Solved BSOD when connecting to wifi
It looked like it worked initially; I was connected to the internet and was able to get my Discord to update, but my internet dropped and then it crashed again. The Discord startup was automatic after enabling all the startup options in the clean boot instructions.
Can you uninstall Discord to test, run the internet flush after uninstall check connection
This time I was able to connect and got a YouTube video started to verify if it worked. After maybe a minute or two, the PC froze and then blue screened.
Ok, are you still under a clean boot? If not make sure you are. Also upload fresh dump files. I think at this point it might just be best to get a new Wifi dongle and test, are you able to connect via your phones hotspot to the wifi ? Can you connect an ethernet cord?
Still getting blue screened after the clean boot. My hotspot isn't working because the second any wifi networks show up, a blue screen. An ethernet cable won't work cause my router is in another room, though it is in the adjacent room so I may just drill a hole through the wall.
I'll buy another dongle in the meantime and see if that fixes things. Will post back once it's confirmed whether my current dongle is the issue or not. Is there anything specific I should be looking for or just make sure it can handle the amount of speed my router puts out?
When you go shopping for one let them know your setup and the issue you are having. BestBuy or somewhere where someone will know something, I would not do walmart...
Reactions: Conroyale
I am kinda curious if there are any more drivers still on your machine associated with those VPN's .
Here is a little tool I have been working on.
It will search for drivers in common locations, and add their filepaths to a log on the desktop.
Download the attached program driver parse tool.
Unzip to your desktop.
Right Click run as admin.
Drag and drop the Driverlist,txt onto the small rectangular window in the tool.
Click Process files.
A new file named drivers.txt will appear on the desktop.
Attach it here.
I got a new wifi dongle and it worked fine immediately. Again, things may get messed up later on as it did with the previous dongle, but I will post in case that happens. Would you like me to still try this last step?
Nevermind, hate to jump the gun Early but I definitely did. Just got yet another blue screen. I'll try that latest step you posted.
Ok, lets see the log. If you are unable to drag and drop just post the initial log Driverlist.txt.
Non MS Drivers installed. In Orange are your phone drivers you mentioned earlier.
Green your old Wifi Dongle
Yellow is VPN software.
C:\Windows\System32\drivers\ovpn-dco.sys
C:\Windows\System32\drivers\rtwlanu.sys
C:\Windows\System32\drivers\ss_conn_usb_driver2.sys
C:\Windows\System32\drivers\ssudbus2.sys
C:\Windows\System32\drivers\ssudmdm.sys
C:\Windows\System32\drivers\ssudqcfilter.sys
C:\Windows\System32\drivers\wireguard.sys
As a test can you just delete all of these? starting with yellow. run the batch file to reboot.
Then green items then run the batch file to reboot. run the batch file to reboot.
If the issue persist then do the orange. run the batch file to reboot.
You're meaning the Flush.bat file, correct?
Sorry, just realized that's the old driver list. Let me get you an updated one.
I have to run for a few. I’ll check this when I get home.
I updated this tool to search in more areas for drivers.
Download this one.
Right Click Run as admin.
Click get Drivers list.
Also in the zip file I am uploading, PCHF Log tool.
Right click run as admin.
Click Gather logs.
A new file named PCHF.txt will be on the desktop.
Attach that here, the tool will automatically zip up your dump files onto the desktop as well.
Attached are the PCHF.txt, the drivers list, and the minidump zip file.
Code:
Malnutrion's PCHF Log-Tool (x64) Log Collector https://pchelpforum.net/
Ran by conno (administrator) on DESKTOP-JHC3JGK at 2024-09-14 14:58:12
Running from:
System Information:
Operating System: Microsoft Windows 10 Home Version 10.0.19045 (True)
Architecture: 64-bit
Processor: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz (8 Cores, 16 Logical Processors)
Installed RAM: 31.92 GB
Available RAM: 28.81 GB
BIOS Version: 2.30
Serial Number: Default string
Manufacturer: Micro-Star International Co., Ltd.
Model: MS-7C75
IP Configuration:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-JHC3JGK
   Primary Dns Suffix  . . . . . . . :
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe 2.5GbE Family Controller
   Physical Address. . . . . . . . . : 2C-F0-5D-A4-14-61
Running services and their registry name and file path:
Application Information                                                 | Appinfo                          | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
AppX Deployment Service (AppXSVC)                                       | AppXSvc                          | C:\WINDOWS\system32\svchost.exe -k wsappx -p
Windows Audio Endpoint Builder                                          | AudioEndpointBuilder             | C:\WINDOWS\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Windows Audio                                                           | Audiosrv                         | C:\WINDOWS\System32\svchost.exe -k LocalServiceNetworkRestricted -p
Base Filtering Engine                                                   | BFE                              | C:\WINDOWS\system32\svchost.exe -k LocalServiceNoNetworkFirewall -p
Background Intelligent Transfer Service                                 | BITS                             | C:\WINDOWS\System32\svchost.exe -k netsvcs -p
Background Tasks Infrastructure Service                                 | BrokerInfrastructure             | C:\WINDOWS\system32\svchost.exe -k DcomLaunch -p
AVCTP service                                                           | BthAvctpSvc                      | C:\WINDOWS\system32\svchost.exe -k LocalService -p
Capability Access Manager Service                                       | camsvc                           | C:\WINDOWS\system32\svchost.exe -k appmodel -p
Connected Devices Platform Service                                      | CDPSvc                           | C:\WINDOWS\system32\svchost.exe -k LocalService -p
CoreMessaging                                                           | CoreMessagingRegistrar           | C:\WINDOWS\system32\svchost.exe -k LocalServiceNoNetwork -p
Cryptographic Services                                                  | CryptSvc                         | C:\WINDOWS\system32\svchost.exe -k NetworkService -p
DCOM Server Process Launcher                                            | DcomLaunch                       | C:\WINDOWS\system32\svchost.exe -k DcomLaunch -p
Device Association Service                                              | DeviceAssociationService         | C:\WINDOWS\system32\svchost.exe -k LocalSystemNetworkRestricted -p
DHCP Client                                                             | Dhcp                             | C:\WINDOWS\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Connected User Experiences and Telemetry                                | DiagTrack                        | C:\WINDOWS\System32\svchost.exe -k utcsvc -p
Display Policy Service                                                  | DispBrokerDesktopSvc             | C:\WINDOWS\system32\svchost.exe -k LocalService -p
DNS Client                                                              | Dnscache                         | C:\WINDOWS\system32\svchost.exe -k NetworkService -p
Delivery Optimization                                                   | DoSvc                            | C:\WINDOWS\System32\svchost.exe -k NetworkService -p
Diagnostic Policy Service                                               | DPS                              | C:\WINDOWS\System32\svchost.exe -k LocalServiceNoNetwork -p
Device Setup Manager                                                    | DsmSvc                           | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Data Sharing Service                                                    | DsSvc                            | C:\WINDOWS\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Data Usage                                                              | DusmSvc                          | C:\WINDOWS\System32\svchost.exe -k LocalServiceNetworkRestricted -p
Windows Event Log                                                       | EventLog                         | C:\WINDOWS\System32\svchost.exe -k LocalServiceNetworkRestricted -p
COM+ Event System                                                       | EventSystem                      | C:\WINDOWS\system32\svchost.exe -k LocalService -p
Everything                                                              | Everything                       | "C:\Program Files (x86)\Everything\Everything.exe" -svc
Windows Font Cache Service                                              | FontCache                        | C:\WINDOWS\system32\svchost.exe -k LocalService -p
Human Interface Device Service                                          | hidserv                          | C:\WINDOWS\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Microsoft Store Install Service                                         | InstallService                   | C:\WINDOWS\System32\svchost.exe -k netsvcs -p
IP Helper                                                               | iphlpsvc                         | C:\WINDOWS\System32\svchost.exe -k NetSvcs -p
Intel(R) Dynamic Application Loader Host Interface Service              | jhi_service                      | C:\WINDOWS\System32\DriverStore\FileRepository\dal.inf_amd64_af50fdb80983f7bc\jhi_service.exe
CNG Key Isolation                                                       | KeyIso                           | C:\WINDOWS\system32\lsass.exe
Server        | LanmanServer                     | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Workstation                                                             | LanmanWorkstation                | C:\WINDOWS\System32\svchost.exe -k NetworkService -p
Geolocation Service                                                     | lfsvc                            | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Intel(R) Management and Security Application Local Management Service   | LMS                              | C:\WINDOWS\System32\DriverStore\FileRepository\lms.inf_amd64_a55aa2cd52a3429d\LMS.exe
Local Session Manager                                                   | LSM                              | C:\WINDOWS\system32\svchost.exe -k DcomLaunch -p
Microsoft Defender Core Service                                         | MDCoreSvc                        | "C:\ProgramData\Microsoft\Windows Defender\platform\4.18.24070.5-0\MpDefenderCoreService.exe"
Windows Defender Firewall                                               | mpssvc                           | C:\WINDOWS\system32\svchost.exe -k LocalServiceNoNetworkFirewall -p
Network Connection Broker                                               | NcbService                       | C:\WINDOWS\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Network Connections                                                     | Netman                           | C:\WINDOWS\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Network List Service                                                    | netprofm                         | C:\WINDOWS\System32\svchost.exe -k LocalService -p
Microsoft Passport Container                                            | NgcCtnrSvc                       | C:\WINDOWS\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Microsoft Passport                                                      | NgcSvc                           | C:\WINDOWS\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Network Location Awareness                                              | NlaSvc                           | C:\WINDOWS\System32\svchost.exe -k NetworkService -p
Network Store Interface Service                                         | nsi                              | C:\WINDOWS\system32\svchost.exe -k LocalService -p
NVIDIA Display Container LS                                             | NVDisplay.ContainerLocalSystem   | C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_7e5fd280efaa5445\Display.NvContainer\NVDisplay.Container.exe -s NVDisplay.ContainerLocalSystem -f C:\ProgramData\NVIDIA\NVDisplay.ContainerLocalSystem.log -l 3 -d C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_7e5fd280efaa5445\Display.NvContainer\plugins\LocalSystem -r -p 30000 -cfg NVDisplay.ContainerLocalSystem\LocalSystem
Program Compatibility Assistant Service                                 | PcaSvc                           | C:\WINDOWS\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Plug and Play                                                           | PlugPlay                         | C:\WINDOWS\system32\svchost.exe -k DcomLaunch -p
Power        | Power                            | C:\WINDOWS\system32\svchost.exe -k DcomLaunch -p
User Profile Service                                                    | ProfSvc                          | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Remote Access Connection Manager                                        | RasMan                           | C:\WINDOWS\System32\svchost.exe -k netsvcs
Radio Management Service                                                | RmSvc                            | C:\WINDOWS\System32\svchost.exe -k LocalServiceNetworkRestricted
RPC Endpoint Mapper                                                     | RpcEptMapper                     | C:\WINDOWS\system32\svchost.exe -k RPCSS -p
Remote Procedure Call (RPC)                                             | RpcSs                            | C:\WINDOWS\system32\svchost.exe -k rpcss -p
Realtek Audio Universal Service                                         | RtkAudioUniversalService         | "C:\WINDOWS\System32\DriverStore\FileRepository\realtekservice.inf_amd64_550508a90a3c9a47\RtkAudUService64.exe"
Security Accounts Manager                                               | SamSs                            | C:\WINDOWS\system32\lsass.exe
Task Scheduler                                                          | Schedule                         | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Windows Security Service                                                | SecurityHealthService            | C:\WINDOWS\system32\SecurityHealthService.exe
System Event Notification Service                                       | SENS                             | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
System Guard Runtime Monitor Broker                                     | SgrmBroker                       | C:\WINDOWS\system32\SgrmBroker.exe
Shell Hardware Detection                                                | ShellHWDetection                 | C:\WINDOWS\System32\svchost.exe -k netsvcs -p
Print Spooler                                                           | Spooler                          | C:\WINDOWS\System32\spoolsv.exe
SSDP Discovery                                                          | SSDPSRV                          | C:\WINDOWS\system32\svchost.exe -k LocalServiceAndNoImpersonation -p
Secure Socket Tunneling Protocol Service                                | SstpSvc                          | C:\WINDOWS\system32\svchost.exe -k LocalService -p
State Repository Service                                                | StateRepository                  | C:\WINDOWS\system32\svchost.exe -k appmodel -p
Windows Image Acquisition (WIA)                                         | StiSvc                           | C:\WINDOWS\system32\svchost.exe -k imgsvc
Storage Service                                                         | StorSvc                          | C:\WINDOWS\System32\svchost.exe -k LocalSystemNetworkRestricted -p
SysMain        | SysMain                          | C:\WINDOWS\system32\svchost.exe -k LocalSystemNetworkRestricted -p
System Events Broker                                                    | SystemEventsBroker               | C:\WINDOWS\system32\svchost.exe -k DcomLaunch -p
Touch Keyboard and Handwriting Panel Service                            | TabletInputService               | C:\WINDOWS\System32\svchost.exe -k LocalSystemNetworkRestricted -p
Telephony                                                               | TapiSrv                          | C:\WINDOWS\System32\svchost.exe -k NetworkService -p
Themes        | Themes                           | C:\WINDOWS\System32\svchost.exe -k netsvcs -p
Time Broker                                                             | TimeBrokerSvc                    | C:\WINDOWS\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Web Account Manager                                                     | TokenBroker                      | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Distributed Link Tracking Client                                        | TrkWks                           | C:\WINDOWS\System32\svchost.exe -k LocalSystemNetworkRestricted -p
User Manager                                                            | UserManager                      | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Update Orchestrator Service                                             | UsoSvc                           | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Credential Manager                                                      | VaultSvc                         | C:\WINDOWS\system32\lsass.exe
Windows Connection Manager                                              | Wcmsvc                           | C:\WINDOWS\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Diagnostic Service Host                                                 | WdiServiceHost                   | C:\WINDOWS\System32\svchost.exe -k LocalService -p
Microsoft Defender Antivirus Network Inspection Service                 | WdNisSvc                         | "C:\ProgramData\Microsoft\Windows Defender\platform\4.18.24070.5-0\NisSrv.exe"
Microsoft Defender Antivirus Service                                    | WinDefend                        | "C:\ProgramData\Microsoft\Windows Defender\platform\4.18.24070.5-0\MsMpEng.exe"
WinHTTP Web Proxy Auto-Discovery Service                                | WinHttpAutoProxySvc              | C:\WINDOWS\system32\svchost.exe -k LocalServiceNetworkRestricted -p
Windows Management Instrumentation                                      | Winmgmt                          | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
WLAN AutoConfig                                                         | WlanSvc                          | C:\WINDOWS\system32\svchost.exe -k LocalSystemNetworkRestricted -p
Portable Device Enumerator Service                                      | WPDBusEnum                       | C:\WINDOWS\system32\svchost.exe -k LocalSystemNetworkRestricted
Windows Push Notifications System Service                               | WpnService                       | C:\WINDOWS\system32\svchost.exe -k netsvcs -p
Security Center                                                         | wscsvc                           | C:\WINDOWS\System32\svchost.exe -k LocalServiceNetworkRestricted -p
Windows Search                                                          | WSearch                          | C:\WINDOWS\system32\SearchIndexer.exe /Embedding
Clipboard User Service_8c5e1                                            | cbdhsvc_8c5e1                    | C:\WINDOWS\system32\svchost.exe -k ClipboardSvcGroup -p
Connected Devices Platform User Service_8c5e1                           | CDPUserSvc_8c5e1                 | C:\WINDOWS\system32\svchost.exe -k UnistackSvcGroup
Sync Host_8c5e1                                                         | OneSyncSvc_8c5e1                 | C:\WINDOWS\system32\svchost.exe -k UnistackSvcGroup
Windows Push Notifications User Service_8c5e1                           | WpnUserService_8c5e1             | C:\WINDOWS\system32\svchost.exe -k UnistackSvcGroup
Running Processes and their appended file path:
AggregatorHost             - C:\WINDOWS\System32\AggregatorHost.exe
ApplicationFrameHost       - C:\WINDOWS\system32\ApplicationFrameHost.exe
audiodg                    - C:\WINDOWS\system32\AUDIODG.EXE
BraveCrashHandler          - C:\Program Files (x86)\BraveSoftware\Update\1.3.361.151\BraveCrashHandler.exe
BraveCrashHandler64        - C:\Program Files (x86)\BraveSoftware\Update\1.3.361.151\BraveCrashHandler64.exe
CompPkgSrv                 - C:\Windows\System32\CompPkgSrv.exe
conhost                    - C:\WINDOWS\system32\conhost.exe
ctfmon                     - C:\WINDOWS\system32\ctfmon.exe
dasHost                    - C:\WINDOWS\system32\dashost.exe
dllhost                    - C:\WINDOWS\system32\DllHost.exe
dwm                        - C:\WINDOWS\system32\dwm.exe
Everything                 - C:\Program Files (x86)\Everything\Everything.exe
explorer                   - C:\WINDOWS\Explorer.EXE
fontdrvhost                - C:\WINDOWS\system32\fontdrvhost.exe
jhi_service                - C:\WINDOWS\System32\DriverStore\FileRepository\dal.inf_amd64_af50fdb80983f7bc\jhi_service.exe
LMS                        - C:\WINDOWS\System32\DriverStore\FileRepository\lms.inf_amd64_a55aa2cd52a3429d\LMS.exe
LockApp                    - C:\Windows\SystemApps\Microsoft.LockApp_cw5n1h2txyewy\LockApp.exe
lsass                      - C:\WINDOWS\system32\lsass.exe
MicrosoftEdgeUpdate        - C:\Program Files (x86)\Microsoft\EdgeUpdate\MicrosoftEdgeUpdate.exe
NonMsdriverFinder          - C:\Users\conno\Desktop\LogTools\NonMsdriverFinder.exe
NVDisplay.Container        - C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_7e5fd280efaa5445\Display.NvContainer\NVDisplay.Container.exe
PCHF-LogTool               - C:\Users\conno\Desktop\LogTools\PCHF-LogTool.exe
PhoneExperienceHost        - C:\Program Files\WindowsApps\Microsoft.YourPhone_1.24081.95.0_x64__8wekyb3d8bbwe\PhoneExperienceHost.exe
RtkAudUService64           - C:\WINDOWS\System32\DriverStore\FileRepository\realtekservice.inf_amd64_550508a90a3c9a47\RtkAudUService64.exe
RuntimeBroker              - C:\Windows\System32\RuntimeBroker.exe
SearchApp                  - C:\Windows\SystemApps\Microsoft.Windows.Search_cw5n1h2txyewy\SearchApp.exe
SearchFilterHost           - C:\WINDOWS\system32\SearchFilterHost.exe
SearchIndexer              - C:\WINDOWS\system32\SearchIndexer.exe
SearchProtocolHost         - C:\WINDOWS\system32\SearchProtocolHost.exe
ShellExperienceHost        - C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
sihost                     - C:\WINDOWS\system32\sihost.exe
smartscreen                - C:\Windows\System32\smartscreen.exe
spoolsv                    - C:\WINDOWS\System32\spoolsv.exe
StartMenuExperienceHost    - C:\Windows\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\StartMenuExperienceHost.exe
svchost                    - C:\WINDOWS\system32\svchost.exe
svchost                    - C:\WINDOWS\System32\svchost.exe
SystemSettings             - C:\Windows\ImmersiveControlPanel\SystemSettings.exe
taskhostw                  - C:\WINDOWS\system32\taskhostw.exe
TextInputHost              - C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\TextInputHost.exe
winlogon                   - C:\WINDOWS\system32\winlogon.exe
WmiPrvSE                   - C:\WINDOWS\system32\wbem\wmiprvse.exe
Non-Microsoft scheduled tasks:
Task: {BraveSoftwareUpdateTaskMachineCore{C74852F6-7B9A-46BB-9FB4-E5A9367C4A61}} - \ => "C:\Program Files (x86)\BraveSoftware\Update\BraveUpdate.exe" [File not found]
Task: {BraveSoftwareUpdateTaskMachineUA{FF6D724C-005B-47CB-BBB5-0E3F915326A8}} - \ => "C:\Program Files (x86)\BraveSoftware\Update\BraveUpdate.exe" [File not found]
Task: {Intel PTT EK Recertification} - \ => "C:\WINDOWS\System32\DriverStore\FileRepository\iclsclient.inf_amd64_fc84dfa25a6a7727\lib\IntelPTTEKRecertification.exe" [File not found]
Task: {MicrosoftEdgeUpdateTaskMachineCore1db01647a0ed4e6} - \ => C:\Program Files (x86)\Microsoft\EdgeUpdate\MicrosoftEdgeUpdate.exe [214952 2021-08-05] (Microsoft Corporation -> Microsoft Edge Update)
Task: {MicrosoftEdgeUpdateTaskMachineUA} - \ => C:\Program Files (x86)\Microsoft\EdgeUpdate\MicrosoftEdgeUpdate.exe [214952 2021-08-05] (Microsoft Corporation -> Microsoft Edge Update)
Startup items from the Run key:
RtkAudUService : "C:\WINDOWS\System32\DriverStore\FileRepository\realtekservice.inf_amd64_550508a90a3c9a47\RtkAudUService64.exe" -background
SecurityHealth : C:\WINDOWS\system32\SecurityHealthSystray.exe
Everything : "C:\Program Files (x86)\Everything\Everything.exe" -startup
UnlockerAssistant : "C:\Program Files (x86)\Unlocker\UnlockerAssistant.exe"
Discord : "C:\Users\conno\AppData\Local\Discord\Update.exe" --processStart Discord.exe
MicrosoftEdgeAutoLaunch_2BCB2C431A8904C9B246BCA687FD7439 : "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --no-startup-window --win-session-start
Steam : "C:\Program Files (x86)\Steam\steam.exe" -silent
Last ten event viewer logs:
09/14/2024 14:57:20 - Microsoft-Windows-Kernel-General - The description for Event ID '16' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'158', '\??\C:\ProgramData\Packages\Microsoft.SkypeApp_kzf8qxf38zg5c\S-1-5-21-590284765-1197234112-77054777-1001\SystemAppData\Helium\Cache\62234312e55d8e77_COM15.dat', '1', '1'
09/14/2024 14:57:20 - Microsoft-Windows-Kernel-General - The description for Event ID '16' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'111', '\??\C:\Users\conno\AppData\Local\Packages\Microsoft.SkypeApp_kzf8qxf38zg5c\SystemAppData\Helium\UserClasses.dat', '1', '1'
09/14/2024 14:57:20 - Microsoft-Windows-Kernel-General - The description for Event ID '16' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'104', '\??\C:\Users\conno\AppData\Local\Packages\Microsoft.SkypeApp_kzf8qxf38zg5c\SystemAppData\Helium\User.dat', '7', '1'
09/14/2024 14:55:59 - Microsoft-Windows-Power-Troubleshooter - The system has returned from a low power state.
Sleep Time: 2024-09-14T06:55:01.8677022Z
Wake Time: 2024-09-14T20:55:58.8234048Z
Wake Source: 1
09/14/2024 14:55:59 - Microsoft-Windows-Kernel-General - The description for Event ID '16' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'104', '\??\C:\Users\conno\AppData\Local\Packages\Microsoft.AAD.BrokerPlugin_cw5n1h2txyewy\Settings\settings.dat', '5', '1'
09/14/2024 14:55:58 - Service Control Manager - The start type of the Background Intelligent Transfer Service service was changed from demand start to auto start.
09/14/2024 14:55:58 - Microsoft-Windows-Kernel-General - The description for Event ID '16' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'118', '\??\C:\Users\conno\AppData\Local\Packages\Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy\Settings\settings.dat', '286', '28'
09/14/2024 14:55:58 - Microsoft-Windows-Kernel-General - The description for Event ID '16' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'46', '\Device\HarddiskVolume3\EFI\Microsoft\Boot\BCD', '128', '8'
09/14/2024 14:55:57 - Microsoft-Windows-Kernel-General - The description for Event ID '16' in Source 'Microsoft-Windows-Kernel-General' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'95', '\??\C:\Users\conno\AppData\Local\Packages\Microsoft.LockApp_cw5n1h2txyewy\Settings\settings.dat', '3', '1'
09/14/2024 14:55:57 - Microsoft-Windows-EnhancedStorage-EhStorTcgDrv - The following informational event has occurred (0x0, 0x4, 0x0, 0x0).
D0Entry
Installed apps:
Installed programs in alphabetical order, and their uninstall command:
Brave [128.1.69.168] [20240913]-->"C:\Program Files\BraveSoftware\Brave-Browser\Application\128.1.69.168\Installer\setup.exe" --uninstall --system-level
Everything 1.4.1.1026 (x86) [1.4.1.1026] []-->C:\Program Files (x86)\Everything\Uninstall.exe
FileASSASSIN [1.06] []-->C:\Program Files (x86)\FileASSASSIN\uninst.exe
Microsoft Edge [128.0.2739.79] [20240913]-->"C:\Program Files (x86)\Microsoft\Edge\Application\128.0.2739.79\Installer\setup.exe" --uninstall --msedge --channel=stable --system-level --verbose-logging
Microsoft Edge Update [1.3.195.19] []-->
Microsoft Edge WebView2 Runtime [128.0.2739.79] [20240913]-->"C:\Program Files (x86)\Microsoft\EdgeWebView\Application\128.0.2739.79\Installer\setup.exe" --uninstall --msedgewebview --system-level --verbose-logging
Microsoft Visual C++ 2010  x86 Redistributable - 10.0.40219 [10.0.40219] [20240907]-->MsiExec.exe /X{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 [11.0.61030.0] []-->"C:\ProgramData\Package Cache\{ca67548a-5ebe-413a-b50c-4b9ceb6d66c6}\vcredist_x64.exe"  /uninstall
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 [11.0.61030.0] []-->"C:\ProgramData\Package Cache\{33d1fd90-4274-48a1-9bc1-97e33d9c2d6f}\vcredist_x86.exe"  /uninstall
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 [11.0.61030] [20240907]-->MsiExec.exe /X{B175520C-86A2-35A7-8619-86DC379688B9}
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 [11.0.61030] [20240907]-->MsiExec.exe /X{BD95A8CD-1D9F-35AD-981A-3E7925026EBB}
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.30501 [12.0.30501.0] []-->"C:\ProgramData\Package Cache\{050d4fc8-5d48-4b8f-8972-47c82c46020f}\vcredist_x64.exe"  /uninstall
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.30501 [12.0.30501.0] []-->"C:\ProgramData\Package Cache\{f65db027-aff3-4070-886a-0d87064aabb1}\vcredist_x86.exe"  /uninstall
Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.21005 [12.0.21005] [20240907]-->MsiExec.exe /X{F8CFEB22-A2E7-3971-9EDA-4B11EDEFC185}
Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.21005 [12.0.21005] [20240907]-->MsiExec.exe /X{13A4EE12-23EA-3371-91EE-EFB36DDFFF3E}
Microsoft Visual C++ 2015-2022 Redistributable (x64) - 14.40.33810 [14.40.33810.0] []-->"C:\ProgramData\Package Cache\{5af95fd8-a22e-458f-acee-c61bd787178e}\VC_redist.x64.exe"  /uninstall
Microsoft Visual C++ 2017 Redistributable (x86) - 14.10.25008 [14.10.25008.0] []-->"C:\ProgramData\Package Cache\{c239cea1-d49e-4e16-8e87-8c055765f7ec}\VC_redist.x86.exe"  /uninstall
Microsoft Visual C++ 2017 x86 Additional Runtime - 14.10.25008 [14.10.25008] [20240907]-->MsiExec.exe /X{E6222D59-608C-3018-B86B-69BD241ACDE5}
Microsoft Visual C++ 2017 x86 Minimum Runtime - 14.10.25008 [14.10.25008] [20240907]-->MsiExec.exe /X{C6CDA568-CD91-3CA0-9EDE-DAD98A13D6E1}
Steam [2.10.91.91] []-->C:\Program Files (x86)\Steam\uninstall.exe
Unlocker 1.8.5 [1.8.5] []-->C:\Program Files (x86)\Unlocker\uninst.exe
Last ten system errors:
09/13/2024 22:27:38 - Microsoft-Windows-TPM-WMI - The Secure Boot update failed to update a Secure Boot variable with error -2147020471. For more information, please see https://go.microsoft.com/fwlink/?linkid=2169931
09/13/2024 22:27:36 - BugCheck - The description for Event ID '1073742825' in Source 'BugCheck' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'0x00000133 (0x0000000000000000, 0x0000000000000501, 0x0000000000000500, 0xfffff8066aefb320)', 'C:\WINDOWS\Minidump\091324-5609-01.dmp', '21155869-0626-477d-8f41-7e5e082b563b'
09/13/2024 22:27:35 - EventLog - The previous system shutdown at 10:25:34 PM on ‎9/‎13/‎2024 was unexpected.
09/13/2024 22:25:37 - Microsoft-Windows-TPM-WMI - The Secure Boot update failed to update a Secure Boot variable with error -2147020471. For more information, please see https://go.microsoft.com/fwlink/?linkid=2169931
09/13/2024 22:25:34 - BugCheck - The description for Event ID '1073742825' in Source 'BugCheck' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'0x00000133 (0x0000000000000000, 0x0000000000000501, 0x0000000000000500, 0xfffff80181afb320)', 'C:\WINDOWS\Minidump\091324-5500-01.dmp', '79e4eb17-64fe-4183-8adf-52d32eff3861'
09/13/2024 22:25:34 - EventLog - The previous system shutdown at 10:24:15 PM on ‎9/‎13/‎2024 was unexpected.
09/13/2024 22:24:18 - Microsoft-Windows-TPM-WMI - The Secure Boot update failed to update a Secure Boot variable with error -2147020471. For more information, please see https://go.microsoft.com/fwlink/?linkid=2169931
09/13/2024 22:24:15 - BugCheck - The description for Event ID '1073742825' in Source 'BugCheck' cannot be found.  The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them.  The following information is part of the event:'0x00000133 (0x0000000000000000, 0x0000000000000501, 0x0000000000000500, 0xfffff80668afb320)', 'C:\WINDOWS\Minidump\091324-5250-01.dmp', '98968efd-baf6-4713-b3c8-93a6fae2340e'
09/13/2024 22:24:15 - EventLog - The previous system shutdown at 4:52:43 AM on ‎9/‎12/‎2024 was unexpected.
09/13/2024 22:16:58 - Service Control Manager - The Steam Client Service service failed to start due to the following error:
%%1053
Zipping minidump files:
Still this driver to blame, since you have a new Wifi adapter.
Delete:
You may need to boot to safe mode to delete.
After you delete, then run this batch:
Code:
@Echo on
pushd\windows\system32\drivers\etc
attrib -h -s -r hosts
echo 127.0.0.1 localhost>HOSTS
attrib +r +h +s hosts
popd
ipconfig /release
ipconfig /renew
ipconfig /flushdns
netsh winsock reset all
netsh int ip reset all
shutdown -r -t 1
del %0
Also in the stack, your graphics card driver.
Dump: 091224-5062-01.dmp (12.09.2024 01:50:27)
Code: 0x133 - DPC_WATCHDOG_VIOLATION
Process: System, probably caused by: rtwlanu.sys
Third-party modules in the stack: rtwlanu.sys
Third-party modules in the Raw Stack: nvlddmkm.sys, rtwlanu.sys
FAILURE_BUCKET_ID: 0x133_DPC_rtwlanu!PlatformAcquireSpinLock
Suggest removing it with DDU
