484-BC2E-61A0C5C4D5A1} - System32\Tasks\StartCN => C:\Program Files\AMD\CNext\CNext\cncmd.exe [56760 2022-11-30] (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.)
Task: {B9EB41A6-4BC0-437F-A6AF-49B19B035911} - System32\Tasks\StartDVR => C:\Program Files\AMD\CNext\CNext\RSServCmd.exe [291768 2022-11-30] (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.)
Task: C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask.job => C:\WINDOWS\explorer.exe
Tcpip\Parameters: [DhcpNameServer] 194.168.4.100 194.168.8.100
Tcpip\..\Interfaces\{ee550c16-21cf-4ff9-a401-2758c1a38dbe}: [DhcpNameServer] 194.168.4.100 194.168.8.100
Edge:
Edge DefaultProfile: Default
Edge Profile: C:\Users\chredge\AppData\Local\Microsoft\Edge\User Data\Default [2024-07-20]
Edge StartupUrls: Default -> "hxxps://uk.search.yahoo.com/yhs/web?hspart=arh&hsimp=yhs-001&type=zxy_03ee163caff7e8f369&param1=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&param2=MapdNGp9NWx6"
Edge DefaultSearchURL: Default -> hxxps://uk.search.yahoo.com/search{google:pathWildcard}?ei={inputEncoding}&fr=crmas&p={searchTerms}
Edge DefaultSearchKeyword: Default -> uk.yahoo.com
Edge DefaultSuggestURL: Default -> hxxps://uk.search.yahoo.com/sugg/chrome?output=fxjson&appid=crmas&command={searchTerms}
Edge Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Microsoft\Edge\User Data\Default\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2024-07-15]
Edge Extension: (Edge relevant text changes) - C:\Users\chredge\AppData\Local\Microsoft\Edge\User Data\Default\Extensions\jmjflgjpcpepeafmmgdpfkogkghcpiha [2024-03-03]
FireFox:
FF DefaultProfile: s2vrsgd6.default-1701613744906
FF ProfilePath: C:\Users\chredge\AppData\Roaming\TomTom\HOME\Profiles\33bmloxc.default [2016-05-17]
FF Extension: (No Name) - C:\Program Files (x86)\TomTom HOME 2\xul\extensions\MapShare-status@tomtom.com [not found]
FF ProfilePath: C:\Users\chredge\AppData\Roaming\Mozilla\Firefox\Profiles\bkulylrj.default-release-1656109909228 [2024-07-27]
FF ProfilePath: C:\Users\chredge\AppData\Roaming\Mozilla\Firefox\Profiles\s2vrsgd6.default-1701613744906 [2024-07-27]
FF Notifications: Mozilla\Firefox\Profiles\s2vrsgd6.default-1701613744906 -> hxxps://team.soccerstreams100.io
FF Plugin: @java.com/DTPlugin,version=10.11.2 -> C:\Windows\system32\npDeployJava1.dll [2013-01-24] (Oracle America, Inc. -> Oracle Corporation)
FF Plugin: @videolan.org/vlc,version=3.0.10 -> C:\Program Files\VideoLAN\VLC\npvlc.dll [2024-06-08] (VideoLAN -> VideoLAN)
FF Plugin: @videolan.org/vlc,version=3.0.21 -> C:\Program Files\VideoLAN\VLC\npvlc.dll [2024-06-08] (VideoLAN -> VideoLAN)
FF Plugin: adobe.com/AdobeAAMDetect -> C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities\npAdobeAAMDetect64.dll [2012-09-20] (Adobe Systems Incorporated -> Adobe Systems)
FF Plugin-x32: @esn/esnlaunch,version=2.1.3 -> C:\Program Files (x86)\Battlelog Web Plugins\2.1.3\npesnlaunch.dll [2013-02-28] (ESN Social Software AB) [File not signed]
FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI ipt;version=2.0.59 -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIIPT.dll [2012-01-06] (Intel® Identity Protection Technology Software -> Intel Corporation)
FF Plugin-x32: @intel-webapi.intel.com/Intel WebAPI updater -> C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT\npIntelWebAPIUpdater.dll [2012-01-06] (Intel® Identity Protection Technology Software -> Intel Corporation)
FF Plugin-x32: @java.com/DTPlugin,version=11.421.2 -> C:\Program Files (x86)\Java\jre1.8.0_421\bin\dtplugin\npDeployJava1.dll [2024-06-05] (Oracle America, Inc. -> Oracle Corporation)
FF Plugin-x32: @java.com/JavaPlugin,version=11.421.2 -> C:\Program Files (x86)\Java\jre1.8.0_421\bin\plugin2\npjp2.dll [2024-06-05] (Oracle America, Inc. -> Oracle Corporation)
FF Plugin-x32: adobe.com/AdobeAAMDetect -> C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities\npAdobeAAMDetect32.dll [2012-09-20] (Adobe Systems Incorporated -> Adobe Systems)
Chrome:
CHR DefaultProfile: Default
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Default [2024-07-27]
CHR DownloadDir: C:\Users\chredge\Desktop
CHR Notifications: Default -> hxxps://scentsatno3.co.uk; hxxps://www.facebook.com
CHR HomePage: Default -> hxxp://www.google.co.uk/
CHR StartupUrls: Default -> "hxxps://www.facebook.com/"
CHR Extension: (Honey: Automatic Coupons & Rewards) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Default\Extensions\bmnlcjabgnpnenekpadlanbbkooimhnj [2024-07-05]
CHR Extension: (I don't care about cookies) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Default\Extensions\fihnjjcciajhdojfnbdddfaoknhalnja [2024-06-26]
CHR Extension: (AdBlock — block ads across the web) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Default\Extensions\gighmmpiobklfepjocnamgkkbiglidom [2024-07-25]
CHR Extension: (Grammarly: AI Writing and Grammar Checker App) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Default\Extensions\kbfnbcaeplbcioakkpcpgfkobkghlhen [2024-07-26]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Default\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2021-01-29]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Guest Profile [2024-07-18]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10 [2024-07-18]
CHR Extension: (Endpoint Verification) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\callobklhcbilhphinckomhgkigmfocg [2023-06-20]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2023-06-20]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2023-06-20]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\gomekmidlodglbbmalcneegieacbdmki [2023-06-20]
CHR Extension: (Gantter Project Management) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\himomacamcpodhkahelbnmaddladgjgo [2023-06-20]
CHR Extension: (Google Forms) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\jhknlonaankphkkbnmjdlpehkinifeeg [2023-06-20]
CHR Extension: (PrinterLogic Client Extension) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\llhfdhidddepenjnklbngmapjohlbekh [2023-06-20]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2023-06-20]
CHR Extension: (Google Drawings) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\mkaakpdehdafacodkgkpghoibnmamcme [2023-06-20]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 10\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2023-06-20]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11 [2024-07-18]
CHR Extension: (Endpoint Verification) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\callobklhcbilhphinckomhgkigmfocg [2023-06-27]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2023-06-27]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\gomekmidlodglbbmalcneegieacbdmki [2023-06-27]
CHR Extension: (Gantter Project Management) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\himomacamcpodhkahelbnmaddladgjgo [2023-06-27]
CHR Extension: (Google Forms) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\jhknlonaankphkkbnmjdlpehkinifeeg [2023-06-27]
CHR Extension: (PrinterLogic Client Extension) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\llhfdhidddepenjnklbngmapjohlbekh [2023-06-27]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2023-06-27]
CHR Extension: (Google Drawings) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\mkaakpdehdafacodkgkpghoibnmamcme [2023-06-27]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 11\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2023-06-27]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12 [2024-07-18]
CHR Extension: (Endpoint Verification) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\callobklhcbilhphinckomhgkigmfocg [2023-12-07]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2023-12-07]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2023-12-07]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\gomekmidlodglbbmalcneegieacbdmki [2023-12-07]
CHR Extension: (Gantter Project Management) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\himomacamcpodhkahelbnmaddladgjgo [2023-12-07]
CHR Extension: (Google Forms) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\jhknlonaankphkkbnmjdlpehkinifeeg [2023-12-07]
CHR Extension: (PrinterLogic Client Extension) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\llhfdhidddepenjnklbngmapjohlbekh [2023-12-07]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2023-12-07]
CHR Extension: (Google Drawings) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\mkaakpdehdafacodkgkpghoibnmamcme [2023-12-07]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 12\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2023-12-07]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13 [2024-07-18]
CHR Extension: (Endpoint Verification) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\callobklhcbilhphinckomhgkigmfocg [2024-02-26]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2024-02-26]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2024-02-26]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\gomekmidlodglbbmalcneegieacbdmki [2024-02-26]
CHR Extension: (Gantter Project Management) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\himomacamcpodhkahelbnmaddladgjgo [2024-02-26]
CHR Extension: (Google Forms) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\jhknlonaankphkkbnmjdlpehkinifeeg [2024-02-26]
CHR Extension: (PrinterLogic Client Extension) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\llhfdhidddepenjnklbngmapjohlbekh [2024-02-26]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2024-02-26]
CHR Extension: (Google Drawings) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\mkaakpdehdafacodkgkpghoibnmamcme [2024-02-26]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 13\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2024-02-26]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2 [2024-07-18]
CHR Notifications: Profile 2 -> hxxps://appstream2.eu-west-1.aws.amazon.com; hxxps://meet.google.com; hxxps://prd-conn-csd.my.connect.aws; hxxps://veolia.bomgarcloud.com; hxxps://veoliauki1.lightning.force.com
CHR Extension: (Authenticator) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\bhghoamapcdpbohphigoooaddinpkbai [2024-06-03]
CHR Extension: (Endpoint Verification) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\callobklhcbilhphinckomhgkigmfocg [2024-02-20]
CHR Extension: (Adobe Acrobat) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2021-12-10]
CHR Extension: (WalkMe Extension) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\fckonodhlfjlkndmedanenhgdnbopbmh [2024-05-27]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2024-06-19]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\gomekmidlodglbbmalcneegieacbdmki [2024-06-05]
CHR Extension: (Gantter Project Management) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\himomacamcpodhkahelbnmaddladgjgo [2021-12-10]
CHR Extension: (Google Forms) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\jhknlonaankphkkbnmjdlpehkinifeeg [2021-12-10]
CHR Extension: (Grammarly: AI Writing and Grammar Checker App) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\kbfnbcaeplbcioakkpcpgfkobkghlhen [2024-07-12]
CHR Extension: (PrinterLogic Client Extension) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\llhfdhidddepenjnklbngmapjohlbekh [2024-07-17]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2023-10-06]
CHR Extension: (Google Drawings) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\mkaakpdehdafacodkgkpghoibnmamcme [2021-12-10]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 2\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2021-12-10]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3 [2024-07-18]
CHR Extension: (Slides) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2022-01-21]
CHR Extension: (Docs) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\aohghmighlieiainnegkcijnfilokake [2022-01-21]
CHR Extension: (Google Drive) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\apdfllckaahabafndbhieahigkjlhalf [2022-01-21]
CHR Extension: (YouTube) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2022-01-21]
CHR Extension: (Adobe Acrobat) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2022-01-21]
CHR Extension: (Sheets) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2022-01-21]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2022-01-21]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\gomekmidlodglbbmalcneegieacbdmki [2022-01-21]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2022-01-21]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2022-01-21]
CHR Extension: (Gmail) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 3\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2022-01-21]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4 [2024-07-18]
CHR Notifications: Profile 4 -> hxxps://prd-conn-csd.awsapps.com
CHR Extension: (Slides) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2022-02-24]
CHR Extension: (Docs) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\aohghmighlieiainnegkcijnfilokake [2022-02-24]
CHR Extension: (Google Drive) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\apdfllckaahabafndbhieahigkjlhalf [2022-02-24]
CHR Extension: (YouTube) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2022-02-24]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2022-02-24]
CHR Extension: (Sheets) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2022-02-24]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2022-02-24]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\gomekmidlodglbbmalcneegieacbdmki [2022-02-24]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2022-02-24]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2022-02-24]
CHR Extension: (Gmail) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 4\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2022-02-24]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5 [2024-07-18]
CHR Extension: (Slides) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2022-03-01]
CHR Extension: (Docs) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\aohghmighlieiainnegkcijnfilokake [2022-03-01]
CHR Extension: (Google Drive) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\apdfllckaahabafndbhieahigkjlhalf [2022-03-01]
CHR Extension: (YouTube) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\blpcfgokakmgnkcojhhkbfbldkacnbeo [2022-03-01]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2024-07-06]
CHR Extension: (Sheets) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2022-03-01]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2022-03-01]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\gomekmidlodglbbmalcneegieacbdmki [2022-03-01]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2024-07-06]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2022-03-01]
CHR Extension: (Gmail) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 5\Extensions\pjkljhegncpnkpknbcohdijeoejaedia [2022-03-01]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 6 [2024-07-18]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 6\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2023-02-15]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 6\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2023-02-15]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 6\Extensions\gomekmidlodglbbmalcneegieacbdmki [2023-02-15]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 6\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2023-02-15]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 6\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2023-02-15]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 7 [2024-07-18]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 7\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2023-03-17]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 7\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2023-03-17]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 7\Extensions\gomekmidlodglbbmalcneegieacbdmki [2023-03-17]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 7\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2023-03-17]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 7\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2023-03-17]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 8 [2024-07-18]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 8\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2023-04-18]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 8\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2023-04-18]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 8\Extensions\gomekmidlodglbbmalcneegieacbdmki [2023-04-18]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 8\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2023-04-18]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 8\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2023-04-18]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 9 [2024-07-18]
CHR Extension: (Adobe Acrobat: PDF edit, convert, sign tools) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 9\Extensions\efaidnbmnnnibpcajpcglclefindmkaj [2023-04-25]
CHR Extension: (Google Docs Offline) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 9\Extensions\ghbmnnjooekpmoecnnnilnnbdlolhkhi [2023-04-25]
CHR Extension: (Avast Online Security & Privacy) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 9\Extensions\gomekmidlodglbbmalcneegieacbdmki [2023-04-25]
CHR Extension: (Ace Script) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 9\Extensions\mjbepbhonbojpoaenhckjocchgfiaofo [2023-04-25]
CHR Extension: (Chrome Web Store Payments) - C:\Users\chredge\AppData\Local\Google\Chrome\User Data\Profile 9\Extensions\nmmhkkegccagdldgiimedpiccmgmieda [2023-04-25]
CHR Profile: C:\Users\chredge\AppData\Local\Google\Chrome\User Data\System Profile [2024-07-27]
CHR HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj]
CHR HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Google\Chrome\Extensions\...\Chrome\Extension: [mjbepbhonbojpoaenhckjocchgfiaofo]
CHR HKLM-x32\...\Chrome\Extension: [gomekmidlodglbbmalcneegieacbdmki]
==================== Services (Whitelisted) ===================
S3 BEService; C:\Program Files (x86)\Common Files\BattlEye\BEService.exe [1467912 2017-02-04] (BattlEye Innovations e.K. -> )
S3 EasyAntiCheat; C:\Program Files (x86)\EasyAntiCheat\EasyAntiCheat.exe [820352 2020-04-20] (EasyAntiCheat Oy -> Epic Games, Inc)
S3 EpicOnlineServices; C:\Program Files (x86)\Epic Games\Epic Online Services\service\EpicOnlineServicesHost.exe [934352 2023-02-10] (Epic Games Inc. -> Epic Games, Inc.)
S3 LibreOfficeMaintenance; C:\Program Files\LibreOffice\program\update_service.exe [123320 2024-07-11] (The Document Foundation -> The Document Foundation)
R2 MBAMService; C:\Program Files\Malwarebytes\Anti-Malware\mbamservice.exe [8901528 2024-07-15] (Malwarebytes Inc. -> Malwarebytes)
S3 MBVpnTunnelService; C:\Program Files\Malwarebytes\Anti-Malware\MBVpnTunnelService.exe [3073888 2024-06-12] (Malwarebytes Inc. -> Malwarebytes)
R2 MDCoreSvc; C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MpDefenderCoreService.exe [1377416 2024-07-08] (Microsoft Windows Publisher -> Microsoft Corporation)
R2 MsDtsServer110; C:\Program Files\Microsoft SQL Server\110\DTS\Binn\MsDtsSrvr.exe [218816 2016-09-24] (Microsoft Corporation -> Microsoft Corporation)
R3 MSSQLFDLauncher; C:\Program Files\Microsoft SQL Server\MSSQL11.MSSQLSERVER\MSSQL\Binn\fdlauncher.exe [50368 2014-05-15] (Microsoft Corporation -> Microsoft Corporation)
R2 MSSQLSERVER; C:\Program Files\Microsoft SQL Server\MSSQL11.MSSQLSERVER\MSSQL\Binn\sqlservr.exe [194240 2016-09-24] (Microsoft Corporation -> Microsoft Corporation)
S3 Origin Client Service; C:\Program Files (x86)\Origin\OriginClientService.exe [2122248 2016-09-01] (Electronic Arts, Inc. -> Electronic Arts)
R2 ReportServer; C:\Program Files\Microsoft SQL Server\MSRS11.MSSQLSERVER\Reporting Services\ReportServer\bin\ReportingServicesService.exe [2454720 2014-05-15] (Microsoft Corporation -> Microsoft Corporation)
S3 SQLSERVERAGENT; C:\Program Files\Microsoft SQL Server\MSSQL11.MSSQLSERVER\MSSQL\Binn\SQLAGENT.EXE [613056 2016-09-24] (Microsoft Corporation -> Microsoft Corporation)
R2 ss_conn_service; C:\Program Files (x86)\Samsung\USB Drivers\27_ssconn\conn\ss_conn_service.exe [752224 2020-11-26] (Samsung Electronics CO., LTD. -> DEVGURU Co., LTD.)
R2 ss_conn_service2; C:\Program Files (x86)\Samsung\USB Drivers\28_ssconn2\conn\ss_conn_service2.exe [919992 2020-11-26] (Samsung Electronics Co., Ltd. -> DEVGURU Co., LTD.)
S3 SwitchBoard; C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe [517096 2010-02-19] (Test Signing Certificate -> Adobe Systems Incorporated) [File not signed]
R3 WdNisSvc; C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\NisSrv.exe [3236728 2024-07-08] (Microsoft Windows Publisher -> Microsoft Corporation)
R2 WinDefend; C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24060.7-0\MsMpEng.exe [133688 2024-07-08] (Microsoft Windows Publisher -> Microsoft Corporation)
R2 MSSQLServerOLAPService; "C:\Program Files\Microsoft SQL Server\MSAS11.MSSQLSERVER\OLAP\bin\msmdsrv.exe" -s "C:\Program Files\Microsoft SQL Server\MSAS11.MSSQLSERVER\OLAP\Config"
===================== Drivers (Whitelisted) ===================
R3 amdfendrmgr; C:\WINDOWS\System32\drivers\amdfendrmgr.sys [25584 2023-06-13] (Microsoft Windows Hardware Compatibility Publisher -> Advanced Micro Devices, Inc.)
R3 AMDSAFD; C:\WINDOWS\System32\DriverStore\FileRepository\amdsafd.inf_amd64_54807f69fe156f14\amdsafd.sys [113088 2023-04-13] (Advanced Micro Devices Inc. -> Advanced Micro Devices)
R3 amdwddmg; C:\WINDOWS\System32\DriverStore\FileRepository\u0390451.inf_amd64_39377efdd62734d1\B390182\amdkmdag.sys [94467928 2023-04-06] (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.)
R3 AMDXE; C:\WINDOWS\System32\drivers\amdxe.sys [61888 2023-05-24] (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.)
S3 CySmb; C:\WINDOWS\System32\drivers\cysmb.sys [10752 2016-05-29] (Cypress Semiconductor, Inc.) [File not signed]
S3 dg_ssudbus; C:\WINDOWS\system32\DRIVERS\ssudbus2.sys [167440 2022-09-30] (Samsung Electronics CO., LTD. -> Samsung Electronics Co., Ltd.)
S3 DIRECTIO; C:\Program Files\PerformanceTest\DirectIo64.sys [31376 2015-03-10] (PassMark Software Pty Ltd -> )
S3 DrvAgent64; C:\Windows\SysWOW64\Drivers\DrvAgent64.SYS [13824 2015-04-04] (Phoenix Technologies) [File not signed]
S3 ksapi64; C:\WINDOWS\system32\drivers\ksapi64.sys [89776 2020-05-18] (Beijing Kingsoft Security software Co.,Ltd -> Kingsoft Corporation)
R2 mbamchameleon; C:\WINDOWS\System32\Drivers\MbamChameleon.sys [221264 2024-07-18] (Microsoft Windows Hardware Compatibility Publisher -> Malwarebytes)
S0 MbamElam; C:\WINDOWS\System32\DRIVERS\MbamElam.sys [21480 2023-09-02] (Microsoft Windows Early Launch Anti-malware Publisher -> Malwarebytes)
R3 MBAMSwissArmy; C:\WINDOWS\System32\Drivers\mbamswissarmy.sys [239568 2024-07-26] (Microsoft Windows Hardware Compatibility Publisher -> Malwarebytes)
S3 MotioninJoyXFilter; C:\WINDOWS\System32\drivers\MijXfilt.sys [121416 2012-05-12] (Shenzhen Saikeware Technology Co., Ltd. -> MotioninJoy) [File not signed]
S4 RsFx0201; C:\WINDOWS\System32\DRIVERS\RsFx0201.sys [337088 2014-05-15] (Microsoft Corporation -> Microsoft Corporation)
R1 RsProxy; C:\Windows\system32\drivers\RsProxy.sys [15976 2013-10-26] (Realtek Semiconductor Corp -> )
S3 ssudmdm; C:\WINDOWS\system32\DRIVERS\ssudmdm.sys [174112 2022-09-30] (Samsung Electronics CO., LTD. -> Samsung Electronics Co., Ltd.)
S3 tap-tb-0901; C:\WINDOWS\System32\drivers\tap-tb-0901.sys [38656 2018-07-31] (TunnelBear, Inc. -> The OpenVPN Project)
S0 WdBoot; C:\WINDOWS\System32\drivers\wd\WdBoot.sys [21968 2024-07-08] (Microsoft Windows Early Launch Anti-malware Publisher -> Microsoft Corporation)
R0 WdFilter; C:\WINDOWS\System32\drivers\wd\WdFilter.sys [602520 2024-07-08] (Microsoft Windows -> Microsoft Corporation)
R3 WdNisDrv; C:\WINDOWS\System32\drivers\wd\WdNisDrv.sys [105864 2024-07-08] (Microsoft Windows -> Microsoft Corporation)
S1 ElRawDisk; \??\C:\WINDOWS\system32\drivers\ElRawDsk.sys [X]
U3 idsvc; no ImagePath
==================== One month (created) (Whitelisted) =========
2024-07-27 23:12 - 2024-07-27 23:13 - 000047566 _____ C:\Users\chredge\Desktop\FRST.txt
2024-07-27 23:06 - 2024-07-27 23:06 - 000003120 _____ C:\WINDOWS\system32\Tasks\AMDInstallLauncher
2024-07-27 19:51 - 2024-07-27 19:51 - 000003328 _____ C:\WINDOWS\system32\Tasks\IORRT
2024-07-27 15:00 - 2024-07-27 15:00 - 002396672 _____ (Farbar) C:\Users\chredge\Desktop\FRST64.exe
2024-07-27 15:00 - 2024-07-27 15:00 - 000000000 ____D C:\Users\chredge\Desktop\FRST-OlderVersion
2024-07-26 16:58 - 2024-07-27 07:16 - 000000000 ____D C:\Program Files\Mozilla Firefox
2024-07-26 15:54 - 2024-07-26 15:54 - 001790024 _____ (Malwarebytes) C:\Users\chredge\Desktop\JRT_8.1.4.exe
2024-07-25 10:11 - 2024-07-25 10:20 - 1014300672 _____ C:\Users\chredge\Desktop\Unconfirmed 93381.crdownload
2024-07-22 15:42 - 2024-07-22 17:08 - 339230666 _____ C:\Users\chredge\Desktop\Unconfirmed 565538.crdownload
2024-07-21 18:00 - 2024-07-21 18:00 - 000000000 ____D C:\Users\chredge\AppData\Local\Slimware Utilities Inc
2024-07-21 07:42 - 2024-07-21 07:42 - 000293638 _____ C:\Users\chredge\Desktop\BootSafe.zip
2024-07-21 07:42 - 2019-03-02 20:57 - 001249808 _____ (d7xTech, Inc.) C:\Users\chredge\Desktop\BootSafe.exe
2024-07-21 07:12 - 2024-07-27 15:00 - 000000000 ____D C:\Users\chredge\Desktop\PC Help Forum items
2024-07-20 21:59 - 2024-07-20 21:59 - 000000000 ___SD C:\ProgramData\Microsoft\Windows\Start Menu\Programs\LibreOffice 24.2
2024-07-20 21:59 - 2024-07-20 21:59 - 000000000 ____D C:\Program Files\LibreOffice
2024-07-20 21:54 - 2024-07-20 21:54 - 000000000 ____D C:\Users\chredge\AppData\Roaming\Sun
2024-07-20 21:54 - 2024-07-20 21:54 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java
2024-07-20 21:54 - 2024-07-20 21:54 - 000000000 ____D C:\Program Files (x86)\Java
2024-07-20 21:54 - 2024-06-05 13:24 - 000178816 _____ (Oracle Corporation) C:\WINDOWS\SysWOW64\WindowsAccessBridge-32.dll
2024-07-20 21:28 - 2024-07-20 21:28 - 000000000 ____D C:\SecurityCheck
2024-07-20 21:26 - 2024-07-20 21:26 - 000000258 __RSH C:\ProgramData\ntuser.pol
2024-07-20 21:22 - 2024-07-25 09:31 - 000000000 ____D C:\Users\chredge\AppData\Local\PrivaZer
2024-07-20 21:22 - 2024-07-20 21:22 - 000003190 _____ C:\WINDOWS\system32\Tasks\PrivaZer_SkipUAC
2024-07-20 21:22 - 2024-07-20 21:22 - 000001966 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PrivaZer.lnk
2024-07-20 21:22 - 2024-07-20 21:22 - 000000000 ____D C:\Users\chredge\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PrivaZer
2024-07-20 21:22 - 2024-07-20 21:22 - 000000000 ____D C:\ProgramData\privazer
2024-07-20 21:22 - 2024-07-20 21:22 - 000000000 ____D C:\Program Files (x86)\PrivaZer
2024-07-20 20:57 - 2024-03-21 12:26 - 001049000 _____ (www.sordum.org) C:\Users\chredge\Desktop\EdgeBlock_x64.exe
2024-07-20 19:34 - 2024-07-20 19:39 - 000000000 ____D C:\Users\chredge\AppData\Roaming\ZHP
2024-07-20 19:34 - 2024-07-20 19:34 - 000000000 ____D C:\Users\chredge\AppData\Local\ZHP
2024-07-20 11:43 - 2024-07-20 13:20 - 000000000 ____D C:\AdwCleaner
2024-07-18 22:27 - 2024-07-18 22:29 - 000188450 _____ C:\WINDOWS\ntbtlog.txt
2024-07-18 22:27 - 2024-07-18 22:27 - 000000214 _____ C:\WINDOWS\Tasks\CreateExplorerShellUnelevatedTask.job
2024-07-18 06:48 - 2024-07-18 06:50 - 000000000 ____D C:\Users\chredge\AppData\Roaming\Geek Uninstaller
2024-07-16 07:19 - 2024-07-16 07:19 - 000033139 _____ C:\Users\chredge\Desktop\MYSTERYMACHINE.speccy
2024-07-09 22:51 - 2024-07-09 20:19 - 000417720 __RSH C:\bootmgr
2024-07-09 22:51 - 2019-12-07 10:08 - 000000001 ___SH C:\BOOTNXT
2024-07-09 22:50 - 2024-07-09 22:50 - 000000000 ____D C:\WINDOWS\system32\compatrel
2024-07-09 20:19 - 2024-07-09 20:19 - 000021724 _____ C:\WINDOWS\SysWOW64\IntegratedServicesRegionPolicySet.json
2024-07-09 20:18 - 2024-07-09 20:18 - 000021724 _____ C:\WINDOWS\system32\IntegratedServicesRegionPolicySet.json
2024-07-09 20:13 - 2024-07-09 20:13 - 000000000 ___HD C:\$WinREAgent
==================== One month (modified) ==================
2024-07-27 23:13 - 2013-07-22 10:04 - 000000000 ____D C:\FRST
2024-07-27 23:11 - 2023-09-02 12:17 - 000000000 ____D C:\Users\chredge\AppData\Local\Malwarebytes
2024-07-27 23:06 - 2021-04-22 18:03 - 000000000 ____D C:\WINDOWS\system32\SleepStudy
2024-07-27 20:01 - 2019-12-07 10:14 - 000000000 ____D C:\ProgramData\regid.1991-06.com.microsoft
2024-07-27 19:51 - 2023-09-02 10:49 - 000008192 ___SH C:\DumpStack.log.tmp
2024-07-27 19:51 - 2021-04-22 18:10 - 000000006 ____H C:\WINDOWS\Tasks\SA.DAT
2024-07-27 15:51 - 2019-12-07 10:03 - 000131072 _____ C:\WINDOWS\system32\config\BBI
2024-07-27 15:51 - 2017-04-15 04:18 - 000065536 _____ C:\WINDOWS\system32\spu_storage.bin
2024-07-27 11:16 - 2018-07-08 15:59 - 000000000 ____D C:\Users\chredge\AppData\Local\D3DSCache
2024-07-27 07:16 - 2023-12-03 15:29 - 000000000 ____D C:\Program Files (x86)\Mozilla Maintenance Service
2024-07-26 22:54 - 2022-02-15 17:03 - 000000000 ____D C:\ProgramData\Mozilla-1de4eec8-1241-4177-a864-e594e8d1fb38
2024-07-26 17:49 - 2023-12-03 15:29 - 000001011 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Firefox.lnk
2024-07-26 17:49 - 2023-12-03 15:29 - 000000000 ____D C:\WINDOWS\system32\Tasks\Mozilla
2024-07-25 16:02 - 2023-10-24 06:55 - 000000000 ____D C:\Users\chredge\Desktop\PPSSPP
2024-07-24 06:15 - 2021-12-14 23:23 - 000000000 ____D C:\WINDOWS\SystemTemp
2024-07-24 06:15 - 2012-12-23 22:12 - 000002301 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome.lnk
2024-07-23 21:00 - 2019-12-07 10:14 - 000000000 ___HD C:\Program Files\WindowsApps
2024-07-23 21:00 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\AppReadiness
2024-07-22 07:41 - 2018-10-25 16:31 - 000000000 ____D C:\Users\chredge\AppData\Local\CrashDumps
2024-07-21 16:23 - 2022-06-29 23:02 - 000000000 ____D C:\Users\chredge\AppData\Local\AMD_Common
2024-07-21 06:13 - 2021-04-22 18:03 - 005272992 _____ C:\WINDOWS\system32\FNTCACHE.DAT
2024-07-21 06:13 - 2013-01-12 17:35 - 000000000 ____D C:\Program Files\WinRAR
2024-07-20 22:02 - 2018-05-01 22:10 - 000000000 ____D C:\Users\chredge\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WinRAR
2024-07-20 22:02 - 2013-01-12 17:35 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
2024-07-20 22:01 - 2021-06-27 09:31 - 000001329 _____ C:\Users\chredge\Desktop\Ubisoft Connect.lnk
2024-07-20 21:54 - 2024-05-18 22:54 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\HWiNFO64
2024-07-20 21:54 - 2024-05-18 22:54 - 000000000 ____D C:\Program Files\HWiNFO64
2024-07-20 20:56 - 2021-04-22 18:10 - 000003522 _____ C:\WINDOWS\system32\Tasks\MicrosoftEdgeUpdateTaskMachineUA
2024-07-20 20:56 - 2021-04-22 18:10 - 000003298 _____ C:\WINDOWS\system32\Tasks\MicrosoftEdgeUpdateTaskMachineCore
2024-07-20 20:56 - 2009-07-14 04:20 - 000000000 ___HD C:\WINDOWS\system32\GroupPolicy
2024-07-20 19:20 - 2023-07-31 06:36 - 000000000 ____D C:\Users\chredge\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Chrome Apps
2024-07-20 19:20 - 2021-04-22 18:10 - 000000000 ____D C:\WINDOWS\system32\Tasks\Avast Software
2024-07-20 19:20 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\SysWOW64\GroupPolicy
2024-07-20 17:27 - 2024-02-22 23:41 - 000002440 _____ C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Edge.lnk
2024-07-20 07:31 - 2021-04-22 18:04 - 000000000 ____D C:\Users\ReportServer
2024-07-20 07:31 - 2021-04-22 18:04 - 000000000 ____D C:\Users\MSSQLServerOLAPService
2024-07-20 07:31 - 2021-04-22 18:04 - 000000000 ____D C:\Users\MSSQLSERVER
2024-07-20 07:31 - 2021-04-22 18:04 - 000000000 ____D C:\Users\MSSQLFDLauncher
2024-07-20 07:31 - 2021-04-22 18:04 - 000000000 ____D C:\Users\MsDtsServer110
2024-07-20 07:08 - 2021-04-22 18:04 - 000000000 ____D C:\Users\chredge
2024-07-19 04:55 - 2019-12-07 10:13 - 000000000 ____D C:\WINDOWS\INF
2024-07-18 07:00 - 2016-03-08 10:13 - 000000000 ____D C:\Users\chredge\AppData\LocalLow\Temp
2024-07-18 06:55 - 2019-12-07 10:03 - 000000000 ____D C:\WINDOWS\CbsTemp
2024-07-16 07:03 - 2021-04-22 18:11 - 000976178 _____ C:\WINDOWS\system32\PerfStringBackup.INI
2024-07-12 07:07 - 2020-06-08 14:56 - 000000000 ____D C:\Users\chredge\AppData\Roaming\vlc
2024-07-09 22:50 - 2024-02-22 23:37 - 000000000 ____D C:\WINDOWS\InboxApps
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ___RD C:\WINDOWS\ImmersiveControlPanel
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\SysWOW64\inetsrv
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\SysWOW64\Dism
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\SystemResources
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\system32\WinBioPlugIns
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\system32\setup
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\system32\SecureBootUpdates
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\system32\oobe
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\system32\inetsrv
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\system32\Dism
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\system32\appraiser
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\ShellExperiences
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\ShellComponents
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\PolicyDefinitions
2024-07-09 22:50 - 2019-12-07 10:14 - 000000000 ____D C:\WINDOWS\bcastdvr
2024-07-09 20:18 - 2021-04-22 18:03 - 003016192 _____ (Microsoft Corporation) C:\WINDOWS\SysWOW64\PrintConfig.dll
2024-07-09 20:12 - 2013-08-02 23:16 - 000000000 ____D C:\WINDOWS\system32\MRT
2024-07-09 20:08 - 2012-12-26 09:07 - 194135240 ____C (Microsoft Corporation) C:\WINDOWS\system32\MRT.exe
2024-07-08 21:50 - 2018-06-06 23:43 - 000000000 ____D C:\WINDOWS\system32\Drivers\wd
==================== Files in the root of some directories ========
2015-12-28 23:34 - 2015-12-28 23:34 - 000000000 _____ () C:\Program Files\Microsoft Security Client
2015-12-28 23:34 - 2015-12-28 23:34 - 000000000 _____ () C:\Program Files (x86)\ATI Technologies
2016-04-02 22:53 - 2024-01-23 21:39 - 000000132 _____ () C:\Users\chredge\AppData\Roaming\Adobe BMP Format CS5 Prefs
2016-07-17 23:20 - 2021-03-20 14:36 - 000000132 _____ () C:\Users\chredge\AppData\Roaming\Adobe PNG Format CS5 Prefs
2019-02-28 22:21 - 2019-02-28 22:21 - 000000132 _____ () C:\Users\chredge\AppData\Roaming\Adobe Targa Format CS5 Prefs
==================== SigCheck ============================
==================== End of FRST.txt ========================
Additional scan result of Farbar Recovery Scan Tool (x64) Version: 25.07.2024
Ran by chredge (27-07-2024 23:14:19)
Microsoft Windows 10 Home Version 22H2 19045.4651 (X64) (2021-04-22 17:10:26)
Boot Mode: Normal
Administrator (S-1-5-21-3466739526-2485095647-408758403-500 - Administrator - Disabled)
chredge (S-1-5-21-3466739526-2485095647-408758403-1009 - Administrator - Enabled) => C:\Users\chredge
DefaultAccount (S-1-5-21-3466739526-2485095647-408758403-503 - Limited - Disabled)
Guest (S-1-5-21-3466739526-2485095647-408758403-501 - Limited - Disabled)
HomeGroupUser$ (S-1-5-21-3466739526-2485095647-408758403-1002 - Limited - Enabled)
WDAGUtilityAccount (S-1-5-21-3466739526-2485095647-408758403-504 - Limited - Disabled)
AV: Windows Defender (Enabled - Up to date) {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
1394 OHCI Compliant Host Controller (Legacy) (HKLM-x32\...\{B12878BB-DA05-4F25-96E7-E0200428B220}) (Version: 0.0.1 - Microsoft Corporation)
Adobe Photoshop CS5.1 (HKLM-x32\...\{9158FF30-78D7-40EF-B83E-451AC5334640}) (Version: 12.1 - Adobe Systems Incorporated)
AMD Software (HKLM\...\AMD Catalyst Install Manager) (Version: 23.7.2 - Advanced Micro Devices, Inc.)
AppNHost 1.0.5.1 (HKLM-x32\...\{A8CB86C7-CD4C-4C4F-AF6A-33D1CAC63562}) (Version: 1.0.5.1 - Mixesoft Project)
Branding64 (HKLM\...\{2A677A6A-43E8-4FE3-A273-07B0E27DADAE}) (Version: 1.00.0008 - Advanced Micro Devices, Inc.) Hidden
Canon IJ Scan Utility (HKLM-x32\...\Canon_IJ_Scan_Utility) (Version: - Canon Inc.)
Canon MG2500 series MP Drivers (HKLM\...\{1199FAD5-9546-44f3-81CF-FFDB8040B7BF}_Canon_MG2500_series) (Version: 1.02 - Canon Inc.)
Canon MG2500 series User Registration (HKLM-x32\...\Canon MG2500 series User Registration) (Version: - ‭Canon Inc.)
Canon My Printer (HKLM-x32\...\CanonMyPrinter) (Version: 3.3.0 - Canon Inc.)
Dual-Core Optimizer (HKLM-x32\...\{9FD6F1A8-5550-46AF-8509-271DF0E768B5}) (Version: 1.1.4.0169 - AMD)
Epic Games Launcher (HKLM-x32\...\{53041896-BE90-4A26-9954-9E9FDC7D4495}) (Version: 1.1.229.0 - Epic Games, Inc.)
Epic Online Services (HKLM-x32\...\{4757C19B-4CE3-418C-91D2-E15E938091FB}) (Version: 2.0.39.0 - Epic Games, Inc.)
GDR 5343 for SQL Server 2012 (KB3045321) (64-bit) (HKLM\...\KB3045321) (Version: 11.2.5343.0 - Microsoft Corporation)
GDR 5388 for SQL Server 2012 (KB3194719) (64-bit) (HKLM\...\KB3194719) (Version: 11.2.5388.0 - Microsoft Corporation)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 127.0.6533.72 - Google LLC)
Google Earth Pro (HKLM\...\{3470AD08-85F2-4B1D-8487-FC4750732087}) (Version: 7.3.6.9796 - Google)
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.25.11 - Google Inc.) Hidden
HP Webcam HD 2300 Software (HKLM-x32\...\{74E6771A-47B5-433E-A96F-15E29F70F920}) (Version: 1.00.0000 - Hewlett-Packard)
HWiNFO64 (HKLM\...\HWiNFO64_is1) (Version: 8.04 - Martin Malik, REALiX s.r.o.)
Imaging And Configuration Designer (HKLM-x32\...\{E0F2B4CC-8551-9304-84E0-73535C1AA953}) (Version: 10.1.17134.1 - Microsoft) Hidden
Imaging Designer (HKLM-x32\...\{E1A52E1E-7F37-2A0D-3F17-F4B349EB9EA2}) (Version: 10.1.17134.1 - Microsoft) Hidden
Imaging Tools Support (HKLM-x32\...\{0EAC56B8-9CC7-C9E0-A0FB-62A6787D2699}) (Version: 10.1.17134.1 - Microsoft) Hidden
Intel(R) Management Engine Components (HKLM-x32\...\{65153EA5-8B6E-43B6-857B-C6E4FC25798A}) (Version: 8.0.10.1464 - Intel Corporation)
Intel(R) USB 3.0 eXtensible Host Controller Driver (HKLM-x32\...\{240C3DDD-C5E9-4029-9DF7-95650D040CF2}) (Version: 1.0.4.225 - Intel Corporation)
Intel® Trusted Connect Service Client (HKLM\...\{171C7193-1BB5-4619-BF23-E962598CAB13}) (Version: 1.23.943.1 - Intel Corporation) Hidden
Java 8 Update 421 (HKLM-x32\...\{77924AE4-039E-4CA4-87B4-2F32180421F0}) (Version: 8.0.4210.9 - Oracle Corporation)
Kits Configuration Installer (HKLM-x32\...\{C690B2D9-0AA8-8CDA-965D-FED648C3EF9C}) (Version: 10.1.17134.1 - Microsoft) Hidden
Launcher Prerequisites (x64) (HKLM-x32\...\{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
LibreOffice 24.2.5.2 (HKLM\...\{7519E50A-1B31-4EAE-9AB3-DEB5C0F764F9}) (Version: 24.2.5.2 - The Document Foundation)
Live! Cam Sync HD VF0770 Driver (1.00.07.00) (HKLM\...\Creative VF0770) (Version: - Creative Technology Ltd.)
Malwarebytes version 5.1.6.117 (HKLM\...\{35065F43-4BB2-439A-BFF7-0F1014F2E0CD}_is1) (Version: 5.1.6.117 - Malwarebytes)
MediaHuman Audio Converter version 1.9.4 (HKLM-x32\...\MediaHuman Audio Converter_is1) (Version: 1.9.4 - MediaHuman)
Microsoft .NET Framework 4 Multi-Targeting Pack (HKLM-x32\...\{CFEF48A8-BFB8-3EAC-8BA5-DE4F8AA267CE}) (Version: 4.0.30319 - Microsoft Corporation)
Microsoft .NET Framework 4.5.1 (HKLM\...\{7DEBE4EB-6B40-3766-BB35-5CBBC385DA37}) (Version: 4.5.50938 - Microsoft Corporation) Hidden
Microsoft Camera Codec Pack (HKLM\...\{D553E8CC-5C56-4B06-AC1A-A443DFF31092}) (Version: 6.3.9723.0 - Microsoft Corporation)
Microsoft DVD App Installation for Microsoft.WindowsDVDPlayer_2019.6.13291.0_neutral_~_8wekyb3d8bbwe (x64) (HKLM\...\{25E80DAA-FD87-DCE5-202C-CC02F6673002}) (Version: 1.0.0.0 - Microsoft Corporation) Hidden
Microsoft Edge (HKLM-x32\...\Microsoft Edge) (Version: 126.0.2592.113 - Microsoft Corporation)
Microsoft Edge WebView2 Runtime (HKLM-x32\...\Microsoft EdgeWebView) (Version: 126.0.2592.113 - Microsoft Corporation)
Microsoft Games for Windows - LIVE (HKLM-x32\...\{2C9EE786-1DDB-4C98-8FA4-B1B9B5A66B77}) (Version: 3.1.186.0 - Microsoft Corporation)
Microsoft Games for Windows - LIVE Redistributable (HKLM-x32\...\{832D9DE0-8AFC-4689-9819-4DBBDEBD3E4F}) (Version: 3.5.92.0 - Microsoft Corporation)
Microsoft Help Viewer 1.1 (HKLM\...\{E5748D30-7E6D-3A8E-BFE6-C1D02C6DDABB}) (Version: 1.1.40219 - Microsoft Corporation) Hidden
Microsoft Help Viewer 1.1 (HKLM\...\Microsoft Help Viewer 1.1) (Version: 1.1.40219 - Microsoft Corporation)
Microsoft HEVC Media Extension Installation for Microsoft.HEVCVideoExtension_1.0.2512.0_x64__8wekyb3d8bbwe (x64) (HKLM\...\{B0169E83-757B-EF66-E2F0-391944D785BC}) (Version: 1.0.0.0 - Microsoft Corporation) Hidden
Microsoft Report Viewer 2012 Runtime (HKLM-x32\...\{9CCE40CE-A9E6-4916-8729-B008558EEF3F}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft Security Client (HKLM\...\{D9FCBAAE-DB72-488B-96D0-0AA3C892C0D6}) (Version: 4.8.0204.0 - Microsoft Corporation) Hidden
Microsoft SQL Server 2008 R2 Management Objects (HKLM-x32\...\{83F2B8F4-5CF3-4BE9-9772-9543EAE4AC5F}) (Version: 10.51.2500.0 - Microsoft Corporation)
Microsoft SQL Server 2008 Setup Support Files (HKLM\...\{B40EE88B-400A-4266-A17B-E3DE64E94431}) (Version: 10.1.2731.0 - Microsoft Corporation)
Microsoft SQL Server 2012 (64-bit) (HKLM\...\Microsoft SQL Server SQLServer2012) (Version: - Microsoft Corporation)
Microsoft SQL Server 2012 Data-Tier App Framework (HKLM\...\{DC5602AF-666C-4A56-92C3-B8D675003775}) (Version: 11.1.2818.0 - Microsoft Corporation)
Microsoft SQL Server 2012 Management Objects (HKLM-x32\...\{DA1C1761-5F4F-4332-AB9D-29EDF3F8EA0A}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft SQL Server 2012 Management Objects (x64) (HKLM\...\{FA0A244E-F3C2-4589-B42A-3D522DE79A42}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft SQL Server 2012 Native Client (HKLM\...\{2B9EE1FE-105F-4093-A40E-C1BF12F873B7}) (Version: 11.2.5388.0 - Microsoft Corporation)
Microsoft SQL Server 2012 Policies (HKLM-x32\...\{DC487E40-046E-42A9-9C7C-5D2B1A7EB211}) (Version: 11.2.5058.0 - Microsoft Corporation)
Microsoft SQL Server 2012 RsFx Driver (HKLM\...\{9F616548-62E3-4C12-9E35-74A650BC199C}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
Microsoft SQL Server 2012 Setup (English) (HKLM\...\{C23DBA16-E075-41BE-AE2E-C1B0DD0B4535}) (Version: 11.2.5388.0 - Microsoft Corporation)
Microsoft SQL Server 2012 Transact-SQL Compiler Service (HKLM\...\{FA73FAE6-BAE5-4928-8CBB-00D311B6DFD3}) (Version: 11.2.5388.0 - Microsoft Corporation)
Microsoft SQL Server 2012 Transact-SQL ScriptDom (HKLM\...\{E721A8AA-2632-4798-B439-6D4C8A689BB8}) (Version: 11.2.5058.0 - Microsoft Corporation)
Microsoft SQL Server 2012 T-SQL Language Service (HKLM\...\{CC8B009A-98C9-497F-99AF-CEBE35D8C0CF}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft SQL Server Data Tools – Database Projects – Web installer entry point (HKLM-x32\...\{F3BBC56F-2282-4464-952F-A89772181F30}) (Version: 10.3.20116.0 - Microsoft Corporation)
Microsoft SQL Server System CLR Types (HKLM-x32\...\{C3F6F200-6D7B-4879-B9EE-700C0CE1FCDA}) (Version: 10.51.2500.0 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2012 (HKLM-x32\...\{E2082604-4BA5-44BB-BBFB-AF0F3CB8C6AB}) (Version: 11.0.2100.60 - Microsoft Corporation)
Microsoft System CLR Types for SQL Server 2012 (x64) (HKLM\...\{DEB263CA-0386-4648-8382-FB78DBFA2C5F}) (Version: 11.2.5058.0 - Microsoft Corporation)
Microsoft Update Health Tools (HKLM\...\{1FC1A6C2-576E-489A-9B4A-92D21F542136}) (Version: 3.74.0.0 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2010 x86 Runtime - 10.0.40219 (HKLM-x32\...\{5D9ED403-94DE-3BA0-B1D6-71F4BDA412E6}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.50727 (HKLM-x32\...\{15134cb0-b767-4960-a911-f2d16ae54797}) (Version: 11.0.50727.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 (HKLM-x32\...\{a1909659-0a08-4554-8af1-2175904903a1}) (Version: 11.0.60610.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.50727 (HKLM-x32\...\{22154f09-719a-4619-bb71-5b3356999fbf}) (Version: 11.0.50727.1 - Microsoft Corporation)
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.50727 (HKLM\...\{AC53FC8B-EE18-3F9C-9B59-60937D0B182C}) (Version: 11.0.50727 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030 (HKLM\...\{37B8F9C7-03FB-3253-8781-2517C99D7C00}) (Version: 11.0.61030 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.50727 (HKLM\...\{A2CB1ACB-94A2-32BA-A15E-7D80319F7589}) (Version: 11.0.50727 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030 (HKLM\...\{CF2BEA3C-26EA-32F8-AA9B-331F7E34BA97}) (Version: 11.0.61030 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.50727 (HKLM-x32\...\{FDB30193-FDA0-3DAA-ACCA-A75EEFE53607}) (Version: 11.0.50727 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 (HKLM-x32\...\{B175520C-86A2-35A7-8619-86DC379688B9}) (Version: 11.0.61030 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.50727 (HKLM-x32\...\{2F73A7B2-E50E-39A6-9ABC-EF89E4C62E36}) (Version: 11.0.50727 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 (HKLM-x32\...\{BD95A8CD-1D9F-35AD-981A-3E7925026EBB}) (Version: 11.0.61030 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.40660 (HKLM-x32\...\{ef6b00ec-13e1-4c25-9064-b2f383cb8412}) (Version: 12.0.40660.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.40660 (HKLM-x32\...\{61087a79-ac85-455c-934d-1fa22cc64f36}) (Version: 12.0.40660.0 - Microsoft Corporation)
Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.40660 (HKLM\...\{5740BD44-B58D-321A-AFC0-6D3D4556DD6C}) (Version: 12.0.40660 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.40660 (HKLM\...\{CB0836EC-B072-368D-82B2-D3470BF95707}) (Version: 12.0.40660 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.40660 (HKLM-x32\...\{7DAD0258-515C-3DD4-8964-BD714199E0F7}) (Version: 12.0.40660 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.40660 (HKLM-x32\...\{E30D8B21-D82D-3211-82CC-0F0A5D1495E8}) (Version: 12.0.40660 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2015-2019 Redistributable (x64) - 14.29.30133 (HKLM-x32\...\{295d1583-fdb9-414b-a4c8-da539362a26b}) (Version: 14.29.30133.0 - Microsoft Corporation)
Microsoft Visual C++ 2015-2019 Redistributable (x86) - 14.24.28127 (HKLM-x32\...\{e31cb1a4-76b5-46a5-a084-3fa419e82201}) (Version: 14.24.28127.4 - Microsoft Corporation)
Microsoft Visual C++ 2019 X64 Additional Runtime - 14.29.30133 (HKLM\...\{E699E009-1C3C-4E50-9B57-2B39F0954C7F}) (Version: 14.29.30133 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2019 X64 Minimum Runtime - 14.29.30133 (HKLM\...\{6CD9E9ED-906D-4196-8DC3-F987D2F6615F}) (Version: 14.29.30133 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2019 X86 Additional Runtime - 14.24.28127 (HKLM-x32\...\{EAC73207-74BD-4B13-AACF-8C0E751FA4E8}) (Version: 14.24.28127 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2019 X86 Minimum Runtime - 14.24.28127 (HKLM-x32\...\{2E72FA1F-BADB-4337-B8AE-F7C17EC57D1D}) (Version: 14.24.28127 - Microsoft Corporation) Hidden
Microsoft Visual Studio 2010 Shell (Integrated) - ENU (HKLM-x32\...\{012D26C3-E12A-3BDA-8ECE-DF14E721A507}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual Studio 2010 Shell (Isolated) - ENU (HKLM-x32\...\{D64B6984-242F-32BC-B008-752806E5FC44}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\{9495AEB4-AB97-39DE-8C42-806EEF75ECA7}) (Version: 10.0.50908 - Microsoft Corporation) Hidden
Microsoft Visual Studio 2010 Tools for Office Runtime (x64) (HKLM\...\Microsoft Visual Studio 2010 Tools for Office Runtime (x64)) (Version: 10.0.50903 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications Design-Time 3.0 (HKLM-x32\...\{5A03C202-08B4-3F1D-9A60-A4F53EF1B636}) (Version: 10.0.40220 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications x64 Runtime 3.0 (HKLM\...\{F14401A9-F0A0-33CC-8444-F60823A60DEB}) (Version: 10.0.40220 - Microsoft Corporation)
Microsoft Visual Studio Tools for Applications x86 Runtime 3.0 (HKLM-x32\...\{191A6F65-6878-398D-A272-EF011B80F371}) (Version: 10.0.40220 - Microsoft Corporation)
Microsoft VSS Writer for SQL Server 2012 (HKLM\...\{3E0DD83F-BE4C-4478-86A0-AD0D79D1353E}) (Version: 11.2.5058.0 - Microsoft Corporation)
Microsoft_VC80_ATL_x86 (HKLM-x32\...\{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}) (Version: 8.0.50727.4053 - Adobe) Hidden
Microsoft_VC80_ATL_x86_x64 (HKLM\...\{925D058B-564A-443A-B4B2-7E90C6432E55}) (Version: 8.0.50727.4053 - Adobe) Hidden
Microsoft_VC80_CRT_x86 (HKLM-x32\...\{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}) (Version: 8.0.50727.4053 - Adobe) Hidden
Microsoft_VC80_CRT_x86_x64 (HKLM\...\{4569AD91-47F4-4D9E-8FC9-717EC32D7AE1}) (Version: 8.0.50727.4053 - Adobe) Hidden
Microsoft_VC80_MFC_x86 (HKLM-x32\...\{D1A19B02-817E-4296-A45B-07853FD74D57}) (Version: 8.0.50727.4053 - Adobe) Hidden
Microsoft_VC80_MFC_x86_x64 (HKLM\...\{C8C1BAD5-54E6-4146-AD07-3A8AD36569C3}) (Version: 8.0.50727.4053 - Adobe) Hidden
Microsoft_VC80_MFCLOC_x86 (HKLM-x32\...\{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}) (Version: 8.0.50727.4053 - Adobe) Hidden
Microsoft_VC80_MFCLOC_x86_x64 (HKLM\...\{1E9FC118-651D-4934-97BE-E53CAE5C7D45}) (Version: 80.50727.4053 - Adobe) Hidden
Microsoft_VC90_ATL_x86 (HKLM-x32\...\{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}) (Version: 1.00.0000 - Adobe) Hidden
Microsoft_VC90_ATL_x86_x64 (HKLM\...\{8557397C-A42D-486F-97B3-A2CBC2372593}) (Version: 1.00.0000 - Adobe) Hidden
Microsoft_VC90_CRT_x86 (HKLM-x32\...\{08D2E121-7F6A-43EB-97FD-629B44903403}) (Version: 1.00.0000 - Adobe) Hidden
Microsoft_VC90_CRT_x86_x64 (HKLM\...\{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}) (Version: 1.00.0000 - Adobe) Hidden
Microsoft_VC90_MFC_x86 (HKLM-x32\...\{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}) (Version: 1.00.0000 - Adobe) Hidden
Microsoft_VC90_MFC_x86_x64 (HKLM\...\{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}) (Version: 1.00.0000 - Adobe) Hidden
Microsoft_VC90_MFCLOC_x86 (HKLM-x32\...\{B6D38690-755E-4F40-A35A-23F8BC2B86AC}) (Version: 1.00.0000 - Adobe) Hidden
Microsoft_VC90_MFCLOC_x86_x64 (HKLM\...\{90BF0360-A1DB-4599-A643-95AB90A52C1E}) (Version: 1.00.0000 - Adobe) Hidden
Mozilla Firefox (x64 en-GB) (HKLM\...\Mozilla Firefox 128.0.2 (x64 en-GB)) (Version: 128.0.2 - Mozilla)
Mozilla Maintenance Service (HKLM\...\MozillaMaintenanceService) (Version: 120.0.1 - Mozilla)
MUSTEK 1248UB V1.2 (HKLM-x32\...\{514C5488-192E-4C40-ACE5-CD28ECEED0E3}) (Version: 1.00.0000 - mustek) Hidden
MUSTEK 1248UB V1.2 (HKLM-x32\...\InstallShield_{514C5488-192E-4C40-ACE5-CD28ECEED0E3}) (Version: 1.00.0000 - mustek)
NirSoft Wireless Network Watcher (HKLM-x32\...\NirSoft Wireless Network Watcher) (Version: - )
NVIDIA PhysX System Software 9.23.1019 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.23.1019 - NVIDIA Corporation)
OpenAL (HKLM-x32\...\OpenAL) (Version: - )
Origin (HKLM-x32\...\Origin) (Version: 9.12.2.60376 - Electronic Arts, Inc.)
paint.net (HKLM\...\{A89BF790-0679-403A-9CC7-4015DBF4FEBA}) (Version: 5.0.13 - dotPDN LLC)
PC VGA Camer@ Plus (HKLM-x32\...\{A59AB961-BE82-41E0-B0FB-648DFA6DDEA4}) (Version: 1.0.0.19 - Aecotech)
PCSX2 - Playstation 2 Emulator (HKLM-x32\...\pcsx2) (Version: 1.6.0 - PCSX2 Team)
PDF Settings CS5 (HKLM-x32\...\{A78FE97A-C0C8-49CE-89D0-EDD524A17392}) (Version: 10.0 - Adobe Systems Incorporated) Hidden
Pegasun System Utilities (HKLM-x32\...\{BFDC3B26-7DB0-43D3-BC84-7E9649C157EA}_is1) (Version: 7.1 - Pegasun)
PixInsight Core for Windows (HKLM-x32\...\PCL64) (Version: - )
Prerequisites for SSDT (HKLM-x32\...\{9169C939-ED01-446A-BD0C-29873BAF4E48}) (Version: 11.0.2100.60 - Microsoft Corporation)
PrivaZer (HKLM-x32\...\PrivaZer) (Version: 4.0.90.0 - Goversoft LLC)
Qtracker (HKLM-x32\...\Qtracker) (Version: 4.92 - )
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 10.053.1001.2021 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.8036 - Realtek Semiconductor Corp.)
RegiStax 5 (HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\RegiStax 5) (Version: - )
RegiStax 6 (HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\RegiStax 6) (Version: - )
RegiStax 6.1.0.8 update (HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\RegiStax 6.1.0.8 update) (Version: - )
Samsung Magician (HKLM-x32\...\{29AE3F9F-7158-4ca7-B1ED-28A73ECDB215}_is1) (Version: 5.1.0.1120 - Samsung Electronics)
Samsung USB Driver for Mobile Phones (HKLM\...\{D0795B21-0CDA-4a92-AB9E-6E92D8111E44}) (Version: 1.7.43.0 - Samsung Electronics Co., Ltd.)
Secure Download Manager (HKLM-x32\...\{E040B65B-8683-4228-8C33-D44A141E40EA}) (Version: 3.1.60 - Kivuto Solutions Inc.)
Service Pack 2 for SQL Server 2012 (KB2958429) (64-bit) (HKLM\...\KB2958429) (Version: 11.2.5058.0 - Microsoft Corporation)
Shotcut (HKLM-x32\...\Shotcut) (Version: 20.04.12 - Meltytech, LLC)
SlimComputer (HKLM-x32\...\{80BDBB4C-163E-4F4B-9533-59A7ED62A695}) (Version: 1.1.4130 - )
Speccy (HKLM\...\Speccy) (Version: 1.32 - Piriform)
SQL Server 2012 Analysis Services (HKLM\...\{9674CB74-4808-4B59-B79D-9AB501F23279}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Analysis Services (HKLM\...\{FB1349FD-D102-4722-9F0A-2543670FF7FB}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 BI Development Studio (HKLM\...\{656E214E-B73F-458C-AD64-ED316F008207}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 BI Development Studio (HKLM\...\{EE1B54D1-BFBC-4C19-8D66-E0AF3E967896}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Client Tools (HKLM\...\{6B3840D6-4B8F-4E74-9202-9CE36DA94E99}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Client Tools (HKLM\...\{7842C220-6E9A-4D5A-AE70-0E138271F883}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Common Files (HKLM\...\{1D411379-9CE0-4B13-A19B-72D3222DD620}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Common Files (HKLM\...\{202AAF1F-69AA-442A-B59F-6B54B1AD07C6}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Data quality client (HKLM\...\{3C50A8F3-6BB8-44E8-9B8B-D3696561DF2E}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Data quality client (HKLM\...\{80162C08-0FA6-4656-9685-AD88C6527F0B}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Data quality service (HKLM\...\{1ABA92B0-CD1F-478B-A351-415F79B2A9E6}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Data quality service (HKLM\...\{38661DD1-576D-48CA-A188-F97819D5B5FB}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
SQL Server 2012 Database Engine Services (HKLM\...\{18B2A97C-92C3-4AC7-BE72-F823E0BC895B}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Database Engine Services (HKLM\...\{84FBCA4A-D650-4B0D-8094-EC0671FA9B91}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Database Engine Shared (HKLM\...\{54FF8FAB-DE27-4187-82F1-EBAE6AEE869A}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Database Engine Shared (HKLM\...\{6603C2CE-3C54-4F1D-92F9-8390CD4CCCA8}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Documentation Components (HKLM\...\{7272DF1C-2F88-43AC-A481-84DD67DF9746}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
SQL Server 2012 Documentation Components (HKLM\...\{B3192F55-2CE8-4C8E-9E40-D3B4998276B2}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
SQL Server 2012 Documentation Components (HKLM\...\{CECA0188-BD7A-43EF-B1F7-DDF719099C46}) (Version: 11.0.2100.60 - Microsoft Corporation) Hidden
SQL Server 2012 Full text search (HKLM\...\{34A7A77A-A23D-44ED-B3B6-EC8198BE2622}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Integration Services (HKLM\...\{22BCA430-2A68-4678-9824-184F3839948F}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Integration Services (HKLM\...\{36BF5D42-BF68-4E0C-A165-A4C6E9841F4A}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Management Studio (HKLM\...\{26BFF1F1-5C03-4C55-9C7C-FD65889AFA70}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Management Studio (HKLM\...\{A7037EB2-F953-4B12-B843-195F4D988DA1}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Reporting Services (HKLM\...\{DCCB1789-1DA0-4E3A-A52F-7815B602CC98}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 Reporting Services (HKLM\...\{FCD81E1A-6ED6-4F19-A572-82FFE102654E}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server 2012 SQL Data Quality Common (HKLM\...\{D307B5CF-D1F0-48A4-8DA3-54765F535208}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
SQL Server Browser for SQL Server 2012 (HKLM-x32\...\{4B9E6EB0-0EED-4E74-9479-F982C3254F71}) (Version: 11.2.5058.0 - Microsoft Corporation)
Sql Server Customer Experience Improvement Program (HKLM\...\{BED1EA3D-592D-4305-9D1F-20F03726EFC1}) (Version: 11.2.5058.0 - Microsoft Corporation) Hidden
Steam (HKLM-x32\...\{048298C9-A4D3-490B-9FF9-AB023A9238F3}) (Version: 1.0.0.0 - Valve Corporation)
swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: 12.0.0.1 - Adobe Systems, Inc) Hidden
TechPowerUp GPU-Z (HKLM-x32\...\TechPowerUp GPU-Z) (Version: - TechPowerUp)
TemWebRTCPlugin (HKLM-x32\...\{00A96020-0597-4602-9E6F-FDACD74483B4}) (Version: 0.8.902 - Temasys)
the Free Unix Spectrum Emulator (Fuse) 1.6.0 (HKLM-x32\...\Fuse) (Version: 1.6.0 - )
Toolkit Documentation (HKLM-x32\...\{563689A6-D95B-EA6D-665F-97959643E0DB}) (Version: 10.1.17134.1 - Microsoft) Hidden
Ubisoft Connect (HKLM-x32\...\Uplay) (Version: 154.1.11095 - Ubisoft)
UE4 Prerequisites (x64) (HKLM\...\{36EAD5CF-44EF-4FCF-8BE1-D96C4835D7A4}) (Version: 1.0.11.0 - Epic Games, Inc.) Hidden
UE4 Prerequisites (x64) (HKLM-x32\...\{2890ae6b-90e9-448d-b3e6-97e43c21e2fd}) (Version: 1.0.13.0 - Epic Games, Inc.) Hidden
UEV Tools on amd64 (HKLM\...\{45B55BB8-B09F-6204-E1A1-1443C81DCDA9}) (Version: 10.1.17134.1 - Microsoft) Hidden
Update for Windows 10 for x64-based Systems (KB5001716) (HKLM\...\{85C69797-7336-4E83-8D97-32A7C8465A3B}) (Version: 8.94.0.0 - Microsoft Corporation)
User State Migration Tool (HKLM-x32\...\{E224B062-6D80-A746-F08C-9847DF1B5144}) (Version: 10.1.17134.1 - Microsoft) Hidden
Visual Studio 2010 Prerequisites - English (HKLM\...\{662014D2-0450-37ED-ABAE-157C88127BEB}) (Version: 10.0.40219 - Microsoft Corporation)
Visual Studio C++ 10.0 Runtime (HKLM-x32\...\{4412F224-3849-4461-A3E9-DEEF8D252790}) (Version: 10.0.0 - TomTom International B.V.)
VLC media player (HKLM\...\VLC media player) (Version: 3.0.21 - VideoLAN)
VobSub v2.23 (Remove Only) (HKLM-x32\...\VobSub) (Version: - )
Windows Assessment and Deployment Kit - Windows 10 (HKLM-x32\...\{d794748d-72e9-45d7-9ab7-83d6c4c80f7f}) (Version: 10.1.17134.1 - Microsoft Corporation)
Windows Deployment Customizations (HKLM-x32\...\{A28EBA01-553B-4346-F8F2-E780592F0BB8}) (Version: 10.1.17134.1 - Microsoft) Hidden
Windows Deployment Tools (HKLM-x32\...\{C4443D4E-AC00-CF0E-9519-C9111E83ADBB}) (Version: 10.1.17134.1 - Microsoft) Hidden
Windows Driver Package - Google, Inc. (WinUSB) AndroidUsbDeviceClass (01/27/2014 9.0.0000.00000) (HKLM\...\9CA77E2A8332A0824C54DA611BBE4CA24AB1F750) (Version: 01/27/2014 9.0.0000.00000 - Google, Inc.)
Windows Live ID Sign-in Assistant (HKLM\...\{CE52672C-A0E9-4450-8875-88A221D5CD50}) (Version: 7.250.4311.0 - Microsoft Corporation) Hidden
Windows PE ARM ARM64 (HKLM-x32\...\{C80B2DA8-46D4-EFFC-8054-D2C663C468D7}) (Version: 10.1.17134.1 - Microsoft) Hidden
Windows PE ARM ARM64 wims (HKLM-x32\...\{1C15FC16-76B9-E297-905C-0A99FBC5DA1F}) (Version: 10.1.17134.1 - Microsoft) Hidden
Windows PE x86 x64 (HKLM-x32\...\{346FC109-E9A8-2224-5726-843C7283E4F7}) (Version: 10.1.17134.1 - Microsoft) Hidden
Windows PE x86 x64 wims (HKLM-x32\...\{64FF0563-D6F1-C8E4-56F8-F678D1158C58}) (Version: 10.1.17134.1 - Microsoft) Hidden
Windows System Image Manager on amd64 (HKLM-x32\...\{90D52AE3-4CAB-C97A-84D9-9DF0348BBDCA}) (Version: 10.1.17134.1 - Microsoft) Hidden
Winki (HKLM-x32\...\{81CF5153-38CF-41e2-AC3C-3D477C987D96}_is1) (Version: 3.2.123 - MSI)
WinRAR 7.01 (64-bit) (HKLM\...\WinRAR archiver) (Version: 7.01.0 - win.rar GmbH)
WP_CPTT_NT-x86-fre (HKLM-x32\...\{E6F4B9E6-6C5C-9EE0-1CEC-23F80B1960F5}) (Version: 10.1.17134.1 - Microsoft) Hidden
WPT Redistributables (HKLM-x32\...\{EEB65046-3AB2-821A-12BD-F0C0490D46D2}) (Version: 10.1.17134.1 - Microsoft) Hidden
WPTx64 (HKLM-x32\...\{C7B318E4-43EF-AA14-637F-6C6EDF59917D}) (Version: 10.1.17134.1 - Microsoft) Hidden
XviD MPEG4 Video Codec (remove only) (HKLM-x32\...\XviD MPEG4 Video Codec) (Version: - )
ZX-Paintbrush (HKLM-x32\...\{59EBF467-993A-48CC-98AE-34510EE8A1F0}) (Version: 2.4.0.1 - Claus Jahn)
Packages:
AMD Link -> C:\Program Files\WindowsApps\AdvancedMicroDevicesInc-2.AMDLink_10.23.30003.0_x64__0a9344xs7nr4m [2024-01-25] (Advanced Micro Devices Inc.)
DuckDuckGo -> C:\Program Files\WindowsApps\DuckDuckGo.DesktopBrowser_0.56.1.0_x64__ya2fgkz3nks94 [2023-11-05] (DuckDuckGo)
Microsoft Advertising SDK for XAML -> C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.1811.1.0_x64__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
Microsoft Advertising SDK for XAML -> C:\Program Files\WindowsApps\Microsoft.Advertising.Xaml_10.1811.1.0_x86__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
PDF X -> C:\Program Files\WindowsApps\6760NGPDFLab.PDFX_1.4.2.0_x64__sbe4t8mqwq93a [2024-07-17] (NG PDF Lab) [Startup Task]
Windows App Studio Installer -> C:\Program Files\WindowsApps\Microsoft.WindowsAppStudioInstaller_1.0.18.0_x86__8wekyb3d8bbwe [2023-01-28] (Microsoft Corporation) [MS Ad]
==================== Custom CLSID (Whitelisted): ==============
ContextMenuHandlers1: [PrivaZer] -> {7691BE2F-3D79-AADE-9C87-4D6EBCC76682} => C:\Program Files (x86)\PrivaZer\PrivaMenu6.dll [2024-07-20] (Goversoft LLC -> )
ContextMenuHandlers1: [WinRAR] -> {B41DB860-64E4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext.dll [2024-05-12] (win.rar GmbH -> Alexander Roshal)
ContextMenuHandlers1-x32: [WinRAR32] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext32.dll [2024-05-12] (win.rar GmbH -> Alexander Roshal)
ContextMenuHandlers2: [PrivaZer] -> {7691BE2F-3D79-AADE-9C87-4D6EBCC76682} => C:\Program Files (x86)\PrivaZer\PrivaMenu6.dll [2024-07-20] (Goversoft LLC -> )
ContextMenuHandlers3: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2023-09-02] (Malwarebytes Inc. -> Malwarebytes)
ContextMenuHandlers3: [PrivaZer] -> {7691BE2F-3D79-AADE-9C87-4D6EBCC76682} => C:\Program Files (x86)\PrivaZer\PrivaMenu6.dll [2024-07-20] (Goversoft LLC -> )
ContextMenuHandlers4: [PrivaZer] -> {7691BE2F-3D79-AADE-9C87-4D6EBCC76682} => C:\Program Files (x86)\PrivaZer\PrivaMenu6.dll [2024-07-20] (Goversoft LLC -> )
ContextMenuHandlers5: [ACE] -> {5E2121EE-0300-11D4-8D3B-444553540000} => C:\Program Files\AMD\CNext\CNext\atiacm64.dll [2022-11-30] (Advanced Micro Devices Inc. -> Advanced Micro Devices, Inc.)
ContextMenuHandlers6: [MBAMShlExt] -> {57CE581A-0CB6-4266-9CA0-19364C90A0B3} => C:\Program Files\Malwarebytes\Anti-Malware\mbshlext.dll [2023-09-02] (Malwarebytes Inc. -> Malwarebytes)
ContextMenuHandlers6: [PrivaZer] -> {7691BE2F-3D79-AADE-9C87-4D6EBCC76682} => C:\Program Files (x86)\PrivaZer\PrivaMenu6.dll [2024-07-20] (Goversoft LLC -> )
ContextMenuHandlers6: [WinRAR] -> {B41DB860-64E4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext.dll [2024-05-12] (win.rar GmbH -> Alexander Roshal)
ContextMenuHandlers6-x32: [WinRAR32] -> {B41DB860-8EE4-11D2-9906-E49FADC173CA} => C:\Program Files\WinRAR\rarext32.dll [2024-05-12] (win.rar GmbH -> Alexander Roshal)
==================== Codecs (Whitelisted) ====================
HKLM\...\Drivers32: [VIDC.FPS1] => C:\WINDOWS\system32\frapsv64.dll [105984 2015-09-05] (Beepa P/L) [File not signed]
HKLM\...\Drivers32: [VIDC.FPS1] => C:\Windows\SysWOW64\frapsvid.dll [94208 2015-09-05] (Beepa P/L) [File not signed]
HKLM\...\Drivers32: [vidc.XVID] => C:\Windows\SysWOW64\xvidvfw.dll [139264 2004-07-03] () [File not signed]
HKLM\...\Drivers32: [msacm.voxacm160] => C:\Windows\SysWOW64\vct3216.acm [82944 2003-05-22] (Voxware, Inc.) [File not signed]
HKLM\...\Drivers32: [msacm.scg726] => C:\Windows\SysWOW64\scg726.acm [13239 2000-03-14] (SHARP Corporation) [File not signed]
HKLM\...\Drivers32: [msacm.alf2cd] => C:\Windows\SysWOW64\alf2cd.acm [38912 2003-05-22] (NCT Company) [File not signed]
HKLM\...\Drivers32: [msacm.ac3acm] => C:\Windows\SysWOW64\AC3ACM.acm [81920 2004-02-04] (fccHandler) [File not signed]
HKLM\...\Drivers32: [msacm.lame] => C:\Windows\SysWOW64\lame.ax [245760 2005-08-01] () [File not signed]
HKLM\...\Drivers32: [vidc.dvsd] => C:\Windows\SysWOW64\mcdvd_32.dll [261632 2003-05-22] (MainConcept) [File not signed]
HKLM\...\Drivers32: [vidc.mpg4] => C:\Windows\SysWOW64\mpg4c32.dll [413760 2002-08-20] (Microsoft Corporation) [File not signed]
HKLM\...\Drivers32: [vidc.mp42] => C:\Windows\SysWOW64\mpg4c32.dll [413760 2002-08-20] (Microsoft Corporation) [File not signed]
HKLM\...\Drivers32: [vidc.mp43] => C:\Windows\SysWOW64\mpg4c32.dll [413760 2002-08-20] (Microsoft Corporation) [File not signed]
HKLM\...\Drivers32: [vidc.DIVX] => C:\Windows\SysWOW64\DivX.dll [638976 2003-05-22] (DivXNetworks, Inc.) [File not signed]
HKLM\...\Drivers32: [vidc.VP60] => C:\Windows\SysWOW64\vp6vfw.dll [438272 2004-12-10] (On2.com) [File not signed]
HKLM\...\Drivers32: [vidc.VP61] => C:\Windows\SysWOW64\vp6vfw.dll [438272 2004-12-10] (On2.com) [File not signed]
HKLM\...\Drivers32: [vidc.VP62] => C:\Windows\SysWOW64\vp6vfw.dll [438272 2004-12-10] (On2.com) [File not signed]
HKLM\...\Drivers32: [vidc.LAGS] => C:\Windows\SysWOW64\lagarith.dll [216064 2011-12-07] () [File not signed]
==================== Loaded Modules (Whitelisted) =============
2012-12-23 21:04 - 2012-03-26 18:12 - 000073728 ____R (Intel Corporation) [File not signed] C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.dll
2021-04-22 18:05 - 2021-04-22 18:05 - 000113664 _____ (Microsoft Corporation) [File not signed] C:\WINDOWS\WinSxS\amd64_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.6229_none_8a167c0b2edeae4c\ATL80.DLL
==================== Alternate Data Streams (Whitelisted) ========
==================== Safe Mode (Whitelisted) ==================
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MBAMService => ""="Service"
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MBAMService => ""="Service"
==================== Association (Whitelisted) =================
==================== Internet Explorer (Whitelisted) ==========
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = www.google.com
HKLM\Software\Microsoft\Internet Explorer\Main,Search Page =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page =
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL =
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL =
HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Local Page =
SearchScopes: HKLM-x32 -> DefaultScope value is missing
BHO-x32: Java(tm) Plug-In SSV Helper -> {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} -> C:\Program Files (x86)\Java\jre1.8.0_421\bin\ssv.dll [2024-06-05] (Oracle America, Inc. -> Oracle Corporation)
BHO-x32: Java(tm) Plug-In 2 SSV Helper -> {DBC80044-A445-435b-BC74-9C25C1C588A9} -> C:\Program Files (x86)\Java\jre1.8.0_421\bin\jp2ssv.dll [2024-06-05] (Oracle America, Inc. -> Oracle Corporation)
==================== Hosts content: =========================
2024-07-18 06:52 - 2024-07-18 06:52 - 000000027 _____ C:\WINDOWS\system32\drivers\etc\hosts
127.0.0.1 localhost
==================== Other Areas ===========================
HKLM\System\CurrentControlSet\Control\Session Manager\Environment\\Path -> C:\Program Files (x86)\Common Files\Oracle\Java\java8path;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\AMD\ATI.ACE\Core-Static;C:\adb;C:\Program Files\Microsoft SQL Server\110\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\110\Tools\Binn\ManagementStudio\;C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\PrivateAssemblies\;C:\Program Files (x86)\Microsoft SQL Server\110\DTS\Binn\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\ProgramData\chocolatey\bin;;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\Control Panel\Desktop\\Wallpaper -> c:\users\chredge\desktop\microsoft_nostalgic_windows_wallpaper_4k.jpg
HKU\S-1-5-80-1770670200-1234090253-3451813168-4041049723-2370973757\Control Panel\Desktop\\Wallpaper ->
HKU\S-1-5-80-2872255330-672591203-888807865-2791174282-1554802921\Control Panel\Desktop\\Wallpaper ->
HKU\S-1-5-80-2885764129-887777008-271615777-1616004480-2722851051\Control Panel\Desktop\\Wallpaper ->
HKU\S-1-5-80-3263513310-3392720605-1798839546-683002060-3227631582\Control Panel\Desktop\\Wallpaper ->
HKU\S-1-5-80-3880718306-3832830129-1677859214-2598158968-1052248003\Control Panel\Desktop\\Wallpaper ->
DNS Servers: 194.168.4.100 - 194.168.8.100
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer => (SmartScreenEnabled: RequireAdmin)
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\SOFTWARE\Microsoft\Windows\CurrentVersion\AppHost => (EnableWebContentEvaluation: 0)
HKLM\software\microsoft\Windows\CurrentVersion\Telephony\Providers => ProviderFileName2 -> ndptsp.tsp (No File)
Windows Firewall is enabled.
Network Binding:
Ethernet 6: Realtek PCIe GbE Family Controller #5 -> rt640x64.sys
netvsc_vfpp: Microsoft NetVsc Failover VF Protocol
MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^HP Button Manager.lnk => C:\Windows\pss\HP Button Manager.lnk.CommonStartup
MSCONFIG\startupfolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^What's my computer doing.lnk => C:\Windows\pss\What's my computer doing.lnk.CommonStartup
MSCONFIG\startupreg: AdobeAAMUpdater-1.0 => "C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA\UpdaterStartupUtility.exe"
MSCONFIG\startupreg: Chromium => "c:\users\chredge\appdata\local\chromium\application\chrome.exe" --auto-launch-at-startup --profile-directory="Default" --restore-last-session
MSCONFIG\startupreg: MicrosoftEdgeAutoLaunch_3B3BB905A374F1CF0D310AB30E4EDE63 => "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --no-startup-window --win-session-start
MSCONFIG\startupreg: SwitchBoard => C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
HKLM\...\StartupApproved\StartupFolder: => "Watch.lnk"
HKLM\...\StartupApproved\StartupFolder: => "What's my computer doing.lnk"
HKLM\...\StartupApproved\Run: => "SecurityHealth"
HKLM\...\StartupApproved\Run: => "SamsungRapidApp"
HKLM\...\StartupApproved\Run: => "AdobeAAMUpdater-1.0"
HKLM\...\StartupApproved\Run: => "Logitech Download Assistant"
HKLM\...\StartupApproved\Run: => "RtsCM"
HKLM\...\StartupApproved\Run32: => "cmsc"
HKLM\...\StartupApproved\Run32: => "AdobeCS5.5ServiceManager"
HKLM\...\StartupApproved\Run32: => "AdobeCS6ServiceManager"
HKLM\...\StartupApproved\Run32: => "CanonQuickMenu"
HKLM\...\StartupApproved\Run32: => "LogMeIn Hamachi Ui"
HKLM\...\StartupApproved\Run32: => "SwitchBoard"
HKLM\...\StartupApproved\Run32: => "Dropbox"
HKLM\...\StartupApproved\Run32: => "PlaysTV"
HKLM\...\StartupApproved\Run32: => "AdobeAAMUpdater-1.0"
HKLM\...\StartupApproved\Run32: => "RtsCM"
HKLM\...\StartupApproved\Run32: => "Adobe ARM"
HKLM\...\StartupApproved\Run32: => "Fitbit Connect"
HKLM\...\StartupApproved\Run32: => "Redirector"
HKLM\...\StartupApproved\Run32: => "ConnectionCenter"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\StartupFolder: => "Citrix Receiver.lnk"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "OneDrive"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "appnhost"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "TomTomHOME.exe"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "AdobeBridge"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "uTorrent"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "Chromium"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "EpicGamesLauncher"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "Fitbit Connect"
HKU\S-1-5-21-3466739526-2485095647-408758403-1009\...\StartupApproved\Run: => "vidnotifier.exe"
==================== FirewallRules (Whitelisted) ================
FirewallRules: [TCP Query User{849EF351-A635-432E-8D35-2D66FC52DA32}C:\program files (x86)\google\chrome\application\chrome.exe] => (Block) C:\program files (x86)\google\chrome\application\chrome.exe (Google LLC -> Google LLC)
FirewallRules: [UDP Query User{5BEE82EE-D4A7-458E-A5E7-688987E99607}C:\program files (x86)\google\chrome\application\chrome.exe] => (Block) C:\program files (x86)\google\chrome\application\chrome.exe (Google LLC -> Google LLC)
FirewallRules: [{75B0B5CF-AE3E-462A-B3FF-293CB364DA56}] => (Allow) C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (Google LLC -> Google LLC)
FirewallRules: [TCP Query User{5AFEFCB8-6834-4B97-BC95-BD9F04A7579D}C:\program files\mozilla firefox\firefox.exe] => (Allow) C:\program files\mozilla firefox\firefox.exe (Mozilla Corporation -> Mozilla Corporation)
FirewallRules: [UDP Query User{F73834E9-A1D3-4547-8F7C-7A7B9B649A68}C:\program files\mozilla firefox\firefox.exe] => (Allow) C:\program files\mozilla firefox\firefox.exe (Mozilla Corporation -> Mozilla Corporation)
FirewallRules: [{8BFCFB3F-2F53-4E20-9D71-42EE62DC539D}] => (Allow) C:\Program Files\Mozilla Firefox\firefox.exe (Mozilla Corporation -> Mozilla Corporation)
FirewallRules: [{D1FD8C05-80A3-4E3B-957F-08BF0D8ED7A4}] => (Allow) C:\Program Files\Mozilla Firefox\firefox.exe (Mozilla Corporation -> Mozilla Corporation)
17-07-2024 19:18:52 Scheduled Checkpoint
20-07-2024 21:52:46 20.07.2024
==================== Faulty Device Manager Devices ============
==================== Event log errors: ========================
Application errors:
Error: (07/27/2024 07:51:46 PM) (Source: Report Server Windows Service (MSSQLSERVER)) (EventID: 107) (User: )
Description: Report Server Windows Service (MSSQLSERVER) cannot connect to the report server database.
Error: (07/27/2024 07:51:46 PM) (Source: Report Server Windows Service (MSSQLSERVER)) (EventID: 113) (User: )
Description: The report server cannot create the Cache Flushes/Sec performance counter.
Description: The report server cannot create the Total Cache Flushes performance counter.
Description: The report server cannot create the Snapshot Updates/Sec performance counter.
Description: The report server cannot create the Total Snapshot Updates performance counter.
Description: The report server cannot create the Events/Sec performance counter.
Description: The report server cannot create the Total Events performance counter.
Description: The report server cannot create the Delivers/Sec performance counter.
System errors:
Error: (07/27/2024 07:51:10 PM) (Source: SNMP) (EventID: 1500) (User: )
Description: The SNMP Service encountered an error while accessing the registry key SYSTEM\CurrentControlSet\Services\SNMP\Parameters\TrapConfiguration.
Error: (07/27/2024 03:02:39 PM) (Source: SNMP) (EventID: 1500) (User: )
Error: (07/27/2024 03:02:12 PM) (Source: Service Control Manager) (EventID: 7000) (User: )
Description: The Windows Search service failed to start due to the following error:
The service did not start due to a logon failure.
Error: (07/27/2024 03:02:12 PM) (Source: Service Control Manager) (EventID: 7038) (User: )
Description: The WSearch service was unable to log on as NT AUTHORITY\SYSTEM with the currently configured password due to the following error:
The request is not supported.
To ensure that the service is configured properly, use the Services snap-in in Microsoft Management Console (MMC).
Error: (07/27/2024 03:02:09 PM) (Source: DCOM) (EventID: 10010) (User: MYSTERYMACHINE)
Description: The server {AB8902B4-09CA-4BB6-B78D-A8F59079A8D5} did not register with DCOM within the required timeout.
Error: (07/27/2024 03:01:42 PM) (Source: Service Control Manager) (EventID: 7034) (User: )
Description: The SQL Server Analysis Services (MSSQLSERVER) service terminated unexpectedly. It has done this 1 time(s).
Description: The SQL Full-text Filter Daemon Launcher (MSSQLSERVER) service terminated unexpectedly. It has done this 1 time(s).
Windows Defender:
Date: 2024-07-27 08:40:00
Description:
Microsoft Defender Antivirus scan has been stopped before completion.
Scan Type: Antimalware
Scan Parameters: Quick Scan
Date: 2024-07-27 08:24:46
Description:
Date: 2024-07-26 23:00:38
Description:
Date: 2024-07-20 22:25:00
Description:
BIOS: American Megatrends Inc. V2.4 06/19/2012
Motherboard: MSI Z77A-G41 (MS-7758)
Processor: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
Percentage of memory in use: 30%
Total physical RAM: 16332.88 MB
Available physical RAM: 11392.05 MB
Total Virtual: 32716.88 MB
Available Virtual: 26160.31 MB
Drive c: () (Fixed) (Total:465.26 GB) (Free:239.87 GB) (Model: Samsung SSD 850 EVO 500GB) NTFS ==>[drive with boot components (obtained from BCD)]
Drive f: (Storage1) (Fixed) (Total:465.75 GB) (Free:218.52 GB) (Model: Hitachi HDT721050SLA360) NTFS
\\?\Volume{03a9c944-0000-0000-0000-c05074000000}\ () (Fixed) (Total:0.5 GB) (Free:0.07 GB) NTFS
==================== MBR & Partition Table ====================
Disk: 0 (MBR Code: Windows 7/8/10) (Size: 465.8 GB) (Disk ID: 03A9C944)
Partition 1: (Active) - (Size=465.3 GB) - (Type=07 NTFS)
Partition 2: (Not Active) - (Size=511 MB) - (Type=27)
Disk: 1 (MBR Code: Windows 7/8/10) (Size: 465.8 GB) (Disk ID: 658D658D)
Partition 1: (Active) - (Size=465.8 GB) - (Type=07 NTFS)
==================== End of Addition.txt =======================
Are there anymore issues with your machine? Are you happy to clean up the tools and mark this as solved?
You can remove this file manaully from your machine, FRST is scripted to not remove it. C:\Program Files\Microsoft Security Client
I suggest this software. W10Privacy Click Here
Download KpRM Click Here
Save to Desktop
Check Delete Tools'
Check Delete Restore points.
Create Restore point.
Click delete quarantines.
Then click run.
I will mark this as solved. Tell a friend about us. :)
Reactions: Ginger-Overlord
