Solved Clean of malware
You posted the Adware cleaner log, I'd like the Malwarebytes log.
Also, a new hijack this log.
Then tell me if you are having anymore issues.
Is the machine running well now?
Your machine is clean... :thumbsup:
Glad to have helped!! Please tell a friend ...... or two about us.
Optimize your internet connection.
Click here for instructions.
suggest the following in place of adblock.
Alternate DNS Server. Ad Blocking DNS.
Ublock Origin.
Anti Ad Block Killer.
Also, keep your browsing private with these tools:
Self Destructing Cookies.
Self Destructing Cookies Chrome.
Some items to keep you safe on the internet.
VooDoo Shield. control of what is running on your machine
Qualys BrowserCheck
To update plugins.
Unchecky To Avoid Bundled Software.
Privazer To Clean up your mahcine.
Now Lets Clean up the tools we used and remove old restore points.
Download DelFix by "Xplode" to your Desktop.
Right Click the tool and Run as Admin ( Xp Users Double Click)
Put a check mark next the items below:
Remove disinfection tools
Create registry backup
Purge System Restore
Now click on "Run" button.
allow the program to complete its work.
all the tools we used will be removed.
Tool will create and open a log report (DelFix.txt)
Note: The report can be located at the following location C:\DelFix.txt
I most definitely will. I've been using the forum for years. Just up until they sold the site. Now I'm here.
Here is the mbam file:
Malwarebytes Anti-Malware
www.malwarebytes.org
Scan Date: 25/5/2017
Scan Time: 7:05 PM
Logfile: mbam.txt
Administrator: Yes
Version: 2.2.1.1043
Malware Database: v2017.05.25.08
Rootkit Database: v2017.04.02.01
License: Trial
Malware Protection: Enabled
Malicious Website Protection: Enabled
Self-protection: Disabled
OS: Windows 10
CPU: x64
File System: NTFS
User: Georgene
Scan Type: Custom Scan
Result: Completed
Objects Scanned: 623154
Time Elapsed: 15 hr, 30 min, 2 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Enabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
(No malicious items detected)
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 0
Folders: 0
Files: 0
Physical Sectors: 0
(end)
OK so long as everything is still running fine i think you are good to go.
Reactions: marioc89
